[GRASS-SVN] r48152 - grass/trunk/scripts/v.out.gps
svn_grass at osgeo.org
Mon Sep 5 18:07:24 EDT 2011
Author: hamish
Date: 2011-09-05 15:07:24 -0700 (Mon, 05 Sep 2011)
New Revision: 48152
Removed:
grass/trunk/scripts/v.out.gps/v.out.gps
replaced by python version
Deleted: grass/trunk/scripts/v.out.gps/v.out.gps
--- grass/trunk/scripts/v.out.gps/v.out.gps 2011-09-05 22:04:47 UTC (rev 48151)
+++ grass/trunk/scripts/v.out.gps/v.out.gps 2011-09-05 22:07:24 UTC (rev 48152)
@@ -1,356 +0,0 @@
-#!/bin/sh
-# MODULE: v.out.gps
-# PURPOSE: Exports a GRASS vector map to a GPS receiver
-# or data file using GpsBabel
-# COPYRIGHT: (c) 2008 Hamish Bowman, and the GRASS Development Team
-# This program is free software under the GNU General Public
-# License (>=v2). Read the file COPYING that comes with GRASS
-# for details.
-# AUTHOR: Hamish Bowman, Dunedin, New Zealand
-# REQUIREMENTS:
-# - GpsBabel from http://gpsbabel.sourceforge.net
-# - cs2cs from PROJ.4 (for m.proj) http://proj.osgeo.org
-# - report supported GpsBabel formats:
-# gpsbabel -^2 | tr '\t' ';' | sort -t';' -k3
-# How to do it
-# http://www.gdal.org/ogr/drv_gpx.html
-# gpsbabel [options] -i INTYPE -f INFILE -o OUTTYPE -F OUTFILE
-#%Module
-#% description: Exports a vector map to a GPS receiver or file format supported by GpsBabel.
-#% keywords: vector, export, GPS
-#%End
-#%flag
-#% key: w
-#% description: Export as waypoints
-#%end
-#%flag
-#% key: r
-#% description: Export as routes
-#%end
-#%flag
-#% key: t
-#% description: Export as tracks
-#%end
-############ TODO:
-##%flag
-##% key: z
-##% description: Export altitude from 3D vector's z-coordinate
-##%end
-#%option
-#% key: input
-#% type: string
-#% description: Name of input vector map
-#% gisprompt: old,vector,vector
-#% required: yes
-#%end
-#%option
-#% key: type
-#% type: string
-#% description: Feature type(s)
-#% options: point,centroid,line,boundary
-#% multiple: yes
-#%end
-#%option
-#% key: output
-#% type: string
-#% description: Name for output file or GPS device
-#% gisprompt: new_file,file,output
-#% key_desc: name
-#% required: yes
-#%end
-#%option
-#% key: format
-#% type: string
-#% description: GpsBabel supported output format
-#% answer: gpx
-#%end
-#%option
-#% key: layer
-#% type: integer
-#% label: Layer number
-#% description: A single vector map can be connected to multiple database tables. This number determines which table to use.
-#% answer: 1
-#% required : no
-#% guisection: Subset
-#%end
-#%option
-#% key: where
-#% type: string
-#% label: WHERE conditions of SQL statement without 'where' keyword
-#% description: Example: income < 1000 and inhab >= 10000
-#% required : no
-#%end
-if [ -z "$GISBASE" ] ; then
- echo "You must be in GRASS GIS to run this program." 1>&2
- exit 1
-fi
-if [ "$1" != "@ARGS_PARSED@" ] ; then
- # save command line
- CMDLINE="`basename $0`"
- for arg in "$@" ; do
- CMDLINE="$CMDLINE \"$arg\""
- done
- export CMDLINE
- exec g.parser "$0" "$@"
-fi
-# set environment so that awk works properly in all languages
-unset LC_ALL
-LC_NUMERIC=C
-export LC_NUMERIC
-eval `g.gisenv`
-: ${GISBASE?} ${GISDBASE?} ${LOCATION_NAME?} ${MAPSET?}
-LOCATION="$GISDBASE"/"$LOCATION_NAME"/"$MAPSET"
-PROG=`basename $0`
-#### check for gpsbabel
-if [ ! -x "`which gpsbabel`" ] ; then
- g.message -e "The gpsbabel program was not found, please install it first.
- http://gpsbabel.sourceforge.net"
- exit 1
-fi
-#### check for cs2cs
-if [ ! -x "`which cs2cs`" ] ; then
- g.message -e "The cs2cs program was not found, please install it first.
- http://proj.osgeo.org"
- exit 1
-fi
-# check if we will overwrite data
-if [ -e "$GIS_OPT_OUTPUT" ] ; then
- if [ -z "$GRASS_OVERWRITE" ] || [ "$GRASS_OVERWRITE" -ne 1 ] ; then
- g.message -e "Output file already exists."
- exit 1
- fi
-fi
-#### set temporary files
-TMP="`g.tempfile pid=$$`"
-if [ $? -ne 0 ] || [ -z "$TMP" ] ; then
- g.message -e "Unable to create temporary files"
- exit 1
-fi
-cleanup()
- g.message -v "Cleaning up ..."
- \rm -f "$TMP" "$TMP.gpx"
- # only try to remove map if it exists to avoid ugly warnings
- g.findfile element=vector file="tmp_vogb_epsg4326_$$" > /dev/null
- if [ $? -eq 0 ] ; then
- g.remove vect="tmp_vogb_epsg4326_$$" --quiet
- fi
- g.findfile element=vector file="tmp_vogb_extr_$$" > /dev/null
- g.remove vect="tmp_vogb_extr_$$" --quiet
- fi
-#### trap ctrl-c so that we can clean up tmp
-trap 'cleanup' 2 3 15
-#### process command line arguments
-WPT=$GIS_FLAG_W ; RTE=$GIS_FLAG_R ; TRK=$GIS_FLAG_T
-if [ $WPT -eq 1 ] && ([ $RTE -eq 1 ] || [ $TRK -eq 1 ]) ; then
- g.message -e "One feature at a time please."
- rm -f "${TMP}"
- exit 1
-fi
-# logic eludes me at pressent.. [combine with above]
-if [ $RTE -eq 1 ] && [ $TRK -eq 1 ] ; then
- rm -f "${TMP}"
- exit 1
-fi
-if [ $WPT -eq 0 ] && [ $RTE -eq 0 ] && [ $TRK -eq 0 ] ; then
- g.message -e "No features requested for export. (wpt/trk/rte)"
- cleanup
- exit 1
-fi
-# set some reasonable defaults
-if [ $WPT -eq 1 ] ; then
- if [ -z "$GIS_OPT_TYPE" ] ; then
- GIS_OPT_TYPE="point"
- fi
-else
- GIS_OPT_TYPE="line"
- fi
-fi
-# SQL extract if needed
-if [ -n "$GIS_OPT_WHERE" ] ; then
- g.message -v "Extracting data ..."
- v.extract in="$GIS_OPT_INPUT" out="tmp_vogb_extr_$$" \
- type="$GIS_OPT_TYPE" layer="$GIS_OPT_LAYER" \
- where="$GIS_OPT_WHERE" --quiet
- if [ $? -ne 0 ] ; then
- g.message -e "Error executing SQL query"
- cleanup
- exit 1
- fi
- eval `v.info -t map="tmp_vogb_extr_$$"`
- if [ "$primitives" -eq 0 ] ; then
- g.message -e "SQL query returned an empty map (no $GIS_OPT_TYPE features?)"
- cleanup
- exit 1
- fi
- INMAP="tmp_vogb_extr_$$"
-else
-# g.copy "$GIS_OPT_INPUT,tmp_vogb_extr_$$" # to get a copy of DB into local mapset
-# INMAP="tmp_vogb_extr_$$"
- INMAP="$GIS_OPT_INPUT"
-fi
-#### set up projection info
-# TODO: check if we are already in ll/WGS84. If so skip m.proj step.
-# TODO: multi layer will probably fail badly due to sed 's/^ 1 /'
-# output as old GRASS 4 vector ascii and fight with dig_ascii/?
-# Change to s/^ \([0-9] .*\) /# \1/' ??? mmph.
-# reproject to lat/lon WGS84
-g.message -v "Reprojecting data ..."
-v.out.ascii in="$INMAP" format=standard | \
- sed -e 's/^\([PLBCFKA]\)/#\1/' -e 's/^ 1 /# 1 /' | \
- tail -n +11 | m.proj -od --quiet | \
- sed -e 's/\t\([-\.0-9]*\) .*/ \1/' \
- -e 's/^\([-\.0-9]\)/ \1/' \
- -e 's/^#//' | \
- v.in.ascii out=tmp_vogb_epsg4326_$$ -n format=standard --quiet
-if [ $? -ne 0 ] ; then
- g.message -e "Error reprojecting data"
- cleanup
- exit 1
-fi
-# don't v.db.connect directly as source table will be removed with
-# temporary map in that case. So we make a temp copy of it to work with.
-DB_PARAMS=`v.db.connect -g "$INMAP" 2> /dev/null | grep "^$GIS_OPT_LAYER "`
-if [ -n "$DB_PARAMS" ] ; then
- DB_TABLE=`echo "$DB_PARAMS" | cut -f2 -d' '`
- DB_KEY=`echo "$DB_PARAMS" | cut -f3 -d' '`
- DB_DATABASE=`echo "$DB_PARAMS" | cut -f4 -d' '`
- DB_DRIVER=`echo "$DB_PARAMS" | cut -f5 -d' '`
- db.copy from_driver="$DB_DRIVER" from_database="$DB_DATABASE" \
- from_table="$DB_TABLE" to_table="tmp_vogb_epsg4326_$$"
- g.message -e "Error copying temporary DB"
- cleanup
- exit 1
- fi
- v.db.connect map="tmp_vogb_epsg4326_$$" table="tmp_vogb_epsg4326_$$" --quiet
- g.message -e "Error reconnecting temporary DB"
- cleanup
- exit 1
- fi
-fi
-# export as GPX using v.out.ogr
-if [ $TRK -eq 1 ] ; then
- LINETYPE="lco=FORCE_GPX_TRACK=YES"
-elif [ $RTE -eq 1 ] ; then
- LINETYPE="lco=FORCE_GPX_ROUTE=YES"
-else
- LINETYPE=""
-fi
-# BUG: cat is being reported as evelation and attribute output is skipped.
-# (v.out.ogr DB reading or ->OGR GPX driver bug<-
-# resolved: see new Create opts at http://www.gdal.org/ogr/drv_gpx.html)
-# v.out.ogr -> shapefile -> GPX works, but we try to avoid that as it's
-# lossy. Also that would allow ogr2ogr -a_srs $IN_PROJ -t_srs EPSG:4326
-# so skip m.proj pains.. if that is done ogr2ogr -s_srs MUST HAVE +wktext
-# with PROJ.4 terms or else the +nadgrids will be ignored! best to feed
-# it IN_PROJ="`g.proj -jf` +wktext" in that case.
-g.message -v "Exporting data ..."
-v.out.ogr in="tmp_vogb_epsg4326_$$" dsn="$TMP.gpx" type="$GIS_OPT_TYPE" \
- format=GPX ${LINETYPE} dsco="GPX_USE_EXTENSIONS=YES" --quiet
- g.message -e "Error exporting data"
- cleanup
- exit 1
-fi
-if [ "$GIS_OPT_FORMAT" = gpx ] ; then
- # short circuit, we have what we came for.
- mv -f "$TMP.gpx" "$GIS_OPT_OUTPUT"
- cleanup
- g.message -v "Fast exit."
- exit 0
-fi
-# run gpsbabel
-GTYPE=""
- GTYPE="-w"
-elif [ $TRK -eq 1 ] ; then
- GTYPE="-t"
- GTYPE="-r"
-fi
-g.message -v "Running GpsBabel ..."
-gpsbabel $GTYPE -i gpx -f "$TMP.gpx" \
- -o "$GIS_OPT_FORMAT" -F "$GIS_OPT_OUTPUT"
- g.message -e "Error running GpsBabel"
- cleanup
- exit 1
-fi
-cleanup
-g.message -v "Done."
-exit
