[GRASS-SVN] r48887 - grass/trunk/vector/v.out.ascii
svn_grass at osgeo.org
Thu Oct 20 17:33:32 EDT 2011
Author: martinl
Date: 2011-10-20 14:33:32 -0700 (Thu, 20 Oct 2011)
New Revision: 48887
grass/trunk/vector/v.out.ascii/main.c
v.out.ascii: #1470 (v.out.ascii with sql where option exports only centroids and not areas)
Modified: grass/trunk/vector/v.out.ascii/main.c
--- grass/trunk/vector/v.out.ascii/main.c 2011-10-20 21:32:52 UTC (rev 48886)
+++ grass/trunk/vector/v.out.ascii/main.c 2011-10-20 21:33:32 UTC (rev 48887)
@@ -69,18 +69,10 @@
G_fatal_error(_("'output' must be given for old version"));
- if (format != GV_ASCII_FORMAT_WKT) {
- Vect_set_open_level(1); /* topology not needed */
- if (Vect_open_old2(&Map, input, "", field_name) < 0)
- G_fatal_error(_("Unable to open vector map <%s>"),
- input);
- else {
- if (Vect_open_old2(&Map, input, "", field_name) < 2) /* topology required for polygons */
- G_warning(_("Unable to open vector map <%s> at topology level. "
- "Only points, lines can be processed."),
- input);
+ if (Vect_open_old2(&Map, input, "", field_name) < 2) /* topology required for areas */
+ G_warning(_("Unable to open vector map <%s> at topology level. "
+ "Areas will not be processed."),
+ input);
field = Vect_get_field_number(&Map, field_name);
