[GRASS-SVN] r48187 - grass/trunk/lib/temporal
Wed Sep 7 12:21:32 EDT 2011
Author: huhabla
Date: 2011-09-07 09:21:32 -0700 (Wed, 07 Sep 2011)
New Revision: 48187
   grass/trunk/lib/temporal/stds_map_register_table_template.sql
   grass/trunk/lib/temporal/str3ds_metadata_table.sql
   grass/trunk/lib/temporal/strds_metadata_table.sql
   grass/trunk/lib/temporal/stvds_metadata_table.sql
   grass/trunk/lib/temporal/test.temporal.py
More tests, SQL trigger bugfixing and variable renaming.
Modified: grass/trunk/lib/temporal/stds_map_register_table_template.sql
--- grass/trunk/lib/temporal/stds_map_register_table_template.sql	2011-09-07 16:20:32 UTC (rev 48186)
+++ grass/trunk/lib/temporal/stds_map_register_table_template.sql	2011-09-07 16:21:32 UTC (rev 48187)
@@ -26,8 +26,8 @@
     UPDATE STDS_base SET modification_time = datetime("NOW") WHERE id = "SPACETIME_ID";
     UPDATE STDS_base SET revision = (revision + 1) WHERE id = "SPACETIME_ID";
     -- Number of registered maps
-    UPDATE STDS_metadata SET number_of_registered_maps =
-           (SELECT count.id) FROM  SPACETIME_NAME_GRASS_MAP_register)
+    UPDATE STDS_metadata SET number_of_maps =
+           (SELECT count(id) FROM SPACETIME_NAME_GRASS_MAP_register)
     -- Update the temporal extent
     UPDATE STDS_absolute_time SET start_time =
@@ -70,8 +70,8 @@
Modified: grass/trunk/lib/temporal/str3ds_metadata_table.sql
--- grass/trunk/lib/temporal/str3ds_metadata_table.sql	2011-09-07 16:20:32 UTC (rev 48186)
+++ grass/trunk/lib/temporal/str3ds_metadata_table.sql	2011-09-07 16:21:32 UTC (rev 48187)
@@ -8,21 +8,21 @@
 PRAGMA foreign_keys = ON;
 CREATE TABLE  str3ds_metadata (
-  id VARCHAR NOT NULL,               -- Id of the space-time raster3d dataset, this is the primary foreign key
-  raster3d_register VARCHAR,         -- The id of the table in which the raster3d maps are registered for this dataset
-  number_of_registered_maps INTEGER, -- The number of registered raster3d maps
-  max_min DOUBLE PRECISION,          -- The minimal maximum of the registered raster3d maps
-  min_min DOUBLE PRECISION,          -- The minimal minimum of the registered raster3d maps
-  max_max DOUBLE PRECISION,          -- The maximal maximum of the registered raster3d maps
-  min_max DOUBLE PRECISION,          -- The maximal minimum of the registered raster3d maps
-  nsres_min DOUBLE PRECISION,        -- The lowest north-south resolution of the registered raster3d maps
-  nsres_max DOUBLE PRECISION,        -- The highest north-south resolution of the registered raster3d maps
-  ewres_min DOUBLE PRECISION,        -- The lowest east-west resolution of the registered raster3d maps
-  ewres_max DOUBLE PRECISION,        -- The highest east-west resolution of the registered raster3d maps
-  tbres_min DOUBLE PRECISION,        -- The lowest top-bottom resolution of the registered raster3d maps
-  tbres_max DOUBLE PRECISION,        -- The highest top-bottom resolution of the registered raster3d maps
-  title VARCHAR,                     -- Title of the space-time raster3d dataset
-  description VARCHAR,               -- Detailed description of the space-time raster3d dataset
+  id VARCHAR NOT NULL,          -- Id of the space-time raster3d dataset, this is the primary foreign key
+  raster3d_register VARCHAR,    -- The id of the table in which the raster3d maps are registered for this dataset
+  number_of_maps INTEGER,       -- The number of registered raster3d maps
+  max_min DOUBLE PRECISION,     -- The minimal maximum of the registered raster3d maps
+  min_min DOUBLE PRECISION,     -- The minimal minimum of the registered raster3d maps
+  max_max DOUBLE PRECISION,     -- The maximal maximum of the registered raster3d maps
+  min_max DOUBLE PRECISION,     -- The maximal minimum of the registered raster3d maps
+  nsres_min DOUBLE PRECISION,   -- The lowest north-south resolution of the registered raster3d maps
+  nsres_max DOUBLE PRECISION,   -- The highest north-south resolution of the registered raster3d maps
+  ewres_min DOUBLE PRECISION,   -- The lowest east-west resolution of the registered raster3d maps
+  ewres_max DOUBLE PRECISION,   -- The highest east-west resolution of the registered raster3d maps
+  tbres_min DOUBLE PRECISION,   -- The lowest top-bottom resolution of the registered raster3d maps
+  tbres_max DOUBLE PRECISION,   -- The highest top-bottom resolution of the registered raster3d maps
+  title VARCHAR,                -- Title of the space-time raster3d dataset
+  description VARCHAR,          -- Detailed description of the space-time raster3d dataset
   PRIMARY KEY (id),
   FOREIGN KEY (id) REFERENCES  str3ds_base (id) ON DELETE CASCADE
@@ -36,7 +36,7 @@
 	    A2.end_time, A2.granularity,
 	    A3.north, A3.south, A3.east, A3.west,
 	    A4.raster3d_register,
-	    A4.number_of_registered_maps,
+	    A4.number_of_maps,
             A4.nsres_min, A4.ewres_min,
             A4.nsres_max, A4.ewres_max,
             A4.tbres_min, A4.tbres_max,
@@ -55,7 +55,7 @@
 	    A2.interval, A2.granularity,
Modified: grass/trunk/lib/temporal/strds_metadata_table.sql
--- grass/trunk/lib/temporal/strds_metadata_table.sql	2011-09-07 16:20:32 UTC (rev 48186)
+++ grass/trunk/lib/temporal/strds_metadata_table.sql	2011-09-07 16:21:32 UTC (rev 48187)
@@ -8,19 +8,19 @@
 CREATE TABLE  strds_metadata (
-  id VARCHAR NOT NULL,            -- Id of the space-time dataset, this is the primary foreign key
-  raster_register VARCHAR,                    -- The id of the table in which the raster maps are registered for this dataset
-  number_of_registered_maps INTEGER,          -- The number of registered raster maps
-  max_min DOUBLE PRECISION,                   -- The minimal maximum of the registered raster maps
-  min_min DOUBLE PRECISION,                   -- The minimal minimum of the registered raster maps
-  max_max DOUBLE PRECISION,                   -- The maximal maximum of the registered raster maps
-  min_max DOUBLE PRECISION,                   -- The maximal minimum of the registered raster maps
-  nsres_min DOUBLE PRECISION,                 -- The lowest north-south resolution of the registered raster maps
-  nsres_max DOUBLE PRECISION,                 -- The highest north-south resolution of the registered raster maps
-  ewres_min DOUBLE PRECISION,                 -- The lowest east-west resolution of the registered raster maps
-  ewres_max DOUBLE PRECISION,                 -- The highest east-west resolution of the registered raster maps
-  title VARCHAR,                              -- Title of the space-time raster dataset
-  description VARCHAR,                        -- Detailed description of the space-time raster dataset
+  id VARCHAR NOT NULL,          -- Id of the space-time dataset, this is the primary foreign key
+  raster_register VARCHAR,      -- The id of the table in which the raster maps are registered for this dataset
+  number_of_maps INTEGER,       -- The number of registered raster maps
+  max_min DOUBLE PRECISION,     -- The minimal maximum of the registered raster maps
+  min_min DOUBLE PRECISION,     -- The minimal minimum of the registered raster maps
+  max_max DOUBLE PRECISION,     -- The maximal maximum of the registered raster maps
+  min_max DOUBLE PRECISION,     -- The maximal minimum of the registered raster maps
+  nsres_min DOUBLE PRECISION,   -- The lowest north-south resolution of the registered raster maps
+  nsres_max DOUBLE PRECISION,   -- The highest north-south resolution of the registered raster maps
+  ewres_min DOUBLE PRECISION,   -- The lowest east-west resolution of the registered raster maps
+  ewres_max DOUBLE PRECISION,   -- The highest east-west resolution of the registered raster maps
+  title VARCHAR,                -- Title of the space-time raster dataset
+  description VARCHAR,          -- Detailed description of the space-time raster dataset
   PRIMARY KEY (id),
   FOREIGN KEY (id) REFERENCES  strds_base (id) ON DELETE CASCADE
@@ -34,7 +34,7 @@
 	    A4.raster_register,
 	    A4.min_min, A4.min_max,
@@ -52,7 +52,7 @@
 	    A4.raster_register,
Modified: grass/trunk/lib/temporal/stvds_metadata_table.sql
--- grass/trunk/lib/temporal/stvds_metadata_table.sql	2011-09-07 16:20:32 UTC (rev 48186)
+++ grass/trunk/lib/temporal/stvds_metadata_table.sql	2011-09-07 16:21:32 UTC (rev 48187)
@@ -10,7 +10,7 @@
 CREATE TABLE  stvds_metadata (
   id VARCHAR NOT NULL,                -- Name of the space-time vector dataset, this is the primary foreign key
   vector_register VARCHAR,                    -- The id of the table in which the vector maps are registered for this dataset
-  number_of_registered_maps INTEGER,          -- The number of registered vector maps
+  number_of_maps INTEGER,          -- The number of registered vector maps
   title VARCHAR,                              -- Title of the space-time vector dataset
   description VARCHAR,                        -- Detailed description of the space-time vector dataset
   PRIMARY KEY (id),
@@ -26,7 +26,7 @@
 	    A4.vector_register,
             A4.title, A4.description
 	    FROM stvds_base A1, stvds_absolute_time A2,
             stvds_spatial_extent A3, stvds_metadata A4 WHERE A1.id = A2.id AND
@@ -40,7 +40,7 @@
 	    A4.vector_register,
 	    FROM stvds_base A1, stvds_relative_time A2,
Modified: grass/trunk/lib/temporal/test.temporal.py
--- grass/trunk/lib/temporal/test.temporal.py	2011-09-07 16:20:32 UTC (rev 48186)
+++ grass/trunk/lib/temporal/test.temporal.py	2011-09-07 16:21:32 UTC (rev 48187)
@@ -278,7 +278,7 @@
 def test_map_metadata():
 	for i in range(2):
-	    base = raster_metadata(ident="soil" + str(i) + "@PERMANENT", strds_register="PERMANENT_soil_strds-register", datatype="CELL", \
+	    base = raster_metadata(ident="soil" + str(i) + "@PERMANENT", strds_register="PERMANENT_soil_strds_register", datatype="CELL", \
 			    cols=500, rows=400, number_of_cells=200000,nsres=1, ewres=1, min=0, max=33)
 	    base.insert()
 	    base.select()
@@ -290,7 +290,7 @@
 	    base.print_self()
 	for i in range(2):
-	    base = raster3d_metadata(ident="soil" + str(i) + "@PERMANENT", str3ds_register="PERMANENT_soil_str3ds-register", datatype="FCELL", \
+	    base = raster3d_metadata(ident="soil" + str(i) + "@PERMANENT", str3ds_register="PERMANENT_soil_str3ds_register", datatype="FCELL", \
 			    cols=500, rows=400, depths=20, number_of_cells=200000,nsres=1, ewres=1, tbres=10, min=0, max=33)
 	    base.insert()
 	    base.select()
@@ -311,7 +311,43 @@
 	    base.update()
 	    base.select()
 	    base.print_self()
+	for i in range(2):
+	    base = strds_metadata(ident="soil" + str(i) + "@PERMANENT", raster_register="PERMANENT_soil_raster_register", \
+                                   title="Test", description="Test description")
+	    base.insert()
+	    base.select()
+	    base.print_self()
+	    base.clear()
+	    base.set_title("More tests")
+	    base.update()
+	    base.select()
+	    base.print_self()
+	    base = str3ds_metadata(ident="soil" + str(i) + "@PERMANENT", raster3d_register="PERMANENT_soil_raster3d_register", \
+	    base.insert()
+	    base.select()
+	    base.print_self()
+	    base.clear()
+	    base.update()
+	    base.select()
+	    base.print_self()
+	    base = stvds_metadata(ident="soil" + str(i) + "@PERMANENT", vector_register="PERMANENT_soil_vector_register", \
+	    base.insert()
+	    base.select()
+	    base.print_self()
+	    base.clear()
+	    base.update()
+	    base.select()
+	    base.print_self()
 def test_base_absolute_time_extent_metadata():
 	for i in range(10):
@@ -476,6 +512,7 @@
 def test_raster_dataset():
+    # Create a test map
     grass.raster.mapcalc("test = sin(x()) + cos(y())", overwrite = True)
     name = "test"
@@ -483,54 +520,64 @@
     print "Create a raster object"
+    # We need to specify the name and the mapset as identifier
     rds = raster_dataset(name + "@" + mapset)
+    # Load data from the raster map in the mapset
     rds.load()
     print "Is in db: ", rds.is_in_db()
-    rds.base.set_ttype("absolue")
-    rds.absolute_time.set_start_time(datetime(year=2000, month=1, day=1))
-    rds.absolute_time.set_end_time(datetime(year=2010, month=1, day=1))
+    if rds.is_in_db():
+        # Remove the entry if it is in the db
+        rds.delete()
-    # Remove the entry if it is in the db
-    rds.delete()
+    # Set the absolute valid time
+    rds.set_absolute_time(start_time= datetime(year=2000, month=1, day=1), \
+                            end_time= datetime(year=2010, month=1, day=1))
+    # Insert the map data into the SQL database
     rds.insert()
+    # Print self info
     rds.print_self()
+    # The temporal relation must be equal
     print rds.temporal_relation(rds)
 def test_raster3d_dataset():
     grass.raster3d.mapcalc3d("test = sin(x()) + cos(y()) + sin(z())", overwrite = True)
     name = "test"
     mapset =  grass.gisenv()["MAPSET"]
-    print "Create a raster3d object"
+    print "Create a raster object"
     r3ds = raster3d_dataset(name + "@" + mapset)
     r3ds.load()
     print "Is in db: ", r3ds.is_in_db()
-    r3ds.print_self()
-    r3ds.base.set_ttype("absolue")
-    r3ds.absolute_time.set_start_time(datetime(year=2000, month=1, day=1))
-    r3ds.absolute_time.set_end_time(datetime(year=2010, month=1, day=1))
+    if r3ds.is_in_db():
+        r3ds.delete()
-    r3ds.delete()
+    r3ds.set_absolute_time(start_time= datetime(year=2000, month=1, day=1), \
     r3ds.insert()
+    # Print self info
     r3ds.print_self()
     print r3ds.temporal_relation(r3ds)
 def test_vector_dataset():
     grass.run_command("v.random", output="test", n=20, column="height", zmin=0, \
                       zmax=100, flags="z", overwrite = True)
@@ -539,34 +586,103 @@
     print "Create a vector object"
     vds = vector_dataset(name + "@" + mapset)
     vds.load()
     print "Is in db: ", vds.is_in_db()
-    vds.print_self()
-    vds.base.set_ttype("absolue")
-    vds.absolute_time.set_start_time(datetime(year=2000, month=1, day=1))
-    vds.absolute_time.set_end_time(datetime(year=2010, month=1, day=1))
+    if vds.is_in_db():
+        vds.delete()
-    vds.delete()
+    vds.set_absolute_time(start_time= datetime(year=2000, month=1, day=1), \
     vds.insert()
+    # Print self info
     vds.print_self()
     print vds.temporal_relation(vds)
+def test_strds_dataset():
+    name = "strds_test_1"
+    mapset =  grass.gisenv()["MAPSET"]
+    print "Create a strds object"
+    strds = space_time_raster_dataset(ident = name + "@" + mapset)
+    # Check if in db
+    print "Is strds in db: ", strds.is_in_db()
+    # Create a new entry if not in db
+    if strds.is_in_db() == False:
+        strds.set_initial_values(temporal_type = "absolute", granularity="1 day",\
+        semantic_type="event", title="This is a test space time raster dataset", description="A space time raster dataset for testing")
+        strds.insert()
+    # Reread the data from the db
+    strds.select()
+    # Print self info
+    strds.print_self()
+    # Create a test maps
+    for i in range(11):
+        i = i + 1
+        grass.raster.mapcalc("test" + str(i) + " = sin(x()) + cos(y())", overwrite = True)
+        name = "test" + str(i)
+        ident = name + "@" + mapset
+        rds = raster_dataset(ident)
+        rds.load()
+        print "Is raster in db: ", rds.is_in_db()
+            rds.select()
+            rds.print_self()
+            rds.delete()
+            rds.reset(ident)
+            rds.load()
+        rds.set_absolute_time(start_time= datetime(year=2000, month=i, day=1), \
+                                end_time= datetime(year=2000, month=i + 1, day=1))
+        rds.insert()
+        # Register the map in the space time raster dataset
+        strds.register_map(rds)
+        # Print self info
+        rds.print_self()
+    strds.select()
+    # Print self info
 #test_dict_sql_serializer()
 create_temporal_database()
-test_dataset_identifer()
-test_absolute_timestamp()
-test_relative_timestamp()
-test_spatial_extent()
+#test_dataset_identifer()
+#test_absolute_timestamp()
+#test_relative_timestamp()
+#test_spatial_extent()
 #test_map_metadata()
 #test_base_absolute_time_extent_metadata()
 #test_absolut_time_temporal_relations()
 #test_raster_dataset()
 #test_raster3d_dataset()
-#test_vector_dataset()
\ No newline at end of file
+#test_vector_dataset()
+test_strds_dataset()
