[GRASS-SVN] r48257 - grass/branches/releasebranch_6_4/gui/wxpython
svn_grass at osgeo.org
Mon Sep 12 18:30:23 EDT 2011
Author: martinl
Date: 2011-09-12 15:30:23 -0700 (Mon, 12 Sep 2011)
New Revision: 48257
grass/branches/releasebranch_6_4/gui/wxpython/gis_set.py
wxGUI: #1407 (confusing error message after grass7 crash)
(merge r47226 from trunk)
Modified: grass/branches/releasebranch_6_4/gui/wxpython/gis_set.py
--- grass/branches/releasebranch_6_4/gui/wxpython/gis_set.py 2011-09-12 21:32:51 UTC (rev 48256)
+++ grass/branches/releasebranch_6_4/gui/wxpython/gis_set.py 2011-09-12 22:30:23 UTC (rev 48257)
@@ -738,11 +738,27 @@
lockfile = os.path.join(dbase, location, mapset, '.gislock')
if os.path.isfile(lockfile):
- GError(_("GRASS is already running in selected mapset <%(mapset)s>\n"
- "(File %(lock)s found).\n\n"
- "Concurrent use not allowed.") % { 'mapset' : mapset, 'lock' : lockfile },
- parent = self)
- return
+ dlg = wx.MessageDialog(parent = self,
+ message = _("GRASS is already running in selected mapset <%(mapset)s>\n"
+ "(file %(lock)s found).\n\n"
+ "Concurrent use not allowed.\n\n"
+ "Do you want to try to remove .gislock (note that you "
+ "need permission for this operation) and continue?") %
+ { 'mapset' : mapset, 'lock' : lockfile },
+ caption = _("Lock file found"),
+ style = wx.YES_NO | wx.NO_DEFAULT |
+ wx.ICON_QUESTION | wx.CENTRE)
+ ret = dlg.ShowModal()
+ if ret == wx.ID_YES:
+ try:
+ os.remove(lockfile)
+ except IOError, e:
+ GError(_("Unable to remove '%(lock)s'.\n\n"
+ "Details: %(reason)s") % { 'lock' : lockfile, 'reason' : e})
+ return
+ else:
+ return
gcmd.RunCommand("g.gisenv",
set = "GISDBASE=%s" % dbase)
