[GRASS-SVN] r48118 - grass/trunk/scripts/d.rast.leg
svn_grass at osgeo.org
Sun Sep 4 18:09:46 EDT 2011
Author: cmbarton
Date: 2011-09-04 15:09:45 -0700 (Sun, 04 Sep 2011)
New Revision: 48118
grass/trunk/scripts/d.rast.leg/d.rast.leg.py
Fix formatting for Python
Modified: grass/trunk/scripts/d.rast.leg/d.rast.leg.py
--- grass/trunk/scripts/d.rast.leg/d.rast.leg.py 2011-09-04 17:48:25 UTC (rev 48117)
+++ grass/trunk/scripts/d.rast.leg/d.rast.leg.py 2011-09-04 22:09:45 UTC (rev 48118)
@@ -34,6 +34,7 @@
# Markus Neteler 10/2003: added g.parser
# Michael Barton 12/2004: remove reference to (null)
# Glynn Clements 10/2008: converted to Python
+# Michael Barton 9/2011: fix formatting in Python
#%module
@@ -68,7 +69,7 @@
import grass.script as grass
def make_frame(f, b, t, l, r):
- (ft, fb, fl, fr) = f
+ (fl, fr, ft, fb) = f
t /= 100.0
b /= 100.0
@@ -80,6 +81,8 @@
rl = fl + l * (fr - fl)
rr = fl + r * (fr - fl)
s = '%f,%f,%f,%f' % (rt, rb, rl, rr)
+ print "f = " + str(f)
+ print "s = " + str(s)
os.environ['GRASS_FRAME'] = s
def main():
@@ -91,11 +94,11 @@
#for -n flag of d.legend
if not grass.find_file(map)['file']:
- grass.fatal(_("Raster map <%s> not found in mapset search path") % map)
+ grass.fatal(_("Raster map <%s> not found in mapset search path") % map)
# for rast=
if rast and not grass.find_file(rast)['file']:
- grass.fatal(_("Raster map <%s> not found in mapset search path") % rast)
+ grass.fatal(_("Raster map <%s> not found in mapset search path") % rast)
s = grass.read_command('d.info', flags = 'f')
f = tuple([float(x) for x in s.split()[1:5]])
@@ -105,32 +108,32 @@
#draw title
# set vertical divide at 65 instead of 80 if real labels in cats/ file??
- make_frame(f, 90, 100, 80, 100)
- grass.write_command('d.text', color = 'black', size = 30, stdin = map)
+ make_frame(f, 90, 100,65, 100)
+ grass.write_command('d.text', color = 'black', size = 50, stdin = map)
#draw legend
if not nlines:
- nlines = None
+ nlines = None
if rast:
- lmap = rast
+ lmap = rast
else:
- lmap = map
+ lmap = map
kv = grass.raster_info(map = lmap)
if kv['datatype'] is 'CELL':
- leg_at = None
+ leg_at = None
else:
- leg_at = '7,93,3,18'
+ leg_at = '10,90,5,15'
histfiledir = grass.find_file(lmap, 'cell_misc')['file']
has_hist = os.path.isfile(os.path.join(histfiledir, 'histogram'))
lflags = ''
if flip:
- lflags += 'f'
+ lflags += 'f'
if has_hist or omit:
- lflags += 'n'
+ lflags += 'n'
make_frame(f, 0, 90, 65, 100)
grass.run_command('d.legend', flags = lflags, map = lmap, lines = nlines, at = leg_at)
