[GRASS-SVN] r48884 - grass/trunk/lib/python/temporal
svn_grass at osgeo.org
Thu Oct 20 15:24:10 EDT 2011
Author: huhabla
Date: 2011-10-20 12:24:10 -0700 (Thu, 20 Oct 2011)
New Revision: 48884
grass/trunk/lib/python/temporal/space_time_datasets_tools.py
Fixing bugs
Modified: grass/trunk/lib/python/temporal/space_time_datasets_tools.py
--- grass/trunk/lib/python/temporal/space_time_datasets_tools.py 2011-10-20 18:36:13 UTC (rev 48883)
+++ grass/trunk/lib/python/temporal/space_time_datasets_tools.py 2011-10-20 19:24:10 UTC (rev 48884)
@@ -227,7 +227,12 @@
else:
id = name
- sp = dataset_factory(type, id)
+ if type == "rast":
+ sp = dataset_factory("strds", id)
+ if type == "rast3d":
+ sp = dataset_factory("str3ds", id)
+ if type == "vect":
+ sp = dataset_factory("stvds", id)
if sp.is_in_db(dbif) == False:
dbif.close()
@@ -267,13 +272,7 @@
else:
mapid = mapname
- # Create a new instance with the map type
- if type == "rast":
- map = raster_dataset(mapid)
- if type == "rast3d":
- map = raster3d_dataset(mapid)
- if type == "vect":
- map = vector_dataset(mapid)
+ map = dataset_factory(type, mapid)
# Unregister map if in database
if map.is_in_db(dbif) == True:
