[GRASS-SVN] r48083 -
grass/branches/releasebranch_6_4/gui/wxpython/gui_modules
svn_grass at osgeo.org
Sat Sep 3 03:07:49 EDT 2011
Author: martinl
Date: 2011-09-03 00:07:49 -0700 (Sat, 03 Sep 2011)
New Revision: 48083
grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/dbm.py
grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/dbm_dialogs.py
wxGUI: fix dbm_dialogs.ModifyTableRecord
(merge r48081 from trunk)
Modified: grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/dbm.py
--- grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/dbm.py 2011-09-03 07:04:38 UTC (rev 48082)
+++ grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/dbm.py 2011-09-03 07:07:49 UTC (rev 48083)
@@ -1356,9 +1356,9 @@
data.append((col, ''))
colIdx += 1
- dlg = ModifyTableRecord(parent=self, id=wx.ID_ANY,
- title=_("Insert new record"),
- data=data, keyEditable=(keyId, True))
+ dlg = ModifyTableRecord(parent = self,
+ title = _("Insert new record"),
+ data = data, keyEditable = (keyId, True))
if dlg.ShowModal() == wx.ID_OK:
try: # get category number
@@ -1471,9 +1471,9 @@
value = list.GetItem(item, i).GetText()
data.append((columnName[i], value))
- title=_("Update existing record"),
- data=data, keyEditable=(keyId, False))
+ title = _("Update existing record"),
+ data = data, keyEditable = (keyId, False))
values = dlg.GetValues() # string
Modified: grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/dbm_dialogs.py
--- grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/dbm_dialogs.py 2011-09-03 07:04:38 UTC (rev 48082)
+++ grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/dbm_dialogs.py 2011-09-03 07:07:49 UTC (rev 48083)
@@ -528,14 +528,13 @@
break
class ModifyTableRecord(wx.Dialog):
- def __init__(self, parent, id, title, data, keyEditable = (-1, True),
- style = wx.DEFAULT_DIALOG_STYLE | wx.RESIZE_BORDER):
+ def __init__(self, parent, title, data, keyEditable = (-1, True),
+ id = wx.ID_ANY, style = wx.DEFAULT_DIALOG_STYLE | wx.RESIZE_BORDER):
"""!Dialog for inserting/updating table record
- Notes:
- 'Data' is a list: [(column, value)]
- 'KeyEditable' (id, editable?) indicates if textarea for key column
- is editable(True) or not.
+ @param data a list: [(column, value)]
+ @param KeyEditable (id, editable?) indicates if textarea for key column
+ is editable(True) or not
# parent -> VDigitWindow
wx.Dialog.__init__(self, parent, id, title, style = style)
@@ -545,35 +544,32 @@
self.keyId = keyEditable[0]
self.panel = wx.Panel(parent = self, id = wx.ID_ANY)
- box = wx.StaticBox(parent = self.panel, id = wx.ID_ANY, label = '')
+ box = wx.StaticBox(parent = self.panel, id = wx.ID_ANY)
+ box.Hide()
self.dataPanel = scrolled.ScrolledPanel(parent = self.panel, id = wx.ID_ANY,
- style = wx.TAB_TRAVERSAL)
+ style = wx.TAB_TRAVERSAL)
self.dataPanel.SetupScrolling(scroll_x = False)
# buttons
self.btnCancel = wx.Button(self.panel, wx.ID_CANCEL)
self.btnSubmit = wx.Button(self.panel, wx.ID_OK, _("&Submit"))
self.btnSubmit.SetDefault()
# data area
self.widgets = []
- id = 0
+ cId = 0
self.usebox = False
self.cat = None
for column, value in data:
- if keyEditable[0] == id:
+ if self.keyId == cId:
self.cat = int(value)
- if keyEditable[1] == False:
+ if not keyEditable[1]:
self.usebox = True
- box.SetLabel =" %s %d " % (_("Category"), self.cat)
+ box.SetLabel(" %s %d " % (_("Category"), self.cat))
+ box.Show()
self.boxSizer = wx.StaticBoxSizer(box, wx.VERTICAL)
- id += 1
+ cId += 1
continue
else:
valueWin = wx.SpinCtrl(parent = self.dataPanel, id = wx.ID_ANY,
@@ -581,38 +577,37 @@
else:
valueWin = wx.TextCtrl(parent = self.dataPanel, id = wx.ID_ANY,
value = value, size = (250, -1))
label = wx.StaticText(parent = self.dataPanel, id = wx.ID_ANY,
label = column + ":")
- self.widgets.append((label.GetId(),
- valueWin.GetId()))
- id += 1
- self.__Layout()
+ self.widgets.append((label.GetId(), valueWin.GetId()))
+ cId += 1
- def __Layout(self):
+ self._layout()
+ def _layout(self):
"""!Do layout"""
sizer = wx.BoxSizer(wx.VERTICAL)
# data area
dataSizer = wx.FlexGridSizer (cols = 2, hgap = 3, vgap = 3)
dataSizer.AddGrowableCol(1)
for labelId, valueId in self.widgets:
label = self.FindWindowById(labelId)
value = self.FindWindowById(valueId)
dataSizer.Add(label, proportion = 0,
flag = wx.ALIGN_CENTER_VERTICAL)
dataSizer.Add(value, proportion = 0,
flag = wx.EXPAND | wx.ALIGN_CENTER_VERTICAL)
self.dataPanel.SetAutoLayout(True)
self.dataPanel.SetSizer(dataSizer)
dataSizer.Fit(self.dataPanel)
if self.usebox:
self.boxSizer.Add(item = self.dataPanel, proportion = 1,
flag = wx.EXPAND | wx.ALL, border = 5)
@@ -622,32 +617,31 @@
btnSizer.AddButton(self.btnCancel)
btnSizer.AddButton(self.btnSubmit)
btnSizer.Realize()
if not self.usebox:
sizer.Add(item = self.dataPanel, proportion = 1,
else:
sizer.Add(item = self.boxSizer, proportion = 1,
sizer.Add(item = btnSizer, proportion = 0,
- flag = wx.EXPAND | wx.ALL, border = 5)
+ flag = wx.EXPAND | wx.ALL, border = 5)
framewidth = self.GetSize()[0]
self.SetMinSize((framewidth,150))
self.SetMaxSize((framewidth,300))
- #sizer.SetSizeHints(self.panel)
+ # sizer.SetSizeHints(self.panel)
self.panel.SetAutoLayout(True)
self.panel.SetSizer(sizer)
sizer.Fit(self.panel)
self.Layout()
def GetValues(self, columns = None):
"""!Return list of values (casted to string).
If columns is given (list), return only values of given columns.
valueList = []
@@ -656,7 +650,7 @@
if columns is None or column in columns:
value = str(self.FindWindowById(valueId).GetValue())
valueList.append(value)
# add key value
if self.usebox:
valueList.insert(self.keyId, str(self.cat))
