[GRASS-SVN] r48076 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Fri Sep 2 16:02:36 EDT 2011
Author: martinl
Date: 2011-09-02 13:02:36 -0700 (Fri, 02 Sep 2011)
New Revision: 48076
grass/trunk/gui/wxpython/gui_modules/mapdisp_vdigit.py
grass/trunk/gui/wxpython/gui_modules/toolbars.py
grass/trunk/gui/wxpython/gui_modules/wxvdigit.py
wxGUI/vdigit: implement missing 'copy attributes'
Modified: grass/trunk/gui/wxpython/gui_modules/mapdisp_vdigit.py
--- grass/trunk/gui/wxpython/gui_modules/mapdisp_vdigit.py 2011-09-02 15:57:39 UTC (rev 48075)
+++ grass/trunk/gui/wxpython/gui_modules/mapdisp_vdigit.py 2011-09-02 20:02:36 UTC (rev 48076)
@@ -928,20 +928,19 @@
return
self._geomAttrbUpdate([fid,])
elif action in ("copyCats", "copyAttrs"):
- try:
- if action == 'copyCats':
- if self.digit.CopyCats(self.copyCatsList,
- self.copyCatsIds, copyAttrb = False) < 0:
- return
- else:
- self.copyCatsIds, copyAttrb = True) < 0:
- return
+ print self.copyCatsList
+ print self.copyCatsIds
+ if action == 'copyCats':
+ if self.digit.CopyCats(self.copyCatsList,
+ self.copyCatsIds, copyAttrb = False) < 0:
+ return
+ else:
+ self.copyCatsIds, copyAttrb = True) < 0:
+ return
- del self.copyCatsList
- del self.copyCatsIds
- except AttributeError:
- pass
+ del self.copyCatsList
+ del self.copyCatsIds
self._updateATM()
Modified: grass/trunk/gui/wxpython/gui_modules/toolbars.py
--- grass/trunk/gui/wxpython/gui_modules/toolbars.py 2011-09-02 15:57:39 UTC (rev 48075)
+++ grass/trunk/gui/wxpython/gui_modules/toolbars.py 2011-09-02 20:02:36 UTC (rev 48076)
@@ -786,7 +786,7 @@
wx.ITEM_CHECK, self.OnCopyCats, "copyCats"),
(_('Copy features from (background) vector map'),
wx.ITEM_CHECK, self.OnCopy, "copyLine"),
- (_('Duplicate attributes'),
+ (_('Copy attributes'),
wx.ITEM_CHECK, self.OnCopyAttrb, "copyAttrs"),
(_('Feature type conversion'),
wx.ITEM_CHECK, self.OnTypeConversion, "typeConv"),
Modified: grass/trunk/gui/wxpython/gui_modules/wxvdigit.py
--- grass/trunk/gui/wxpython/gui_modules/wxvdigit.py 2011-09-02 15:57:39 UTC (rev 48075)
+++ grass/trunk/gui/wxpython/gui_modules/wxvdigit.py 2011-09-02 20:02:36 UTC (rev 48076)
@@ -929,7 +929,7 @@
return ret
- def CopyCats(self, fromId, toId, copyAttrb=False):
+ def CopyCats(self, fromId, toId, copyAttrb = False):
"""!Copy given categories to objects with id listed in ids
@param cats ids of 'from' feature
@@ -938,16 +938,131 @@
@return number of modified features
@return -1 on error
- if len(fromId) == 0 or len(toId) == 0:
+ if len(fromId) < 1 or len(toId) < 1:
return 0
- ret = self.digit.CopyCats(fromId, toId, copyAttrb)
- if ret > 0:
+ poCatsFrom = self.poCats
+ poCatsTo = Vect_new_cats_struct();
+ nlines = 0
+ for fline in fromId:
+ if not Vect_line_alive(self.poMapInfo, fline):
+ continue
+ if Vect_read_line(self.poMapInfo, None, poCatsFrom, fline) < 0:
+ self._error.ReadLine(fline)
+ return -1
+ for tline in toId:
+ if not Vect_line_alive(self.poMapInfo, tline):
+ continue
+ ltype = Vect_read_line(self.poMapInfo, self.poPoints, poCatsTo, tline)
+ if ltype < 0:
+ return -1
+ catsFrom = poCatsFrom.contents
+ for i in range(catsFrom.n_cats):
+ if not copyAttrb:
+ # duplicate category
+ cat = catsFrom.cat[i]
+ else:
+ # duplicate attributes
+ cat = self.cats[catsFrom.field[i]] + 1
+ self.cats[catsFrom.field[i]] = cat
+ poFi = Vect_get_field(self.poMapInfo, catsFrom.field[i])
+ if not poFi:
+ self._error.DbLink(i)
+ return -1
+ fi = poFi.contents
+ driver = db_start_driver(fi.driver)
+ if not driver:
+ self._error.Driver(fi.driver)
+ return -1
+ handle = dbHandle()
+ db_init_handle(byref(handle))
+ db_set_handle(byref(handle), fi.database, None)
+ if db_open_database(driver, byref(handle)) != DB_OK:
+ db_shutdown_driver(driver)
+ self._error.Database(fi.driver, fi.database)
+ return -1
+ stmt = dbString()
+ db_init_string(byref(stmt))
+ db_set_string(byref(stmt),
+ "SELECT * FROM %s WHERE %s=%d" % (fi.table, fi.key,
+ catsFrom.cat[i]))
+ cursor = dbCursor()
+ if db_open_select_cursor(driver, byref(stmt), byref(cursor),
+ DB_SEQUENTIAL) != DB_OK:
+ db_close_database_shutdown_driver(driver)
+ return -1
+ table = db_get_cursor_table(byref(cursor))
+ ncols = db_get_table_number_of_columns(table)
+ sql = "INSERT INTO %s VALUES (" % fi.table
+ # fetch the data
+ more = c_int()
+ while True:
+ if db_fetch(byref(cursor), DB_NEXT, byref(more)) != DB_OK:
+ return -1
+ if not more.value:
+ break
+ value_string = dbString()
+ for col in range(ncols):
+ if col > 0:
+ sql += ","
+ column = db_get_table_column(table, col)
+ if db_get_column_name(column) == fi.key:
+ sql += "%d" % cat
+ continue
+ value = db_get_column_value(column)
+ db_convert_column_value_to_string(column, byref(value_string))
+ if db_test_value_isnull(value):
+ sql += "NULL"
+ else:
+ ctype = db_sqltype_to_Ctype(db_get_column_sqltype(column))
+ if ctype != DB_C_TYPE_STRING:
+ sql += db_get_string(byref(value_string))
+ else:
+ sql += "'%s'" % db_get_string(byref(value_string))
+ sql += ")"
+ db_set_string(byref(stmt), sql)
+ print db_get_string(byref(stmt))
+ if db_execute_immediate(driver, byref(stmt)) != DB_OK:
+ return -1
+ G_free(poFi)
+ if Vect_cat_set(poCatsTo, catsFrom.field[i], cat) < 1:
+ continue
+ if Vect_rewrite_line(self.poMapInfo, tline, ltype, self.poPoints, poCatsTo) < 0:
+ self._error.WriteLine()
+ return -1
+ nlines +=1
+ Vect_destroy_cats_struct(poCatsTo)
+ if nlines > 0:
self.toolbar.EnableUndo()
+ return nlines
- return ret
def _selectLinesByQueryThresh(self):
"""!Generic method used for SelectLinesByQuery() -- to get
threshold value"""
@@ -1460,7 +1575,7 @@
if Vect_get_point_in_area(self.poMapInfo, left, byref(x), byref(y)) == 0:
Vect_reset_line(bpoints)
Vect_append_point(bpoints, x.value, y.value, 0.0)
- newline = Vect_write_line(byref(self.poMapInfo), GV_CENTROID,
+ newline = Vect_write_line(self.poMapInfo, GV_CENTROID,
bpoints, self.poCats)
if newline < 0:
