[GRASS-SVN] r48962 - grass/trunk/lib/vector/Vlib
svn_grass at osgeo.org
Thu Oct 27 07:19:10 EDT 2011
Author: martinl
Date: 2011-10-27 04:19:10 -0700 (Thu, 27 Oct 2011)
New Revision: 48962
grass/trunk/lib/vector/Vlib/map.c
vlib: Vect_copy_map_lines() support for OGR output added
Modified: grass/trunk/lib/vector/Vlib/map.c
--- grass/trunk/lib/vector/Vlib/map.c 2011-10-27 11:17:24 UTC (rev 48961)
+++ grass/trunk/lib/vector/Vlib/map.c 2011-10-27 11:19:10 UTC (rev 48962)
@@ -47,6 +47,8 @@
\brief Copy all alive vector features from given layer of opened
vector map to another opened vector map
+ Note: Try to copy on level 2 otherwise level 1 is used.
\param In input vector map
\param field layer number (-1 for all layers)
\param[out] Out output vector map
@@ -57,7 +59,7 @@
int Vect_copy_map_lines_field(struct Map_info *In, int field,
struct Map_info *Out)
- int i, type, nlines, ret, left, rite, centroid;
+ int i, type, nlines, ret, left, rite, centroid, ogr;
struct line_pnts *Points, *CPoints;
struct line_cats *Cats, *CCats;
@@ -70,6 +72,7 @@
G_fatal_error("Vect_copy_map_lines(): %s",
_("input vector map is not open"));
+ ogr = Vect_maptype(Out) == GV_FORMAT_OGR_DIRECT;
ret = 0;
/* Note: sometimes is important to copy on level 2 (pseudotopo centroids)
* and sometimes on level 1 if build take too long time */
@@ -89,6 +92,11 @@
if (type == 0)
continue; /* dead line */
+ if (ogr && (type == GV_CENTROID || type == GV_BOUNDARY))
+ /* OGR layers: centroids are stored in topo */
+ /* polygon defined by areas (topo required) */
+ continue;
/* don't skips boundaries if field != -1 */
if (field != -1) {
if (type & GV_BOUNDARY) {
@@ -129,10 +137,30 @@
Vect_write_line(Out, type, Points, Cats);
+ if (ogr) {
+ int area, nareas;
+ /* copy areas/polygons */
+ nareas = Vect_get_num_areas(In);
+ for (area = 1; area <= nareas; area++) {
+ G_debug(3, "area = %d", area);
+ Vect_get_area_points(In, area, Points);
+ centroid = Vect_get_area_centroid(In, area);
+ if (centroid > 0)
+ Vect_read_line(In, NULL, CCats, centroid);
+ else
+ Vect_reset_cats(CCats);
+ Vect_write_line(Out, GV_BOUNDARY, Points, CCats);
- else { /* Level 1 */
+ else {
+ /* Level 1 */
+ if (ogr)
+ G_warning(_("Topology not available. Polygons will be skipped."));
Vect_rewind(In);
- while (1) {
+ while (TRUE) {
type = Vect_read_next_line(In, Points, Cats);
if (type == -1) {
G_warning(_("Unable to read vector map <%s>"),
