[GRASS-SVN] r48125 - grass/trunk/scripts/d.rast.leg
svn_grass at osgeo.org
Mon Sep 5 02:36:28 EDT 2011
Author: cmbarton
Date: 2011-09-04 23:36:28 -0700 (Sun, 04 Sep 2011)
New Revision: 48125
grass/trunk/scripts/d.rast.leg/d.rast.leg.py
Further improving formatting
Modified: grass/trunk/scripts/d.rast.leg/d.rast.leg.py
--- grass/trunk/scripts/d.rast.leg/d.rast.leg.py 2011-09-05 06:27:22 UTC (rev 48124)
+++ grass/trunk/scripts/d.rast.leg/d.rast.leg.py 2011-09-05 06:36:28 UTC (rev 48125)
@@ -34,7 +34,6 @@
# Markus Neteler 10/2003: added g.parser
# Michael Barton 12/2004: remove reference to (null)
# Glynn Clements 10/2008: converted to Python
-# Michael Barton 9/2011: fix formatting in Python
#%module
@@ -100,16 +99,30 @@
s = grass.read_command('d.info', flags = 'f')
f = tuple([float(x) for x in s.split()[1:5]])
grass.run_command('d.erase')
os.environ['GRASS_PNG_READ'] = 'TRUE'
#draw title
# set vertical divide at 65 instead of 80 if real labels in cats/ file??
- make_frame(f, 90, 100,65, 100)
- grass.write_command('d.text', color = 'black', size = 50, stdin = map)
+ make_frame(f, 90, 100, 70, 100)
+ # use map name without mapset suffix
+ mapname = map.split('@')[0]
+ grass.run_command('d.text', color='black', size=50, at='5,50', align='cl', text=mapname)
#draw legend
+ # set legend vertical position and size based on number of categories
+ cats = grass.read_command('r.describe', map=map, flags = '1n')
+ ncats = len(cats.strip().split('\n'))
+ # Only need to adjust legend size if number of categories is between 1 and 10
+ if ncats < 2: ncats = 2
+ if ncats > 10: ncats = 10
+ VSpacing = (100 - (ncats * 10) + 10)
if not nlines:
nlines = None
@@ -122,22 +135,26 @@
if kv['datatype'] is 'CELL':
leg_at = None
else:
- leg_at = '10,90,5,15'
+ leg_at = '%f,95,5,15' %VSpacing
- histfiledir = grass.find_file(lmap, 'cell_misc')['file']
- has_hist = os.path.isfile(os.path.join(histfiledir, 'histogram'))
+# checking for histogram causes more problems than it solves
+# histfiledir = grass.find_file(lmap, 'cell_misc')['file']
+# has_hist = os.path.isfile(os.path.join(histfiledir, 'histogram'))
lflags = ''
if flip:
lflags += 'f'
- if has_hist or omit:
+ if omit:
lflags += 'n'
- make_frame(f, 0, 90, 65, 100)
+# if has_hist or omit:
+# lflags += 'n'
+ make_frame(f, 0, 90, 70, 100)
grass.run_command('d.legend', flags = lflags, map = lmap, lines = nlines, at = leg_at)
#draw map
- make_frame(f, 0, 100, 0, 65)
+ make_frame(f, 0, 100, 0, 70)
grass.run_command('d.rast', map = map)
if __name__ == "__main__":
