[GRASS-SVN] r49008 - in grass-addons/vector: . v.in.ply
Sun Oct 30 14:20:13 EDT 2011
Author: neteler
Date: 2011-10-30 11:20:13 -0700 (Sun, 30 Oct 2011)
New Revision: 49008
Added:
   grass-addons/vector/v.in.ply/
   grass-addons/vector/v.in.ply/Makefile
   grass-addons/vector/v.in.ply/description.html
   grass-addons/vector/v.in.ply/v.in.ply
new
Added: grass-addons/vector/v.in.ply/Makefile
--- grass-addons/vector/v.in.ply/Makefile	                        (rev 0)
+++ grass-addons/vector/v.in.ply/Makefile	2011-10-30 18:20:13 UTC (rev 49008)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../..
+PGM = v.in.ply
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script
Property changes on: grass-addons/vector/v.in.ply/Makefile
___________________________________________________________________
Added: svn:eol-style
   + native
Added: grass-addons/vector/v.in.ply/description.html
--- grass-addons/vector/v.in.ply/description.html	                        (rev 0)
+++ grass-addons/vector/v.in.ply/description.html	2011-10-30 18:20:13 UTC (rev 49008)
@@ -0,0 +1,25 @@
+<h2>DESCRIPTION</h2>
+<em>v.in.ply</em> imports point clouds stored as PLY file
+(<a href="http://en.wikipedia.org/wiki/PLY_%28file_format%29">PLY format</a>)
+as vector points into GRASS.
+<br>
+If color definitions are present for each point, a corresponding
+GRASSRGB (RRR:GGG:BBB, varchar (11)) column is created and populated.
+<h2>EXAMPLE</h2>
+<div class="code"><pre>
+v.in.ply archaeo_pointcloud.ply
+</pre></div>
+<h2>SEE ALSO</h2>
+<em><a href="v.in.ascii.html">v.in.ascii</a></em>
+<h2>AUTHOR</h2>
+Markus Neteler<br>
+during his visit at <a href="http://www.topoi.org/">TOPOI Excellence Cluster</a>, FU Berlin, Germany
+<p><i>Last changed: $Date$</i>
Property changes on: grass-addons/vector/v.in.ply/description.html
Added: svn:mime-type
   + text/html
Added: svn:keywords
   + Author Date Id
   + native
Added: grass-addons/vector/v.in.ply/v.in.ply
--- grass-addons/vector/v.in.ply/v.in.ply	                        (rev 0)
+++ grass-addons/vector/v.in.ply/v.in.ply	2011-10-30 18:20:13 UTC (rev 49008)
@@ -0,0 +1,103 @@
+#!/bin/sh
+# MODULE:       v.in.ply
+# AUTHOR(S):    Markus Neteler
+# PURPOSE:      Imports PLY file as a GRASS vector map
+#               http://en.wikipedia.org/wiki/PLY_%28file_format%29
+#               If RGB colors are present in the PLY file, automatically
+#               a GRASSRGB column is created and populated with RRR:GGG:BBB
+# COPYRIGHT:    (c) 2011 Markus Neteler, GRASS Development Team
+#               This program is free software under the GNU General Public
+#               License (>=v2). Read the file COPYING that comes with GRASS
+#               for details.
+#%Module
+#%  description: Import PLY file into a vector map.
+#%  keywords: vector, import
+#%End
+#%option
+#% key: file
+#% type: string
+#% description: PLY file
+#% gisprompt: old_file,file,input
+#% required : yes
+#%end
+#%option
+#% key: vect
+#% type: string
+#% gisprompt: new,vector,vector
+#% description: Name for output vector map
+#% required : no
+#%end
+if  [ -z "$GISBASE" ] ; then
+    echo "You must be in GRASS GIS to run this program." >&2
+ exit 1
+fi
+# save command line
+if [ "$1" != "@ARGS_PARSED@" ] ; then
+    CMDLINE=`basename "$0"`
+    for arg in "$@" ; do
+        CMDLINE="$CMDLINE \"$arg\""
+    done
+    export CMDLINE
+    exec g.parser "$0" "$@"
+fi
+PROG=`basename "$0"`
+#### check if we have awk
+if [ ! -x "`which awk`" ] ; then
+    g.message -e "awk required, please install awk or gawk first"
+    exit 1
+fi
+# setting environment, so that awk works properly in all languages
+unset LC_ALL
+LC_NUMERIC=C
+export LC_NUMERIC
+cat ${GIS_OPT_FILE} | awk "/ply/,/end_header/" > /dev/null
+DATALINES=`head -n 30 ${GIS_OPT_FILE} | grep 'element vertex' | cut -d' ' -f3`
+head -n 30 ${GIS_OPT_FILE} | grep 'char red' > /dev/null 2>/dev/null
+if [ $? == 0 ] ; then
+   echo "Colors found in PLY file, creating GRASSRGB column"
+   COLOR=1
+else
+   COLOR=0
+fi
+if [ -n "$GIS_OPT_VECT" ] ; then
+    MAP="$GIS_OPT_VECT"
+else
+    MAP=`basename $GIS_OPT_FILE .ply`
+fi
+if [ $COLOR == 0 ] ; then
+   tail -n $DATALINES ${GIS_OPT_FILE} | tr -s ' ' ' ' | sed 's+^ ++g' | cut -d' ' -f1-3 | v.in.ascii -z x=1 y=2 z=3 out=$MAP fs=" "
+   if [ $? -ne 0 ] ; then
+      g.message -e "An error occurred. Halting."
+      exit 1
+   fi
+else
+   tail -n $DATALINES ${GIS_OPT_FILE} | tr -s ' ' ' ' | sed 's+^ ++g' | cut -d' ' -f1-7 | awk -F " " '{printf "%f,%f,%f,%d:%d:%d,%d\n", $1, $2, $3, $4, $5, $6, $7}' | v.in.ascii -z x=1 y=2 z=3 out=$MAP fs="," columns="x double precision,y double precision,z double precision,GRASSRGB varchar(11),alpha integer"
+      exit 1
+   fi
+fi
+# write cmd history:
+v.support "$MAP" cmdhist="${CMDLINE}"
+exit 0
Property changes on: grass-addons/vector/v.in.ply/v.in.ply
Added: svn:executable
   + text/x-sh
   + native
