[GRASS-SVN] r48997 -
grass/branches/develbranch_6/gui/wxpython/gui_modules
svn_grass at osgeo.org
Sat Oct 29 17:56:46 EDT 2011
Author: martinl
Date: 2011-10-29 14:56:45 -0700 (Sat, 29 Oct 2011)
New Revision: 48997
grass/branches/develbranch_6/gui/wxpython/gui_modules/gmodeler.py
wxGUI/modeler: substitute variables also in input files (ascii)
(merge r48994 from trunk)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/gmodeler.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/gmodeler.py 2011-10-29 21:56:20 UTC (rev 48996)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/gmodeler.py 2011-10-29 21:56:45 UTC (rev 48997)
@@ -50,6 +50,7 @@
import tempfile
import copy
import re
+import mimetypes
try:
import xml.etree.ElementTree as etree
@@ -433,11 +434,74 @@
if statusbar:
statusbar.SetStatusText(_('Running model...'), 0)
+ # collect ascii inputs
+ self.fileInput = dict()
+ for p in item.GetParams()['params']:
+ if p.get('element', '') == 'file' and \
+ p.get('prompt', '') == 'input' and \
+ p.get('age', '') == 'old':
+ filename = p.get('value', p.get('default', ''))
+ if filename and \
+ mimetypes.guess_type(filename)[0] == 'text/plain':
+ self.fileInput[filename] = None
+ for finput in self.fileInput:
+ # read lines
+ fd = open(finput, "r")
+ try:
+ data = self.fileInput[finput] = fd.read()
+ finally:
+ fd.close()
+ # substitute variables
+ write = False
+ variables = self.GetVariables()
+ for variable in variables:
+ pattern= re.compile('%' + variable)
+ value = ''
+ if params and 'variables' in params:
+ for p in params['variables']['params']:
+ if variable == p.get('name', ''):
+ value = p.get('value', '')
+ break
+ if not value:
+ value = variables[variable].get('value', '')
+ data = pattern.sub(value, data)
+ write = True
+ if write:
+ fd = open(finput, "w")
+ try:
+ fd.write(data)
+ finally:
+ fd.close()
+ else:
+ self.fileInput[finput] = None
log.RunCmd(command = item.GetLog(string = False, substitute = True),
onDone = onDone)
if name in params:
item.SetParams(paramsOrig)
+ def CleanUp(self):
+ """!Clean up model"""
+ if hasattr(self, "fileInput"):
+ # restore original files
+ if not data:
+ continue
+ try:
+ fd.write(data)
+ finally:
+ fd.close()
+ del self.fileInput
def Run(self, log, onDone, parent = None):
"""!Run model
@@ -1079,6 +1143,7 @@
def OnDone(self, cmd, returncode):
"""!Computation finished"""
self.SetStatusText('', 0)
+ self.model.CleanUp()
def OnValidateModel(self, event, showMsg = True):
"""!Validate entire model"""
