[GRASS-SVN] r48265 -
grass/branches/develbranch_6/gui/wxpython/gui_modules
svn_grass at osgeo.org
Tue Sep 13 12:12:52 EDT 2011
Author: martinl
Date: 2011-09-13 09:12:52 -0700 (Tue, 13 Sep 2011)
New Revision: 48265
grass/branches/develbranch_6/gui/wxpython/gui_modules/gselect.py
attempt to fix #1398 (problem with multiple entry selection)
(merge r48264 from relbr64)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/gselect.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/gselect.py 2011-09-13 16:08:13 UTC (rev 48264)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/gselect.py 2011-09-13 16:12:52 UTC (rev 48265)
@@ -187,13 +187,9 @@
return self.seltree
def GetStringValue(self):
- str = ""
- for value in self.value:
- str += value + ","
- str = str.rstrip(',')
- return str
+ """!Get value as a string separated by commas"""
+ return ','.join(self.value)
def SetFilter(self, filter):
"""!Set filter for GIS elements, see e.g. VectorSelect"""
self.filterElements = filter
@@ -245,11 +241,15 @@
if not root:
return
found = self.FindItem(root, value)
- self.value = self.GetCombo().GetValue().strip(',').split(',')
+ winValue = self.GetCombo().GetValue().strip(',')
+ self.value = []
+ if winValue:
+ self.value = winValue.split(',')
if found:
self.value.append(found)
self.seltree.SelectItem(found)
def GetAdjustedSize(self, minWidth, prefHeight, maxHeight):
"""!Reads UserSettings to get height (which was 200 in old implementation).
@@ -336,7 +336,7 @@
first_mapset = None
for mapset in mapsets:
- mapset_node = self.AddItem('Mapset: ' + mapset)
+ mapset_node = self.AddItem(_('Mapset:') + ' ' + mapset)
if not first_mapset:
first_mapset = mapset_node
@@ -356,9 +356,9 @@
if self.filterElements:
if self.filterElements(fullqElem):
- self.AddItem(elem, parent=mapset_node)
+ self.AddItem(elem, parent = mapset_node)
else:
except StandardError, e:
sys.stderr.write(_("GSelect: invalid item: %s") % e)
continue
@@ -475,10 +475,10 @@
# text item should be unique
self.value.append(fullName)
else:
- self.value = [fullName, ]
+ self.value = [fullName]
self.Dismiss()
def OnMotion(self, evt):
"""!Have the selection follow the mouse, like in a real combobox
@@ -501,11 +501,12 @@
mapsetItem = self.seltree.GetItemParent(item)
fullName = self.seltree.GetItemText(item) + '@' + \
self.seltree.GetItemText(mapsetItem).split(' ', 1)[1]
if self.multiple is True:
else:
self.Dismiss()
