[GRASS-SVN] r48056 - grass/branches/releasebranch_6_4/gui/wxpython/gui_modules
Thu Sep 1 16:20:43 EDT 2011
Author: martinl
Date: 2011-09-01 13:20:43 -0700 (Thu, 01 Sep 2011)
New Revision: 48056
   grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/mapdisp_vdigit.py
   grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/vdigit.py
   grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/wxvdigit.py
wxGUI/vdigit: fix 'update categories', implement SetLineCats()
             (merge r48054 from trunk)
Modified: grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/mapdisp_vdigit.py
--- grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/mapdisp_vdigit.py	2011-09-01 20:18:38 UTC (rev 48055)
+++ grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/mapdisp_vdigit.py	2011-09-01 20:20:43 UTC (rev 48056)
@@ -363,7 +363,7 @@
             if self.parent.dialogs['category'] is None:
                 # open new dialog
                 dlg = VDigitCategoryDialog(parent = self,
-                                           map = mapLayer,
+                                           vectorName = mapLayer,
                                            cats = cats,
                                            pos = posWindow,
                                            title = _("Update categories"))
Modified: grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/vdigit.py
--- grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/vdigit.py	2011-09-01 20:18:38 UTC (rev 48055)
+++ grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/vdigit.py	2011-09-01 20:20:43 UTC (rev 48056)
@@ -816,25 +816,22 @@
 class VDigitCategoryDialog(wx.Dialog, listmix.ColumnSorterMixin):
     def __init__(self, parent, title,
-                 map, query = None, cats = None,
-                 pos = wx.DefaultPosition,
-                 style = wx.DEFAULT_DIALOG_STYLE | wx.RESIZE_BORDER):
+                 vectorName, query = None, cats = None,
+                 style = wx.DEFAULT_DIALOG_STYLE | wx.RESIZE_BORDER, **kwargs):
         """!Dialog used to display/modify categories of vector objects
         @param parent
         @param title dialog title
         @param query {coordinates, qdist} - used by v.edit/v.what
         @param cats  directory of lines (layer/categories) - used by vdigit
-        @param pos
-        @param style
+        @param style dialog style
-        # parent
-        self.parent = parent # mapdisplay.BufferedWindow class instance
+        self.parent = parent       # mapdisplay.BufferedWindow class instance
         self.digit = parent.digit
         # map name
-        self.map = map
+        self.vectorName = vectorName
         # line : {layer: [categories]}
         self.cats = {}
@@ -856,7 +853,7 @@
         self.cats_orig = copy.deepcopy(self.cats)
         wx.Dialog.__init__(self, parent = self.parent, id = wx.ID_ANY, title = title,
-                          style = style, pos = pos)
+                           style = style, **kwargs)
         # list of categories
         box = wx.StaticBox(parent = self, id = wx.ID_ANY,
@@ -1122,7 +1119,7 @@
         ret = gcmd.RunCommand('v.what',
                               parent = self,
                               quiet = True,
-                              map = self.map,
+                              map = self.vectorName,
                               east_north = '%f,%f' % \
                                   (float(coords[0]), float(coords[1])),
                               distance = qdist)
@@ -1172,7 +1169,7 @@
         for fid in self.cats.keys():
             newfid = self.ApplyChanges(fid)
-            if fid == self.fid:
+            if fid == self.fid and newfid > 0:
                 self.fid = newfid
     def ApplyChanges(self, fid):
@@ -1240,28 +1237,26 @@
             if layer <= 0:
                 raise ValueError
         except ValueError:
-            dlg = wx.MessageDialog(self, _("Unable to add new layer/category <%(layer)s/%(category)s>.\n"
-                                           "Layer and category number must be integer.\n"
-                                           "Layer number must be greater then zero.") %
-                                   {'layer' : str(self.layerNew.GetValue()),
-                                    'category' : str(self.catNew.GetValue())},
-                                   _("Error"), wx.OK | wx.ICON_ERROR)
-            dlg.ShowModal()
-            dlg.Destroy()
+            gcmd.GError(parent = self,
+                        message = _("Unable to add new layer/category <%(layer)s/%(category)s>.\n"
+                                    "Layer and category number must be integer.\n"
+                                    "Layer number must be greater then zero.") %
+                        {'layer' : str(self.layerNew.GetValue()),
+                         'category' : str(self.catNew.GetValue())})
             return False
         if layer not in self.cats[self.fid].keys():
             self.cats[self.fid][layer] = []
         self.cats[self.fid][layer].append(cat)
         # reload list
         self.itemDataMap = self.list.Populate(self.cats[self.fid],
                                               update = True)
         # update category number for add
         self.catNew.SetValue(cat + 1)
         event.Skip()
         return True
Modified: grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/wxvdigit.py
--- grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/wxvdigit.py	2011-09-01 20:18:38 UTC (rev 48055)
+++ grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/wxvdigit.py	2011-09-01 20:20:43 UTC (rev 48056)
@@ -1102,7 +1102,7 @@
         return perimeter
-    def SetLineCats(self, line, layer, cats, add=True):
+    def SetLineCats(self, line, layer, cats, add = True):
         """!Set categories for given line and layer
         @param line feature id
@@ -1113,13 +1113,46 @@
         @return new feature id (feature need to be rewritten)
         @return -1 on error
-        ret = self.digit.SetLineCats(line, layer, cats, add)
-        if ret > 0:
+        if not self._checkMap():
+            return -1
+        if line < 1 and len(self._display.selected['ids']) < 1:
+            return -1
+        update = False
+        if line == -1:
+            update = True
+            line = self._display.selected['ids'][0]
+        if not Vect_line_alive(self.poMapInfo, line):
+            return -1
+        ltype = Vect_read_line(self.poMapInfo, self.poPoints, self.poCats, line)
+        if ltype < 0:
+            self._error.ReadLine(line)
+            return -1
+        for c in cats:
+            if add:
+                Vect_cat_set(self.poCats, layer, c)
+            else:
+                Vect_field_cat_del(self.poCats, layer, c)
+        nlines = Vect_get_num_lines(self.poMapInfo)
+        changeset = self._addActionsBefore()
+        newline = Vect_rewrite_line(self.poMapInfo, line, ltype,
+                                    self.poPoints, self.poCats)
+        if newline > 0:
+            self._addActionsAfter(changeset, nlines)
             self.toolbar.EnableUndo()
+        if update:
+            # update line id since the line was rewritten
+            self._display.selected['ids'][0] =  newline
+        return newline
-        return ret
     def TypeConvForSelectedLines(self):
         """!Feature type conversion for selected objects.
