[GRASS-SVN] r48026 - grass/trunk/vector/v.edit
svn_grass at osgeo.org
Thu Sep 1 07:53:25 EDT 2011
Author: martinl
Date: 2011-09-01 04:53:25 -0700 (Thu, 01 Sep 2011)
New Revision: 48026
grass/trunk/vector/v.edit/main.c
v.edit: fix segfault when no input is defined
Modified: grass/trunk/vector/v.edit/main.c
--- grass/trunk/vector/v.edit/main.c 2011-09-01 11:39:52 UTC (rev 48025)
+++ grass/trunk/vector/v.edit/main.c 2011-09-01 11:53:25 UTC (rev 48026)
@@ -69,18 +69,18 @@
/* open input file */
- if (strcmp(params.in->answer, "-") == 0 ||
- (action_mode != MODE_CREATE && params.in->answer == NULL)) {
- ascii = stdin;
- else if (params.in->answer) {
+ if (params.in->answer &&
+ strcmp(params.in->answer, "-") != 0) {
ascii = fopen(params.in->answer, "r");
if (ascii == NULL) {
- G_fatal_error(_("Unable to open ASCII file <%s>"),
+ G_fatal_error(_("Unable to open file <%s>"),
params.in->answer);
+ else if (action_mode != MODE_CREATE) {
+ ascii = stdin;
if (action_mode == MODE_CREATE) {
int overwrite;
