[GRASS-SVN] r48102 - grass/trunk/scripts/v.out.gps
Sun Sep 4 05:43:15 EDT 2011
Author: neteler
Date: 2011-09-04 02:43:15 -0700 (Sun, 04 Sep 2011)
New Revision: 48102
   grass/trunk/scripts/v.out.gps/v.out.gps.html
   grass/trunk/scripts/v.out.gps/v.out.gps.py
fix parameter; HTML update
Modified: grass/trunk/scripts/v.out.gps/v.out.gps.html
--- grass/trunk/scripts/v.out.gps/v.out.gps.html	2011-09-04 08:03:54 UTC (rev 48101)
+++ grass/trunk/scripts/v.out.gps/v.out.gps.html	2011-09-04 09:43:15 UTC (rev 48102)
@@ -1,18 +1,18 @@
-<H2>DESCRIPTION</H2>
+<h2>DESCRIPTION</h2>
-<EM>v.out.gps</EM> allows the user to export waypoint, route, and track
+<em>v.out.gps</em> allows the user to export waypoint, route, and track
 data from a vector map into a locally connected GPS receiver or as a file in
 many common GPS data formats. Translation is done via the
-<EM><A HREF="http://www.gpsbabel.org">GpsBabel</a></EM> program.
+<em><a href="http://www.gpsbabel.org">GPSBabel</a></em> program.
-<P>
+<p>
 Do not use as a primary means of navigation.
 This program is distributed in the hope that it will be useful,
 but WITHOUT ANY WARRANTY; without even the implied warranty of
 MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
 GNU General Public License (GPL) for more details.
-<H2>NOTES</H2>
+<h2>NOTES</h2>
 <em>v.out.gps</em> automatically reprojects data from the
 projection settings of the current location to Lat/Lon WGS84.
@@ -26,7 +26,7 @@
 section of the record. Not all fields names are used with all feature
 types (e.g. DOP fix error is not meaningful for route lines). You can
 use the <em>v.db.renamecolumn</em> module to rename columns.
-<P>
+<p>
 These are the standard GPX data fields known to OGR:
 <div class="code"><pre>
 ageofdgpsdata
@@ -59,7 +59,7 @@
 </pre></div>
-<H2>EXAMPLES</H2>
+<h2>EXAMPLES</h2>
 <h3>GPX Export</h3>
Modified: grass/trunk/scripts/v.out.gps/v.out.gps.py
--- grass/trunk/scripts/v.out.gps/v.out.gps.py	2011-09-04 08:03:54 UTC (rev 48101)
+++ grass/trunk/scripts/v.out.gps/v.out.gps.py	2011-09-04 09:43:15 UTC (rev 48102)
@@ -5,7 +5,7 @@
 # MODULE:	v.out.gps
 # PURPOSE:	Exports a GRASS vector map to a GPS receiver
-#		or data file using GpsBabel
+#		or data file using GPSBabel
 # COPYRIGHT:	(c) 2008-2009 Hamish Bowman, and the GRASS Development Team
 #		This program is free software under the GNU General Public
@@ -18,10 +18,10 @@
 # REQUIREMENTS:
-#      -  GpsBabel from 	http://gpsbabel.sourceforge.net
+#      -  GPSBabel from 	http://gpsbabel.sourceforge.net
 #      -  cs2cs from PROJ.4 (for m.proj)	http://proj.osgeo.org
-#      - report supported GpsBabel formats:
+#      - report supported GPSBabel formats:
 #	 gpsbabel -^2 | tr '\t' ';' | sort -t';' -k3
@@ -33,7 +33,7 @@
 #%Module
-#%  description: Exports a vector map to a GPS receiver or file format supported by GpsBabel.
+#%  description: Exports a vector map to a GPS receiver or file format supported by GPSBabel.
 #%  keywords: vector
 #%  keywords: export
 #%  keywords: GPS
@@ -60,6 +60,7 @@
 #%end
 #%option G_OPT_V_TYPE
 #% options: point,centroid,line,boundary
+#% answer: point,centroid,line,boundary
 #%end
 #%option G_OPT_F_OUTPUT
 #% description: Name for output file or GPS device
@@ -67,7 +68,7 @@
 #%option
 #% key: format
 #% type: string
-#% description: GpsBabel supported output format
+#% description: GPSBabel supported output format
 #% answer: gpx
 #%end
 #%option G_OPT_V_FIELD
@@ -295,7 +296,7 @@
     else:
 	gtype = ''
-    grass.verbose("Running GpsBabel ...")
+    grass.verbose("Running GPSBabel ...")
     ret = grass.call(['gpsbabel',
 		      gtype,
@@ -305,7 +306,7 @@
 		      '-F', output])
     if ret != 0:
-	grass.fatal(_("Error running GpsBabel"))
+	grass.fatal(_("Error running GPSBabel"))
     grass.verbose("Done.")
