[GRASS-SVN] r48889 - grass/trunk/vector/v.out.ascii
svn_grass at osgeo.org
Fri Oct 21 04:14:22 EDT 2011
Author: mmetz
Date: 2011-10-21 01:14:22 -0700 (Fri, 21 Oct 2011)
New Revision: 48889
grass/trunk/vector/v.out.ascii/main.c
v.out.ascii: use topology only when needed (maintain support for massive point export)
Modified: grass/trunk/vector/v.out.ascii/main.c
--- grass/trunk/vector/v.out.ascii/main.c 2011-10-21 08:11:51 UTC (rev 48888)
+++ grass/trunk/vector/v.out.ascii/main.c 2011-10-21 08:14:22 UTC (rev 48889)
@@ -69,10 +69,19 @@
G_fatal_error(_("'output' must be given for old version"));
- if (Vect_open_old2(&Map, input, "", field_name) < 2) /* topology required for areas */
- G_warning(_("Unable to open vector map <%s> at topology level. "
- "Areas will not be processed."),
- input);
+ /* open with topology only if needed */
+ if (format == GV_ASCII_FORMAT_WKT || (format == GV_ASCII_FORMAT_STD &&
+ (where || clist))) {
+ if (Vect_open_old2(&Map, input, "", field_name) < 2) /* topology required for areas */
+ G_warning(_("Unable to open vector map <%s> at topology level. "
+ "Areas will not be processed."),
+ input);
+ else {
+ Vect_set_open_level(1); /* topology not needed */
+ if (Vect_open_old2(&Map, input, "", field_name) < 0)
+ G_fatal_error(_("Unable to open vector map <%s>"), input);
field = Vect_get_field_number(&Map, field_name);
