[GRASS-SVN] r48958 -
grass/branches/develbranch_6/gui/wxpython/gui_modules
svn_grass at osgeo.org
Thu Oct 27 05:17:18 EDT 2011
Author: martinl
Date: 2011-10-27 02:17:18 -0700 (Thu, 27 Oct 2011)
New Revision: 48958
grass/branches/develbranch_6/gui/wxpython/gui_modules/colorrules.py
wxGUI/ColorRules: cosmetics in layout (define growable widgets)
(merge r48957 from trunk)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/colorrules.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/colorrules.py 2011-10-27 09:12:09 UTC (rev 48957)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/colorrules.py 2011-10-27 09:17:18 UTC (rev 48958)
@@ -390,33 +390,37 @@
inputSizer = wx.StaticBoxSizer(inputBox, wx.VERTICAL)
self.loadRules = filebrowse.FileBrowseButton(parent = parent, id = wx.ID_ANY, fileMask = '*',
- size = globalvar.DIALOG_GSELECT_SIZE,
- labelText = _('Load color table from file:'),
- dialogTitle = _('Choose file to load color table'),
- buttonText = _('Load'),
- toolTip = _("Type filename or click to choose "
- "file and load color table"),
- startDirectory = os.getcwd(), fileMode = wx.OPEN,
- changeCallback = self.OnLoadRulesFile)
+ size = globalvar.DIALOG_GSELECT_SIZE,
+ labelText = _('Load color table from file:'),
+ dialogTitle = _('Choose file to load color table'),
+ buttonText = _('Load'),
+ toolTip = _("Type filename or click to choose "
+ "file and load color table"),
+ startDirectory = os.getcwd(), fileMode = wx.OPEN,
+ changeCallback = self.OnLoadRulesFile)
self.saveRules = filebrowse.FileBrowseButton(parent = parent, id = wx.ID_ANY, fileMask = '*',
- labelText = _('Save color table to file:'),
- dialogTitle = _('Choose file to save color table'),
- "file and save color table"),
- buttonText = _('Save'),
- startDirectory = os.getcwd(), fileMode = wx.SAVE,
- changeCallback = self.OnSaveRulesFile)
+ labelText = _('Save color table to file:'),
+ dialogTitle = _('Choose file to save color table'),
+ "file and save color table"),
+ buttonText = _('Save'),
+ startDirectory = os.getcwd(), fileMode = wx.SAVE,
+ changeCallback = self.OnSaveRulesFile)
default = wx.Button(parent = parent, id = wx.ID_ANY, label = _("Reload default table"))
# layout
sizer = wx.BoxSizer(wx.HORIZONTAL)
- sizer.Add(item = self.loadRules, flag = wx.RIGHT, border = 10)
+ sizer.Add(item = self.loadRules, proportion = 1,
+ flag = wx.RIGHT | wx.EXPAND, border = 10)
sizer.Add(item = default, flag = wx.ALIGN_CENTER_VERTICAL)
- inputSizer.Add(item = sizer, flag = wx.TOP|wx.LEFT, border = 5)
+ inputSizer.Add(item = sizer,
+ flag = wx.TOP | wx.LEFT | wx.RIGHT | wx.EXPAND, border = 5)
- sizer.Add(item = self.saveRules, flag = wx.ALIGN_CENTER_VERTICAL)
- inputSizer.Add(item = sizer, flag = wx.ALL, border = 5)
+ sizer.Add(item = self.saveRules, proportion = 1,
+ flag = wx.ALIGN_CENTER_VERTICAL | wx.EXPAND)
+ inputSizer.Add(item = sizer, proportion = 1,
+ flag = wx.ALL | wx.EXPAND, border = 5)
default.Bind(wx.EVT_BUTTON, self.OnLoadDefaultTable)
@@ -462,27 +466,29 @@
def _createBody(self, parent):
"""!Create dialog body consisting of rules and preview"""
bodySizer = wx.GridBagSizer(hgap = 5, vgap = 5)
+ bodySizer.AddGrowableRow(1)
+ bodySizer.AddGrowableCol(2)
row = 0
# label with range
self.cr_label = wx.StaticText(parent, id = wx.ID_ANY)
bodySizer.Add(item = self.cr_label, pos = (row, 0), span = (1, 3),
row += 1
# color table
self.rulesPanel = RulesPanel(parent = parent, mapType = self.mapType,
- attributeType = self.attributeType, properties = self.properties)
+ attributeType = self.attributeType, properties = self.properties)
- bodySizer.Add(item = self.rulesPanel.mainPanel, pos = (row, 0), span = (1, 2),
- flag = wx.ALL, border = 5)
+ bodySizer.Add(item = self.rulesPanel.mainPanel, pos = (row, 0),
+ span = (1, 2), flag = wx.EXPAND)
# add two rules as default
self.rulesPanel.AddRules(2)
# preview window
self._createPreview(parent = parent)
- bodySizer.Add(item = self.preview, pos = (row, 2),
- flag = wx.EXPAND | wx.LEFT | wx.RIGHT, border = 5)
+ bodySizer.Add(item = self.preview, pos = (row, 2), flag = wx.EXPAND)
row += 1
# add ckeck all and clear all
bodySizer.Add(item = self.rulesPanel.checkAll, flag = wx.ALIGN_CENTER_VERTICAL,
@@ -497,6 +503,7 @@
self.btnPreview.Enable(False)
self.btnPreview.SetToolTipString(_("Show preview of map "
"(current Map Display extent is used)."))
row +=1
# add rules button and spin to sizer
bodySizer.Add(item = self.rulesPanel.numRules, pos = (row, 0),
@@ -931,7 +938,7 @@
self.SetMinSize(self.GetSize())
self.CentreOnScreen()
- self.SetSize((-1, 735))
+ self.SetSize((-1, 760))
self.Show()
def _createVectorAttrb(self, parent):
@@ -1040,10 +1047,9 @@
# body & preview
bodySizer = self._createBody(parent = scrollPanel)
- sizer.Add(item = bodySizer, proportion = 0,
+ sizer.Add(item = bodySizer, proportion = 1,
scrollPanel.SetSizer(sizer)
scrollPanel.Fit()
@@ -1097,7 +1103,6 @@
def OnCheckColumn(self, event):
"""!Use color column instead of color table"""
if self.useColumn.GetValue():
self.properties['loadColumn'] = self.fromColumn.GetStringSelection()
self.properties['storeColumn'] = self.toColumn.GetStringSelection()
