[GRASS-SVN] r48905 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Sat Oct 22 05:19:25 EDT 2011
Author: annakrat
Date: 2011-10-22 02:19:25 -0700 (Sat, 22 Oct 2011)
New Revision: 48905
grass/trunk/gui/wxpython/gui_modules/gdialogs.py
wxGUI: improvements in GroupDialog
Modified: grass/trunk/gui/wxpython/gui_modules/gdialogs.py
--- grass/trunk/gui/wxpython/gui_modules/gdialogs.py 2011-10-21 18:35:17 UTC (rev 48904)
+++ grass/trunk/gui/wxpython/gui_modules/gdialogs.py 2011-10-22 09:19:25 UTC (rev 48905)
@@ -913,17 +913,21 @@
self.parent = parent
self.defaultGroup = defaultGroup
+ self.currentGroup = self.defaultGroup
+ self.groupChanged = False
self.bodySizer = self._createDialogBody()
# buttons
+ btnOk = wx.Button(parent = self, id = wx.ID_OK)
btnApply = wx.Button(parent = self, id = wx.ID_APPLY)
btnClose = wx.Button(parent = self, id = wx.ID_CANCEL)
- btnApply.SetToolTipString(_("Apply changes to selected group."))
- btnClose.SetToolTipString(_("Close dialog, changes are not applied."))
+ btnOk.SetToolTipString(_("Apply changes to selected group and close dialog"))
+ btnApply.SetToolTipString(_("Apply changes to selected group"))
+ btnClose.SetToolTipString(_("Close dialog, changes are not applied"))
- btnApply.SetDefault()
+ btnOk.SetDefault()
# sizers & do layout
# btnSizer = wx.BoxSizer(wx.HORIZONTAL)
@@ -932,6 +936,7 @@
# btnSizer.Add(item = btnApply, proportion = 0,
# flag = wx.LEFT, border = 5)
btnSizer = wx.StdDialogButtonSizer()
+ btnSizer.AddButton(btnOk)
btnSizer.AddButton(btnApply)
btnSizer.AddButton(btnClose)
btnSizer.Realize()
@@ -949,6 +954,7 @@
self.SetSizer(mainSizer)
mainSizer.Fit(self)
+ btnOk.Bind(wx.EVT_BUTTON, self.OnOk)
btnApply.Bind(wx.EVT_BUTTON, self.OnApply)
btnClose.Bind(wx.EVT_BUTTON, self.OnClose)
@@ -1019,6 +1025,7 @@
for layer in layers:
if layer not in self.GetLayers():
self.layerBox.Append(layer)
+ self.groupChanged = True
def OnRemoveLayer(self, event):
@@ -1026,6 +1033,7 @@
while self.layerBox.GetSelections():
sel = self.layerBox.GetSelections()[0]
self.layerBox.Delete(sel)
def GetLayers(self):
"""!Get layers"""
@@ -1033,12 +1041,33 @@
def OnGroupSelected(self, event):
"""!Text changed in group selector"""
+ # callAfter must be called to close popup before other actions
+ wx.CallAfter(self.GroupSelected)
+ def GroupSelected(self):
+ """!Group was selected, check if changes were apllied"""
group = self.GetSelectedGroup()
+ if self.groupChanged:
+ dlg = wx.MessageDialog(self, message = _("Group <%s> was changed, "
+ "do you want to apply changes?") % self.currentGroup,
+ caption = _("Unapplied changes"),
+ style = wx.YES_NO | wx.ICON_QUESTION | wx.YES_DEFAULT)
+ if dlg.ShowModal() == wx.ID_YES:
+ self.ApplyChanges(showResult = True)
+ dlg.Destroy()
groups = self.GetExistGroups()
if group in groups:
self.ShowGroupLayers(self.GetGroupLayers(group))
+ self.currentGroup = group
+ self.ClearNotification()
def ShowGroupLayers(self, mapList):
"""!Show map layers in currently selected group"""
self.layerBox.Set(mapList)
@@ -1073,7 +1102,7 @@
group = group,
input = ','.join(add))
- self.ShowResult(group = group, returnCode = ret, create = False)
+ return ret
def CreateNewGroup(self, group):
"""!Create new group"""
@@ -1082,8 +1111,8 @@
parent = self,
group = group,
input = layers)
- self.ShowResult(group = group, returnCode = ret, create = True)
+ return ret
def GetExistGroups(self):
"""!Returns existing groups in current mapset"""
@@ -1119,15 +1148,17 @@
flags = 'g',
group = group,
read = True).strip()
- return res.split('\n')
+ if res.split('\n')[0]:
+ return res.split('\n')
+ return []
def ClearNotification(self):
"""!Clear notification string"""
self.infoLabel.SetLabel("")
- def OnApply(self, event):
+ def ApplyChanges(self, showResult):
"""!Create or edit group"""
- group = self.GetSelectedGroup()
+ group = self.currentGroup
if not group:
gcmd.GMessage(parent = self,
message = _("No group selected."))
@@ -1135,10 +1166,24 @@
if group in groups:
- self.EditGroup(group)
+ ret = self.EditGroup(group)
+ self.ShowResult(group = group, returnCode = ret, create = False)
else:
- self.CreateNewGroup(group)
+ ret = self.CreateNewGroup(group)
+ self.ShowResult(group = group, returnCode = ret, create = True)
+ def OnApply(self, event):
+ """!Apply changes"""
+ def OnOk(self, event):
+ """!Apply changes and close dialog"""
+ self.ApplyChanges(showResult = False)
+ self.OnClose(event)
def OnClose(self, event):
"""!Close dialog"""
if not self.IsModal():
