[GRASS-SVN] r48247 - grass/trunk/lib/init
Mon Sep 12 08:00:39 EDT 2011
Author: martinl
Date: 2011-09-12 05:00:38 -0700 (Mon, 12 Sep 2011)
New Revision: 48247
Added:
   grass/trunk/lib/init/prompt.py
   grass/trunk/lib/init/Makefile
   grass/trunk/lib/init/grass.py
introduce prompt.py (check for mask)
Modified: grass/trunk/lib/init/Makefile
--- grass/trunk/lib/init/Makefile	2011-09-12 08:43:58 UTC (rev 48246)
+++ grass/trunk/lib/init/Makefile	2011-09-12 12:00:38 UTC (rev 48247)
@@ -27,6 +27,7 @@
 	$(ETC)/license \
 	$(ETC)/welcome \
 	$(ETC)/VERSIONNUMBER \
+	$(ETC)/prompt.py \
 	$(HTMLDIR)/variables.html \
 	$(HTMLDIR)/grass7.html \
 	$(HTMLDIR)/helptext.html \
Modified: grass/trunk/lib/init/grass.py
--- grass/trunk/lib/init/grass.py	2011-09-12 08:43:58 UTC (rev 48246)
+++ grass/trunk/lib/init/grass.py	2011-09-12 12:00:38 UTC (rev 48247)
@@ -810,6 +810,7 @@
     f = open(bashrc, 'w')
     f.write("test -r ~/.alias && . ~/.alias\n")
     f.write("PS1='GRASS %s (%s@%s):\w > '\n" % (grass_version, location_name, mapset))
+    f.write("PROMPT_COMMAND=\"'%s'\"\n" % os.path.join(gisbase, 'etc', 'prompt.py'))
     path = os.path.join(userhome, ".grass.bashrc")
     if os.access(path, os.R_OK):
Added: grass/trunk/lib/init/prompt.py
--- grass/trunk/lib/init/prompt.py	                        (rev 0)
+++ grass/trunk/lib/init/prompt.py	2011-09-12 12:00:38 UTC (rev 48247)
@@ -0,0 +1,29 @@
+#!/usr/bin/env python
+import os
+import sys
+from grass.script import core as grass
+gisenv = grass.gisenv()
+import gettext
+gettext.install('grasslibs', os.path.join(gisenv['GISDBASE'], 'locale'), unicode = True)
+location = os.path.join(gisenv['GISDBASE'], gisenv['LOCATION_NAME'], gisenv['MAPSET'])
+has_mask   = os.path.isfile(os.path.join(location, 'cell', 'MASK'))
+has_mask3d = os.path.isdir(os.path.join(location, 'grid3', 'G3D_MASK'))
+def main():
+    if has_mask and has_mask3d:
+        grass.info(_("[Raster and Volume MASKs present]"))
+    elif has_mask:
+        grass.info(_("[Raster MASK present]"))
+    elif has_mask3d:
+        grass.info(_("[Volume MASK present]"))
+    return 0
+if __name__ == "__main__":
+    sys.exit(main())
Property changes on: grass/trunk/lib/init/prompt.py
___________________________________________________________________
Added: svn:mime-type
   + text/x-python
Added: svn:eol-style
   + native
