[GRASS-SVN] r48253 - grass/trunk/tools
svn_grass at osgeo.org
Mon Sep 12 16:39:36 EDT 2011
Author: neteler
Date: 2011-09-12 13:39:36 -0700 (Mon, 12 Sep 2011)
New Revision: 48253
Added:
grass/trunk/tools/reindent.py
Python indentation tool from http://svn.python.org/view/python/trunk/Tools/scripts/reindent.py
Added: grass/trunk/tools/reindent.py
--- grass/trunk/tools/reindent.py (rev 0)
+++ grass/trunk/tools/reindent.py 2011-09-12 20:39:36 UTC (rev 48253)
@@ -0,0 +1,306 @@
+#! /usr/bin/env python
+# FROM http://svn.python.org/view/python/trunk/Tools/scripts/reindent.py
+# Released to the public domain, by Tim Peters, 03 October 2000.
+"""reindent [-d][-r][-v] [ path ... ]
+-d (--dryrun) Dry run. Analyze, but don't make any changes to, files.
+-r (--recurse) Recurse. Search for all .py files in subdirectories too.
+-n (--nobackup) No backup. Does not make a ".bak" file before reindenting.
+-v (--verbose) Verbose. Print informative msgs; else no output.
+-h (--help) Help. Print this usage information and exit.
+Change Python (.py) files to use 4-space indents and no hard tab characters.
+Also trim excess spaces and tabs from ends of lines, and remove empty lines
+at the end of files. Also ensure the last line ends with a newline.
+If no paths are given on the command line, reindent operates as a filter,
+reading a single source file from standard input and writing the transformed
+source to standard output. In this case, the -d, -r and -v flags are
+ignored.
+You can pass one or more file and/or directory paths. When a directory
+path, all .py files within the directory will be examined, and, if the -r
+option is given, likewise recursively for subdirectories.
+If output is not to standard output, reindent overwrites files in place,
+renaming the originals with a .bak extension. If it finds nothing to
+change, the file is left alone. If reindent does change a file, the changed
+file is a fixed-point for future runs (i.e., running reindent on the
+resulting .py file won't change it again).
+The hard part of reindenting is figuring out what to do with comment
+lines. So long as the input files get a clean bill of health from
+tabnanny.py, reindent should do a good job.
+The backup file is a copy of the one that is being reindented. The ".bak"
+file is generated with shutil.copy(), but some corner cases regarding
+user/group and permissions could leave the backup file more readable that
+you'd prefer. You can always use the --nobackup option to prevent this.
+__version__ = "1"
+import tokenize
+import os, shutil
+import sys
+verbose = 0
+recurse = 0
+dryrun = 0
+makebackup = True
+def usage(msg=None):
+ if msg is not None:
+ print >> sys.stderr, msg
+ print >> sys.stderr, __doc__
+def errprint(*args):
+ sep = ""
+ for arg in args:
+ sys.stderr.write(sep + str(arg))
+ sep = " "
+ sys.stderr.write("\n")
+def main():
+ import getopt
+ global verbose, recurse, dryrun, makebackup
+ try:
+ opts, args = getopt.getopt(sys.argv[1:], "drnvh",
+ ["dryrun", "recurse", "nobackup", "verbose", "help"])
+ except getopt.error, msg:
+ usage(msg)
+ return
+ for o, a in opts:
+ if o in ('-d', '--dryrun'):
+ dryrun += 1
+ elif o in ('-r', '--recurse'):
+ recurse += 1
+ elif o in ('-n', '--nobackup'):
+ makebackup = False
+ elif o in ('-v', '--verbose'):
+ verbose += 1
+ elif o in ('-h', '--help'):
+ usage()
+ return
+ if not args:
+ r = Reindenter(sys.stdin)
+ r.run()
+ r.write(sys.stdout)
+ return
+ for arg in args:
+ check(arg)
+def check(file):
+ if os.path.isdir(file) and not os.path.islink(file):
+ if verbose:
+ print "listing directory", file
+ names = os.listdir(file)
+ for name in names:
+ fullname = os.path.join(file, name)
+ if ((recurse and os.path.isdir(fullname) and
+ not os.path.islink(fullname) and
+ not os.path.split(fullname)[1].startswith("."))
+ or name.lower().endswith(".py")):
+ check(fullname)
+ return
+ if verbose:
+ print "checking", file, "...",
+ try:
+ f = open(file)
+ except IOError, msg:
+ errprint("%s: I/O Error: %s" % (file, str(msg)))
+ return
+ r = Reindenter(f)
+ f.close()
+ if r.run():
+ if verbose:
+ print "changed."
+ if dryrun:
+ print "But this is a dry run, so leaving it alone."
+ if not dryrun:
+ bak = file + ".bak"
+ if makebackup:
+ shutil.copyfile(file, bak)
+ if verbose:
+ print "backed up", file, "to", bak
+ f = open(file, "w")
+ r.write(f)
+ f.close()
+ if verbose:
+ print "wrote new", file
+ return True
+ else:
+ if verbose:
+ print "unchanged."
+ return False
+def _rstrip(line, JUNK='\n \t'):
+ """Return line stripped of trailing spaces, tabs, newlines.
+ Note that line.rstrip() instead also strips sundry control characters,
+ but at least one known Emacs user expects to keep junk like that, not
+ mentioning Barry by name or anything <wink>.
+ i = len(line)
+ while i > 0 and line[i-1] in JUNK:
+ i -= 1
+ return line[:i]
+class Reindenter:
+ def __init__(self, f):
+ self.find_stmt = 1 # next token begins a fresh stmt?
+ self.level = 0 # current indent level
+ # Raw file lines.
+ self.raw = f.readlines()
+ # File lines, rstripped & tab-expanded. Dummy at start is so
+ # that we can use tokenize's 1-based line numbering easily.
+ # Note that a line is all-blank iff it's "\n".
+ self.lines = [_rstrip(line).expandtabs() + "\n"
+ for line in self.raw]
+ self.lines.insert(0, None)
+ self.index = 1 # index into self.lines of next line
+ # List of (lineno, indentlevel) pairs, one for each stmt and
+ # comment line. indentlevel is -1 for comment lines, as a
+ # signal that tokenize doesn't know what to do about them;
+ # indeed, they're our headache!
+ self.stats = []
+ def run(self):
+ tokenize.tokenize(self.getline, self.tokeneater)
+ # Remove trailing empty lines.
+ lines = self.lines
+ while lines and lines[-1] == "\n":
+ lines.pop()
+ # Sentinel.
+ stats = self.stats
+ stats.append((len(lines), 0))
+ # Map count of leading spaces to # we want.
+ have2want = {}
+ # Program after transformation.
+ after = self.after = []
+ # Copy over initial empty lines -- there's nothing to do until
+ # we see a line with *something* on it.
+ i = stats[0][0]
+ after.extend(lines[1:i])
+ for i in range(len(stats)-1):
+ thisstmt, thislevel = stats[i]
+ nextstmt = stats[i+1][0]
+ have = getlspace(lines[thisstmt])
+ want = thislevel * 4
+ if want < 0:
+ # A comment line.
+ if have:
+ # An indented comment line. If we saw the same
+ # indentation before, reuse what it most recently
+ # mapped to.
+ want = have2want.get(have, -1)
+ if want < 0:
+ # Then it probably belongs to the next real stmt.
+ for j in xrange(i+1, len(stats)-1):
+ jline, jlevel = stats[j]
+ if jlevel >= 0:
+ if have == getlspace(lines[jline]):
+ want = jlevel * 4
+ break
+ if want < 0: # Maybe it's a hanging
+ # comment like this one,
+ # in which case we should shift it like its base
+ # line got shifted.
+ for j in xrange(i-1, -1, -1):
+ if jlevel >= 0:
+ want = have + getlspace(after[jline-1]) - \
+ getlspace(lines[jline])
+ break
+ if want < 0:
+ # Still no luck -- leave it alone.
+ want = have
+ else:
+ want = 0
+ assert want >= 0
+ have2want[have] = want
+ diff = want - have
+ if diff == 0 or have == 0:
+ after.extend(lines[thisstmt:nextstmt])
+ else:
+ for line in lines[thisstmt:nextstmt]:
+ if diff > 0:
+ if line == "\n":
+ after.append(line)
+ else:
+ after.append(" " * diff + line)
+ else:
+ remove = min(getlspace(line), -diff)
+ after.append(line[remove:])
+ return self.raw != self.after
+ def write(self, f):
+ f.writelines(self.after)
+ # Line-getter for tokenize.
+ def getline(self):
+ if self.index >= len(self.lines):
+ line = ""
+ else:
+ line = self.lines[self.index]
+ self.index += 1
+ return line
+ # Line-eater for tokenize.
+ def tokeneater(self, type, token, (sline, scol), end, line,
+ INDENT=tokenize.INDENT,
+ DEDENT=tokenize.DEDENT,
+ NEWLINE=tokenize.NEWLINE,
+ COMMENT=tokenize.COMMENT,
+ NL=tokenize.NL):
+ if type == NEWLINE:
+ # A program statement, or ENDMARKER, will eventually follow,
+ # after some (possibly empty) run of tokens of the form
+ # (NL | COMMENT)* (INDENT | DEDENT+)?
+ elif type == INDENT:
+ self.level += 1
+ elif type == DEDENT:
+ self.level -= 1
+ elif type == COMMENT:
+ if self.find_stmt:
+ self.stats.append((sline, -1))
+ # but we're still looking for a new stmt, so leave
+ # find_stmt alone
+ elif type == NL:
+ pass
+ elif self.find_stmt:
+ # This is the first "real token" following a NEWLINE, so it
+ # must be the first token of the next program statement, or an
+ # ENDMARKER.
+ self.find_stmt = 0
+ if line: # not endmarker
+ self.stats.append((sline, self.level))
+# Count number of leading blanks.
+def getlspace(line):
+ i, n = 0, len(line)
+ while i < n and line[i] == " ":
+ i += 1
+ return i
+if __name__ == '__main__':
+ main()
Property changes on: grass/trunk/tools/reindent.py
___________________________________________________________________
Added: svn:executable
Added: svn:mime-type
+ text/x-python
Added: svn:eol-style
+ native
