[GRASS-SVN] r48894 - grass/trunk/lib/vector/Vlib
svn_grass at osgeo.org
Fri Oct 21 05:26:30 EDT 2011
Author: martinl
Date: 2011-10-21 02:26:30 -0700 (Fri, 21 Oct 2011)
New Revision: 48894
grass/trunk/lib/vector/Vlib/ascii.c
vlib: fix r48888
Modified: grass/trunk/lib/vector/Vlib/ascii.c
--- grass/trunk/lib/vector/Vlib/ascii.c 2011-10-21 09:09:59 UTC (rev 48893)
+++ grass/trunk/lib/vector/Vlib/ascii.c 2011-10-21 09:26:30 UTC (rev 48894)
@@ -389,7 +389,7 @@
if (format == GV_ASCII_FORMAT_POINT && !(type & GV_POINTS))
continue;
- found = check_cat(ACats, Clist, cats, ncats);
+ found = check_cat(Cats, Clist, cats, ncats);
if (!found && type == GV_BOUNDARY && Vect_level(Map) > 1) {
Vect_get_line_areas(Map, line, &left, &right);
