[GRASS-SVN] r48283 -
grass/branches/develbranch_6/gui/wxpython/gui_modules
svn_grass at osgeo.org
Tue Sep 13 18:09:46 EDT 2011
Author: martinl
Date: 2011-09-13 15:09:46 -0700 (Tue, 13 Sep 2011)
New Revision: 48283
grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp_vdigit.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/wxvdigit.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/wxvdriver.py
wxGUI/vdigit: fix copying feature from background map
(merge r48282 from trunk)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp_vdigit.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp_vdigit.py 2011-09-13 22:08:07 UTC (rev 48282)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp_vdigit.py 2011-09-13 22:09:46 UTC (rev 48283)
@@ -21,10 +21,11 @@
import dbm_dialogs
import gcmd
-from debug import Debug
+from debug import Debug
from mapdisp_window import BufferedWindow
-from preferences import globalSettings as UserSettings
+from preferences import globalSettings as UserSettings
+from utils import ListOfCatsToRange
+from globalvar import QUERYLAYER
from vdigit import VDigitCategoryDialog
from vdigit import VDigitZBulkDialog
from vdigit import VDigitDuplicatesDialog
@@ -705,7 +706,7 @@
if UserSettings.Get(group = 'vdigit', key = 'bgmap',
subkey = 'value', internal = True) == '':
# no background map -> copy from current vector map layer
- nselected = self.digit.GetDisplay().SelectLinesByBox((pos1, pos2))
+ nselected = self.bdigit.GetDisplay().SelectLinesByBox((pos1, pos2))
if nselected > 0:
# highlight selected features
@@ -714,17 +715,15 @@
self.UpdateMap(render = False, renderVector = False)
else:
# copy features from background map
- self.copyIds += self.digit.SelectLinesFromBackgroundMap(bbox = (pos1, pos2))
+ self.copyIds = self.digit.SelectLinesFromBackgroundMap(bbox = (pos1, pos2))
if len(self.copyIds) > 0:
color = UserSettings.Get(group = 'vdigit', key = 'symbol',
subkey = ['highlight', 'color'])
- colorStr = str(color[0]) + ":" + \
- str(color[1]) + ":" + \
- str(color[2])
+ colorStr = str(color[0]) + ":" + str(color[1]) + ":" + str(color[2])
dVectTmp = ['d.vect',
'map=%s' % UserSettings.Get(group = 'vdigit', key = 'bgmap',
subkey = 'value', internal = True),
- 'cats=%s' % utils.ListOfCatsToRange(self.copyIds),
+ 'cats=%s' % ListOfCatsToRange(self.copyIds),
'-i',
'color=%s' % colorStr,
'fcolor=%s' % colorStr,
@@ -733,16 +732,16 @@
if not self.layerTmp:
self.layerTmp = self.Map.AddLayer(type = 'vector',
- name = globalvar.QUERYLAYER,
+ name = QUERYLAYER,
command = dVectTmp)
else:
self.layerTmp.SetCmd(dVectTmp)
- self.UpdateMap(render = True, renderVector = False)
else:
- self.UpdateMap(render = False, renderVector = False)
+ if self.layerTmp:
+ self.Map.DeleteLayer(self.layerTmp)
+ self.layerTmp = None
- self.redrawAll = None
+ self.UpdateMap(render = True, renderVector = True)
def OnLeftUpBulkLine(self, event):
"""!Left mouse button released - vector digitizer z-bulk line
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/wxvdigit.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/wxvdigit.py 2011-09-13 22:08:07 UTC (rev 48282)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/wxvdigit.py 2011-09-13 22:09:46 UTC (rev 48283)
@@ -1722,15 +1722,12 @@
@return list of selected feature ids
- ret = list()
+ # try select features by box first
+ if self._display.SelectLinesByBox(bbox, poMapInfo = self.poBgMapInfo) < 1:
+ self._display.SelectLineByPoint(bbox[0], poMapInfo = self.poBgMapInfo)['line']
+ return self._display.selected['ids']
- # try select features by Box
- ids = self._display.SelectLinesByBox(bbox, poMapInfo = self.poBgMapInfo)
- if not ids:
- ids = [self._display.SelectLineByPoint(bbox[0], poMapInfo = self.poBgMapInfo)['line'], ]
- return ids
def GetUndoLevel(self):
"""!Get undo level (number of active changesets)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/wxvdriver.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/wxvdriver.py 2011-09-13 22:08:07 UTC (rev 48282)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/wxvdriver.py 2011-09-13 22:09:46 UTC (rev 48283)
@@ -524,11 +524,6 @@
# select by ids
self.selected['cats'] = list()
- if thisMapInfo:
- selected = self.selected['ids']
- else:
- selected = list()
poList = Vect_new_list()
x1, y1 = bbox[0]
x2, y2 = bbox[1]
@@ -565,9 +560,9 @@
continue # skip lines just overlapping bbox
if not self._isSelected(line):
- selected.append(line)
+ self.selected['ids'].append(line)
else:
- selected.remove(line)
+ self.selected['ids'].remove(line)
Vect_destroy_line_struct(poBbox)
Vect_destroy_list(poList)
@@ -598,11 +593,6 @@
# select by ids
- if thisMapInfo:
- else:
- selected = list()
poFound = Vect_new_list()
lineNearest = Vect_find_line_list(poMapInfo, point[0], point[1], 0,
@@ -612,9 +602,9 @@
if lineNearest > 0:
if not self._isSelected(lineNearest):
- selected.append(lineNearest)
+ self.selected['ids'].append(lineNearest)
else:
- selected.remove(lineNearest)
+ self.selected['ids'].remove(lineNearest)
px = c_double()
py = c_double()
@@ -632,14 +622,14 @@
for i in range(found.n_values):
line = found.value[i]
if line != lineNearest:
self.GetDuplicates()
if line != lineNearest and not self._isDuplicated(line):
Vect_destroy_list(poFound)
