[GRASS-SVN] r48296 - grass-addons/vector/v.mkhexgrid
svn_grass at osgeo.org
Wed Sep 14 15:27:09 EDT 2011
Author: tsw
Date: 2011-09-14 12:27:09 -0700 (Wed, 14 Sep 2011)
New Revision: 48296
grass-addons/vector/v.mkhexgrid/v.mkhexgrid
fix for systems without schemas
Modified: grass-addons/vector/v.mkhexgrid/v.mkhexgrid
--- grass-addons/vector/v.mkhexgrid/v.mkhexgrid 2011-09-14 17:10:43 UTC (rev 48295)
+++ grass-addons/vector/v.mkhexgrid/v.mkhexgrid 2011-09-14 19:27:09 UTC (rev 48296)
@@ -90,7 +90,7 @@
-def WriteHexGridVectors(vf, sf, table_name, schema, side_len, xstart, ystart, xlimit, ylimit):
+def WriteHexGridVectors(vf, sf, table_name, side_len, xstart, ystart, xlimit, ylimit):
# basic trig
angle_a = math.radians(30)
@@ -109,12 +109,8 @@
name = 'x%f_y%f' % (x,y)
outstring = CreateHexagon((x, y), side_len, cat)
vf.write(outstring)
- if schema == '':
- outstring = "UPDATE %s SET row_num = %d, col_num = %d, row_col = '%d_%d' WHERE cat = %d;\n" % \
- (table_name,row,col,row,col,cat)
- else:
- outstring = "UPDATE %s.%s SET row_num = %d, col_num = %d, row_col = '%d_%d' WHERE cat = %d;\n" % \
- (schema,table_name,row,col,row,col,cat)
+ outstring = "UPDATE %s SET row_num = %d, col_num = %d, row_col = '%d_%d' WHERE cat = %d;\n" % \
+ (table_name,row,col,row,col,cat)
sf.write(outstring)
cat = cat + 1
x = x + (2*side_len) + (2*side_a)
@@ -258,9 +254,13 @@
vf = open(vectorfile, "w")
sf = open(sqlfile, "w")
WriteGrassHeader(vf,vectorfile,xstart,ystart,xmax,ymax)
- table_name = options['output'].split('@')[0]
+ tname = options['output'].split('@')[0]
schema = gdb.db_connection()['schema']
- WriteHexGridVectors(vf, sf, table_name, schema, float(side_len), float(xstart), float(ystart), float(xmax), float(ymax))
+ if schema.strip() == '':
+ table_name = tname
+ else:
+ table_name = schema + '.' + tname
+ WriteHexGridVectors(vf, sf, table_name, float(side_len), float(xstart), float(ystart), float(xmax), float(ymax))
vf.close()
sf.close()
# now import and clean up the vector
@@ -276,7 +276,7 @@
grass.message('Cleaning and building topology')
try:
r = grass.run_command('v.clean', flags='-q', input=tempname, \
- output=table_name, type='point,line,boundary,centroid,area', tool='rmdupl')
+ output=tname, type='point,line,boundary,centroid,area', tool='rmdupl')
if r <> 0:
raise
except:
@@ -289,7 +289,7 @@
grass.message(vectorfile)
try:
# add attribute table
- r = grass.run_command('v.db.addtable', map=table_name, table=schema+'.'+table_name, layer=1, columns='cat integer, row_num integer, col_num integer, row_col varchar(255)' )
+ r = grass.run_command('v.db.addtable', map=tname, table=table_name, layer=1, columns='cat integer, row_num integer, col_num integer, row_col varchar(255)' )
if r <> 0:
raise
except:
