[GRASS-SVN] r48975 - grass/trunk/gui/wxpython
svn_grass at osgeo.org
Thu Oct 27 17:57:07 EDT 2011
Author: martinl
Date: 2011-10-27 14:57:07 -0700 (Thu, 27 Oct 2011)
New Revision: 48975
grass/trunk/gui/wxpython/gis_set.py
wxGUI/welcome screen: check reserved mapsets (OGR)
Modified: grass/trunk/gui/wxpython/gis_set.py
--- grass/trunk/gui/wxpython/gis_set.py 2011-10-27 19:25:50 UTC (rev 48974)
+++ grass/trunk/gui/wxpython/gis_set.py 2011-10-27 21:57:07 UTC (rev 48975)
@@ -683,13 +683,32 @@
"""!Create new mapset"""
self.gisdbase = self.tgisdbase.GetValue()
location = self.listOfLocations[self.lblocations.GetSelection()]
dlg = wx.TextEntryDialog(parent = self,
message = _('Enter name for new mapset:'),
caption = _('Create new mapset'))
if dlg.ShowModal() == wx.ID_OK:
mapset = dlg.GetValue()
+ if mapset in self.listOfMapsets:
+ GMessage(parent = self,
+ message = _("Mapset <%s> already exists.") % mapset)
+ return
+ if mapset.lower() == 'ogr':
+ dlg1 = wx.MessageDialog(parent = self,
+ message = _("Mapset <%s> is reserved for direct "
+ "read access to OGR layers. Please consider to use "
+ "another name for your mapset.\n\n"
+ "Are you really sure that you want to create this mapset?") % mapset,
+ caption = _("Reserved mapset name"),
+ style = wx.YES_NO | wx.NO_DEFAULT | wx.ICON_QUESTION)
+ ret = dlg1.ShowModal()
+ dlg1.Destroy()
+ if ret == wx.ID_NO:
+ dlg.Destroy()
+ return
try:
os.mkdir(os.path.join(self.gisdbase, location, mapset))
# copy WIND file and its permissions from PERMANENT and set permissions to u+rw,go+r
@@ -699,12 +718,11 @@
self.OnSelectLocation(None)
self.lbmapsets.SetSelection(self.listOfMapsets.index(mapset))
except StandardError, e:
- dlg = wx.MessageDialog(parent = self, message = _("Unable to create new mapset: %s") % e,
- caption = _("Error"), style = wx.OK | wx.ICON_ERROR)
- dlg.ShowModal()
- dlg.Destroy()
+ GError(parent = self,
+ message = _("Unable to create new mapset: %s") % e)
return False
+ dlg.Destroy()
self.bstart.SetFocus()
return True
