[GRASS-SVN] r48219 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Thu Sep 8 17:58:48 EDT 2011
Author: cmbarton
Date: 2011-09-08 14:58:48 -0700 (Thu, 08 Sep 2011)
New Revision: 48219
grass/trunk/gui/wxpython/gui_modules/psmap_dialogs.py
Bug fixes and enhancements to color management
Modified: grass/trunk/gui/wxpython/gui_modules/psmap_dialogs.py
--- grass/trunk/gui/wxpython/gui_modules/psmap_dialogs.py 2011-09-08 13:50:19 UTC (rev 48218)
+++ grass/trunk/gui/wxpython/gui_modules/psmap_dialogs.py 2011-09-08 21:58:48 UTC (rev 48219)
@@ -2644,7 +2644,7 @@
self.btnDel = wx.Button(self, id = wx.ID_ANY, label = _("Delete"))
self.btnProp = wx.Button(self, id = wx.ID_ANY, label = _("Properties..."))
- self.updateListBox(selected = 0)
+ self.updateListBox(selected=0)
gridBagSizer.Add(text, pos = (0,0), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
@@ -4579,17 +4579,14 @@
self.panel = self._mapinfoPanel()
self._layout(self.panel)
- self.OnIsBackground(None)
- self.OnIsBorder(None)
+# self.OnIsBackground(None)
+# self.OnIsBorder(None)
def _mapinfoPanel(self):
panel = wx.Panel(parent = self, id = wx.ID_ANY, size = (-1, -1), style = wx.TAB_TRAVERSAL)
#panel.SetupScrolling(scroll_x = False, scroll_y = True)
border = wx.BoxSizer(wx.VERTICAL)
# position
box = wx.StaticBox (parent = panel, id = wx.ID_ANY, label = " %s " % _("Position"))
@@ -4645,29 +4642,24 @@
self.colors['borderColor'] = wx.ColourPickerCtrl(panel, id = wx.ID_ANY)
self.colors['backgroundColor'] = wx.ColourPickerCtrl(panel, id = wx.ID_ANY)
- if self.mapinfoDict['border'] != 'none':
+ if self.mapinfoDict['border'] == None:
+ self.mapinfoDict['border'] = 'none'
+ elif self.mapinfoDict['border'] != 'none':
self.colors['borderCtrl'].SetValue(True)
+ self.colors['borderColor'].SetColour(convertRGB(self.mapinfoDict['border']))
else:
self.colors['borderCtrl'].SetValue(False)
+ self.colors['borderColor'].SetColour('white')
- if self.mapinfoDict['background'] != 'none':
+ if self.mapinfoDict['background'] == None:
+ self.mapinfoDict['background'] == 'none'
+ elif self.mapinfoDict['background'] != 'none':
self.colors['backgroundCtrl'].SetValue(True)
+ self.colors['backgroundColor'].SetColour(convertRGB(self.mapinfoDict['background']))
else:
self.colors['backgroundCtrl'].SetValue(False)
+ self.colors['backgroundColor'].SetColour('white')
- self.colors['borderColor'].SetColour(convertRGB(self.mapinfoDict['border']))
- else:
- self.colors['borderColor'].SetColour('black')
- self.colors['backgroundColor'].SetColour(convertRGB(self.mapinfoDict['background']))
- else:
- self.colors['backgroundColor'].SetColour('black')
flexSizer.Add(self.colors['borderCtrl'], proportion = 0, flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
flexSizer.Add(self.colors['borderColor'], proportion = 0, flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
flexSizer.Add(self.colors['backgroundCtrl'], proportion = 0, flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
@@ -4687,12 +4679,14 @@
def OnIsBackground(self, event):
if self.colors['backgroundCtrl'].GetValue():
self.colors['backgroundColor'].Enable()
+ self.update()
else:
self.colors['backgroundColor'].Disable()
def OnIsBorder(self, event):
if self.colors['borderCtrl'].GetValue():
self.colors['borderColor'].Enable()
+ self.update()
else:
self.colors['borderColor'].Disable()
@@ -5352,6 +5346,7 @@
def OnBackground(self, event):
if self.effect['backgroundCtrl'].GetValue():
self.effect['backgroundColor'].Enable()
+ self.update()
else:
self.effect['backgroundColor'].Disable()
@@ -5360,6 +5355,7 @@
self.effect['highlightColor'].Enable()
self.effect['highlightWidth'].Enable()
self.effect['highlightWidthLabel'].Enable()
+ self.update()
else:
self.effect['highlightColor'].Disable()
self.effect['highlightWidth'].Disable()
@@ -5370,6 +5366,7 @@
self.effect['borderColor'].Enable()
self.effect['borderWidth'].Enable()
self.effect['borderWidthLabel'].Enable()
+ self.update()
else:
self.effect['borderColor'].Disable()
self.effect['borderWidth'].Disable()
@@ -5489,43 +5486,27 @@
def convertRGB(rgb):
- """!Converts wx.Colour(255,255,255,255) and string '255:255:255',
- depends on input"""
- psmapColors = { "white" : (1.00, 1.00, 1.00),
- "black" : (0.00, 0.00, 0.00),
- "red" : (1.00, 0.00, 0.00),
- "green" : (0.00, 1.00, 0.00),
- "blue" : (0.00, 0.00, 1.00),
- "yellow" : (1.00, 1.00, 0.00),
- "magenta" : (1.00, 0.00, 1.00),
- "cyan" : (0.00, 1.00, 1.00),
- "aqua" : (0.00, 0.75, 0.75),
- "grey" : (0.75, 0.75, 0.75),
- "gray" : (0.75, 0.75, 0.75),
- "orange" : (1.00, 0.50, 0.00),
- "brown" : (0.75, 0.50, 0.25),
- "purple" : (0.50, 0.00, 1.00),
- "violet" : (0.50, 0.00, 1.00),
- "indigo" : (0.00, 0.50, 1.00)}
+ """!Converts wx.Colour(r,g,b,a) to string 'r:g:b' or named color,
+ or named color/r:g:b string to wx.Colour, depending on input"""
+ # transform a wx.Colour tuple into an r:g:b string
if type(rgb) == wx.Colour:
- for name, color in psmapColors.items():
+ for name, color in grass.named_colors.items():
if rgb.Red() == int(color[0] * 255) and\
rgb.Green() == int(color[1] * 255) and\
rgb.Blue() == int(color[2] * 255):
return name
return str(rgb.Red()) + ':' + str(rgb.Green()) + ':' + str(rgb.Blue())
- elif type(rgb) == str or type(rgb) == unicode:
- if ':' in rgb:
- return wx.Colour(*map(int, rgb.split(':')))
- else:
- color = map(lambda x: int(x * 255), psmapColors[rgb])
- color = wx.Color(*color)
- if color.IsOk():
- return color
+ # transform a GRASS named color or an r:g:b string into a wx.Colour tuple
+ else:
+ color = (grass.parse_color(rgb)[0]*255,
+ grass.parse_color(rgb)[1]*255,
+ grass.parse_color(rgb)[2]*255)
+ color = wx.Color(*color)
+ if color.IsOk():
+ return color
+ else:
return None
def PaperMapCoordinates(map, x, y, paperToMap = True):
"""!Converts paper (inch) coordinates -> map coordinates"""
unitConv = UnitConversion()
