[GRASS-SVN] r48024 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Thu Sep 1 07:18:34 EDT 2011
Author: annakrat
Date: 2011-09-01 04:18:34 -0700 (Thu, 01 Sep 2011)
New Revision: 48024
grass/trunk/gui/wxpython/gui_modules/colorrules.py
wxGUI: vector color rules: use color tables in vcolr2/
Modified: grass/trunk/gui/wxpython/gui_modules/colorrules.py
--- grass/trunk/gui/wxpython/gui_modules/colorrules.py 2011-09-01 11:17:54 UTC (rev 48023)
+++ grass/trunk/gui/wxpython/gui_modules/colorrules.py 2011-09-01 11:18:34 UTC (rev 48024)
@@ -1160,20 +1160,16 @@
self.DisableClearAll()
return
- if self.inmap and not self.CheckMapset():
- # currently v.colors need the map to be in current mapset
- if self.version7 and self.attributeType == 'color':
+ if not self.CheckMapset():
+ # v.colors doesn't need the map to be in current mapset
+ if not (self.version7 and self.attributeType == 'color'):
message = _("Selected map <%s> is not in current mapset <%s>. "
- "Color rules cannot be edited.") % \
- (self.inmap, grass.gisenv()['MAPSET'])
- else:
- message = _("Selected map <%s> is not in current mapset <%s>. "
"Attribute table cannot be edited.") % \
- wx.CallAfter(gcmd.GMessage, parent = self, message = message)
- self.DisableClearAll()
- return
+ wx.CallAfter(gcmd.GMessage, parent = self, message = message)
+ self.DisableClearAll()
+ return
# check for db connection
self.dbInfo = gselect.VectorDBInfo(self.inmap)
enable = True
@@ -1209,6 +1205,7 @@
self.useColumn.SetValue(False)
self.OnCheckColumn(event = None)
+ self.useColumn.Enable(self.CheckMapset())
self.LoadTable()
@@ -1221,6 +1218,8 @@
need to be deleted when closing dialog and unloading map
@param type type of column (e.g. vachar(11))"""
+ return
# because more than one dialog with the same map can be opened we must test column name and
# create another one
while self.properties['tmpColumn'] in self.dbInfo.GetTableDesc(self.properties['table']).keys():
@@ -1241,6 +1240,9 @@
def DeleteTemporaryColumn(self):
"""!Delete temporary column"""
+ return
if self.inmap:
if self.version7:
modul = 'v.db.dropcolumn'
@@ -1481,11 +1483,21 @@
'map=%s' % self.inmap]
# find existing color table and copy to temp file
+ try:
+ name, mapset = self.inmap.split('@')
+ except ValueError:
+ name = self.inmap
+ mapset = grass.find_file(self.inmap, element = 'cell')['mapset']
+ if not mapset:
+ return
old_colrtable = None
- path = grass.find_file(name = self.inmap, element = 'vector')['file']
- if os.path.exists(os.path.join(path, 'colr')):
- old_colrtable = os.path.join(path, 'colr')
+ if mapset == grass.gisenv()['MAPSET']:
+ old_colrtable = grass.find_file(name = 'colr', element = os.path.join('vector', name))['file']
+ else:
+ old_colrtable = grass.find_file(name = name, element = os.path.join('vcolr2', mapset))['file']
+ if old_colrtable:
colrtemp = utils.GetTempfile()
shutil.copyfile(old_colrtable, colrtemp)
