[GRASS-SVN] r48951 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Wed Oct 26 07:59:10 EDT 2011
Author: martinl
Date: 2011-10-26 04:59:10 -0700 (Wed, 26 Oct 2011)
New Revision: 48951
grass/trunk/gui/wxpython/gui_modules/dbm_dialogs.py
grass/trunk/gui/wxpython/gui_modules/mapdisp_vdigit.py
grass/trunk/gui/wxpython/gui_modules/vdigit.py
wxGUI/vdigit: don't try to add new attribute record when no attribute table is defined
Modified: grass/trunk/gui/wxpython/gui_modules/dbm_dialogs.py
--- grass/trunk/gui/wxpython/gui_modules/dbm_dialogs.py 2011-10-26 09:18:01 UTC (rev 48950)
+++ grass/trunk/gui/wxpython/gui_modules/dbm_dialogs.py 2011-10-26 11:59:10 UTC (rev 48951)
@@ -32,7 +32,7 @@
query = None, cats = None, line = None,
style = wx.DEFAULT_DIALOG_STYLE | wx.RESIZE_BORDER,
pos = wx.DefaultPosition,
- action = "add"):
+ action = "add", ignoreError = False):
"""!Standard dialog used to add/update/display attributes linked
to the vector map.
@@ -47,6 +47,7 @@
@param style
@param pos
@param action (add, update, display)
+ @param ignoreError True to ignore errors
self.parent = parent # mapdisplay.BufferedWindow
self.map = map
@@ -64,17 +65,21 @@
# check if db connection / layer exists
if len(layers) <= 0:
- label = _("Database connection "
- "is not defined in DB file.")
- gcmd.GMessage(parent = self.parent,
- message = _("No attribute table linked to "
- "vector map <%(vector)s> found. %(msg)s\n\n"
- "New attribute table can be created by "
- "Attribute Table Manager.") %
- {'vector' : self.map, 'msg' : label})
+ if not ignoreError:
+ dlg = wx.MessageDialog(parent = self.parent,
+ message = _("No attribute table found.\n\n"
+ "Do you want to create a new attribute table "
+ "and defined a link to vector map <%s>?") % self.map,
+ caption = _("Create table?"),
+ style = wx.YES_NO | wx.NO_DEFAULT | wx.ICON_QUESTION)
+ if dlg.ShowModal() == wx.ID_YES:
+ lmgr = self.parent.lmgr
+ lmgr.OnShowAttributeTable(event = None, selection = 'layers')
+ dlg.Destroy()
self.mapDBInfo = None
wx.Dialog.__init__(self, parent = self.parent, id = wx.ID_ANY,
title = "", style = style, pos = pos)
Modified: grass/trunk/gui/wxpython/gui_modules/mapdisp_vdigit.py
--- grass/trunk/gui/wxpython/gui_modules/mapdisp_vdigit.py 2011-10-26 09:18:01 UTC (rev 48950)
+++ grass/trunk/gui/wxpython/gui_modules/mapdisp_vdigit.py 2011-10-26 11:59:10 UTC (rev 48951)
@@ -159,7 +159,7 @@
addRecordDlg = dbm_dialogs.DisplayAttributesDialog(parent = self, map = mapLayer,
cats = cats,
pos = posWindow,
- action = "add")
+ action = "add", ignoreError = True)
if self.toolbar.GetAction('type') == 'centroid':
for fid in fids:
@@ -350,7 +350,8 @@
# upgrade dialog
self.parent.dialogs['attributes'].UpdateDialog(cats = cats)
- if self.parent.dialogs['attributes']:
+ if self.parent.dialogs['attributes'] and \
+ self.parent.dialogs['attributes'].mapDBInfo:
if len(cats.keys()) > 0:
# highlight feature & re-draw map
if not self.parent.dialogs['attributes'].IsShown():
@@ -883,7 +884,7 @@
addRecordDlg = dbm_dialogs.DisplayAttributesDialog(parent = self, map = mapName,
cats = cats,
pos = posWindow,
- action = "add")
for fid in fids:
self._geomAttrb(fid, addRecordDlg, 'length')
Modified: grass/trunk/gui/wxpython/gui_modules/vdigit.py
--- grass/trunk/gui/wxpython/gui_modules/vdigit.py 2011-10-26 09:18:01 UTC (rev 48950)
+++ grass/trunk/gui/wxpython/gui_modules/vdigit.py 2011-10-26 11:59:10 UTC (rev 48951)
@@ -606,7 +606,8 @@
def OnChangeAddRecord(self, event):
"""!Checkbox 'Add new record' status changed
- self.category.SetValue(self.digit.SetCategory())
+ pass
+ # self.category.SetValue(self.digit.SetCategory())
def OnChangeSnappingValue(self, event):
"""!Change snapping value - update static text
