[GRASS-SVN] r48059 - grass-addons/vector/v.rast.stats2
svn_grass at osgeo.org
Fri Sep 2 05:11:23 EDT 2011
Author: mmetz
Date: 2011-09-02 02:11:23 -0700 (Fri, 02 Sep 2011)
New Revision: 48059
grass-addons/vector/v.rast.stats2/v.rast.stats2
update grass-addon v.rast.stats2
Modified: grass-addons/vector/v.rast.stats2/v.rast.stats2
--- grass-addons/vector/v.rast.stats2/v.rast.stats2 2011-09-02 09:02:58 UTC (rev 48058)
+++ grass-addons/vector/v.rast.stats2/v.rast.stats2 2011-09-02 09:11:23 UTC (rev 48059)
@@ -12,7 +12,6 @@
# License (>=v2). Read the file COPYING that comes with GRASS
# for details.
-# TODO: do we need layer= management?
#%Module
@@ -47,7 +46,6 @@
#% key: keycol
#% type: string
#% description: Key column of attribute table used to join statistics
-#% answer: cat
#% required : no
#%end
#%option
@@ -111,32 +109,32 @@
fi
#### setup temporary file
-TMP="`g.tempfile pid=$$`"
-if [ $? -ne 0 ] || [ -z "$TMP" ] ; then
+TEMPFILE="`g.tempfile pid=$$`"
+if [ $? -ne 0 ] || [ -z "$TEMPFILE" ] ; then
g.message -e "Unable to create temporary files"
exit 1
fi
### variables for temp files
-SQLTMP="$TMP.sql"
-STATSTMP="$TMP.csv"
-COLNAMETMP="$TMP.col"
+SQLTMP="$TEMPFILE.sql"
+STATSTMP="$TEMPFILE.csv"
+COLNAMETMP="$TEMPFILE.col"
-### we need a random name
-TMPNAME=`basename "$TMP"`
+# we need a random name
+TMPNAME=`basename "$TEMPFILE"`
cleanup()
# restore settings:
g.region region="$TMPNAME"
g.remove region="$TMPNAME" --quiet
- g.remove rast="${VECTOR}_${TMPNAME}" --quiet
+ g.remove rast="${VECTOR}_$TMPNAME" --quiet
g.remove MASK --quiet 2>/dev/null
if [ $MASKFOUND -eq 1 ] ; then
g.message "Restoring previous MASK..."
g.rename "${TMPNAME}_origmask",MASK --quiet
fi
- rm -f "$TMP" "$TMPNAME" "$TMP.cats" "$SQLTMP"
+ rm -f "$TEMPFILE" "$TMPNAME" "$TEMPFILE.cats" "$SQLTMP"
# what to do in case of user break:
@@ -151,7 +149,6 @@
RASTER="$GIS_OPT_RASTER"
COLPREFIX="$GIS_OPT_COLPREFIX"
-KEYCOL="$GIS_OPT_KEYCOL"
### setup enviro vars ###
eval `g.gisenv`
@@ -200,13 +197,11 @@
# save current settings:
g.region save="$TMPNAME" --quiet
-# temporarily setting raster resolution to $RASTER resolution
-# keep boundary settings
-g.region nsres=$NSRES ewres=$EWRES -a
+# temporarily aligning current region to raster <$RASTER>
+g.region align="$RASTER"
-# create raster from vector map for r.univar.zonal
-v.to.rast in="$VECTORFULL" out="${VECTOR}_${TMPNAME}" use=attr \
-col="$KEYCOL" type=area --quiet
+# create raster from vector map for r.univar
+v.to.rast in="$VECTORFULL" out="${VECTOR}_$TMPNAME" layer="$GIS_OPT_LAYER" use=cat type=area --quiet
if [ $? -ne 0 ] ; then
g.message -e "An error occurred while converting vector to raster"
cleanup
@@ -214,9 +209,9 @@
fi
# dump cats to file to avoid "too many argument" problem:
-r.category "${VECTOR}_${TMPNAME}" fs=';' --quiet | cut -d';' -f1 > "$TMP.cats"
+r.category "${VECTOR}_$TMPNAME" fs=';' --quiet | cut -d';' -f1 > "$TEMPFILE.cats"
# echo "List of categories found: $CATSLIST"
-NUMBER=`cat "$TMP.cats" | wc -l | awk '{print $1}'`
+NUMBER=`cat "$TEMPFILE.cats" | wc -l | awk '{print $1}'`
if [ $NUMBER -lt 1 ] ; then
g.message -e "No categories found in raster map"
cleanup
@@ -225,30 +220,52 @@
# check if DBF driver used, in this case cut to 10 chars col names:
DBFDRIVER=0
-v.db.connect -g "$VECTORFULL" fs=";" | grep -w "$GIS_OPT_LAYER" | cut -d';' -f5 | grep -i dbf --quiet
+v.db.connect -gl map="$VECTOR" fs="|" layer="$GIS_OPT_LAYER" | \
+ cut -d'|' -f5 | grep -i 'dbf' --quiet
if [ $? -eq 0 ] ; then
DBFDRIVER=1
else
# in case a table is missing, we'll trap a crash later...
DBFDRIVER=0
fi
+if [ $DBFDRIVER -eq 1 ] ; then
+ # `wc -c` reports number of chars + 1 for the newline
+ if [ `echo "$COLPREFIX" | wc -c` -gt 10 ] ; then
+ g.message -e "Cannot create unique names for columns. \
+ Either use a shorter column prefix or switch to another DB \
+ backend such as SQLite. DBF limits the length to 10 characters"
+ cleanup
+ exit 1
+ fi
+fi
# we need this for non-DBF driver:
-DB_SQLDRIVER=`v.db.connect -g "$VECTORFULL" fs=";" | grep -w "$GIS_OPT_LAYER" | cut -d';' -f5`
-DB_DATABASE="`v.db.connect -g "$VECTORFULL" fs=";" | grep -w "$GIS_OPT_LAYER" | cut -d';' -f4`"
+DB_SQLDRIVER=`v.db.connect -gl map="$VECTOR" fs="|" layer="$GIS_OPT_LAYER" | cut -d'|' -f5`
+g.message -d message="sql driver: [$DB_SQLDRIVER]"
+DB_DATABASE="`v.db.connect -gl map=$VECTOR fs='|' layer=$GIS_OPT_LAYER | cut -d'|' -f4`"
+g.message -d message="database: [$DB_DATABASE]"
# find out which table is linked to the vector map on the given layer
-TABLE=`v.db.connect map="$VECTORFULL" -g fs=";" | grep -w "$GIS_OPT_LAYER" | awk -F ";" '{print $2}'`
+TABLE=`v.db.connect map="$VECTOR" -gl fs='|' layer="$GIS_OPT_LAYER" | cut -d'|' -f2`
if [ -z "$TABLE" ] ; then
g.message -e 'There is no table connected to this map! Run v.db.connect or v.db.addtable first.'
exit 1
fi
+g.message -d message="table: [$TABLE]"
+# get key column
+if [ -z "$GIS_OPT_KEYCOL" ] ; then
+ KEYCOL=`v.db.connect map="$VECTOR" -gl fs='|' layer="$GIS_OPT_LAYER" | cut -d'|' -f3`
+fi
BASECOLS="n min max range mean stddev variance cf_var sum"
# do extended stats?
if [ $GIS_FLAG_E -eq 1 ] ; then
# namespace is limited in DBF but the % value is important
- if [ $DBFDRIVER -eq 1 ] ; then
+ if [ "$DBFDRIVER" -eq 1 ] ; then
PERCCOL="per$GIS_OPT_PERCENTILE"
else
PERCCOL="percentile_$GIS_OPT_PERCENTILE"
@@ -263,21 +280,22 @@
for i in $BASECOLS $EXTRACOLS ; do
# check if column already present
- CURRCOLUMN="`echo "${COLPREFIX}_${i}" | cut -b1-10`"
+ CURRCOLUMN="`echo "${COLPREFIX}_$i" | cut -b1-10`"
else
- CURRCOLUMN="${COLPREFIX}_${i}"
+ CURRCOLUMN="${COLPREFIX}_$i"
fi
if [ -n "$COLNAMES" ] ; then
COLNAMES="${COLNAMES},$CURRCOLUMN"
else
COLNAMES="$CURRCOLUMN"
fi
- v.info -c $VECTORFULL layer="$GIS_OPT_LAYER" --quiet | sed 's+^+|+g' | sed 's+$+|+g' | \
+ g.message -d message="Looking for <$CURRCOLUMN> in <$VECTOR> ..."
+ v.info -c "$VECTORFULL" layer="$GIS_OPT_LAYER" --quiet | sed -e 's+^+|+' -e 's+$+|+' | \
grep "|$CURRCOLUMN|" --quiet
- if [ $GIS_FLAG_C -ne 1 ] ; then
- g.message -w "Cannot create column <$CURRCOLUMN> (already present)."
- g.message -e "Use -c flag to update values in this column."
+ if [ "$GIS_FLAG_C" -ne 1 ] ; then
+ g.message -e "Cannot create column <$CURRCOLUMN> (already present). \
+ Use -c flag to update values in this column."
cleanup
exit 1
fi
@@ -330,10 +348,10 @@
unset $BASECOLS $EXTRACOLS
$univar_cmd -t -e map="$RASTER" \
- zones="${VECTOR}_${TMPNAME}" percentile="$GIS_OPT_PERCENTILE" | \
+ zones="${VECTOR}_$TMPNAME" percentile="$GIS_OPT_PERCENTILE" | \
cut -f1,3,5-8,10-13,15-18 -d'|' | sed 's+nan+NULL+g' > "$STATSTMP"
else
- $univar_cmd -t map="$RASTER" zones="${VECTOR}_${TMPNAME}" | \
+ $univar_cmd -t map="$RASTER" zones="${VECTOR}_$TMPNAME" | \
cut -f1,3,5-8,10-13 -d'|' | sed 's+nan+NULL+g' > "$STATSTMP"
fi
@@ -366,7 +384,7 @@
sed -e '1d' "$STATSTMP" | awk -F "|" '{printf "\nUPDATE '${TABLE}' SET '${col1}' = %i , '${col2}' = %.2f , '${col3}' = %.2f , '${col4}' = %.2f , '${col5}' = %.2f , '${col6}' = %.2f , '${col7}' = %.2f , '${col8}' = %.2f , '${col9}' = %.2f WHERE '${KEYCOL}' = %i;", $2,$3,$4,$5,$6,$7,$8,$9,$10,$1}' > "$SQLTMP"
fi
-g.message -v "Updating the database ..."
+g.message message="Updating the database ..."
db.execute input="$SQLTMP" database="${DB_DATABASE}" driver="$DB_SQLDRIVER"
EXITCODE=$?
