[GRASS-SVN] r48130 - grass/trunk/lib/python
svn_grass at osgeo.org
Mon Sep 5 09:05:03 EDT 2011
Author: huhabla
Date: 2011-09-05 06:05:03 -0700 (Mon, 05 Sep 2011)
New Revision: 48130
Added:
grass/trunk/lib/python/raster3d.py
grass/trunk/lib/python/Makefile
grass/trunk/lib/python/__init__.py
Raster3d info and mapcalc python functions inspired by the grass.script
python raster package
Modified: grass/trunk/lib/python/Makefile
--- grass/trunk/lib/python/Makefile 2011-09-05 12:56:24 UTC (rev 48129)
+++ grass/trunk/lib/python/Makefile 2011-09-05 13:05:03 UTC (rev 48130)
@@ -8,7 +8,7 @@
GDIR = $(PYDIR)/grass
DSTDIR = $(GDIR)/script
-MODULES = core db raster vector array setup task
+MODULES = core db raster raster3d vector array setup task
PYFILES := $(patsubst %,$(DSTDIR)/%.py,$(MODULES) __init__)
PYCFILES := $(patsubst %,$(DSTDIR)/%.pyc,$(MODULES) __init__)
Modified: grass/trunk/lib/python/__init__.py
--- grass/trunk/lib/python/__init__.py 2011-09-05 12:56:24 UTC (rev 48129)
+++ grass/trunk/lib/python/__init__.py 2011-09-05 13:05:03 UTC (rev 48130)
@@ -1,4 +1,5 @@
from core import *
from db import *
from raster import *
+from raster3d import *
from vector import *
Added: grass/trunk/lib/python/raster3d.py
--- grass/trunk/lib/python/raster3d.py (rev 0)
+++ grass/trunk/lib/python/raster3d.py 2011-09-05 13:05:03 UTC (rev 48130)
@@ -0,0 +1,86 @@
+"""!@package grass.script.raster3d
+ at brief GRASS Python scripting module (raster3d functions)
+Raster3d related functions to be used in Python scripts.
+Usage:
+ at code
+from grass.script import raster3d as grass
+grass.raster3d_info(map)
+ at endcode
+(C) 2008-2009 by the GRASS Development Team
+This program is free software under the GNU General Public
+License (>=v2). Read the file COPYING that comes with GRASS
+for details.
+ at author Glynn Clements
+ at author Martin Landa <landa.martin gmail.com>
+ at author Soeren Gebbert <soeren.gebbert gmail.com>
+import os
+import string
+from core import *
+# add raster history
+# run "r3.info -rstgip ..." and parse output
+def raster3d_info(map):
+ """!Return information about a raster map (interface to
+ `r3.info'). Example:
+ \code
+ >>> grass.raster3d_info('volume')
+ {'tiledimz': 1, 'tbres': 1.0, 'tiledimx': 27, 'tiledimy': 16, 'north': 60.490001999999997, 'tilenumy': 1, 'tilenumz': 1,
+ 'min': 1.0, 'datatype': '"DCELL"', 'max': 1.0, 'top': 0.5, 'bottom': -0.5, 'west': -3.2200000000000002, 'tilenumx': 1,
+ 'ewres': 0.98222219, 'east': 23.299999, 'nsres': 0.99937511999999995, 'Timestamp': '"none"', 'south': 44.5}
+ \endcode
+ @param map map name
+ @return parsed raster3d info
+ def float_or_null(s):
+ if s == 'NULL':
+ return None
+ else:
+ return float(s)
+ s = read_command('r3.info', flags = 'rstgip', map = map)
+ kv = parse_key_val(s)
+ for k in ['min', 'max']:
+ kv[k] = float_or_null(kv[k])
+ for k in ['north', 'south', 'east', 'west', 'top', 'bottom']:
+ kv[k] = float(kv[k])
+ for k in ['nsres', 'ewres', 'tbres']:
+ kv[k] = float_or_dms(kv[k])
+ for k in ['tilenumx', 'tilenumy', 'tilenumz']:
+ kv[k] = int(kv[k])
+ for k in ['tiledimx', 'tiledimy', 'tiledimz']:
+ return kv
+# interface to r3.mapcalc
+def mapcalc3d(exp, quiet = False, verbose = False, overwrite = False, **kwargs):
+ """!Interface to r3.mapcalc.
+ @param exp expression
+ @param kwargs
+ t = string.Template(exp)
+ e = t.substitute(**kwargs)
+ if run_command('r3.mapcalc', expression = e,
+ quiet = quiet,
+ verbose = verbose,
+ overwrite = overwrite) != 0:
+ fatal(_("An error occurred while running r3.mapcalc"))
