[GRASS-SVN] r48323 - in grass/branches/develbranch_6/gui/wxpython: . docs gui_modules icons xml
Fri Sep 16 07:53:04 EDT 2011
Author: annakrat
Date: 2011-09-16 04:53:03 -0700 (Fri, 16 Sep 2011)
New Revision: 48323
   grass/branches/develbranch_6/gui/wxpython/docs/wxGUI.Attribute_Table_Manager.html
   grass/branches/develbranch_6/gui/wxpython/docs/wxGUI.GCP_Manager.html
   grass/branches/develbranch_6/gui/wxpython/docs/wxGUI.Modeler.html
   grass/branches/develbranch_6/gui/wxpython/docs/wxGUI.Nviz.html
   grass/branches/develbranch_6/gui/wxpython/docs/wxGUI.PsMap.html
   grass/branches/develbranch_6/gui/wxpython/docs/wxGUI.Vector_Digitizer.html
   grass/branches/develbranch_6/gui/wxpython/docs/wxGUI.html
   grass/branches/develbranch_6/gui/wxpython/gui_modules/menudata.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/psmap.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/toolbars.py
   grass/branches/develbranch_6/gui/wxpython/icons/icon.py
   grass/branches/develbranch_6/gui/wxpython/wxgui.py
   grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml
   grass/branches/develbranch_6/gui/wxpython/xml/menudata_psmap.xml
wx.psmap: renamed from Hardcopy Map Output Utility to Cartographic Composer (merge from trunk, r48322)
Modified: grass/branches/develbranch_6/gui/wxpython/docs/wxGUI.Attribute_Table_Manager.html
--- grass/branches/develbranch_6/gui/wxpython/docs/wxGUI.Attribute_Table_Manager.html	2011-09-16 11:15:12 UTC (rev 48322)
+++ grass/branches/develbranch_6/gui/wxpython/docs/wxGUI.Attribute_Table_Manager.html	2011-09-16 11:53:03 UTC (rev 48323)
@@ -23,11 +23,11 @@
 <p>
 Other wxGUI components:<br>
 <em>
-  <a href="wxGUI.Vector_Digitizer.html">Vector Digitizer</a><br>
-  <a href="wxGUI.Nviz.html">3D Viewer</a><br>
-  <a href="wxGUI.Modeler.html">Graphical Modeler</a><br>
-  <a href="wxGUI.GCP_Manager.html">Manage Ground Control Points</a><br>
-  <a href="wxGUI.PsMap.html">Hardcopy Map Output Utility</a><br>
+<a href="wxGUI.Vector_Digitizer.html">Vector Digitizer</a><br>
+<a href="wxGUI.Nviz.html">3D Viewer</a><br>
+<a href="wxGUI.Modeler.html">Graphical Modeler</a><br>
+<a href="wxGUI.GCP_Manager.html">Manage Ground Control Points</a><br>
+<a href="wxGUI.PsMap.html">Cartographic Composer</a><br>
 </em>
 <p>
Modified: grass/branches/develbranch_6/gui/wxpython/docs/wxGUI.GCP_Manager.html
--- grass/branches/develbranch_6/gui/wxpython/docs/wxGUI.GCP_Manager.html	2011-09-16 11:15:12 UTC (rev 48322)
+++ grass/branches/develbranch_6/gui/wxpython/docs/wxGUI.GCP_Manager.html	2011-09-16 11:53:03 UTC (rev 48323)
@@ -302,7 +302,7 @@
   <a href="wxGUI.Attribute_Table_Manager.html">Attribute Table Manager</a><br>
+  <a href="wxGUI.PsMap.html">Cartographic Composer</a><br>
 </em>
 <p>
Modified: grass/branches/develbranch_6/gui/wxpython/docs/wxGUI.Modeler.html
--- grass/branches/develbranch_6/gui/wxpython/docs/wxGUI.Modeler.html	2011-09-16 11:15:12 UTC (rev 48322)
+++ grass/branches/develbranch_6/gui/wxpython/docs/wxGUI.Modeler.html	2011-09-16 11:53:03 UTC (rev 48323)
@@ -33,11 +33,11 @@
 <p>
 <em>
-  <a href="wxGUI.Attribute_Table_Manager.html">Attribute Table Manager</a><br>
+<a href="wxGUI.Attribute_Table_Manager.html">Attribute Table Manager</a><br>
 </em>
 <p>
Modified: grass/branches/develbranch_6/gui/wxpython/docs/wxGUI.Nviz.html
--- grass/branches/develbranch_6/gui/wxpython/docs/wxGUI.Nviz.html	2011-09-16 11:15:12 UTC (rev 48322)
+++ grass/branches/develbranch_6/gui/wxpython/docs/wxGUI.Nviz.html	2011-09-16 11:53:03 UTC (rev 48323)
@@ -305,7 +305,7 @@
 </em>
 <p>
Modified: grass/branches/develbranch_6/gui/wxpython/docs/wxGUI.PsMap.html
--- grass/branches/develbranch_6/gui/wxpython/docs/wxGUI.PsMap.html	2011-09-16 11:15:12 UTC (rev 48322)
+++ grass/branches/develbranch_6/gui/wxpython/docs/wxGUI.PsMap.html	2011-09-16 11:53:03 UTC (rev 48323)
@@ -1,10 +1,10 @@
 <h2>DESCRIPTION</h2>
-Note: <b>wxGUI Hardcopy Map Output Utility is currently under development. Not
-all functionality is implemented.</b>
+<b>Note:</b> <em>wxGUI Cartographic Composer is currently under
+development.</em>
 <p>
-<b>wxGUI Hardcopy Map Output Utility</b> also called <em>wx.psmap</em> is
+<b>wxGUI Cartographic Composer</b> also called <em>wx.psmap</em> is
 a <em><a href="wxGUI.html">wxGUI</a></em> extension which allows the
 user to create interactively hardcopy map outputs. This tool
 generates <em><a href="ps.map.html">ps.map</a></em> configuration file
@@ -23,7 +23,7 @@
 </ul>
 <p>
-Hardcopy Map Output Utility enables to load in saved instructions file. It
+Cartographic Composer enables to load in saved instructions file. It
 works better with files created by wx.psmap (more tested).</p>
 <p>
@@ -46,7 +46,7 @@
 </ul>
-<h3>HARDCOPY MAP UTILITY TOOLBAR</h3>
+<h3>CARTOGRAPHIC COMPOSER TOOLBAR</h3>
 <dl>
   <dt><img src="icons/script-save.png">&nbsp;
     <em>Generate instructions file</em></dt>
@@ -197,7 +197,7 @@
 </em>
 </p>
 <p>
-See also <a href="http://grass.osgeo.org/wiki/WxGUI_Hardcopy_Map_Output_Utility">wiki</a> page.
+See also <a href="http://grass.osgeo.org/wiki/WxGUI_Cartographic_Composer">wiki</a> page.
 </p>
 <h2>AUTHORS</h2>
Modified: grass/branches/develbranch_6/gui/wxpython/docs/wxGUI.Vector_Digitizer.html
--- grass/branches/develbranch_6/gui/wxpython/docs/wxGUI.Vector_Digitizer.html	2011-09-16 11:15:12 UTC (rev 48322)
+++ grass/branches/develbranch_6/gui/wxpython/docs/wxGUI.Vector_Digitizer.html	2011-09-16 11:53:03 UTC (rev 48323)
@@ -233,7 +233,7 @@
 </em>
 <p>
Modified: grass/branches/develbranch_6/gui/wxpython/docs/wxGUI.html
--- grass/branches/develbranch_6/gui/wxpython/docs/wxGUI.html	2011-09-16 11:15:12 UTC (rev 48322)
+++ grass/branches/develbranch_6/gui/wxpython/docs/wxGUI.html	2011-09-16 11:53:03 UTC (rev 48323)
@@ -565,7 +565,7 @@
 </em>
 <p>
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/menudata.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/menudata.py	2011-09-16 11:15:12 UTC (rev 48322)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/menudata.py	2011-09-16 11:53:03 UTC (rev 48323)
@@ -238,7 +238,7 @@
 class PsMapData(MenuData):
     def __init__(self, path = None):
-        """!Menu for Hardcopy Map Output Utility (psmap.py)
+        """!Menu for Cartographic Composer (psmap.py)
         @path path to XML to be read (None for menudata_psmap.xml)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/psmap.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/psmap.py	2011-09-16 11:15:12 UTC (rev 48322)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/psmap.py	2011-09-16 11:53:03 UTC (rev 48323)
@@ -52,7 +52,7 @@
 class PsMapFrame(wx.Frame):
     def __init__(self, parent = None, id = wx.ID_ANY,
-                 title = _("GRASS GIS Hardcopy Map Output Utility (experimental prototype)"), **kwargs):
+                 title = _("GRASS GIS Cartographic Composer (experimental prototype)"), **kwargs):
         """!Main window of ps.map GUI
         @param parent parent window
@@ -909,7 +909,7 @@
         info = wx.AboutDialogInfo()
         info.SetIcon(wx.Icon(os.path.join(globalvar.ETCICONDIR, 'grass.ico'), wx.BITMAP_TYPE_ICO))
-        info.SetName(_('wxGUI Hardcopy Map Utility'))
+        info.SetName(_('wxGUI Cartographic Composer'))
         info.SetWebSite('http://grass.osgeo.org')
         info.SetDescription(_('(C) 2011 by the GRASS Development Team\n\n') +
                             '\n'.join(textwrap.wrap(_('This program is free software under the GNU General Public License'
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/toolbars.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/toolbars.py	2011-09-16 11:15:12 UTC (rev 48322)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/toolbars.py	2011-09-16 11:53:03 UTC (rev 48323)
@@ -1538,7 +1538,7 @@
 class PsMapToolbar(AbstractToolbar):
     def __init__(self, parent):
-        """!Toolbar Hardcopy Map Output Utility (psmap.py)
+        """!Toolbar Cartographic Composer (psmap.py)
Modified: grass/branches/develbranch_6/gui/wxpython/icons/icon.py
--- grass/branches/develbranch_6/gui/wxpython/icons/icon.py	2011-09-16 11:15:12 UTC (rev 48322)
+++ grass/branches/develbranch_6/gui/wxpython/icons/icon.py	2011-09-16 11:53:03 UTC (rev 48323)
@@ -270,7 +270,7 @@
         'layerOptions'  : MetaIcon(img = iconSet.get('options', wx.ART_ERROR),
                                    label = _('Set options')),
         'mapOutput'  : MetaIcon(img = iconSet.get('print-compose', wx.ART_ERROR),
-                                label = _('Hardcopy Map Output Utility')),
+                                label = _('Cartographic Composer')),
         'mapcalc'    : MetaIcon(img = iconSet.get('calculator', wx.ART_ERROR),
                                 label = _('Raster Map Calculator')),
@@ -458,7 +458,7 @@
         'preview'    : MetaIcon(img = iconSet['execute'],
                                 label = _("Show preview")),
         'quit'       : MetaIcon(img = iconSet['quit'],
-                                label = _('Quit Hardcopy Map Utility')),
+                                label = _('Quit Cartographic Composer')),
         'addText'    : MetaIcon(img = iconSet['text-add'],
                                 label = _('Add text')),
         'addMapinfo' : MetaIcon(img = iconSet['map-info'],
Modified: grass/branches/develbranch_6/gui/wxpython/wxgui.py
--- grass/branches/develbranch_6/gui/wxpython/wxgui.py	2011-09-16 11:15:12 UTC (rev 48322)
+++ grass/branches/develbranch_6/gui/wxpython/wxgui.py	2011-09-16 11:53:03 UTC (rev 48323)
@@ -338,7 +338,7 @@
         win.Show()
     def OnPsMap(self, event):
-        """!Launch Hardcopy Map Output Utility
+        """!Launch Cartographic Composer
         try:
             from gui_modules import psmap
Modified: grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml
--- grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml	2011-09-16 11:15:12 UTC (rev 48322)
+++ grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml	2011-09-16 11:53:03 UTC (rev 48323)
@@ -688,8 +688,8 @@
 	</menuitem>
 	<separator />
 	<menuitem>
-	  <label>Hardcopy Map Output Utility</label>
-	  <help>Launch Hardcopy Map Output Utility</help>
+	  <label>Cartographic Composer</label>
+	  <help>Launch Cartographic Composer</help>
 	  <keywords>postscript,map,printing</keywords>
 	  <handler>OnPsMap</handler>
 	  <command>ps.map</command>
Modified: grass/branches/develbranch_6/gui/wxpython/xml/menudata_psmap.xml
--- grass/branches/develbranch_6/gui/wxpython/xml/menudata_psmap.xml	2011-09-16 11:15:12 UTC (rev 48322)
+++ grass/branches/develbranch_6/gui/wxpython/xml/menudata_psmap.xml	2011-09-16 11:53:03 UTC (rev 48323)
@@ -43,7 +43,7 @@
 	<separator/>
 	<menuitem>
 	  <label>Quit</label>
-	  <help>Close Hardcopy Map Output Utility</help>
+	  <help>Close Cartographic Composer</help>
 	  <handler>OnCloseWindow</handler>
 	  <shortcut>Ctrl+W</shortcut>
 	</menuitem>
@@ -108,13 +108,13 @@
       <items>
 	<menuitem>
 	  <label>Help</label>
-	  <help>Display the HTML man pages of Hardcopy Map Output Utility</help>
+	  <help>Display the HTML man pages of Cartographic Composer</help>
 	  <handler>OnHelp</handler>
 	</menuitem>
 	<separator />
 	<menuitem>
-	  <label>About Hardcopy Map Output Utility</label>
-	  <help>Display information about Hardcopy Map Output Utility</help>
+	  <label>About Cartographic Composer</label>
+	  <help>Display information about Cartographic Composer</help>
 	  <handler>OnAbout</handler>
 	</menuitem>
       </items>
