[GRASS-SVN] r48882 - grass/trunk/lib/python/temporal
svn_grass at osgeo.org
Thu Oct 20 14:28:20 EDT 2011
Author: huhabla
Date: 2011-10-20 11:28:19 -0700 (Thu, 20 Oct 2011)
New Revision: 48882
grass/trunk/lib/python/temporal/abstract_dataset.py
grass/trunk/lib/python/temporal/abstract_space_time_dataset.py
grass/trunk/lib/python/temporal/base.py
grass/trunk/lib/python/temporal/space_time_datasets_tools.py
Removed some performance issues
Modified: grass/trunk/lib/python/temporal/abstract_dataset.py
--- grass/trunk/lib/python/temporal/abstract_dataset.py 2011-10-20 12:00:07 UTC (rev 48881)
+++ grass/trunk/lib/python/temporal/abstract_dataset.py 2011-10-20 18:28:19 UTC (rev 48882)
@@ -103,6 +103,16 @@
def select(self, dbif=None):
"""Select temporal dataset entry from database and fill up the internal structure"""
+ connect = False
+ if dbif == None:
+ dbif = sql_database_interface()
+ dbif.connect()
+ connect = True
+ dbif.cursor.execute("BEGIN TRANSACTION")
self.base.select(dbif)
if self.is_time_absolute():
self.absolute_time.select(dbif)
@@ -110,6 +120,11 @@
self.relative_time.select(dbif)
self.spatial_extent.select(dbif)
self.metadata.select(dbif)
+ dbif.cursor.execute("COMMIT TRANSACTION")
+ if connect:
+ dbif.close()
def is_in_db(self, dbif=None):
"""Check if the temporal dataset entry is in the database"""
@@ -121,6 +136,17 @@
def insert(self, dbif=None):
"""Insert temporal dataset entry into database from the internal structure"""
+ connect = False
+ if dbif == None:
+ dbif.connect()
+ connect = True
self.base.insert(dbif)
self.absolute_time.insert(dbif)
@@ -129,10 +155,26 @@
self.spatial_extent.insert(dbif)
self.metadata.insert(dbif)
+ if connect:
+ dbif.close()
def update(self, dbif=None):
"""Update temporal dataset entry of database from the internal structure
excluding None variables
+ connect = False
+ if dbif == None:
+ dbif.connect()
+ connect = True
self.base.update(dbif)
self.absolute_time.update(dbif)
@@ -141,12 +183,28 @@
self.spatial_extent.update(dbif)
self.metadata.update(dbif)
+ if connect:
+ dbif.close()
def update_all(self, dbif=None):
and include None varuables.
@param dbif: The database interface to be used
+ connect = False
+ if dbif == None:
+ dbif.connect()
+ connect = True
self.base.update_all(dbif)
self.absolute_time.update_all(dbif)
@@ -155,6 +213,11 @@
self.spatial_extent.update_all(dbif)
self.metadata.update_all(dbif)
+ if connect:
+ dbif.close()
def print_self(self):
"""Print the content of the internal structure to stdout"""
self.base.print_self()
Modified: grass/trunk/lib/python/temporal/abstract_space_time_dataset.py
--- grass/trunk/lib/python/temporal/abstract_space_time_dataset.py 2011-10-20 12:00:07 UTC (rev 48881)
+++ grass/trunk/lib/python/temporal/abstract_space_time_dataset.py 2011-10-20 18:28:19 UTC (rev 48882)
@@ -87,6 +87,10 @@
self.metadata.set_title(title)
self.metadata.set_description(description)
+ def get_semantic_type(self):
+ """Return the semantic type of this dataset"""
+ return self.base.get_semantic_type()
def get_initial_values(self):
"""Return the initial values: temporal_type, semantic_type, title, description"""
@@ -134,7 +138,6 @@
return map_time
def print_temporal_relation_matrix(self, maps):
"""Print the temporal relation matrix of all registered maps to stdout
@@ -342,9 +345,66 @@
return True
+ def get_registered_maps_as_objects_with_gaps(self, where=None, dbif=None):
+ """Return all registered maps as ordered (by start_time) object list with
+ "gap" map objects (id==None) for temporal topological operations
+ Gaps between maps are identified as maps with id==None
+ The objects are initialized with the id and the temporal extent (temporal type, start time, end time).
+ In case more map informations are needed, use the select() method for each listed object.
+ @param where: The SQL where statement to select a subset of the registered maps without "WHERE"
+ @param dbif: The database interface to be used
+ In case nothing found None is returned
+ connect = False
+ if dbif == None:
+ dbif.connect()
+ connect = True
+ obj_list = []
+ maps = self.get_registered_maps_as_objects(where, "start_time", dbif)
+ if maps and len(maps) > 0:
+ for i in range(len(maps)):
+ obj_list.append(maps[i])
+ # Detect and insert gaps
+ if i < len(maps) - 1:
+ relation = maps[i + 1].temporal_relation(maps[i])
+ if relation == "after":
+ start1, end1 = maps[i].get_valid_time()
+ start2, end2 = maps[i + 1].get_valid_time()
+ end = start2
+ if end1:
+ start = end1
+ else:
+ start = start1
+ map = self.get_new_map_instance(None)
+ if self.is_time_absolute():
+ map.set_absolute_time(start, end)
+ elif self.is_time_relative():
+ map.set_relative_time(start, end)
+ obj_list.append(copy.copy(map))
+ if connect == True:
+ dbif.close()
+ return obj_list
def get_registered_maps_as_objects(self, where=None, order="start_time", dbif=None):
- """Return all registered maps as ordered object list
+ """Return all registered maps as ordered object list for temporal topological operations
@param order: The SQL order statement to be used to order the objects in the list without "ORDER BY"
@@ -361,14 +421,22 @@
obj_list = []
- rows = self.get_registered_maps("id", where, order, dbif)
+ rows = self.get_registered_maps("id,start_time,end_time", where, order, dbif)
+ count = 0
if rows:
for row in rows:
+ core.percent(count, len(rows), 1)
map = self.get_new_map_instance(row["id"])
- map.select(dbif)
+ map.set_absolute_time(row["start_time"], row["end_time"])
+ map.set_relative_time(row["start_time"], row["end_time"])
+ count += 1
+ core.percent(1, 1, 1)
if connect == True:
dbif.close()
@@ -377,7 +445,7 @@
def get_registered_maps(self, columns=None, where = None, order = None, dbif=None):
"""Return sqlite rows of all registered maps.
- Each row includes all columns specified in the datatype specific view
+ In case columsn are not specified, each row includes all columns specified in the datatype specific view
@param columns: Columns to be selected as SQL compliant string
Modified: grass/trunk/lib/python/temporal/base.py
--- grass/trunk/lib/python/temporal/base.py 2011-10-20 12:00:07 UTC (rev 48881)
+++ grass/trunk/lib/python/temporal/base.py 2011-10-20 18:28:19 UTC (rev 48882)
@@ -188,20 +188,15 @@
* Temporal extent
* Metadata
- def __init__(self, table=None, ident=None, database=None):
+ def __init__(self, table=None, ident=None):
"""Constructor of this class
@param table: The name of the table
@param ident: The identifier (primary key) of this object in the database table
- @param database: A specific string used in the dbmi connect method. This should be the path to the database , user name, ...
dict_sql_serializer.__init__(self)
self.table = table # Name of the table, set in the subclass
- if database == None:
- self.database = get_temporal_dbmi_init_string()
- else:
- self.database = database
self.ident = ident
def get_table_name(self):
@@ -213,16 +208,17 @@
Supported backends are sqlite3 and postgresql
+ init = get_temporal_dbmi_init_string()
#print "Connect to", self.database
if dbmi.__name__ == "sqlite3":
- self.connection = dbmi.connect(self.database, detect_types=dbmi.PARSE_DECLTYPES|dbmi.PARSE_COLNAMES)
+ self.connection = dbmi.connect(init, detect_types=dbmi.PARSE_DECLTYPES|dbmi.PARSE_COLNAMES)
self.connection.row_factory = dbmi.Row
self.connection.isolation_level = None
self.cursor = self.connection.cursor()
self.cursor.execute("PRAGMA synchronous = OFF")
self.cursor.execute("PRAGMA journal_mode = MEMORY")
elif dbmi.__name__ == "psycopg2":
- self.connection = dbmi.connect(self.database)
+ self.connection = dbmi.connect(init)
self.connection.set_isolation_level(dbmi.extensions.ISOLATION_LEVEL_AUTOCOMMIT)
self.cursor = self.connection.cursor(cursor_factory=dbmi.extras.DictCursor)
@@ -391,6 +387,9 @@
sql_database_interface.__init__(self, table, ident)
self.set_id(ident)
+ if ident != None and name == None and mapset == None:
+ if ident.find("@") >= 0:
+ name, mapset = ident.split("@")
self.set_name(name)
self.set_mapset(mapset)
self.set_creator(creator)
Modified: grass/trunk/lib/python/temporal/space_time_datasets_tools.py
--- grass/trunk/lib/python/temporal/space_time_datasets_tools.py 2011-10-20 12:00:07 UTC (rev 48881)
+++ grass/trunk/lib/python/temporal/space_time_datasets_tools.py 2011-10-20 18:28:19 UTC (rev 48882)
@@ -524,7 +524,6 @@
@param type: the dataset type: rast, rast3d, vect, strds, str3ds, stvds
@param id: The id of the dataset ("name at mapset")
- print type, id
if type == "strds":
sp = space_time_raster_dataset(id)
elif type == "str3ds":
