[GRASS-SVN] r48121 - grass-addons/vector/v.surf.icw
svn_grass at osgeo.org
Sun Sep 4 21:59:39 EDT 2011
Author: hamish
Date: 2011-09-04 18:59:39 -0700 (Sun, 04 Sep 2011)
New Revision: 48121
grass-addons/vector/v.surf.icw/v.surf.icw
quote path names to make MS Windows happy
Modified: grass-addons/vector/v.surf.icw/v.surf.icw
--- grass-addons/vector/v.surf.icw/v.surf.icw 2011-09-04 22:22:02 UTC (rev 48120)
+++ grass-addons/vector/v.surf.icw/v.surf.icw 2011-09-05 01:59:39 UTC (rev 48121)
@@ -114,13 +114,13 @@
-if [ -z $GISBASE ] ; then
+if [ -z "$GISBASE" ] ; then
echo "You have to be in GRASS to use this." 1>&2
exit 1
fi
if [ "$1" != "@ARGS_PARSED@" ] ; then
- exec $GISBASE/bin/g.parser "$0" "$@"
+ exec "$GISBASE/bin/g.parser" "$0" "$@"
fi
if [ -z "$GIS_OPT_POST_MASK" ] ; then
@@ -139,7 +139,7 @@
fi
echo "------------------------------------------------------------------------"
-FRICTION=$GIS_OPT_FRICTION
+FRICTION="$GIS_OPT_FRICTION"
if [ "$FRICTION" -lt 1 ] || [ "$FRICTION" -gt 6 ]; then
echo "Friction of Distance out of range [1-6]" 1>&2
exit 1
@@ -229,7 +229,7 @@
CAT=`echo "$POS" | cut -f"$CATCOL" -d"|"`
DATA_VALUE="`db.select -c tmp_icw_points_$$ sql="select $COL_NAME from tmp_icw_points_$$ where cat=${CAT}"`"
- echo Site $NUM of $N e=$EASTING n=$NORTHING data=$DATA_VALUE
+ echo "Site $NUM of $N e=$EASTING n=$NORTHING data=$DATA_VALUE"
if [ -z "$DATA_VALUE" ] ; then
echo " Skipping, no data here." 1>&2
@@ -279,7 +279,7 @@
INPUT_MAPS=1by_cost_site_sqrd.1
NUM=2
while [ $NUM -le $N ] ; do
- INPUT_MAPS=$INPUT_MAPS,1by_cost_site_sqrd.$NUM
+ INPUT_MAPS="$INPUT_MAPS,1by_cost_site_sqrd.$NUM"
NUM="`expr $NUM + 1`"
done
@@ -289,7 +289,7 @@
fi
echo "Summation of cost weights.." 1>&2
-r.series method=sum in=$INPUT_MAPS out=sum_of_1by_cost_sqs
+r.series method=sum in="$INPUT_MAPS" out=sum_of_1by_cost_sqs
if [ -n "$GIS_OPT_POST_MASK" ] ; then
echo "Removing post_mask [$GIS_OPT_POST_MASK]" 1>&2
