[GRASS-SVN] r48086 - grass/trunk/scripts/db.out.ogr
svn_grass at osgeo.org
Sat Sep 3 06:28:21 EDT 2011
Author: neteler
Date: 2011-09-03 03:28:20 -0700 (Sat, 03 Sep 2011)
New Revision: 48086
grass/trunk/scripts/db.out.ogr/db.out.ogr.py
fixes; still broken
Modified: grass/trunk/scripts/db.out.ogr/db.out.ogr.py
--- grass/trunk/scripts/db.out.ogr/db.out.ogr.py 2011-09-03 08:49:57 UTC (rev 48085)
+++ grass/trunk/scripts/db.out.ogr/db.out.ogr.py 2011-09-03 10:28:20 UTC (rev 48086)
@@ -59,7 +59,7 @@
input = options['input']
format = options['format']
dsn = options['dsn']
- table = options['db_table']
+ table = options['table']
if format.lower() == 'dbf':
format = "ESRI_Shapefile"
@@ -83,11 +83,11 @@
if dsn.endswith('.dbf'):
outname = grass.basename(dsn, 'dbf')
for ext in exts:
- try_remove("%s.%s" % (outname, ext))
+ grass.try_remove("%s.%s" % (outname, ext))
outname += '.dbf'
else:
for ext in exts:
- try_remove(os.path.join(dsn, "%s.%s" % (input, ext)))
+ grass.try_remove(os.path.join(dsn, "%s.%s" % (input, ext)))
outname = os.path.join(dsn, input + ".dbf")
elif format.lower() == 'csv':
outname = dsn + '.csv'
