[GRASS-SVN] r48144 - grass/trunk/gui/wxpython/docs
Mon Sep 5 13:28:26 EDT 2011
Author: neteler
Date: 2011-09-05 10:28:26 -0700 (Mon, 05 Sep 2011)
New Revision: 48144
   grass/trunk/gui/wxpython/docs/wxGUI.Attribute_Table_Manager.html
   grass/trunk/gui/wxpython/docs/wxGUI.GCP_Manager.html
   grass/trunk/gui/wxpython/docs/wxGUI.Modeler.html
   grass/trunk/gui/wxpython/docs/wxGUI.Nviz.html
   grass/trunk/gui/wxpython/docs/wxGUI.PsMap.html
   grass/trunk/gui/wxpython/docs/wxGUI.Vector_Digitizer.html
   grass/trunk/gui/wxpython/docs/wxGUI.html
cosmetics
Modified: grass/trunk/gui/wxpython/docs/wxGUI.Attribute_Table_Manager.html
--- grass/trunk/gui/wxpython/docs/wxGUI.Attribute_Table_Manager.html	2011-09-05 17:28:20 UTC (rev 48143)
+++ grass/trunk/gui/wxpython/docs/wxGUI.Attribute_Table_Manager.html	2011-09-05 17:28:26 UTC (rev 48144)
@@ -7,8 +7,8 @@
   statements</li>
   <li>Modify attribute data, insert new records to attribute table,
   delete existing records</li>
-  <li>Highlight selected items in Map Display Window</li>
-  <li>Extract selected items into new vector map</li>
+  <li>Highlight selected items in the Map Display Window</li>
+  <li>Extract selected items into a new vector map</li>
   <li>Modify attribute table - add, drop, rename columns</li>
   <li>Modify vector map DB connection settings - add, remove or
   modify layers</li>
@@ -17,37 +17,37 @@
 <h2>SEE ALSO</h2>
 <em>
-  <a href="wxGUI.html">wxGUI</a>
+<a href="wxGUI.html">wxGUI</a>
 </em>
 <p>
 Other wxGUI components:<br>
 <em>
-  <a href="wxGUI.Vector_Digitizer.html">Vector Digitizer</a><br>
-  <a href="wxGUI.Nviz.html">3D Viewer</a><br>
-  <a href="wxGUI.Modeler.html">Graphical Modeler</a><br>
-  <a href="wxGUI.GCP_Manager.html">Manage Ground Control Points</a><br>
-  <a href="wxGUI.PsMap.html">Hardcopy Map Output Utility</a><br>
+<a href="wxGUI.Vector_Digitizer.html">Vector Digitizer</a><br>
+<a href="wxGUI.Nviz.html">3D Viewer</a><br>
+<a href="wxGUI.Modeler.html">Graphical Modeler</a><br>
+<a href="wxGUI.GCP_Manager.html">Manage Ground Control Points</a><br>
+<a href="wxGUI.PsMap.html">Hardcopy Map Output Utility</a><br>
 </em>
 <p>
 <em>
-  <a href="db.columns.html">db.columns</a>,
-  <a href="db.connect.html">db.connect</a>,
-  <a href="db.describe.html">db.describe</a>,
-  <a href="db.drivers.html">db.drivers</a>,
-  <a href="db.execute.html">db.execute</a>,
-  <a href="db.select.html">db.select</a>,
-  <a href="db.tables.html">db.tables</a>
+<a href="db.columns.html">db.columns</a>,
+<a href="db.connect.html">db.connect</a>,
+<a href="db.describe.html">db.describe</a>,
+<a href="db.drivers.html">db.drivers</a>,
+<a href="db.execute.html">db.execute</a>,
+<a href="db.select.html">db.select</a>,
+<a href="db.tables.html">db.tables</a>
 </em>
 <p>
 <em>
-  <a href="v.db.addcolumn.html">v.db.addcolumn</a>,
-  <a href="v.db.connect.html">v.db.connect</a>,
-  <a href="v.db.dropcolumn.html">v.db.dropcolumn</a>,
-  <a href="v.db.renamecolumn.html">v.db.renamecolumn</a>,
-  <a href="v.what.html">v.what</a>
+<a href="v.db.addcolumn.html">v.db.addcolumn</a>,
+<a href="v.db.connect.html">v.db.connect</a>,
+<a href="v.db.dropcolumn.html">v.db.dropcolumn</a>,
+<a href="v.db.renamecolumn.html">v.db.renamecolumn</a>,
+<a href="v.what.html">v.what</a>
 </em>
 <p>
Modified: grass/trunk/gui/wxpython/docs/wxGUI.GCP_Manager.html
--- grass/trunk/gui/wxpython/docs/wxGUI.GCP_Manager.html	2011-09-05 17:28:20 UTC (rev 48143)
+++ grass/trunk/gui/wxpython/docs/wxGUI.GCP_Manager.html	2011-09-05 17:28:26 UTC (rev 48144)
@@ -1,6 +1,5 @@
 <h2>DESCRIPTION</h2>
-<p>
 The <b>GCP Manager</b> is a <em><a href="wxGUI.html">wxGUI</a></em>
 extension which allows the user to create, edit, and manage
 Ground Control Points. It is available from the menu
@@ -314,8 +313,7 @@
 <h2>AUTHORS</h2>
 Markus Metz<br><br>
-<em>Based on the Georectifier (GRASS 6.4.0) by</em><br>
-Michael Barton<br>
+<em>Based on the Georectifier (GRASS 6.4.0)</em> by Michael Barton<br>
 <a href="http://geo.fsv.cvut.cz/gwiki/Landa">Martin Landa</a>, <a
 href="http://www.cvut.cz">Czech Technical University in Prague</a>, Czech Republic
Modified: grass/trunk/gui/wxpython/docs/wxGUI.Modeler.html
--- grass/trunk/gui/wxpython/docs/wxGUI.Modeler.html	2011-09-05 17:28:20 UTC (rev 48143)
+++ grass/trunk/gui/wxpython/docs/wxGUI.Modeler.html	2011-09-05 17:28:26 UTC (rev 48144)
@@ -3,7 +3,7 @@
 <b>Note:</b> <em>wxGUI Modeler is currently under development.</em>
 <p>
-<b>Graphical modeler</b> is a <em><a href="wxGUI.html">wxGUI</a></em>
+The <b>Graphical modeler</b> is a <em><a href="wxGUI.html">wxGUI</a></em>
 models. The modeler can be launched from the menu &quot;File |
 Graphical modeler&quot; or by clicking on
@@ -13,8 +13,8 @@
 The modeler currently allows to:
 <ul>
+  <li>define data items (raster, vector, 3D raster maps)
   <li>define actions (GRASS modules)
-  <li>define data items (raster, vector, 3D raster maps)
   <li>define relations between data and action items
   <li>define loops and conditions (if-else statements)
   <li>define model variables
@@ -30,23 +30,23 @@
 <h2>SEE ALSO</h2>
 <em>
 </em>
 <p>
 <em>
-  <a href="wxGUI.Attribute_Table_Manager.html">Attribute Table Manager</a><br>
+<a href="wxGUI.Attribute_Table_Manager.html">Attribute Table Manager</a><br>
 </em>
 <p>
 See also user <a href="http://grass.osgeo.org/wiki/WxGUI_Modeler">wiki</a> page.
-<h2>AUTHORS</h2>
+<h2>AUTHOR</h2>
Modified: grass/trunk/gui/wxpython/docs/wxGUI.Nviz.html
--- grass/trunk/gui/wxpython/docs/wxGUI.Nviz.html	2011-09-05 17:28:20 UTC (rev 48143)
+++ grass/trunk/gui/wxpython/docs/wxGUI.Nviz.html	2011-09-05 17:28:26 UTC (rev 48144)
@@ -1,7 +1,7 @@
 Note: <b>wxNviz is currently under development. Not
-all functionality is implemented.</b>
+all planned functionality is already implemented.</b>
 <p>
 <b>wxNviz</b> is a <em><a href="wxGUI.html">wxGUI</a></em> <b>3D view
Modified: grass/trunk/gui/wxpython/docs/wxGUI.PsMap.html
--- grass/trunk/gui/wxpython/docs/wxGUI.PsMap.html	2011-09-05 17:28:20 UTC (rev 48143)
+++ grass/trunk/gui/wxpython/docs/wxGUI.PsMap.html	2011-09-05 17:28:26 UTC (rev 48144)
@@ -12,10 +12,10 @@
 PostScript output. There are two modes - <em>Draft mode</em> for map
 composing and <em>Preview mode</em> to see how the result will look
 like. In draft mode map features (like legend or scalebar) are
-represented by a colored rectangle with a label.</p>
+represented by a colored rectangle with a label.
 <p>
-Possible output files:</p>
+Possible output files:
 <ul>
   <li> <em><a href="ps.map.html">ps.map</a></em> instructions file
   <li> PostScript/EPS file
@@ -24,10 +24,10 @@
 <p>
 Hardcopy Map Output Utility enables to load in saved instructions file. It
-works better with files created by wx.psmap (more tested).</p>
+works better with files created by wx.psmap (more tested).
 <p>
-Currently supported <em><a href="ps.map.html">ps.map</a></em> instructions:</p>
+Currently supported <em><a href="ps.map.html">ps.map</a></em> instructions:
 <ul>
   <li> paper
@@ -195,13 +195,13 @@
 </em>
-</p>
 <p>
 See also <a href="http://grass.osgeo.org/wiki/WxGUI_Hardcopy_Map_Output_Utility">wiki</a> page.
-</p>
 <h2>AUTHORS</h2>
 Anna Kratochvilova, Czech Technical Univesity (CTU) in Prague, Czech Republic (bachelor's final project 2011, mentor: Martin Landa)
 <p>
-<i>$Date$</i></p>
+<i>$Date$</i>
Modified: grass/trunk/gui/wxpython/docs/wxGUI.Vector_Digitizer.html
--- grass/trunk/gui/wxpython/docs/wxGUI.Vector_Digitizer.html	2011-09-05 17:28:20 UTC (rev 48143)
+++ grass/trunk/gui/wxpython/docs/wxGUI.Vector_Digitizer.html	2011-09-05 17:28:26 UTC (rev 48144)
@@ -1,6 +1,6 @@
-<b>Vector digitizer</b> is
+The <b>Vector digitizer</b> is
 a <em><a href="wxGUI.html">wxGUI</a></em> component intended for
 interactive editing vector maps
 (see <em><a href="v.edit.html">v.edit</a></em> for non-interactive
Modified: grass/trunk/gui/wxpython/docs/wxGUI.html
--- grass/trunk/gui/wxpython/docs/wxGUI.html	2011-09-05 17:28:20 UTC (rev 48143)
+++ grass/trunk/gui/wxpython/docs/wxGUI.html	2011-09-05 17:28:26 UTC (rev 48144)
@@ -3,44 +3,45 @@
 wxGUI is native <em>Graphical User Interface</em> (GUI) for GRASS GIS.
 <p>
-If wxGUI is not your default UI, you can define it as default by
-typing at GRASS command line prompt
+If the wxGUI is not the default user interface, it can defined as default by
+typing at the GRASS command line prompt:
 <div class="code"><pre>
-   g.gui -u wxpython
+g.gui -u wxpython
 </pre></div>
-Alternatively define in your <tt>.grass7/rc</tt> file 'GUI' variable
+Alternatively it may be defined in the settings file
+<tt>$HOME/.grass7/rc</tt> with the 'GUI' variable:
-    GUI: wxpython
+GUI: wxpython
 </pre></div>
-or set up shell environmental variable <tt>GRASS_GUI</tt>.
-The GUI can be quit by selecting the 'File->Exit' menu item. The GUI
+or it can be set with the shell environmental variable <tt>GRASS_GUI</tt>.
+<p>
+The GUI can be quit by selecting the 'File -&gt; Exit' menu item. The GUI
 can be restarted from the GRASS command line prompt by typing
-    g.gui wxpython
+g.gui wxpython
 </pre></div>
-or  to restart with previously saved workspace type:
+or, to restart with previously saved workspace type:
-    g.gui wxpython workspace=file.gxw
+g.gui wxpython workspace=file.gxw
 </pre></div>
 <p>
-You can also start GRASS from the shell command line with wxGUI
-defined by the <tt>-wxpython</tt> switch:
+The user can also start GRASS from the shell command line with the wxGUI
+specifying the <tt>-gui</tt> (or, <tt>-wxpython</tt>) switch:
-    grass70 -wxpython
+grass70 -gui
 </pre></div>
 <p>
-The GUI is composed by <em>two</em> main components:
+The GUI is composed of <em>two</em> main components:
 <ul>
   <li>The <b>Layer Manager</b> includes map layer management, integrated
