[GRASS-SVN] r49021 - grass/trunk/imagery/i.vi
svn_grass at osgeo.org
Mon Oct 31 11:52:36 EDT 2011
Author: ychemin
Date: 2011-10-31 08:52:36 -0700 (Mon, 31 Oct 2011)
New Revision: 49021
grass/trunk/imagery/i.vi/main.c
added switch for input data types other than double
Modified: grass/trunk/imagery/i.vi/main.c
--- grass/trunk/imagery/i.vi/main.c 2011-10-31 13:02:22 UTC (rev 49020)
+++ grass/trunk/imagery/i.vi/main.c 2011-10-31 15:52:36 UTC (rev 49021)
@@ -4,21 +4,21 @@
* MODULE: i.vi
* AUTHOR(S): Baburao Kamble baburaokamble at gmail.com
* Yann Chemin - yann.chemin at gmail.com
- * PURPOSE: Calculates 14 vegetation indices
- * based on biophysical parameters.
+ * PURPOSE: Calculates 14 vegetation indices
+ * based on biophysical parameters.
* COPYRIGHT: (C) 2002-2008 by the GRASS Development Team
* This program is free software under the GNU General Public
* License (>=v2). Read the file COPYING that comes with GRASS
* for details.
- * Remark:
- * These are generic indices that use red and nir for most of them.
+ * Remark:
+ * These are generic indices that use red and nir for most of them.
* Those can be any use by standard satellite having V and IR.
- * However arvi uses red, nir and blue;
+ * However arvi uses red, nir and blue;
* GVI uses B,G,R,NIR, chan5 and chan 7 of landsat;
- * and GARI uses B,G,R and NIR.
+ * and GARI uses B,G,R and NIR.
* Changelog: Added EVI on 20080718 (Yann)
* Added VARI on 20081014 (Yann)
@@ -50,7 +50,7 @@
double greenchan);
double va_ri(double redchan, double greenchan, double bluechan);
-int main(int argc, char *argv[])
+int main(int argc, char *argv[])
int nrows, ncols;
int row, col;
@@ -69,6 +69,10 @@
DCELL *inrast_redchan, *inrast_nirchan, *inrast_greenchan;
DCELL *inrast_bluechan, *inrast_chan5chan, *inrast_chan7chan;
DCELL *outrast;
+ RASTER_MAP_TYPE data_type_redchan;
+ RASTER_MAP_TYPE data_type_nirchan, data_type_greenchan;
+ RASTER_MAP_TYPE data_type_bluechan;
+ RASTER_MAP_TYPE data_type_chan5chan, data_type_chan7chan;
CELL val1, val2;
G_gisinit(argv[0]);
@@ -81,8 +85,8 @@
_("Calculates different types of vegetation indices.");
module->description = _("Uses red and nir bands mostly, "
"and some indices require additional bands.");
- /* Define the different options */
+ /* Define the different options */
input1 = G_define_option();
input1->key = _("viname");
input1->type = TYPE_STRING;
@@ -123,7 +127,7 @@
input4->label =
_("Name of the green channel surface reflectance map");
input4->description = _("Range: [0.0;1.0]");
input5 = G_define_standard_option(G_OPT_R_INPUT);
input5->key = "blue";
input5->required = NO;
@@ -141,7 +145,7 @@
input7 = G_define_standard_option(G_OPT_R_INPUT);
input7->key = "chan7";
input7->required = NO;
- input7->label =
+ input7->label =
_("Name of the chan7 channel surface reflectance map");
input7->description = _("Range: [0.0;1.0]");
@@ -189,24 +193,24 @@
if (!strcmp(viflag, "gemi") && (!(input2->answer) || !(input3->answer)) )
G_fatal_error(_("gemi index requires red and nir maps"));
- if (!strcmp(viflag, "arvi") && (!(input2->answer) || !(input3->answer)
+ if (!strcmp(viflag, "arvi") && (!(input2->answer) || !(input3->answer)
|| !(input5->answer)) )
G_fatal_error(_("arvi index requires blue, red and nir maps"));
- if (!strcmp(viflag, "evi") && (!(input2->answer) || !(input3->answer)
+ if (!strcmp(viflag, "evi") && (!(input2->answer) || !(input3->answer)
G_fatal_error(_("evi index requires blue, red and nir maps"));
- if (!strcmp(viflag, "vari") && (!(input2->answer) || !(input4->answer)
+ if (!strcmp(viflag, "vari") && (!(input2->answer) || !(input4->answer)
G_fatal_error(_("vari index requires blue, green and red maps"));
- if (!strcmp(viflag, "gari") && (!(input2->answer) || !(input3->answer)
+ if (!strcmp(viflag, "gari") && (!(input2->answer) || !(input3->answer)
|| !(input4->answer) || !(input5->answer)) )
G_fatal_error(_("gari index requires blue, green, red and nir maps"));
- if (!strcmp(viflag, "gvi") && (!(input2->answer) || !(input3->answer)
- || !(input4->answer) || !(input5->answer)
+ if (!strcmp(viflag, "gvi") && (!(input2->answer) || !(input3->answer)
+ || !(input4->answer) || !(input5->answer)
|| !(input6->answer) || !(input7->answer)) )
G_fatal_error(_("gvi index requires blue, green, red, nir, chan5 and chan7 maps"));
@@ -215,37 +219,42 @@
if (nirchan) {
infd_nirchan = Rast_open_old(nirchan, "");
- inrast_nirchan = Rast_allocate_d_buf();
+ data_type_nirchan = Rast_map_type(nirchan, "");
+ inrast_nirchan = Rast_allocate_buf(data_type_nirchan);
if (greenchan) {
- infd_greenchan = Rast_open_old(greenchan, "");
- inrast_greenchan = Rast_allocate_d_buf();
+ infd_greenchan = Rast_open_old(greenchan, "");
+ data_type_greenchan = Rast_map_type(greenchan, "");
+ inrast_greenchan = Rast_allocate_buf(data_type_greenchan);
if (bluechan) {
- infd_bluechan = Rast_open_old(bluechan, "");
- inrast_bluechan = Rast_allocate_d_buf();
+ infd_bluechan = Rast_open_old(bluechan, "");
+ data_type_bluechan = Rast_map_type(bluechan, "");
+ inrast_bluechan = Rast_allocate_buf(data_type_bluechan);
if (chan5chan) {
- infd_chan5chan = Rast_open_old(chan5chan, "");
- inrast_chan5chan = Rast_allocate_d_buf();
+ infd_chan5chan = Rast_open_old(chan5chan, "");
+ data_type_chan5chan = Rast_map_type(chan5chan, "");
+ inrast_chan5chan = Rast_allocate_buf(data_type_chan5chan);
if (chan7chan) {
- infd_chan7chan = Rast_open_old(chan7chan, "");
- inrast_chan7chan = Rast_allocate_d_buf();
+ infd_chan7chan = Rast_open_old(chan7chan, "");
+ data_type_chan7chan = Rast_map_type(chan7chan, "");
+ inrast_chan7chan = Rast_allocate_buf(data_type_chan7chan);
nrows = Rast_window_rows();
ncols = Rast_window_cols();
outrast = Rast_allocate_d_buf();
- /* Create New raster files */
+ /* Create New raster files */
outfd = Rast_open_new(result, DCELL_TYPE);
- /* Process pixels */
+ /* Process pixels */
for (row = 0; row < nrows; row++)
DCELL d_bluechan;
@@ -257,19 +266,84 @@
G_percent(row, nrows, 2);
- Rast_get_d_row(infd_redchan, inrast_redchan, row);
- if (nirchan)
- Rast_get_d_row(infd_nirchan, inrast_nirchan, row);
- if (greenchan)
- Rast_get_d_row(infd_greenchan, inrast_greenchan, row);
- if (bluechan)
- Rast_get_d_row(infd_bluechan, inrast_bluechan, row);
- if (chan5chan)
- Rast_get_d_row(infd_chan5chan, inrast_chan5chan, row);
- if (chan7chan)
- Rast_get_d_row(infd_chan7chan, inrast_chan7chan, row);
+ switch(data_type_redchan){
+ case CELL_TYPE:
+ d_redchan = (double) ((CELL *) inrast_redchan)[col];
+ break;
+ case FCELL_TYPE:
+ d_redchan = (double) ((FCELL *) inrast_redchan)[col];
+ break;
+ case DCELL_TYPE:
+ d_redchan = ((DCELL *) inrast_redchan)[col];
+ break;
+ if (nirchan) {
+ switch(data_type_nirchan){
+ case CELL_TYPE:
+ d_nirchan = (double) ((CELL *) inrast_nirchan)[col];
+ break;
+ case FCELL_TYPE:
+ d_nirchan = (double) ((FCELL *) inrast_nirchan)[col];
+ break;
+ case DCELL_TYPE:
+ d_nirchan = ((DCELL *) inrast_nirchan)[col];
+ break;
+ if (greenchan) {
+ switch(data_type_greenchan){
+ case CELL_TYPE:
+ d_greenchan = (double) ((CELL *) inrast_greenchan)[col];
+ break;
+ case FCELL_TYPE:
+ d_greenchan = (double) ((FCELL *) inrast_greenchan)[col];
+ break;
+ case DCELL_TYPE:
+ d_greenchan = ((DCELL *) inrast_greenchan)[col];
+ break;
+ if (bluechan) {
+ switch(data_type_bluechan){
+ case CELL_TYPE:
+ d_bluechan = (double) ((CELL *) inrast_bluechan)[col];
+ break;
+ case FCELL_TYPE:
+ d_bluechan = (double) ((FCELL *) inrast_bluechan)[col];
+ break;
+ case DCELL_TYPE:
+ d_bluechan = ((DCELL *) inrast_bluechan)[col];
+ break;
+ if (chan5chan) {
+ switch(data_type_chan5chan){
+ case CELL_TYPE:
+ d_chan5chan = (double) ((CELL *) inrast_chan5chan)[col];
+ break;
+ case FCELL_TYPE:
+ d_chan5chan = (double) ((FCELL *) inrast_chan5chan)[col];
+ break;
+ case DCELL_TYPE:
+ d_chan5chan = ((DCELL *) inrast_chan5chan)[col];
+ break;
+ if (chan7chan) {
+ switch(data_type_chan7chan){
+ case CELL_TYPE:
+ d_chan7chan = (double) ((CELL *) inrast_chan7chan)[col];
+ break;
+ case FCELL_TYPE:
+ d_chan7chan = (double) ((FCELL *) inrast_chan7chan)[col];
+ break;
+ case DCELL_TYPE:
+ d_chan7chan = ((DCELL *) inrast_chan7chan)[col];
+ break;
- /* process the data */
+ /* process the data */
for (col = 0; col < ncols; col++)
d_redchan = inrast_redchan[col];
@@ -285,7 +359,7 @@
d_chan7chan = inrast_chan7chan[col];
if (Rast_is_d_null_value(&d_redchan) ||
- ((nirchan) && Rast_is_d_null_value(&d_nirchan)) ||
+ ((nirchan) && Rast_is_d_null_value(&d_nirchan)) ||
((greenchan) && Rast_is_d_null_value(&d_greenchan)) ||
((bluechan) && Rast_is_d_null_value(&d_bluechan)) ||
((chan5chan) && Rast_is_d_null_value(&d_chan5chan)) ||
@@ -293,11 +367,11 @@
Rast_set_d_null_value(&outrast[col], 1);
else {
- /* calculate simple_ratio */
+ /* calculate simple_ratio */
if (!strcmp(viflag, "sr"))
outrast[col] = s_r(d_redchan, d_nirchan);
- /* calculate ndvi */
+ /* calculate ndvi */
if (!strcmp(viflag, "ndvi")) {
if (d_redchan + d_nirchan < 0.001)
@@ -373,7 +447,7 @@
G_free(outrast);
Rast_close(outfd);
- /* Color from -1.0 to +1.0 in grey */
+ /* Color from -1.0 to +1.0 in grey */
Rast_init_colors(&colors);
val1 = -1;
val2 = 1;
@@ -381,7 +455,7 @@
Rast_short_history(result, "raster", &history);
Rast_command_history(&history);
Rast_write_history(result, &history);
exit(EXIT_SUCCESS);
