[GRASS-SVN] r48903 - grass/trunk/lib/python/temporal
Fri Oct 21 14:33:50 EDT 2011
Author: huhabla
Date: 2011-10-21 11:33:50 -0700 (Fri, 21 Oct 2011)
New Revision: 48903
Added:
   grass/trunk/lib/python/temporal/aggregation.py
   grass/trunk/lib/python/temporal/Makefile
   grass/trunk/lib/python/temporal/__init__.py
   grass/trunk/lib/python/temporal/space_time_datasets_tools.py
Moved code from list and aggregation modules into the library.
Modified: grass/trunk/lib/python/temporal/Makefile
--- grass/trunk/lib/python/temporal/Makefile	2011-10-21 11:55:26 UTC (rev 48902)
+++ grass/trunk/lib/python/temporal/Makefile	2011-10-21 18:33:50 UTC (rev 48903)
@@ -8,7 +8,7 @@
 GDIR = $(PYDIR)/grass
 DSTDIR = $(GDIR)/temporal
-MODULES = base core abstract_dataset abstract_map_dataset abstract_space_time_dataset space_time_datasets space_time_datasets_tools metadata spatial_extent temporal_extent datetime_math temporal_granularity unit_tests
+MODULES = base core abstract_dataset abstract_map_dataset abstract_space_time_dataset space_time_datasets space_time_datasets_tools metadata spatial_extent temporal_extent datetime_math temporal_granularity unit_tests aggregation
 PYFILES := $(patsubst %,$(DSTDIR)/%.py,$(MODULES) __init__)
 PYCFILES := $(patsubst %,$(DSTDIR)/%.pyc,$(MODULES) __init__)
Modified: grass/trunk/lib/python/temporal/__init__.py
--- grass/trunk/lib/python/temporal/__init__.py	2011-10-21 11:55:26 UTC (rev 48902)
+++ grass/trunk/lib/python/temporal/__init__.py	2011-10-21 18:33:50 UTC (rev 48903)
@@ -11,3 +11,4 @@
 from datetime_math import *
 from temporal_granularity import *
 from unit_tests import *
+from aggregation import *
Added: grass/trunk/lib/python/temporal/aggregation.py
--- grass/trunk/lib/python/temporal/aggregation.py	                        (rev 0)
+++ grass/trunk/lib/python/temporal/aggregation.py	2011-10-21 18:33:50 UTC (rev 48903)
@@ -0,0 +1,100 @@
+"""!@package grass.temporal
+ at brief GRASS Python scripting module (temporal GIS functions)
+Temporal GIS related functions to be used in Python scripts.
+Usage:
+ at code
+import grass.temporal as tgis
+tgis.aggregate_raster_maps(dataset, mapset, inputs, base, start, end, count, method, register_null, dbif)
+ at endcode
+(C) 2008-2011 by the GRASS Development Team
+This program is free software under the GNU General Public
+License (>=v2). Read the file COPYING that comes with GRASS
+for details.
+ at author Soeren Gebbert
+from space_time_datasets import *
+def collect_map_names(sp, dbif, start, end):
+    where = " start_time >= \'%s\' and start_time < \'%s\'" % (start, end)
+    print where
+    rows = sp.get_registered_maps("id", where, "start_time", dbif)
+    if not rows:
+        return None
+    names = []
+    for row in rows:
+        names.append(row["id"])
+    return names
+def aggregate_raster_maps(dataset, mapset, inputs, base, start, end, count, method, register_null, dbif):
+    core.verbose(_("Aggregate %s raster maps") %(len(inputs)))
+    output = "%s_%i" % (base, count)
+    map_id = output + "@" + mapset
+    new_map = dataset.get_new_map_instance(map_id)
+    # Check if new map is in the temporal database
+    if new_map.is_in_db(dbif):
+        if core.overwrite() == True:
+            # Remove the existing temporal database entry
+            new_map.delete(dbif)
+        else:
+            core.error(_("Raster map <%s> is already in temporal database, use overwrite flag to overwrite"))
+            return
+    core.verbose(_("Compute aggregation of maps between %s - %s" % (str(start), str(end))))
+    # Create the r.series input file
+    filename = core.tempfile(True)
+    file = open(filename, 'w')
+    for name in inputs:
+        string = "%s\n" % (name)
+        file.write(string)
+    file.close()
+    # Run r.series
+    ret = core.run_command("r.series", flags="z", file=filename, output=output, overwrite=core.overwrite(), method=method)
+    if ret != 0:
+        dbif.close()
+        core.fatal(_("Error while r.series computation"))
+    # Read the raster map data
+    new_map.load()
+    # In case of a null map continue, do not register null maps
+    if new_map.metadata.get_min() == None and new_map.metadata.get_max() == None:
+        if not register_null:
+            core.run_command("g.remove", rast=output)
+            return
+    # Set the time stamp
+    if dataset.is_time_absolute():
+        new_map.set_absolute_time(start, end, None)
+    else:
+        new_map.set_relative_time(start, end)
+    # Insert map in temporal database
+    new_map.insert(dbif)
+    dataset.register_map(new_map, dbif)
Modified: grass/trunk/lib/python/temporal/space_time_datasets_tools.py
--- grass/trunk/lib/python/temporal/space_time_datasets_tools.py	2011-10-21 11:55:26 UTC (rev 48902)
+++ grass/trunk/lib/python/temporal/space_time_datasets_tools.py	2011-10-21 18:33:50 UTC (rev 48903)
@@ -91,7 +91,7 @@
     if sp.is_in_db(dbif) == False:
         dbif.close()
-        core.fatal(_("Space time %s dataset <%s> no found") % (sp.get_new_map_instance(None).get_type(). name))
+        core.fatal(_("Space time %s dataset <%s> no found") % (sp.get_new_map_instance(None).get_type(), name))
     maplist = []
@@ -541,3 +541,128 @@
     return sp
+def list_maps_of_stds(type, input, columns, order, where, separator, method, header):
+    """ List the maps of a space time dataset using diffetent methods
+        @param type: The type of the maps raster, raster3d or vector
+        @param input: Name of a space time raster dataset
+        @param columns: A comma separated list of columns to be printed to stdout
+        @param order: A comma seoarated list of columns to order the space time dataset by category
+        @param where: A where statement for selected listing without "WHERE" e.g: start_time < "2001-01-01" and end_time > "2001-01-01"
+        @param separator: The field separator character between the columns
+        @param method: String identifier to select a method out of cols,comma,delta or deltagaps
+            * "cols": Print preselected columns specified by columns
+            * "comma": Print the map ids (name at mapset) as comma separated string
+            * "delta": Print the map ids (name at mapset) with start time, end time, relative length of intervals and the relative distance to the begin
+            * "deltagaps": Same as "delta" with addtitionakl listing of gaps. Gaps can be simply identified as the id is "None"
+        @param header: Set True to print column names
+    mapset =  core.gisenv()["MAPSET"]
+    if input.find("@") >= 0:
+        id = input
+    else:
+        id = input + "@" + mapset
+    sp = dataset_factory(type, id)
+    if sp.is_in_db() == False:
+        core.fatal(_("Dataset <%s> not found in temporal database") % (id))
+    sp.select()
+    if separator == None or separator == "":
+        separator = "\t"
+    # This method expects a list of objects for gap detection
+    if method == "delta" or method == "deltagaps":
+        columns = "id,start_time,end_time"
+        if method == "deltagaps":
+            maps = sp.get_registered_maps_as_objects_with_gaps(where, None)
+        else:
+            maps = sp.get_registered_maps_as_objects(where, "start_time", None)
+        if header:
+            string = ""
+            string += "%s%s" % ("id", separator)
+            string += "%s%s" % ("start_time", separator)
+            string += "%s%s" % ("end_time", separator)
+            string += "%s%s" % ("interval_length", separator)
+            string += "%s"   % ("distance_from_begin")
+            print string
+        if maps and len(maps) > 0:
+            first_time, dummy = maps[0].get_valid_time()
+            for map in maps:
+                start, end = map.get_valid_time()
+                if end:
+                    delta = end -start
+                else:
+                    delta = None
+                delta_first = start - first_time
+                if map.is_time_absolute():
+                    if end:
+                        delta = time_delta_to_relative_time(delta)
+                    delta_first = time_delta_to_relative_time(delta_first)
+                string = ""
+                string += "%s%s" % (map.get_id(), separator)
+                string += "%s%s" % (start, separator)
+                string += "%s%s" % (end, separator)
+                string += "%s%s" % (delta, separator)
+                string += "%s"   % (delta_first)
+                print string
+    else:
+        # In comma separated mode only map ids are needed
+        if method == "comma":
+            columns = "id"
+        rows = sp.get_registered_maps(columns, where, order, None)
+        if rows:
+                string = ""
+                count = 0
+                for row in rows:
+                    if count == 0:
+                        string += row["id"]
+                    else:
+                        string += ",%s" % row["id"]
+                    count += 1
+                print string
+            elif method == "cols":
+                # Print the column names if requested
+                if header:
+                    output = ""
+                    count = 0
+                    collist = columns.split(",")
+                    for key in collist:
+                        if count > 0:
+                            output += separator + str(key)
+                        else:
+                            output += str(key)
+                        count += 1
+                    print output
+                for row in rows:
+                    output = ""
+                    count = 0
+                    for col in row:
+                        if count > 0:
+                            output += separator + str(col)
+                        else:
+                            output += str(col)
+                        count += 1
+                    print output
