[GRASS-SVN] r48878 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Thu Oct 20 06:32:46 EDT 2011
Author: martinl
Date: 2011-10-20 03:32:46 -0700 (Thu, 20 Oct 2011)
New Revision: 48878
grass/trunk/gui/wxpython/gui_modules/dbm_base.py
grass/trunk/gui/wxpython/gui_modules/dbm_dialogs.py
wxGUI/vector query: don't fail when no attribute table linked to the vector map
Modified: grass/trunk/gui/wxpython/gui_modules/dbm_base.py
--- grass/trunk/gui/wxpython/gui_modules/dbm_base.py 2011-10-20 03:16:32 UTC (rev 48877)
+++ grass/trunk/gui/wxpython/gui_modules/dbm_base.py 2011-10-20 10:32:46 UTC (rev 48878)
@@ -97,7 +97,7 @@
coord = (float(queryCoords[0]), float(queryCoords[1])),
distance = float(qdist))
- if len(data) < 1:
+ if len(data) < 1 or 'Table' not in data[0]:
return None
# process attributes
@@ -137,7 +137,7 @@
sql = "SELECT %s FROM %s" % (cols, table)
else:
sql = "SELECT %s FROM %s WHERE %s" % (cols, table, where)
ret = gcmd.RunCommand('db.select',
parent = self,
read = True,
Modified: grass/trunk/gui/wxpython/gui_modules/dbm_dialogs.py
--- grass/trunk/gui/wxpython/gui_modules/dbm_dialogs.py 2011-10-20 03:16:32 UTC (rev 48877)
+++ grass/trunk/gui/wxpython/gui_modules/dbm_dialogs.py 2011-10-20 10:32:46 UTC (rev 48878)
@@ -67,14 +67,12 @@
label = _("Database connection "
"is not defined in DB file.")
- wx.MessageBox(parent = self.parent,
+ gcmd.GMessage(parent = self.parent,
message = _("No attribute table linked to "
- "vector map <%(vector)s> found. %(msg)s"
- "\nYou can disable this message from digitization settings. Or "
- "you can create and link attribute table to the vector map "
- "using Attribute Table Manager.") %
- {'vector' : self.map, 'msg' : label},
- caption = _("Message"), style = wx.OK | wx.ICON_EXCLAMATION | wx.CENTRE)
+ "vector map <%(vector)s> found. %(msg)s\n\n"
+ "New attribute table can be created by "
+ "Attribute Table Manager.") %
+ {'vector' : self.map, 'msg' : label})
self.mapDBInfo = None
wx.Dialog.__init__(self, parent = self.parent, id = wx.ID_ANY,
