[GRASS-SVN] r48157 - grass/branches/develbranch_6/db/drivers/sqlite
svn_grass at osgeo.org
Tue Sep 6 02:43:03 EDT 2011
Author: mmetz
Date: 2011-09-05 23:43:03 -0700 (Mon, 05 Sep 2011)
New Revision: 48157
grass/branches/develbranch_6/db/drivers/sqlite/create_table.c
grass/branches/develbranch_6/db/drivers/sqlite/cursor.c
grass/branches/develbranch_6/db/drivers/sqlite/db.c
grass/branches/develbranch_6/db/drivers/sqlite/describe.c
grass/branches/develbranch_6/db/drivers/sqlite/driver.c
grass/branches/develbranch_6/db/drivers/sqlite/error.c
grass/branches/develbranch_6/db/drivers/sqlite/execute.c
grass/branches/develbranch_6/db/drivers/sqlite/fetch.c
grass/branches/develbranch_6/db/drivers/sqlite/index.c
grass/branches/develbranch_6/db/drivers/sqlite/listtab.c
grass/branches/develbranch_6/db/drivers/sqlite/main.c
grass/branches/develbranch_6/db/drivers/sqlite/proto.h
grass/branches/develbranch_6/db/drivers/sqlite/select.c
sqlite driver: fix for #548 and related
Modified: grass/branches/develbranch_6/db/drivers/sqlite/create_table.c
--- grass/branches/develbranch_6/db/drivers/sqlite/create_table.c 2011-09-06 06:41:44 UTC (rev 48156)
+++ grass/branches/develbranch_6/db/drivers/sqlite/create_table.c 2011-09-06 06:43:03 UTC (rev 48157)
@@ -8,8 +8,9 @@
* (>=v2). Read the file COPYING that comes with GRASS for details.
* \author Radim Blazek
+ * \author Support for multiple connections by Markus Metz
- * \date 2005-2007
+ * \date 2005-2011
#include <grass/dbmi.h>
@@ -112,6 +113,9 @@
G_debug(3, " SQL: %s", db_get_string(&sql));
ret = sqlite3_prepare(sqlite, db_get_string(&sql), -1, &statement, &rest);
+ while (ret == SQLITE_BUSY || ret == SQLITE_IOERR_BLOCKED) {
+ ret = sqlite3_busy_handler(sqlite, sqlite_busy_callback, NULL);
if (ret != SQLITE_OK) {
append_error("Cannot create table:\n");
Modified: grass/branches/develbranch_6/db/drivers/sqlite/cursor.c
--- grass/branches/develbranch_6/db/drivers/sqlite/cursor.c 2011-09-06 06:41:44 UTC (rev 48156)
+++ grass/branches/develbranch_6/db/drivers/sqlite/cursor.c 2011-09-06 06:43:03 UTC (rev 48157)
@@ -3,9 +3,9 @@
* MODULE: SQLite driver
-* AUTHOR(S): Radim Blazek
+* AUTHOR(S): Radim Blazek, Markus Metz
-* COPYRIGHT: (C) 2005 by the GRASS Development Team
+* COPYRIGHT: (C) 2011 by the GRASS Development Team
* This program is free software under the GNU General Public
* License (>=v2). Read the file COPYING that comes with GRASS
@@ -21,6 +21,7 @@
int db__driver_close_cursor(dbCursor * dbc)
cursor *c;
+ int ret;
init_error();
@@ -29,7 +30,10 @@
if (c == NULL)
return DB_FAILED;
- sqlite3_finalize(c->statement);
+ ret = sqlite3_finalize(c->statement);
/* free_cursor(cursor) */
free_cursor(c);
Modified: grass/branches/develbranch_6/db/drivers/sqlite/db.c
--- grass/branches/develbranch_6/db/drivers/sqlite/db.c 2011-09-06 06:41:44 UTC (rev 48156)
+++ grass/branches/develbranch_6/db/drivers/sqlite/db.c 2011-09-06 06:43:03 UTC (rev 48157)
@@ -7,8 +7,9 @@
- * \date 2005-2007
+ * \date 2005-2011
#include <stdlib.h>
@@ -102,7 +103,8 @@
G_debug(3, "db_close_database()");
init_error();
- sqlite3_close(sqlite);
+ if (sqlite3_close(sqlite) == SQLITE_BUSY)
+ G_fatal_error(_("SQLite database connection is still busy"));
return DB_OK;
Modified: grass/branches/develbranch_6/db/drivers/sqlite/describe.c
--- grass/branches/develbranch_6/db/drivers/sqlite/describe.c 2011-09-06 06:41:44 UTC (rev 48156)
+++ grass/branches/develbranch_6/db/drivers/sqlite/describe.c 2011-09-06 06:43:03 UTC (rev 48157)
@@ -8,8 +8,9 @@
- * \date 2005-2007
+ * \date 2005-2011
#include <string.h>
@@ -49,6 +50,9 @@
db_append_string(&sql, " where oid < 0");
append_error("Error in sqlite3_prepare():");
@@ -90,7 +94,7 @@
int describe_table(sqlite3_stmt * statement, dbTable ** table, cursor * c)
- int i, ncols, nkcols;
+ int i, ncols, nkcols, ret;
G_debug(3, "describe_table()");
@@ -98,7 +102,10 @@
G_debug(3, "ncols = %d", ncols);
/* Try to get first row */
- sqlite3_step(statement);
+ ret = sqlite3_step(statement);
/* Count columns of known type */
nkcols = 0;
@@ -442,5 +449,6 @@
#undef streq
G_warning("SQLite driver: unable to parse decltype: %s", declared);
return DB_SQL_TYPE_UNKNOWN;
Modified: grass/branches/develbranch_6/db/drivers/sqlite/driver.c
--- grass/branches/develbranch_6/db/drivers/sqlite/driver.c 2011-09-06 06:41:44 UTC (rev 48156)
+++ grass/branches/develbranch_6/db/drivers/sqlite/driver.c 2011-09-06 06:43:03 UTC (rev 48157)
@@ -3,9 +3,9 @@
@@ -19,6 +19,7 @@
int db__driver_init(int argc, char *argv[])
init_error();
return DB_OK;
Modified: grass/branches/develbranch_6/db/drivers/sqlite/error.c
--- grass/branches/develbranch_6/db/drivers/sqlite/error.c 2011-09-06 06:41:44 UTC (rev 48156)
+++ grass/branches/develbranch_6/db/drivers/sqlite/error.c 2011-09-06 06:43:03 UTC (rev 48157)
@@ -3,9 +3,9 @@
Modified: grass/branches/develbranch_6/db/drivers/sqlite/execute.c
--- grass/branches/develbranch_6/db/drivers/sqlite/execute.c 2011-09-06 06:41:44 UTC (rev 48156)
+++ grass/branches/develbranch_6/db/drivers/sqlite/execute.c 2011-09-06 06:43:03 UTC (rev 48157)
@@ -9,8 +9,9 @@
* \author Antonio Galea
- * \date 2005-2007
+ * \date 2005-2011
#include <stdlib.h>
@@ -41,6 +42,9 @@
G_debug(3, "execute: %s", s);
ret = sqlite3_prepare(sqlite, s, -1, &stmt, &rest);
append_error("Error in sqlite3_prepare():\n");
@@ -50,6 +54,7 @@
ret = sqlite3_step(stmt);
+ /* check if sqlite is still busy preparing the statement? */
if (ret != SQLITE_DONE) {
append_error("Error in sqlite3_step():\n");
@@ -91,6 +96,9 @@
G_debug(3, "execute: BEGIN");
ret = sqlite3_exec(sqlite, "BEGIN", NULL, NULL, NULL);
append_error("Cannot 'BEGIN' transaction:\n");
append_error((char *)sqlite3_errmsg(sqlite));
@@ -117,6 +125,9 @@
G_debug(3, "execute: COMMIT");
ret = sqlite3_exec(sqlite, "COMMIT", NULL, NULL, NULL);
append_error("Cannot 'COMMIT' transaction:\n");
Modified: grass/branches/develbranch_6/db/drivers/sqlite/fetch.c
--- grass/branches/develbranch_6/db/drivers/sqlite/fetch.c 2011-09-06 06:41:44 UTC (rev 48156)
+++ grass/branches/develbranch_6/db/drivers/sqlite/fetch.c 2011-09-06 06:43:03 UTC (rev 48157)
@@ -8,8 +8,9 @@
- * \date 2005-2007
+ * \date 2005-2011
#include <stdlib.h>
@@ -63,6 +64,9 @@
c->row = -1;
ret = sqlite3_step(c->statement);
if (ret != SQLITE_ROW) {
append_error("Cannot step:\n");
@@ -248,7 +252,7 @@
cursor *c;
dbToken token;
- int row;
+ int row, ret;
/* get cursor token */
token = db_get_cursor_token(cn);
@@ -264,14 +268,17 @@
return (c->nrows);
- sqlite3_reset(c->statement);
+ ret = sqlite3_reset(c->statement);
c->nrows = 0;
while (sqlite3_step(c->statement) == SQLITE_ROW) {
c->nrows++;
/* Reset cursor position */
row = -1;
Modified: grass/branches/develbranch_6/db/drivers/sqlite/index.c
--- grass/branches/develbranch_6/db/drivers/sqlite/index.c 2011-09-06 06:41:44 UTC (rev 48156)
+++ grass/branches/develbranch_6/db/drivers/sqlite/index.c 2011-09-06 06:43:03 UTC (rev 48157)
@@ -8,8 +8,9 @@
- * \date 2005-2007
+ * \date 2005-2011
@@ -65,6 +66,9 @@
append_error("Cannot create index:\n");
@@ -86,6 +90,7 @@
return DB_FAILED;
+ sqlite3_reset(statement);
sqlite3_finalize(statement);
db_free_string(&sql);
Modified: grass/branches/develbranch_6/db/drivers/sqlite/listtab.c
--- grass/branches/develbranch_6/db/drivers/sqlite/listtab.c 2011-09-06 06:41:44 UTC (rev 48156)
+++ grass/branches/develbranch_6/db/drivers/sqlite/listtab.c 2011-09-06 06:43:03 UTC (rev 48157)
@@ -8,8 +8,9 @@
- * \date 2005-2007
+ * \date 2005-2011
#include <stdlib.h>
@@ -44,6 +45,10 @@
"select name from sqlite_master where type = 'table' or type = 'view'",
append_error("Cannot list tables\n");
Modified: grass/branches/develbranch_6/db/drivers/sqlite/main.c
--- grass/branches/develbranch_6/db/drivers/sqlite/main.c 2011-09-06 06:41:44 UTC (rev 48156)
+++ grass/branches/develbranch_6/db/drivers/sqlite/main.c 2011-09-06 06:43:03 UTC (rev 48157)
@@ -3,9 +3,9 @@
@@ -14,6 +14,7 @@
#include <stdlib.h>
+#include <time.h>
#include "globals.h"
#include "dbdriver.h"
@@ -25,3 +26,27 @@
init_dbdriver();
exit(db_driver(argc, argv));
+int sqlite_busy_callback(void *arg, int n_calls)
+ static time_t start_time = 0;
+ time_t curr_time;
+ int min;
+ static int last_min = 0;
+ /* do something here while waiting? */
+ if (n_calls > 0) {
+ time(&curr_time);
+ min = (curr_time - start_time) / 60;
+ if (min > 1 && min > last_min) {
+ last_min = min;
+ G_debug(3, "Already waiting for %d minutes...", min);
+ else {
+ time(&start_time);
+ last_min = 0;
+ return 1;
Modified: grass/branches/develbranch_6/db/drivers/sqlite/proto.h
--- grass/branches/develbranch_6/db/drivers/sqlite/proto.h 2011-09-06 06:41:44 UTC (rev 48156)
+++ grass/branches/develbranch_6/db/drivers/sqlite/proto.h 2011-09-06 06:43:03 UTC (rev 48157)
@@ -15,4 +15,7 @@
/* describe.c */
int describe_table(sqlite3_stmt *, dbTable **, cursor *);
+/* main.c */
+int sqlite_busy_callback(void *, int);
#endif /* __SQLITE_PROTO_H__ */
Modified: grass/branches/develbranch_6/db/drivers/sqlite/select.c
--- grass/branches/develbranch_6/db/drivers/sqlite/select.c 2011-09-06 06:41:44 UTC (rev 48156)
+++ grass/branches/develbranch_6/db/drivers/sqlite/select.c 2011-09-06 06:43:03 UTC (rev 48157)
@@ -8,8 +8,9 @@
- * \date 2005-2007
+ * \date 2005-2011
#include <stdlib.h>
@@ -53,6 +54,9 @@
G_debug(3, "Escaped SQL: %s", str);
ret = sqlite3_prepare(sqlite, str, -1, &(c->statement), &rest);
if (str)
G_free(str);
