[GRASS-SVN] r48935 - grass/branches/develbranch_6/gui/wxpython/gui_modules
Tue Oct 25 09:37:19 EDT 2011
Author: martinl
Date: 2011-10-25 06:37:19 -0700 (Tue, 25 Oct 2011)
New Revision: 48935
   grass/branches/develbranch_6/gui/wxpython/gui_modules/gmodeler.py
wxGUI/modeler: improve validity check (variable substitution)
	       (merge r48934 from trunk)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/gmodeler.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/gmodeler.py	2011-10-25 13:35:35 UTC (rev 48934)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/gmodeler.py	2011-10-25 13:37:19 UTC (rev 48935)
@@ -392,6 +392,8 @@
         """!Validate model, return None if model is valid otherwise
         error string"""
         errList = list()
+        pattern = re.compile(r'(.*)(%.+\s?)(.*)')
         for action in self.GetItems(objType = ModelAction):
             cmd = action.GetLog(string = False, substitute = True)
@@ -402,8 +404,16 @@
                 if '=' not in opt:
                     continue
                 key, value = opt.split('=', 1)
-                if '%' in value:
-                    errList.append(_("%s: undefined variable '%s'") % (cmd[0], value.strip()))
+                sval = pattern.search(value)
+                if sval:
+                    var = sval.group(2).strip()[1:] # ignore '%'
+                    report = True
+                    for item in filter(lambda x: isinstance(x, ModelLoop), action.GetBlock()):
+                        if var in item.GetText():
+                            report = False
+                            break
+                    if report:
+                        errList.append(_("%s: undefined variable '%s'") % (cmd[0], var))
         return errList
@@ -4866,7 +4876,7 @@
             variables = self.model.GetVariables()
             cond = item.GetText()
             for variable in variables:
-                pattern= re.compile('%' + variable)
+                pattern = re.compile('%' + variable)
                 if pattern.search(cond):
                     value = variables[variable].get('value', '')
                     if variables[variable].get('type', 'string') == 'string':
