[GRASS-SVN] r48956 - in grass/trunk: imagery/i.cluster imagery/i.group imagery/i.maxlik imagery/i.rectify imagery/i.target scripts/r.in.srtm vector/v.qcount vector/v.sample vector/v.to.points
Wed Oct 26 16:50:52 EDT 2011
Author: neteler
Date: 2011-10-26 13:50:52 -0700 (Wed, 26 Oct 2011)
New Revision: 48956
   grass/trunk/imagery/i.cluster/i.cluster.html
   grass/trunk/imagery/i.group/i.group.html
   grass/trunk/imagery/i.maxlik/i.maxlik.html
   grass/trunk/imagery/i.rectify/i.rectify.html
   grass/trunk/imagery/i.target/i.target.html
   grass/trunk/scripts/r.in.srtm/r.in.srtm.html
   grass/trunk/vector/v.qcount/v.qcount.html
   grass/trunk/vector/v.sample/v.sample.html
   grass/trunk/vector/v.to.points/v.to.points.html
HTML prettified
Modified: grass/trunk/imagery/i.cluster/i.cluster.html
--- grass/trunk/imagery/i.cluster/i.cluster.html	2011-10-26 20:50:24 UTC (rev 48955)
+++ grass/trunk/imagery/i.cluster/i.cluster.html	2011-10-26 20:50:52 UTC (rev 48956)
@@ -1,16 +1,13 @@
 <h2>DESCRIPTION</h2>
 <em>i.cluster</em>
 performs the first pass in the GRASS two-pass unsupervised
 classification of imagery, while the GRASS program <em>
-<a href="i.maxlik.html">i.maxlik</A></em> executes
+<a href="i.maxlik.html">i.maxlik</a></em> executes
 the second pass. Both programs must be run to complete the unsupervised
 classification.
 <p>
 <em>i.cluster</em> is a clustering algorithm that reads
 through the (raster) imagery data and builds pixel clusters
 based on the spectral reflectances of the pixels (see Figure).
@@ -49,7 +46,7 @@
 The cluster spectral signatures that result are composed of
 cluster means and covariance matrices.  These cluster means
 and covariance matrices are used in the second pass
-(<em><a href="i.maxlik.html">i.maxlik</A></em>) to
+(<em><a href="i.maxlik.html">i.maxlik</a></em>) to
 classify the image.  The clusters or spectral classes
 result can be related to land cover types on the ground.
@@ -62,7 +59,7 @@
 a subset of this group.  The user must create a group and
 subgroup by running the GRASS program
-<em><a href="i.group.html">i.group</A></em>
+<em><a href="i.group.html">i.group</a></em>
 before running <em>i.cluster</em>.  The subgroup should
 contain only the imagery band files that the user wishes to
@@ -72,7 +69,7 @@
 <em>sigfile</em> is the file to contain result signatures
 which can be used as input for
-<em><a href="i.maxlik.html">i.maxlik</A></em>.
+<em><a href="i.maxlik.html">i.maxlik</a></em>.
 The classes value is the initial number of clusters to be
 discriminated; any parameter values left unspecified are
@@ -108,7 +105,7 @@
 than one band file. The user must create a group and a
 before
@@ -118,7 +115,7 @@
 <dd>The name assigned to output signature file which
 contains signatures of classes and can be used as the input
 file for the GRASS program
 for an unsupervised classification.
 <dt><b>classes=</b><em>value</em>
@@ -137,7 +134,7 @@
 supervised classification signature training site section
 (e.g., using the signature file output by
-<em><a href="i.class.html">i.class</A></em>).
+<em><a href="i.class.html">i.class</a></em>).
 The purpose of seed signatures is to optimize the cluster
 decision boundaries (means) for the number of clusters
@@ -157,7 +154,7 @@
 default value is 30. If the number of iterations reaches
 the maximum designated by the user; the user may want to
 rerun <em>i.cluster</em> with a higher number of iterations
-(see <a href="#reportfile"><em>reportfile</em></A>).
+(see <a href="#reportfile"><em>reportfile</em></a>).
 <br>
@@ -183,7 +180,7 @@
 is reached, it is probable that the desired percent
 convergence was not reached. The number of iterations is
 reported in the cluster statistics in the report file
 <br>
@@ -201,7 +198,7 @@
 maximum number of iterations should also be increased to
 achieve this separation with a high percentage of
 convergence
-(see <a href="#convergence"><em>convergence</em></A>).
+(see <a href="#convergence"><em>convergence</em></a>).
 <br>
@@ -218,7 +215,7 @@
 Default: 17
-<A NAME="reportfile"></A>
+<A NAME="reportfile"></a>
 <dt><b>reportfile=</b><em>name</em>
 <dd>The reportfile is an optional parameter which contains
@@ -226,7 +223,6 @@
 included are the resulting percent convergence for the
 clusters, the number of iterations that was required to
 achieve the convergence, and the separability matrix.
 </dl>
@@ -240,16 +236,16 @@
 <h2>SEE ALSO</h2>
 The GRASS 4 <em>
-<a href="http://grass.itc.it/gdp/imagery/grass4_image_processing.pdf">Image
-Processing manual</A></em>
+<a href="http://grass.osgeo.org/gdp/imagery/grass4_image_processing.pdf">Image
+Processing manual</a></em>
 <p>
 <em>
-<a href="i.class.html">i.class</A><br>
-<a href="i.group.html">i.group</A><br>
-<a href="i.gensig.html">i.gensig</A><br>
+<a href="i.class.html">i.class</a>,
+<a href="i.group.html">i.group</a>,
+<a href="i.gensig.html">i.gensig</a>,
 </em>
 <h2>AUTHORS</h2>
@@ -259,7 +255,6 @@
 Research Laboratory
 <br>
 Tao Wen,
 University of Illinois at
 Urbana-Champaign,
Modified: grass/trunk/imagery/i.group/i.group.html
--- grass/trunk/imagery/i.group/i.group.html	2011-10-26 20:50:24 UTC (rev 48955)
+++ grass/trunk/imagery/i.group/i.group.html	2011-10-26 20:50:52 UTC (rev 48956)
@@ -5,13 +5,13 @@
 enables the user to run analyses on any combination of the raster map layers
 in a group.  The user creates the groups and subgroups and selects the
 raster map layers that are to reside in them. Imagery analysis programs like
-<em><a href="i.points.html">i.points</A></em>,
-<em><a href="i.rectify.html">i.rectify</A></em>,
-<em><a href="i.ortho.photo.html">i.ortho.photo</A></em> and
+<em><a href="i.points.html">i.points</a></em>,
+<em><a href="i.rectify.html">i.rectify</a></em>,
+<em><a href="i.ortho.photo.html">i.ortho.photo</a></em> and
 others ask the user for the name of an imagery group whose data are to be
 analyzed. Imagery analysis programs like
-<em><a href="i.cluster.html">i.cluster</A></em> and
-<em><a href="i.maxlik.html">i.maxlik</A></em> ask the user for the imagery group
+<em><a href="i.cluster.html">i.cluster</a></em> and
+<em><a href="i.maxlik.html">i.maxlik</a></em> ask the user for the imagery group
 and imagery subgroup whose data are to be analyzed.
@@ -27,16 +27,16 @@
 <h2>SEE ALSO</h2>
 The GRASS 4 <em>
 <p>
 <em>
-<a href="i.cluster.html">i.cluster</A><br>
-<a href="i.maxlik.html">i.maxlik</A><br>
-<a href="i.points.html">i.points</A><br>
-<a href="i.rectify.html">i.rectify</A><br>
-<a href="i.ortho.photo.html">i.ortho.photo</A>
+<a href="i.cluster.html">i.cluster</a>,
+<a href="i.maxlik.html">i.maxlik</a>,
+<a href="i.points.html">i.points</a>,
+<a href="i.rectify.html">i.rectify</a>,
+<a href="i.ortho.photo.html">i.ortho.photo</a>
 </em>
Modified: grass/trunk/imagery/i.maxlik/i.maxlik.html
--- grass/trunk/imagery/i.maxlik/i.maxlik.html	2011-10-26 20:50:24 UTC (rev 48955)
+++ grass/trunk/imagery/i.maxlik/i.maxlik.html	2011-10-26 20:50:52 UTC (rev 48956)
@@ -1,6 +1,5 @@
 <em>i.maxlik</em> is a maximum-likelihood discriminant
 analysis classifier.  It can be used to perform the second
 step in either an unsupervised or a supervised image
@@ -10,30 +9,28 @@
 Either image classification methods are performed in two
 steps.  The first step in an unsupervised image
 classification is performed by
-<em><a href="i.cluster.html">i.cluster</A></em>; the
+<em><a href="i.cluster.html">i.cluster</a></em>; the
 first step in a supervised classification is executed by
-<a href="i.class.html">i.class</A></em>. In both cases,
+<a href="i.class.html">i.class</a></em>. In both cases,
 the second step in the image classification procedure is
 performed by <em>i.maxlik</em>.
 <p>
 In an unsupervised classification, the maximum-likelihood
 classifier uses the cluster means and covariance matrices
-from the <em><a href="i.cluster.html">i.cluster</A></em>
+from the <em><a href="i.cluster.html">i.cluster</a></em>
 signature file to determine to which category (spectral
 class) each cell in the image has the highest probability
 of belonging. In a supervised image classification, the
 maximum-likelihood classifier uses the region means and
 covariance matrices from the spectral signature file
 generated by <em>
-<a href="i.class.html">i.class</A></em>, based on regions
+<a href="i.class.html">i.class</a></em>, based on regions
 (groups of image pixels) chosen by the user, to determine
 to which category each cell in the image has the highest
 probability of belonging.
 <p>
 In either case, the raster map layer output by
 <em>i.maxlik</em> is a classified image in which each cell
@@ -41,7 +38,6 @@
 The spectral classes (categories) can be related to
 specific land cover types on the ground.
 <p>
 The program will run non-interactively if the user
 specifies the names of raster map layers, i.e., group and
@@ -49,7 +45,6 @@
 classification file name, and any combination of
 non-required options in the command line, using the form
 <dl>
 <dd>
 <b>i.maxlik</b>[<b>-q</b>] <b>group=</b><em>name</em>
@@ -87,25 +82,25 @@
 <dt><b>group=</b><em>name</em>
-<dd>The <a href="i.group.html">imagery</A> group
+<dd>The <a href="i.group.html">imagery</a> group
 contains the subgroup to be classified.
 <dt><b>subgroup=</b><em>name</em>
 <dd>The subgroup contains image files, which were used to create
 the signature file
-in the program <em><a href="i.cluster.html">i.cluster</A></em>,
-<em><a href="i.class.html">i.class</A></em>, or
-<em><a href="i.gensig.html">i.gensig</A></em> to be classified.
+in the program <em><a href="i.cluster.html">i.cluster</a></em>,
+<em><a href="i.class.html">i.class</a></em>, or
+<em><a href="i.gensig.html">i.gensig</a></em> to be classified.
 <dt><b>sigfile=</b><em>name</em>
 <dd>The name of the signatures to be used for the
 classification. The signature file contains the cluster and
 covariance matrices that were calculated by the GRASS
-program <em><a href="i.cluster.html">i.cluster</A></em>
+program <em><a href="i.cluster.html">i.cluster</a></em>
 (or the region means and covariance matrices generated by
-<em><a href="i.class.html">i.class</A></em>, if the
+<em><a href="i.class.html">i.class</a></em>, if the
 user runs a supervised classification). These spectral
 signatures are what determine the categories (classes) to
 which image pixels will be assigned during the
@@ -140,12 +135,12 @@
 signatures for each class (category) in each band file
 are normally distributed (i.e., Gaussian in nature).
 Algorithms, such as
-<em><a href="i.cluster.html">i.cluster</A></em>,
-or <em><a href="i.gensig.html">i.gensig</A></em>,
+<em><a href="i.cluster.html">i.cluster</a></em>,
+or <em><a href="i.gensig.html">i.gensig</a></em>,
 however, can create signatures that are not valid
 distributed (more likely with
-<em><a href="i.class.html">i.class</A>).</em>
+<em><a href="i.class.html">i.class</a>).</em>
 If this occurs,
 <em>i.maxlik</em>
 will reject them and display a warning message.
@@ -161,15 +156,15 @@
 <h2>SEE ALSO</h2>
 The GRASS 4 <em>
 <p>
 <em>
 </em>
 <h2>AUTHORS</h2>
Modified: grass/trunk/imagery/i.rectify/i.rectify.html
--- grass/trunk/imagery/i.rectify/i.rectify.html	2011-10-26 20:50:24 UTC (rev 48955)
+++ grass/trunk/imagery/i.rectify/i.rectify.html	2011-10-26 20:50:52 UTC (rev 48956)
@@ -3,9 +3,9 @@
 <em>i.rectify</em> uses the control
 points identified in
 or
-<em><a href="i.vpoints.html">i.vpoints</A></em>
+<em><a href="i.vpoints.html">i.vpoints</a></em>
 to calculate a transformation matrix based on a first,
 second, or third order polynomial and then converts x,y
@@ -16,9 +16,9 @@
 <p>
 or
 must be run before <em>i.rectify</em>, and both programs
 are required to rectify an image. An image must be
@@ -29,7 +29,7 @@
 deposited in the target standard coordinate LOCATION. This
 LOCATION is selected using
-<em><a href="i.target.html">i.target</A></em>.
+<em><a href="i.target.html">i.target</a></em>.
 <p>More than one raster map may be rectified at a time. Each cell file
 should be given a unique output file name. The rectified image or
@@ -159,18 +159,18 @@
 <h2>SEE ALSO</h2>
 The GRASS 4 <em>
 <p>
 <em>
-  <a href="m.transform.html">m.transform</A>,
-  <a href="r.proj.html">r.proj</A>,
-  <a href="v.proj.html">v.proj</A>,
-  <a href="i.group.html">i.group</A>,
-  <a href="i.points.html">i.points</A>,
-  <a href="i.vpoints.html">i.vpoints</A>,
-  <a href="i.target.html">i.target</A>
+  <a href="m.transform.html">m.transform</a>,
+  <a href="r.proj.html">r.proj</a>,
+  <a href="v.proj.html">v.proj</a>,
+  <a href="i.group.html">i.group</a>,
+  <a href="i.points.html">i.points</a>,
+  <a href="i.vpoints.html">i.vpoints</a>,
+  <a href="i.target.html">i.target</a>
   <br>
   <a href="wxGUI.GCP_Manager.html">Manage Ground Control Points</a>
 </em>
Modified: grass/trunk/imagery/i.target/i.target.html
--- grass/trunk/imagery/i.target/i.target.html	2011-10-26 20:50:24 UTC (rev 48955)
+++ grass/trunk/imagery/i.target/i.target.html	2011-10-26 20:50:52 UTC (rev 48956)
@@ -4,22 +4,22 @@
 group</a> to a GRASS data base location name and mapset.
 A location name and mapset are required for the
-<em><a href="i.rectify.html">i.rectify</A></em> imagery module, into which
+<em><a href="i.rectify.html">i.rectify</a></em> imagery module, into which
 to write the rectified map just prior to completion of the program;
 <em>i.target</em> enables the user to specify this location.
 <em>i.target</em> must be run before
-<em><a href="i.points.html">i.points</A></em> and
-<em><a href="i.rectify.html">i.rectify</A></em>.
+<em><a href="i.points.html">i.points</a></em> and
+<em><a href="i.rectify.html">i.rectify</a></em>.
 <h2>NOTES</h2>
 <p>
 The module's first option asks for the name of the
-<a href="i.group.html">imagery group</A> that needs a target.
+<a href="i.group.html">imagery group</a> that needs a target.
 The imagery group must be present in the user's current mapset.
-An <a href="i.group.html">imagery group</A> may be targeted to any GRASS
+An <a href="i.group.html">imagery group</a> may be targeted to any GRASS
 location.
 <p>
 If a group name is given without setting options, the currently targeted
@@ -30,16 +30,16 @@
 The GRASS 4 <em>
 <p>
 <em>
-<a href="i.vpoints.html">i.vpoints</A><br>
+<a href="i.vpoints.html">i.vpoints</a>,
 </em><br>
-<em><a href="gm_georect.html">gis.m: GEORECTIFY TOOL</a></em>
+<em><a href="wxGUI.GCP_Manager.html">Manage Ground Control Points</a></em>
 <h2>AUTHOR</h2>
Modified: grass/trunk/scripts/r.in.srtm/r.in.srtm.html
--- grass/trunk/scripts/r.in.srtm/r.in.srtm.html	2011-10-26 20:50:24 UTC (rev 48955)
+++ grass/trunk/scripts/r.in.srtm/r.in.srtm.html	2011-10-26 20:50:52 UTC (rev 48956)
@@ -22,7 +22,7 @@
 <h2>SEE ALSO</h2>
 <em>
-<a href="r.in.bin.html">r.in.bin</A>
+<a href="r.in.bin.html">r.in.bin</a>
 </em>
 <p>
 The <a href="http://www2.jpl.nasa.gov/srtm/">Shuttle Radar Topography Mission</a>
@@ -32,7 +32,7 @@
 <h2>REFERENCES</h2>
-M. Neteler, 2005. <a href="http://grass.itc.it/newsletter/GRASSNews_vol3.pdf">SRTM and VMAP0 data in OGR and GRASS.</a> <i><a href="http://grass.itc.it/newsletter/">GRASS Newsletter</a></i>, Vol.3, pp. 2-6, June 2005. ISSN 1614-8746.
+M. Neteler, 2005. <a href="http://grass.osgeo.org/newsletter/GRASSNews_vol3.pdf">SRTM and VMAP0 data in OGR and GRASS.</a> <i><a href="http://grass.osgeo.org/newsletter/">GRASS Newsletter</a></i>, Vol.3, pp. 2-6, June 2005. ISSN 1614-8746.
 <h2>AUTHORS</h2>
Modified: grass/trunk/vector/v.qcount/v.qcount.html
--- grass/trunk/vector/v.qcount/v.qcount.html	2011-10-26 20:50:24 UTC (rev 48955)
+++ grass/trunk/vector/v.qcount/v.qcount.html	2011-10-26 20:50:52 UTC (rev 48956)
@@ -10,71 +10,55 @@
 <h2>NOTES</h2>
 This program may not work properly with lat-long data. It uses
-<em>hypot()</em>
-in two files: <em>count.c</em> and <em>findquads.c</em>.
+<em>hypot()</em> in two files: <em>count.c</em> and
+<em>findquads.c</em>.
 <h2>SEE ALSO</h2>
-<em><a href="v.random.html">v.random</A></em>
+<em><a href="v.random.html">v.random</a></em>
 <p>
 <em>Complete Spatial Randomness and Quadrat Methods</em>  -
 GRASS Tutorial on <em>v.qcount</em>
 (only available as older file s.qcount-tutorial.ps),
 <p>
 General references include:
 <br>
 Noel A. C. Cressie.
 <em>Statistics for Spatial Data</em>.
 Wiley Series in Probability and Mathematical Statistics. John Wiley
 &amp; Sons, New York, NY, 1st edition, 1991.
 <br>
 Brian D. Ripley.
 <em>Spatial Statistics</em>.
 John Wiley \&amp; Sons, New York, NY, 1981.
 <p>
 References to the indices include:
 <br>
 F. N. David and P. G. Moore.
 Notes on contagious distributions in plant populations.
-<em>Annals of Botany</em>,
-18:47-53, 1954.
+<em>Annals of Botany</em>, 18:47-53, 1954.
 <br>
 J. B. Douglas.  Clustering and aggregation.
-<em>Sankhya B</em>,
-37:398-417, 1975.
+<em>Sankhya B</em>, 37:398-417, 1975.
 <br>
 R. A. Fisher, H. G. Thornton, and W. A. Mackenzie.
 The accuracy of the plating method of estimating the density of
 bacterial populations.
-<em>Annals of Applied Biology</em>,
-9:325-359, 1922.
+<em>Annals of Applied Biology</em>, 9:325-359, 1922.
 <br>
-M. Lloyd.
-Mean crowding.
-<em>Journal of Animal Ecology</em>,
-36:1-30, 1967.
+M. Lloyd. Mean crowding.
+<em>Journal of Animal Ecology</em>, 36:1-30, 1967.
 <br>
 M. Morista.
 Measuring the dispersion and analysis of distribution patterns.
 <em>Memoires of the Faculty of Science, Kyushu University, Series E.
@@ -85,21 +69,20 @@
 Timestamp not working for header part of counts output. (2000-10-28)
 <p>
 Please send all bug fixes and comments to the author
-or the grass development team. <br>
-<a href="http://grass.itc.it"><tt>http://grass.itc.it</tt></a>.
+or the GRASS development team. <br>
+<a href="http://grass.osgeo.org"><tt>http://grass.osgeo.org</tt></a>.
-<h2>AUTHOR</h2>
+<h2>AUTHORS</h2>
-<a href="http://mccauley-usa.com/">James Darrell McCauley</A>
-<a href="mailto:darrell at mccauley-usa.com">&lt;darrell at mccauley-usa.com&gt;</A>,
+<a href="http://mccauley-usa.com/">James Darrell McCauley</a>
+<a href="mailto:darrell at mccauley-usa.com">&lt;darrell at mccauley-usa.com&gt;</a>,
 <br>when he was at:
-<a href="http://ABE.www.ecn.purdue.edu/ABE/">Agricultural Engineering</A>
-<a href="http://www.purdue.edu/">Purdue University</A>
+<a href="http://ABE.www.ecn.purdue.edu/ABE/">Agricultural Engineering</a>
+<a href="http://www.purdue.edu/">Purdue University</a>
 <p>
 Modified for GRASS 5.0 by Eric G. Miller (2000-10-28)
 <br>
 Modified for GRASS 5.7 by R. Blazek (2004-10-14)
 <p><i>Last changed: $Date$</i>
Modified: grass/trunk/vector/v.sample/v.sample.html
--- grass/trunk/vector/v.sample/v.sample.html	2011-10-26 20:50:24 UTC (rev 48955)
+++ grass/trunk/vector/v.sample/v.sample.html	2011-10-26 20:50:52 UTC (rev 48956)
@@ -6,7 +6,6 @@
 sampling (default).
 <p>
 This program may be especially useful when sampling for
 cross validation of interpolations whose output is a raster
 map.
@@ -23,12 +22,10 @@
 by using the default nearest neighbor comparisons.
 <p>
 This program may not work properly with lat-long data when
 the <b>-BC</b> flags are used.
 <p>
 When interpolation is done (i.e., the <b>-BC</b> flags are
 used), values are assumed to be located at the centroid of
 grid cells.  Therefore, current resolution settings are
@@ -63,22 +60,22 @@
 <h2>SEE ALSO</h2>
 <em>
-<a href="v.random.html">v.random</A>,
-<a href="g.region.html">g.region</A>
+<a href="v.random.html">v.random</a>,
+<a href="g.region.html">g.region</a>
 </em>
 <em>Image Sampling Methods</em> - GRASS Tutorial on <em>s.sample</em>
 (available as
-<a href="http://grass.itc.it/gdp/sites/">s.sample-tutorial.ps.gz</A>)
+<a href="http://grass.osgeo.org/gdp/sites/">s.sample-tutorial.ps.gz</a>)
 <h2>AUTHOR</h2>
 <br>when he was at:
 <p>
 Updated for GRASS 5.0 by Eric G. Miller
 <br>
Modified: grass/trunk/vector/v.to.points/v.to.points.html
--- grass/trunk/vector/v.to.points/v.to.points.html	2011-10-26 20:50:24 UTC (rev 48955)
+++ grass/trunk/vector/v.to.points/v.to.points.html	2011-10-26 20:50:52 UTC (rev 48956)
@@ -64,7 +64,7 @@
 <h2>EXAMPLE</h2>
 In this example, the 't_powerlines' vector lines map in the
-<a href="http://grass.itc.it/download/data6.php">Spearfish 6</a>
+<a href="http://grass.osgeo.org/download/data6.php">Spearfish 6</a>
 location is used to create points along the input lines:
 <div class="code"><pre>
