[GRASS-SVN] r48270 - in grass/trunk/lib/vector: Vlib diglib
Tue Sep 13 15:21:33 EDT 2011
Author: martinl
Date: 2011-09-13 12:21:33 -0700 (Tue, 13 Sep 2011)
New Revision: 48270
   grass/trunk/lib/vector/Vlib/read.c
   grass/trunk/lib/vector/Vlib/read_ogr.c
   grass/trunk/lib/vector/Vlib/write_nat.c
   grass/trunk/lib/vector/Vlib/write_ogr.c
   grass/trunk/lib/vector/diglib/plus_line.c
vlib: fix Vect_rewrite_line_ogr()
      various minor fixes in reading/writing features
Modified: grass/trunk/lib/vector/Vlib/read.c
--- grass/trunk/lib/vector/Vlib/read.c	2011-09-13 16:48:54 UTC (rev 48269)
+++ grass/trunk/lib/vector/Vlib/read.c	2011-09-13 19:21:33 UTC (rev 48270)
@@ -102,7 +102,7 @@
 		   struct line_pnts *line_p, struct line_cats *line_c, int line)
-    G_debug(3, "Vect_read_line() line=%d", line);
+    G_debug(3, "Vect_read_line() line = %d", line);
     if (!VECT_OPEN(Map))
 	G_fatal_error("Vect_read_line(): %s", _("vector map is not opened"));
Modified: grass/trunk/lib/vector/Vlib/read_ogr.c
--- grass/trunk/lib/vector/Vlib/read_ogr.c	2011-09-13 16:48:54 UTC (rev 48269)
+++ grass/trunk/lib/vector/Vlib/read_ogr.c	2011-09-13 19:21:33 UTC (rev 48270)
@@ -266,17 +266,16 @@
     int eType, line;
     OGRGeometryH hGeom2;
-    /* Read coors if hGeom is a simple element (wkbPoint, wkbLineString) otherwise
-     * descend to geometry specified by offset[offset] */
+    /* Read coors if hGeom is a simple element (wkbPoint,
+     * wkbLineString) otherwise descend to geometry specified by
+     * offset[offset] */
-    G_debug(4, "read_line() offset = %ld", offset);
     eType = wkbFlatten(OGR_G_GetGeometryType(hGeom));
-    G_debug(4, "OGR Geometry of type: %d", eType);
+    G_debug(4, "OGR geometry type: %d", eType);
     switch (eType) {
     case wkbPoint:
-	G_debug(4, "Point");
+	G_debug(4, "\t->Point");
 	if (Points) {
 	    Vect_append_point(Points, OGR_G_GetX(hGeom, 0), OGR_G_GetY(hGeom, 0),
 			      OGR_G_GetZ(hGeom, 0));
@@ -285,7 +284,7 @@
 	break;
     case wkbLineString:
-	G_debug(4, "LineString");
+	G_debug(4, "\t->LineString");
 	if (Points) {
 	    nPoints = OGR_G_GetPointCount(hGeom);
 	    for (i = 0; i < nPoints; i++) {
@@ -301,7 +300,7 @@
     case wkbMultiLineString:
     case wkbMultiPolygon:
     case wkbGeometryCollection:
-	G_debug(4, " more geoms -> part %d", Map->fInfo.ogr.offset[offset]);
+	G_debug(4, " \t->more geoms -> part %d", Map->fInfo.ogr.offset[offset]);
 	hGeom2 = OGR_G_GetGeometryRef(hGeom, Map->fInfo.ogr.offset[offset]);
 	line = read_line(Map, hGeom2, offset + 1, Points);
 	if (eType == wkbPolygon || wkbMultiPolygon)
@@ -402,7 +401,8 @@
     int type;
     OGRGeometryH hGeom;
-    G_debug(4, "V1_read_line_ogr() offset = %lu", (long) offset);
+    G_debug(4, "V1_read_line_ogr() offset = %lu offset_num = %lu",
+	    (long) offset, (long) Map->fInfo.ogr.offset_num);
     if (offset >= Map->fInfo.ogr.offset_num)
 	return -2;
@@ -419,7 +419,7 @@
     if (line_p != NULL) {
 	/* Read feature to cache if necessary */
 	if (Map->fInfo.ogr.feature_cache_id != FID) {
-	    G_debug(4, "Read feature (FID = %ld) to cache.", FID);
+	    G_debug(4, "Read feature (FID = %ld) to cache", FID);
 	    if (Map->fInfo.ogr.feature_cache) {
 		OGR_F_Destroy(Map->fInfo.ogr.feature_cache);
Modified: grass/trunk/lib/vector/Vlib/write_nat.c
--- grass/trunk/lib/vector/Vlib/write_nat.c	2011-09-13 16:48:54 UTC (rev 48269)
+++ grass/trunk/lib/vector/Vlib/write_nat.c	2011-09-13 19:21:33 UTC (rev 48270)
@@ -157,12 +157,11 @@
     if (plus->built >= GV_BUILD_AREAS) {
 	if (type == GV_BOUNDARY) {
+	    struct P_topo_b *topo = (struct P_topo_b *)Line->topo;
 	    /* Delete neighbour areas/isles */
-	    first = 1;
+	    first = TRUE;
 	    for (s = 0; s < 2; s++) {	/* for each node */
-		struct P_topo_b *topo = (struct P_topo_b *)Line->topo;
 		node = (s == 0 ? topo->N1 : topo->N2);
 		G_debug(3,
 			"  delete neighbour areas/isles: %s node = %d",
@@ -176,9 +175,11 @@
 		G_debug(3, "  number of boundaries at node = %d", n);
-		if (n > 2) {	/* more than 2 boundaries at node ( >= 2 old + 1 new ) */
-		    /* Line above (to the right), it is enough to check to the right, because if area/isle
-		     *  exists it is the same to the left */
+		if (n > 2) {
+		    /* more than 2 boundaries at node ( >= 2 old + 1 new ) */
+		    /* Line above (to the right), it is enough to check to
+		       the right, because if area/isle
+		       exists it is the same to the left */
 		    if (!s)
 			next_line =
 			    dig_angle_next_line(plus, line, GV_RIGHT,
@@ -192,7 +193,8 @@
 			NLine = plus->Line[abs(next_line)];
 			topo = (struct P_topo_b *)NLine->topo;
 			if (next_line > 0)	/* the boundary is connected by 1. node */
-			    area = topo->right;	/* we are interested just in this side (close to our line) */
+			    /* we are interested just in this side (close to our line) */
+			    area = topo->right;
 			else if (next_line < 0)	/* the boundary is connected by 2. node */
 			    area = topo->left;
@@ -202,7 +204,7 @@
 			    Vect_get_area_box(Map, area, &box);
 			    if (first) {
 				Vect_box_copy(&abox, &box);
-				first = 0;
+				first = FALSE;
 			    else
 				Vect_box_extend(&abox, &box);
@@ -219,9 +221,9 @@
 	    /* Build new areas/isles.
-	     *  It's true that we deleted also adjacent areas/isles, but
-	     *  if they form new one our boundary must participate, so
-	     *  we need to build areas/isles just for our boundary */
+	     * It's true that we deleted also adjacent areas/isles, but
+	     * if they form new one our boundary must participate, so
+	     * we need to build areas/isles just for our boundary */
 		side = (s == 0 ? GV_LEFT : GV_RIGHT);
 		G_debug(3, "  build area/isle on side = %d", side);
@@ -233,7 +235,7 @@
 		    if (first) {
-			first = 0;
+			first = FALSE;
 		    else
@@ -243,7 +245,7 @@
 		    Vect_get_isle_box(Map, -area, &box);
 		    if (first) {
-			first = 0;
+			first = FALSE;
 		    else
@@ -251,8 +253,9 @@
 		new_area[s] = area;
 	    /* Reattach all centroids/isles in deleted areas + new area.
-	     *  Because isles are selected by box it covers also possible new isle created above */
-	    if (!first) {	/* i.e. old area/isle was deleted or new one created */
+	     * Because isles are selected by box it covers also possible
+	     * new isle created above */
+	    if (!first) { /* i.e. old area/isle was deleted or new one created */
 		/* Reattach isles */
 		if (plus->built >= GV_BUILD_ATTACH_ISLES)
 		    Vect_attach_isles(Map, &abox);
@@ -325,7 +328,7 @@
     off_t offset;
-    if (dig_fseek(&(Map->dig_fp), 0L, SEEK_END) == -1)	/* set to  end of file */
+    if (dig_fseek(&(Map->dig_fp), 0L, SEEK_END) == -1)	/* set to end of file */
 	return -1;
     offset = dig_ftell(&(Map->dig_fp));
Modified: grass/trunk/lib/vector/Vlib/write_ogr.c
--- grass/trunk/lib/vector/Vlib/write_ogr.c	2011-09-13 16:48:54 UTC (rev 48269)
+++ grass/trunk/lib/vector/Vlib/write_ogr.c	2011-09-13 19:21:33 UTC (rev 48270)
@@ -31,9 +31,9 @@
 static int write_attributes(dbDriver *, int, const struct field_info *,
 			    OGRLayerH, OGRFeatureH);
-void V2__add_line_to_topo_ogr(struct Map_info *Map, int line,
-			      const struct line_pnts *points,
-			      const struct line_cats *cats)
+static void V2__add_line_to_topo_ogr(struct Map_info *Map, int line,
+				     const struct line_pnts *points,
+				     const struct line_cats *cats)
     /* recycle code from build_ogr */
     G_warning("feature not yet implemented, coming soon...");
@@ -59,6 +59,7 @@
     int i, cat, ret;
     struct field_info *Fi;
+    struct Format_info_ogr *fInfo;
     OGRGeometryH       Ogr_geometry;
     OGRFeatureH        Ogr_feature;
@@ -85,7 +86,8 @@
-    Ogr_featuredefn = OGR_L_GetLayerDefn(Map->fInfo.ogr.layer);
+    fInfo = &(Map->fInfo.ogr);
+    Ogr_featuredefn = OGR_L_GetLayerDefn(fInfo->layer);
     Ogr_geom_type = OGR_FD_GetGeomType(Ogr_featuredefn);
     /* determine matching OGR feature geometry type */
@@ -166,14 +168,24 @@
     OGR_F_SetGeometry(Ogr_feature, Ogr_geometry);
     /* write attributes */
-    if (cat > -1 && Map->fInfo.ogr.dbdriver) {
-	write_attributes(Map->fInfo.ogr.dbdriver,
-			 cat, Fi, Map->fInfo.ogr.layer, Ogr_feature);
+    if (cat > -1 && fInfo->dbdriver) {
+	write_attributes(fInfo->dbdriver,
+			 cat, Fi, fInfo->layer, Ogr_feature);
 	G_free(Fi);
     /* write feature into layer */
-    ret = OGR_L_CreateFeature(Map->fInfo.ogr.layer, Ogr_feature);
+    ret = OGR_L_CreateFeature(fInfo->layer, Ogr_feature);
+    /* update offset array */
+    if (fInfo->offset_num >= fInfo->offset_alloc) {
+	fInfo->offset_alloc += 1000;
+	fInfo->offset = (int *) G_realloc(fInfo->offset,
+					  fInfo->offset_alloc *
+					  sizeof(int));
+    /* how to deal with OGRNullFID ? */
+    fInfo->offset[fInfo->offset_num] = (int)OGR_F_GetFID(Ogr_feature);
     /* destroy */
     OGR_G_DestroyGeometry(Ogr_geometry);
     OGR_F_Destroy(Ogr_feature);
@@ -181,7 +193,7 @@
     if (ret != OGRERR_NONE)
 	return -1;
-    return Map->fInfo.ogr.offset_num++;
+    return fInfo->offset_num++;
@@ -206,6 +218,7 @@
     line = 0;
     G_debug(3, "V2_write_line_ogr()");
     offset = V1_write_line_ogr(Map, type, points, cats);
     if (offset < 0)
 	return -1;
@@ -269,8 +282,9 @@
   \brief Rewrites feature to 'coor' file (topology level) - internal use only
   \param Map pointer to Map_info structure
+  \param line feature id
   \param type feature type
-  \param line feature id
+  \param offset unused
   \param points feature geometry
   \param cats feature categories
@@ -280,9 +294,14 @@
 off_t V2_rewrite_line_ogr(struct Map_info *Map, int line, int type, off_t offset,
 			  const struct line_pnts *points, const struct line_cats *cats)
+    if (type != V2_read_line_ogr(Map, NULL, NULL, line)) {
+	G_warning(_("Unable to rewrite feature (incompatible feature types)"));
+	return -1;
     V2_delete_line_ogr(Map, line);
-    return (V2_write_line_ogr(Map, type, points, cats));
+    return V2_write_line_ogr(Map, type, points, cats);
@@ -329,7 +348,7 @@
     static struct line_cats *Cats = NULL;
     static struct line_pnts *Points = NULL;
-    G_debug(3, "V2_delete_line_nat(), line = %d", (int) line);
+    G_debug(3, "V2_delete_line_ogr(), line = %d", (int) line);
     type = first = 0;
     Line = NULL;
@@ -350,7 +369,7 @@
 	Points = Vect_new_line_struct();
-    type = V2_read_line_nat(Map, Points, Cats, line);
+    type = V2_read_line_ogr(Map, Points, Cats, line);
     /* Update category index */
     if (plus->update_cidx) {
Modified: grass/trunk/lib/vector/diglib/plus_line.c
--- grass/trunk/lib/vector/diglib/plus_line.c	2011-09-13 16:48:54 UTC (rev 48269)
+++ grass/trunk/lib/vector/diglib/plus_line.c	2011-09-13 19:21:33 UTC (rev 48270)
@@ -82,13 +82,12 @@
     lp = Points->n_points - 1;
     G_debug(3, "Register node %f,%f", Points->x[lp], Points->y[lp]);
-    node =
-	dig_find_node(plus, Points->x[lp], Points->y[lp], Points->z[lp]);
+    node = dig_find_node(plus, Points->x[lp], Points->y[lp],
+			 Points->z[lp]);
     G_debug(3, "node = %d", node);
     if (node == 0) {
-	node =
-	    dig_add_node(plus, Points->x[lp], Points->y[lp],
-			 Points->z[lp]);
+	node = dig_add_node(plus, Points->x[lp], Points->y[lp],
+			    Points->z[lp]);
 	G_debug(3, "Add new node: %d", node);
     else {
