[GRASS-SVN] r48864 -
grass/branches/releasebranch_6_4/gui/wxpython/gui_modules
svn_grass at osgeo.org
Wed Oct 19 17:41:54 EDT 2011
Author: martinl
Date: 2011-10-19 14:41:53 -0700 (Wed, 19 Oct 2011)
New Revision: 48864
grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/gmodeler.py
grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/preferences.py
wxGUI/modeler: fix disabling items
fix removing loop
(merge r48862 from trunk)
Modified: grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/gmodeler.py
--- grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/gmodeler.py 2011-10-19 21:38:04 UTC (rev 48863)
+++ grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/gmodeler.py 2011-10-19 21:41:53 UTC (rev 48864)
@@ -197,6 +197,12 @@
else:
relList.append(rel.GetFrom())
+ elif isinstance(item, ModelLoop):
+ for rel in item.GetRelations():
+ relList.append(rel)
+ for action in self.GetItems():
+ action.UnSetBlock(item)
return relList, upList
def FindAction(self, aId):
@@ -505,9 +511,12 @@
for action in item.GetItems():
for vars()[condVar] in eval(condText):
- if isinstance(action, ModelAction):
+ if not isinstance(action, ModelAction) or \
+ not action.IsEnabled():
+ continue
self.RunAction(action, params, log, onDone)
if params:
dlg.Destroy()
@@ -1592,7 +1601,7 @@
remList, upList = self.parent.GetModel().RemoveItem(shape)
shape.Select(False)
diagram.RemoveShape(shape)
- del shape
+ shape.__del__()
for item in remList:
diagram.RemoveShape(item)
item.__del__()
@@ -1735,8 +1744,8 @@
color = UserSettings.Get(group='modeler', key='action',
subkey=('color', 'running'))
elif not self.isEnabled:
- color = UserSettings.Get(group='modeler', key='action',
- subkey=('color', 'disabled'))
+ color = UserSettings.Get(group='modeler', key='disabled',
+ subkey='color')
elif self.isValid:
subkey=('color', 'valid'))
@@ -2291,56 +2300,56 @@
def OnRightClick(self, x, y, keys = 0, attachment = 0):
"""!Right click -> pop-up menu"""
- if not hasattr (self, "popupID1"):
- self.popupID1 = wx.NewId()
- self.popupID2 = wx.NewId()
- self.popupID3 = wx.NewId()
- self.popupID4 = wx.NewId()
+ if not hasattr (self, "popupID"):
+ self.popupID = dict()
+ for key in ('remove', 'enable', 'addPoint',
+ 'delPoint', 'intermediate', 'props', 'id'):
+ self.popupID[key] = wx.NewId()
# record coordinates
self.x = x
self.y = y
shape = self.GetShape()
popupMenu = wx.Menu()
- popupMenu.Append(self.popupID1, text=_('Remove'))
- self.frame.Bind(wx.EVT_MENU, self.OnRemove, id = self.popupID1)
- if isinstance(shape, ModelAction):
+ popupMenu.Append(self.popupID['remove'], text=_('Remove'))
+ self.frame.Bind(wx.EVT_MENU, self.OnRemove, id = self.popupID['remove'])
+ if isinstance(shape, ModelAction) or isinstance(shape, ModelLoop):
if shape.IsEnabled():
- popupMenu.Append(self.popupID3, text=_('Disable'))
- self.frame.Bind(wx.EVT_MENU, self.OnDisable, id = self.popupID3)
+ popupMenu.Append(self.popupID['enable'], text=_('Disable'))
+ self.frame.Bind(wx.EVT_MENU, self.OnDisable, id = self.popupID['enable'])
else:
- popupMenu.Append(self.popupID3, text=_('Enable'))
- self.frame.Bind(wx.EVT_MENU, self.OnEnable, id = self.popupID3)
+ popupMenu.Append(self.popupID['enable'], text=_('Enable'))
+ self.frame.Bind(wx.EVT_MENU, self.OnEnable, id = self.popupID['enable'])
if isinstance(shape, ModelRelation):
popupMenu.AppendSeparator()
- popupMenu.Append(self.popupID2, text=_('Add control point'))
- self.frame.Bind(wx.EVT_MENU, self.OnAddPoint, id = self.popupID2)
- popupMenu.Append(self.popupID3, text=_('Remove control point'))
- self.frame.Bind(wx.EVT_MENU, self.OnRemovePoint, id = self.popupID3)
+ popupMenu.Append(self.popupID['addPoint'], text=_('Add control point'))
+ self.frame.Bind(wx.EVT_MENU, self.OnAddPoint, id = self.popupID['addPoint'])
+ popupMenu.Append(self.popupID['delPoint'], text=_('Remove control point'))
+ self.frame.Bind(wx.EVT_MENU, self.OnRemovePoint, id = self.popupID['delPoint'])
if len(shape.GetLineControlPoints()) == 2:
- popupMenu.Enable(self.popupID3, False)
+ popupMenu.Enable(self.popupID['delPoint'], False)
if isinstance(shape, ModelData) and '@' not in shape.GetValue():
- popupMenu.Append(self.popupID3, text=_('Intermediate'),
+ popupMenu.Append(self.popupID['intermediate'], text=_('Intermediate'),
kind = wx.ITEM_CHECK)
if self.GetShape().IsIntermediate():
- popupMenu.Check(self.popupID3, True)
+ popupMenu.Check(self.popupID['intermediate'], True)
- self.frame.Bind(wx.EVT_MENU, self.OnIntermediate, id = self.popupID3)
+ self.frame.Bind(wx.EVT_MENU, self.OnIntermediate, id = self.popupID['intermediate'])
if isinstance(shape, ModelData) or \
isinstance(shape, ModelAction) or \
- popupMenu.Append(self.popupID2, text=_('Properties'))
- self.frame.Bind(wx.EVT_MENU, self.OnProperties, id = self.popupID2)
+ popupMenu.Append(self.popupID['props'], text=_('Properties'))
+ self.frame.Bind(wx.EVT_MENU, self.OnProperties, id = self.popupID['props'])
- popupMenu.Append(self.popupID4, text=_('Change ID'))
- self.frame.Bind(wx.EVT_MENU, self.OnChangeId, id = self.popupID3)
+ popupMenu.Append(self.popupID['id'], text=_('Change ID'))
+ self.frame.Bind(wx.EVT_MENU, self.OnChangeId, id = self.popupID['id'])
self.frame.PopupMenu(popupMenu)
popupMenu.Destroy()
@@ -2351,15 +2360,15 @@
def OnDisable(self, event):
"""!Disable action"""
- action = self.GetShape()
- action.Enable(False)
- self.frame.ModelChanged()
- self.frame.canvas.Refresh()
+ self._onEnable(False)
def OnEnable(self, event):
- action.Enable(True)
+ self._onEnable(True)
+ def _onEnable(self, enable):
+ shape = self.GetShape()
+ shape.Enable(enable)
@@ -2535,9 +2544,11 @@
ogl.LineShape.__init__(self)
def __del__(self):
- self.fromShape.rels.remove(self)
- self.toShape.rels.remove(self)
+ if self in self.fromShape.rels:
+ self.fromShape.rels.remove(self)
+ if self in self.toShape.rels:
+ self.toShape.rels.remove(self)
def GetFrom(self):
"""!Get id of 'from' shape"""
return self.fromShape
@@ -4119,6 +4130,32 @@
else:
self.AddText('(' + str(self.id) + ')')
+ self._setBrush()
+ def _setBrush(self):
+ """!Set brush"""
+ if not self.isEnabled:
+ subkey='color')
+ else:
+ color = UserSettings.Get(group='modeler', key='loop',
+ subkey=('color', 'valid'))
+ wxColor = wx.Color(color[0], color[1], color[2])
+ self.SetBrush(wx.Brush(wxColor))
+ def Enable(self, enabled = True):
+ """!Enable/disable action"""
+ for item in self.items:
+ if not isinstance(item, ModelAction):
+ continue
+ item.Enable(enabled)
+ ModelObject.Enable(self, enabled)
+ def Update(self):
+ self._setBrush()
def GetName(self):
"""!Get name"""
return _("loop")
Modified: grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/preferences.py
--- grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/preferences.py 2011-10-19 21:38:04 UTC (rev 48863)
+++ grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/preferences.py 2011-10-19 21:41:53 UTC (rev 48864)
@@ -562,12 +562,14 @@
'modeler' : {
+ 'disabled': {
+ 'color': (211, 211, 211, 255), # light grey
'action' : {
'color' : {
'valid' : (180, 234, 154, 255), # light green
'invalid' : (255, 255, 255, 255), # white
'running' : (255, 0, 0, 255), # red
- 'disabled' : (211, 211, 211, 255), # light grey
'size' : {
'width' : 100,
@@ -590,6 +592,9 @@
'loop' : {
+ 'color' : {
+ 'valid' : (234, 226, 154, 255), # light yellow
'size' : {
'width' : 175,
'height' : 40,
