[GRASS-SVN] r49003 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Sun Oct 30 05:58:44 EDT 2011
Author: annakrat
Date: 2011-10-30 02:58:43 -0700 (Sun, 30 Oct 2011)
New Revision: 49003
grass/trunk/gui/wxpython/gui_modules/mapdisp_statusbar.py
wxGUI: fixed removing/inserting statusbar items when switching 2D/3D view
Modified: grass/trunk/gui/wxpython/gui_modules/mapdisp_statusbar.py
--- grass/trunk/gui/wxpython/gui_modules/mapdisp_statusbar.py 2011-10-29 22:14:49 UTC (rev 49002)
+++ grass/trunk/gui/wxpython/gui_modules/mapdisp_statusbar.py 2011-10-30 09:58:43 UTC (rev 49003)
@@ -142,13 +142,17 @@
@see ShowStatusbarChoiceItemsByClass
@todo consider adding similar function which would take item names
+ index = []
for itemClass in itemClasses:
for i in range(0, self.choice.GetCount() - 1):
item = self.choice.GetClientData(i)
if item.__class__ == itemClass:
- self.choice.Delete(i)
- self._hiddenItems[item] = i
+ index.append(i)
+ self._hiddenItems[i] = item
+ # must be sorted in reverse order to be removed correctly
+ for i in sorted(index, reverse = True):
+ self.choice.Delete(i)
def ShowStatusbarChoiceItemsByClass(self, itemClasses):
"""!Shows items showed in choice
@@ -160,14 +164,12 @@
@see HideStatusbarChoiceItemsByClass
- for itemClass in itemClasses:
- for item in self.statusbarItems.values():
- if item.__class__ == itemClass:
- if self.choice.FindString(item.label) != wx.NOT_FOUND:
- return # item already in choice
- pos = self._hiddenItems[item]
- self.choice.Insert(item.label, pos, item)
+ # must be sorted to be inserted correctly
+ for pos in sorted(self._hiddenItems.keys()):
+ item = self._hiddenItems[pos]
+ if item.__class__ in itemClasses:
+ self.choice.Insert(item.label, pos, item)
def ShowItem(self, itemName):
"""!Invokes showing of particular item
