[GRASS-SVN] r48869 -
grass/branches/develbranch_6/gui/wxpython/gui_modules
svn_grass at osgeo.org
Wed Oct 19 20:40:54 EDT 2011
Author: martinl
Date: 2011-10-19 17:40:53 -0700 (Wed, 19 Oct 2011)
New Revision: 48869
grass/branches/develbranch_6/gui/wxpython/gui_modules/gmodeler.py
wxGUI: add variable type: file
check for missing variables
(merge r48868 from trunk)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/gmodeler.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/gmodeler.py 2011-10-20 00:35:51 UTC (rev 48868)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/gmodeler.py 2011-10-20 00:40:53 UTC (rev 48869)
@@ -409,8 +409,17 @@
error string"""
errList = list()
for action in self.GetItems(objType = ModelAction):
- task = menuform.GUI(show = None).ParseCommand(cmd = action.GetLog(string = False))
- errList += task.get_cmd_error()
+ cmd = action.GetLog(string = False, substitute = True)
+ task = menuform.GUI(show = None).ParseCommand(cmd = cmd)
+ errList += map(lambda x: cmd[0] + ': ' + x, task.get_cmd_error())
+ # check also variables
+ for opt in cmd[1:]:
+ if '=' not in opt:
+ continue
+ key, value = opt.split('=', 1)
+ if '%' in value:
+ errList.append(_("%s: undefined variable '%s'") % (cmd[0], value.strip()))
return errList
@@ -430,7 +439,7 @@
if statusbar:
statusbar.SetStatusText(_('Running model...'), 0)
- log.RunCmd(command = item.GetLog(string = False),
+ log.RunCmd(command = item.GetLog(string = False, substitute = True),
onDone = onDone)
if name in params:
@@ -483,7 +492,7 @@
err = dlg.GetErrors()
if err:
- GError(parent = self, message = unicode('\n'.join(err)))
+ GError(parent = parent, message = unicode('\n'.join(err)))
return
# get variable values
@@ -547,7 +556,12 @@
par[idx]['value'] = pattern.sub(var, par[idx]['value'])
self.RunAction(action, { action.GetName(): {'params': par } }, log, onDone)
+ # discard values
if params:
+ for var in params['variables']['params']:
+ var['value'] = ''
+ if params:
dlg.Destroy()
def DeleteIntermediateData(self, log):
@@ -614,7 +628,7 @@
'idx' : idx }
for name, values in self.variables.iteritems():
gtype = values.get('type', 'string')
- if gtype in ('raster', 'vector', 'mapset'):
+ if gtype in ('raster', 'vector', 'mapset', 'file'):
gisprompt = True
prompt = gtype
if gtype == 'raster':
@@ -668,7 +682,7 @@
'idx' : idx }
result[name]['params'].append(p)
idx += 1
self.variablesParams = result # record parameters
return result
@@ -1829,37 +1843,44 @@
"""!Get properties dialog"""
return self.propWin
- def GetLog(self, string = True):
- """!Get logging info"""
+ def GetLog(self, string = True, substitute = False):
+ """!Get logging info
+ @param string True to get cmd as a string otherwise a list
+ @param substitute True to substitute variables
cmd = self.task.get_cmd(ignoreErrors = True, ignoreRequired = True)
# substitute variables
- variables = self.parent.GetVariables()
- fparams = self.parent.GetVariables(params = True)
- params = None
- for values in fparams.itervalues():
- params = values['params']
- break
+ if substitute:
+ variables = self.parent.GetVariables()
+ fparams = self.parent.GetVariables(params = True)
+ params = None
+ for values in fparams.itervalues():
+ params = values['params']
+ break
- for variable in variables:
- pattern= re.compile('%' + variable)
- value = None
- if params:
- for p in params:
- if variable == p.get('name', ''):
- value = p.get('value', '')
+ for variable in variables:
+ pattern= re.compile('%' + variable)
+ value = None
+ if params:
+ for p in params:
+ if variable == p.get('name', ''):
+ value = p.get('value', '')
+ break
+ if not value:
+ value = variables[variable].get('value', '')
+ for idx in range(len(cmd)):
+ if pattern.search(cmd[idx]):
+ if value:
+ cmd[idx] = pattern.sub(value, cmd[idx])
+ else:
+ cmd[idx] = pattern.sub('', cmd[idx])
+ self.isValid = False
break
- if not value:
- value = variables[variable].get('value', '')
- for idx in range(len(cmd)):
- if pattern.search(cmd[idx]):
- if value:
- cmd[idx] = pattern.sub(value, cmd[idx])
- else:
- self.isValid = False
- break
- idx += 1
+ idx += 1
if string:
if cmd is None:
@@ -3933,7 +3954,8 @@
_("string"),
_("raster"),
_("vector"),
- _("mapset")])
+ _("mapset"),
+ _("file")])
self.value = wx.TextCtrl(parent = self, id = wx.ID_ANY)
self.desc = wx.TextCtrl(parent = self, id = wx.ID_ANY)
