[GRASS-SVN] r48326 - in grass/trunk: . lib lib/python lib/temporal
temporal temporal/t.list temporal/t.remove
temporal/tr.register temporal/tr.unregister
temporal/tr3.register temporal/tr3.unregister
temporal/tv.register temporal/tv.unregister
svn_grass at osgeo.org
Fri Sep 16 19:05:45 EDT 2011
Author: huhabla
Date: 2011-09-16 16:05:45 -0700 (Fri, 16 Sep 2011)
New Revision: 48326
Added:
grass/trunk/lib/temporal/update_stds_spatial_temporal_extent_template.sql
grass/trunk/lib/temporal/update_str3ds_metadata_template.sql
grass/trunk/lib/temporal/update_strds_metadata_template.sql
grass/trunk/lib/temporal/update_stvds_metadata_template.sql
grass/trunk/temporal/Makefile
grass/trunk/temporal/tgisintro.html
grass/trunk/temporal/tr.register/register_ECAD_maps_temp_mean_1995_2010.py
grass/trunk/temporal/tr3.register/
grass/trunk/temporal/tr3.register/Makefile
grass/trunk/temporal/tr3.register/test.tr3.register.sh
grass/trunk/temporal/tr3.register/tr3.register.html
grass/trunk/temporal/tr3.register/tr3.register.py
grass/trunk/temporal/tr3.unregister/
grass/trunk/temporal/tr3.unregister/Makefile
grass/trunk/temporal/tr3.unregister/tr3.unregister.html
grass/trunk/temporal/tr3.unregister/tr3.unregister.py
grass/trunk/temporal/tv.register/
grass/trunk/temporal/tv.register/Makefile
grass/trunk/temporal/tv.register/test.tv.register.sh
grass/trunk/temporal/tv.register/tv.register.html
grass/trunk/temporal/tv.register/tv.register.py
grass/trunk/temporal/tv.unregister/
grass/trunk/temporal/tv.unregister/Makefile
grass/trunk/temporal/tv.unregister/tv.unregister.html
grass/trunk/temporal/tv.unregister/tv.unregister.py
grass/trunk/Makefile
grass/trunk/lib/Makefile
grass/trunk/lib/python/__init__.py
grass/trunk/lib/python/tgis_abstract_datasets.py
grass/trunk/lib/python/tgis_base.py
grass/trunk/lib/python/tgis_core.py
grass/trunk/lib/python/tgis_space_time_datasets.py
grass/trunk/lib/temporal/stds_map_register_table_template.sql
grass/trunk/lib/temporal/stds_raster3d_register_trigger_template.sql
grass/trunk/lib/temporal/stds_raster_register_trigger_template.sql
grass/trunk/temporal/t.list/t.list.py
grass/trunk/temporal/t.remove/t.remove.py
grass/trunk/temporal/tr.register/test.tr.register.sh
grass/trunk/temporal/tr.register/tr.register.py
grass/trunk/temporal/tr.unregister/tr.unregister.py
TGIS registration modules for raster, raster3d and vector maps implemented.
Modified: grass/trunk/Makefile
--- grass/trunk/Makefile 2011-09-16 19:00:16 UTC (rev 48325)
+++ grass/trunk/Makefile 2011-09-16 23:05:45 UTC (rev 48326)
@@ -35,6 +35,7 @@
raster \
raster3d \
vector \
+ temporal \
misc \
imagery \
ps \
Modified: grass/trunk/lib/Makefile
--- grass/trunk/lib/Makefile 2011-09-16 19:00:16 UTC (rev 48325)
+++ grass/trunk/lib/Makefile 2011-09-16 23:05:45 UTC (rev 48326)
@@ -44,6 +44,7 @@
nviz \
python \
iostream \
+ temporal \
manage
include $(MODULE_TOPDIR)/include/Make/Dir.make
Modified: grass/trunk/lib/python/__init__.py
--- grass/trunk/lib/python/__init__.py 2011-09-16 19:00:16 UTC (rev 48325)
+++ grass/trunk/lib/python/__init__.py 2011-09-16 23:05:45 UTC (rev 48326)
@@ -4,6 +4,7 @@
from raster3d import *
from vector import *
# Temporal GIS library functions
+from tgis_core import *
from tgis_base import *
from tgis_temporal_extent import *
from tgis_spatial_extent import *
Modified: grass/trunk/lib/python/tgis_abstract_datasets.py
--- grass/trunk/lib/python/tgis_abstract_datasets.py 2011-09-16 19:00:16 UTC (rev 48325)
+++ grass/trunk/lib/python/tgis_abstract_datasets.py 2011-09-16 23:05:45 UTC (rev 48326)
@@ -156,7 +156,7 @@
return None
def temporal_relation(self, map):
- """Return the temporal relation of this and the provided temporal raster map"""
+ """Return the temporal relation of this and the provided temporal map"""
if self.is_time_absolute() and map.is_time_absolute():
return self.absolute_time.temporal_relation(map.absolute_time)
if self.is_time_relative() and map.is_time_relative():
@@ -168,8 +168,6 @@
class abstract_map_dataset(abstract_dataset):
"""This is the base class for all maps (raster, vector, raster3d)
providing additional function to set the valid time and the spatial extent.
- Valid time and spatial extent will be set automatically in the space-time datasets
def get_new_stds_instance(self, ident):
@@ -280,9 +278,12 @@
for row in rows:
# Create a space time dataset object to remove the map
# from its register
- strds = self.get_new_stds_instance(row["id"])
- strds.select()
- strds.unregister_map(self)
+ stds = self.get_new_stds_instance(row["id"])
+ stds.select()
+ stds.unregister_map(self)
+ # Take care to update the space time dataset after
+ # the map has been unregistred
+ stds.update_from_registered_maps()
@@ -372,7 +373,8 @@
This method takes care of the registration of a map
in a space time dataset.
- Break with a warning in case the map is already registered.
+ In case the map is already registered this function will break with a warning
+ and return False
if map.is_in_db() == False:
@@ -408,8 +410,8 @@
self.base.close()
# In case of no entry make a new one
if row and row[0] == map_id:
- core.warning("Map " + map_id + "is already registered. Will unregister map and register again.")
- self.unregister_map(map)
+ core.warning("Map " + map_id + "is already registered.")
+ return False
# Create tables
sql_path = get_sql_template_path()
@@ -449,22 +451,34 @@
sql = sql.replace("SPACETIME_ID", self.base.get_id())
sql = sql.replace("STDS", self.get_type())
+ sql_script = ""
+ sql_script += "BEGIN TRANSACTION;\n"
+ sql_script += sql
+ sql_script += "\n"
+ sql_script += "END TRANSACTION;"
self.base.connect()
- self.base.cursor.executescript(sql)
+ self.base.cursor.executescript(sql_script)
self.base.close()
- # We need raster specific trigger
- sql = open(os.path.join(sql_path, "stds_" + map.get_type() + "_register_trigger_template.sql"), 'r').read()
- # Create the raster, raster3d and vector tables
- sql = sql.replace("GRASS_MAP", map.get_type())
- sql = sql.replace("SPACETIME_NAME", stds_name + "_" + stds_mapset )
- sql = sql.replace("SPACETIME_ID", self.base.get_id())
- sql = sql.replace("STDS", self.get_type())
+ # Trigger have been disabled due to peformance issues while registration
+ ## We need raster specific trigger
+ #sql = open(os.path.join(sql_path, "stds_" + map.get_type() + "_register_trigger_template.sql"), 'r').read()
+ #sql = sql.replace("GRASS_MAP", map.get_type())
+ #sql = sql.replace("SPACETIME_NAME", stds_name + "_" + stds_mapset )
+ #sql = sql.replace("SPACETIME_ID", self.base.get_id())
+ #sql = sql.replace("STDS", self.get_type())
- self.base.connect()
- self.base.close()
+ #sql_script = ""
+ #sql_script += "BEGIN TRANSACTION;\n"
+ #sql_script += sql
+ #sql_script += "\n"
+ #sql_script += "END TRANSACTION;"
+ #self.base.connect()
+ #self.base.cursor.executescript(sql_script)
+ #self.base.close()
stds_register_table = stds_name + "_" + stds_mapset + "_" + map.get_type() + "_register"
# Set the map register table name and put it into the DB
@@ -499,10 +513,10 @@
return True
def unregister_map(self, map):
- """Remove a register a map from the space time dataset.
+ """Unregister a map from the space time dataset.
This method takes care of the unregistration of a map
- in a space time dataset.
+ from a space time dataset.
@@ -543,3 +557,50 @@
self.base.connect()
self.base.cursor.execute(sql, (map_id,))
self.base.close()
+ def update_from_registered_maps(self):
+ """This methods updates the spatial and temporal extent as well as
+ type specific metadata. It should always been called after maps are registered
+ or unregistered/deleted from the space time dataset.
+ An other solution to automate this is to use the diactivated trigger
+ in the SQL files. But this will result in a huge performance issue
+ in case many maps are registred (>1000).
+ core.info("Update metadata, spatial and temporal extent from all registered maps of <" + self.get_id() + ">")
+ # Get basic info
+ stds_name = self.base.get_name()
+ stds_mapset = self.base.get_mapset()
+ sql_path = get_sql_template_path()
+ #We create a transaction
+ sql_script = ""
+ # Update the spatial and temporal extent from registered maps
+ # Read the SQL template
+ sql = open(os.path.join(sql_path, "update_stds_spatial_temporal_extent_template.sql"), 'r').read()
+ sql = sql.replace("GRASS_MAP", self.get_new_map_instance(None).get_type())
+ sql = sql.replace("SPACETIME_NAME", stds_name + "_" + stds_mapset )
+ sql = sql.replace("SPACETIME_ID", self.base.get_id())
+ sql = sql.replace("STDS", self.get_type())
+ sql_script += sql
+ # Update type specific metadata
+ sql = open(os.path.join(sql_path, "update_" + self.get_type() + "_metadata_template.sql"), 'r').read()
+ sql_script += sql
+ self.base.connect()
+ self.base.close()
Modified: grass/trunk/lib/python/tgis_base.py
--- grass/trunk/lib/python/tgis_base.py 2011-09-16 19:00:16 UTC (rev 48325)
+++ grass/trunk/lib/python/tgis_base.py 2011-09-16 23:05:45 UTC (rev 48326)
@@ -2,11 +2,12 @@
@brief GRASS Python scripting module (temporal GIS functions)
-Temporal GIS basic functions and classes to be used in other
+Temporal GIS base classes to be used in other
Python temporal gis packages.
This packages includes all base classes to stor basic information like id, name,
-mapset creation and modification time.
+mapset creation and modification time as well as sql serialization and deserialization
+and the sqlite3 database interface.
Usage:
@@ -27,6 +28,217 @@
+class dict_sql_serializer(object):
+ def __init__(self):
+ self.D = {}
+ def serialize(self, type, table, where=None):
+ """Convert the internal dictionary into a string of semicolon separated SQL statements
+ The keys are the colum names and the values are the row entries
+ @type must be SELECT. INSERT, UPDATE
+ @table The name of the table to select, insert or update
+ @where The optinal where statment
+ @return the sql string
+ sql = ""
+ args = []
+ # Create ordered select statement
+ if type == "SELECT":
+ sql += 'SELECT '
+ count = 0
+ for key in self.D.keys():
+ if count == 0:
+ sql += ' %s ' % key
+ else:
+ sql += ' , %s ' % key
+ count += 1
+ sql += ' FROM ' + table + ' '
+ if where:
+ sql += where
+ # Create insert statement
+ if type =="INSERT":
+ count = 0
+ sql += 'INSERT INTO ' + table + ' ('
+ if count == 0:
+ else:
+ sql += ' ,%s ' % key
+ count += 1
+ count = 0
+ sql += ') VALUES ('
+ if count == 0:
+ sql += '?'
+ else:
+ sql += ',?'
+ count += 1
+ args.append(self.D[key])
+ sql += ') '
+ if where:
+ sql += where
+ # Create update statement
+ if type =="UPDATE":
+ count = 0
+ sql += 'UPDATE ' + table + ' SET '
+ # Update only entries which are not None
+ if self.D[key] != None:
+ if count == 0:
+ sql += ' %s = ? ' % key
+ else:
+ sql += ' ,%s = ? ' % key
+ count += 1
+ if where:
+ sql += where
+ return sql, tuple(args)
+ def deserialize(self, row):
+ """Convert the content of the sqlite row into the internal dictionary"""
+ self.D = {}
+ for key in row.keys():
+ self.D[key] = row[key]
+ def clear(self):
+ """Remove all the content of this class"""
+ self.D = {}
+ def print_self(self):
+ print self.D
+ def test(self):
+ t = dict_sql_serializer()
+ t.D["id"] = "soil at PERMANENT"
+ t.D["name"] = "soil"
+ t.D["mapset"] = "PERMANENT"
+ t.D["creator"] = "soeren"
+ t.D["creation_time"] = datetime.now()
+ t.D["modification_time"] = datetime.now()
+ t.D["revision"] = 1
+ sql, values = t.serialize(type="SELECT", table="raster_base")
+ print sql, '\n', values
+ sql, values = t.serialize(type="INSERT", table="raster_base")
+ sql, values = t.serialize(type="UPDATE", table="raster_base")
+class sql_database_interface(dict_sql_serializer):
+ """This is the sql database interface to sqlite3"""
+ def __init__(self, table=None, ident=None, database=None):
+ dict_sql_serializer.__init__(self)
+ self.table = table # Name of the table, set in the subclass
+ if database == None:
+ self.database = get_grass_location_db_path()
+ else:
+ self.database = database
+ self.ident = ident
+ def get_table_name(self):
+ return self.table
+ def connect(self):
+ self.connection = sqlite3.connect(self.database, detect_types=sqlite3.PARSE_DECLTYPES|sqlite3.PARSE_COLNAMES)
+ self.connection.row_factory = sqlite3.Row
+ self.cursor = self.connection.cursor()
+ def close(self):
+ self.connection.commit()
+ self.cursor.close()
+ def get_delete_statement(self):
+ return "DELETE FROM " + self.get_table_name() + " WHERE id = \"" + str(self.ident) + "\""
+ def delete(self):
+ self.connect()
+ sql = self.get_delete_statement()
+ #print sql
+ self.cursor.execute(sql)
+ self.close()
+ def get_is_in_db_statement(self):
+ return "SELECT id FROM " + self.get_table_name() + " WHERE id = \"" + str(self.ident) + "\""
+ def is_in_db(self):
+ self.connect()
+ sql = self.get_is_in_db_statement()
+ #print sql
+ row = self.cursor.fetchone()
+ self.close()
+ # Nothing found
+ if row == None:
+ return False
+ return True
+ def get_select_statement(self):
+ return self.serialize("SELECT", self.get_table_name(), "WHERE id = \"" + str(self.ident) + "\"")
+ def select(self):
+ self.connect()
+ sql, args = self.get_select_statement()
+ #print sql
+ #print args
+ if len(args) == 0:
+ else:
+ self.cursor.execute(sql, args)
+ # Nothing found
+ if row == None:
+ return False
+ if len(row) > 0:
+ self.deserialize(row)
+ else:
+ raise IOError
+ self.close()
+ return True
+ def get_insert_statement(self):
+ return self.serialize("INSERT", self.get_table_name())
+ def insert(self):
+ self.connect()
+ sql, args = self.get_insert_statement()
+ #print sql
+ #print args
+ self.close()
+ def get_update_statement(self):
+ return self.serialize("UPDATE", self.get_table_name(), "WHERE id = \"" + str(self.ident) + "\"")
+ def update(self):
+ if self.ident == None:
+ raise IOError("Missing identifer");
+ sql, args = self.get_update_statement()
+ #print sql
+ #print args
+ self.connect()
+ self.close()
class dataset_base(sql_database_interface):
"""This is the base class for all maps and spacetime datasets storing basic information"""
def __init__(self, table=None, ident=None, name=None, mapset=None, creator=None, ctime=None,\
Modified: grass/trunk/lib/python/tgis_core.py
--- grass/trunk/lib/python/tgis_core.py 2011-09-16 19:00:16 UTC (rev 48325)
+++ grass/trunk/lib/python/tgis_core.py 2011-09-16 23:05:45 UTC (rev 48326)
@@ -2,11 +2,8 @@
-Temporal GIS core functions to be used in Python tgis packages.
+Temporal GIS core functions to be used in Python sripts.
-This class provides the SQL interface for serialization and deserialization
-of map and space time dataset data.
Usage:
@code
@@ -109,7 +106,7 @@
def increment_datetime(mydate, years=0, months=0, weeks=0, days=0, hours=0, minutes=0, seconds=0):
- """Return a new datetime object incremented with the provided relative dates"""
+ """Return a new datetime object incremented with the provided relative dates and times"""
tdelta_seconds = timedelta(seconds=seconds)
tdelta_minutes = timedelta(minutes=minutes)
@@ -217,212 +214,3 @@
connection.commit()
cursor.close()
-class dict_sql_serializer(object):
- def __init__(self):
- self.D = {}
- def serialize(self, type, table, where=None):
- """Convert the internal dictionary into a string of semicolon separated SQL statements
- The keys are the colum names and the values are the row entries
- @type must be SELECT. INSERT, UPDATE
- @table The name of the table to select, insert or update
- @where The optinal where statment
- @return the sql string
- sql = ""
- args = []
- # Create ordered select statement
- if type == "SELECT":
- sql += 'SELECT '
- count = 0
- for key in self.D.keys():
- if count == 0:
- sql += ' %s ' % key
- else:
- sql += ' , %s ' % key
- count += 1
- sql += ' FROM ' + table + ' '
- if where:
- sql += where
- # Create insert statement
- if type =="INSERT":
- count = 0
- sql += 'INSERT INTO ' + table + ' ('
- if count == 0:
- else:
- sql += ' ,%s ' % key
- count += 1
- count = 0
- sql += ') VALUES ('
- if count == 0:
- sql += '?'
- else:
- sql += ',?'
- count += 1
- args.append(self.D[key])
- sql += ') '
- if where:
- sql += where
- # Create update statement
- if type =="UPDATE":
- count = 0
- sql += 'UPDATE ' + table + ' SET '
- # Update only entries which are not None
- if self.D[key] != None:
- if count == 0:
- sql += ' %s = ? ' % key
- else:
- sql += ' ,%s = ? ' % key
- count += 1
- if where:
- sql += where
- return sql, tuple(args)
- def deserialize(self, row):
- """Convert the content of the sqlite row into the internal dictionary"""
- self.D = {}
- for key in row.keys():
- self.D[key] = row[key]
- def clear(self):
- """Remove all the content of this class"""
- self.D = {}
- def print_self(self):
- print self.D
- def test(self):
- t = dict_sql_serializer()
- t.D["id"] = "soil at PERMANENT"
- t.D["name"] = "soil"
- t.D["mapset"] = "PERMANENT"
- t.D["creator"] = "soeren"
- t.D["creation_time"] = datetime.now()
- t.D["modification_time"] = datetime.now()
- t.D["revision"] = 1
- sql, values = t.serialize(type="SELECT", table="raster_base")
- print sql, '\n', values
- sql, values = t.serialize(type="INSERT", table="raster_base")
- sql, values = t.serialize(type="UPDATE", table="raster_base")
-class sql_database_interface(dict_sql_serializer):
- """This is the sql database interface to sqlite3"""
- def __init__(self, table=None, ident=None, database=None):
- dict_sql_serializer.__init__(self)
- self.table = table # Name of the table, set in the subclass
- if database == None:
- self.database = get_grass_location_db_path()
- else:
- self.database = database
- self.ident = ident
- def get_table_name(self):
- return self.table
- def connect(self):
- self.connection = sqlite3.connect(self.database, detect_types=sqlite3.PARSE_DECLTYPES|sqlite3.PARSE_COLNAMES)
- self.connection.row_factory = sqlite3.Row
- self.cursor = self.connection.cursor()
- def close(self):
- self.connection.commit()
- self.cursor.close()
- def get_delete_statement(self):
- return "DELETE FROM " + self.get_table_name() + " WHERE id = \"" + str(self.ident) + "\""
- def delete(self):
- self.connect()
- sql = self.get_delete_statement()
- #print sql
- self.cursor.execute(sql)
- self.close()
- def get_is_in_db_statement(self):
- return "SELECT id FROM " + self.get_table_name() + " WHERE id = \"" + str(self.ident) + "\""
- def is_in_db(self):
- self.connect()
- sql = self.get_is_in_db_statement()
- #print sql
- row = self.cursor.fetchone()
- self.close()
- # Nothing found
- if row == None:
- return False
- return True
- def get_select_statement(self):
- return self.serialize("SELECT", self.get_table_name(), "WHERE id = \"" + str(self.ident) + "\"")
- def select(self):
- self.connect()
- sql, args = self.get_select_statement()
- #print sql
- #print args
- if len(args) == 0:
- else:
- self.cursor.execute(sql, args)
- # Nothing found
- if row == None:
- return False
- if len(row) > 0:
- self.deserialize(row)
- else:
- raise IOError
- self.close()
- return True
- def get_insert_statement(self):
- return self.serialize("INSERT", self.get_table_name())
- def insert(self):
- self.connect()
- sql, args = self.get_insert_statement()
- #print sql
- #print args
- self.close()
- def get_update_statement(self):
- return self.serialize("UPDATE", self.get_table_name(), "WHERE id = \"" + str(self.ident) + "\"")
- def update(self):
- if self.ident == None:
- raise IOError("Missing identifer");
- sql, args = self.get_update_statement()
- #print sql
- #print args
- self.connect()
- self.close()
Modified: grass/trunk/lib/python/tgis_space_time_datasets.py
--- grass/trunk/lib/python/tgis_space_time_datasets.py 2011-09-16 19:00:16 UTC (rev 48325)
+++ grass/trunk/lib/python/tgis_space_time_datasets.py 2011-09-16 23:05:45 UTC (rev 48326)
@@ -318,8 +318,9 @@
self.base = str3ds_base(ident=ident)
- self.base.set_name(self.ident.split("@")[0])
- self.base.set_mapset(self.ident.split("@")[1])
+ if ident != None:
+ self.base.set_name(self.ident.split("@")[0])
+ self.base.set_mapset(self.ident.split("@")[1])
self.base.set_creator(str(getpass.getuser()))
self.absolute_time = str3ds_absolute_time(ident=ident)
self.relative_time = str3ds_relative_time(ident=ident)
@@ -361,11 +362,193 @@
self.base = stvds_base(ident=ident)
+ if ident != None:
self.absolute_time = stvds_absolute_time(ident=ident)
self.relative_time = stvds_relative_time(ident=ident)
self.spatial_extent = stvds_spatial_extent(ident=ident)
self.metadata = stvds_metadata(ident=ident)
\ No newline at end of file
+def register_maps_in_space_time_dataset(type, name, maps, start=None, increment=None):
+ """Use this method to register maps in space time datasets. This function is generic and
+ can handle raster, vector and raster3d maps as well as there space time datasets.
+ Additionally a start time string and an increment string can be specified
+ to assign a time interval automatically to the maps.
+ It takes care of the correct update of the space time datasets from all
+ registered maps.
+ @type The type of the maps raster, raster3d or vector
+ @name The name of the space time dataset
+ @maps A comma separated list of map names
+ @start The start date and time of the first raster map, in case the map has no date (format absolute: "yyyy-mm-dd HH:MM:SS" or "yyyy-mm-dd", format relative 5.0)
+ @increment Time increment between maps for time stamp creation (format absolute: NNN seconds, minutes, hours, days, weeks, months, years; format relative: 1.0)
+ # We may need the mapset
+ mapset = core.gisenv()["MAPSET"]
+ # Check if the dataset name contains the mapset as well
+ if name.find("@") < 0:
+ id = name + "@" + mapset
+ else:
+ id = name
+ if type == "raster":
+ sp = space_time_raster_dataset(id)
+ if type == "raster3d":
+ sp = space_time_raster3d_dataset(id)
+ if type == "vector":
+ sp = space_time_vector_dataset(id)
+ # Read content from temporal database
+ sp.select()
+ if sp.is_in_db() == False:
+ core.fatal("Space time " + sp.get_new_map_instance(None).get_type() + " dataset <" + name + "> not found")
+ if maps.find(",") == -1:
+ maplist = (maps,)
+ else:
+ maplist = tuple(maps.split(","))
+ count = 0
+ for mapname in maplist:
+ mapname = mapname.strip()
+ # Check if the map name contains the mapset as well
+ if mapname.find("@") < 0:
+ mapid = mapname + "@" + mapset
+ else:
+ mapid = mapname
+ # Get a new instance of the space time dataset map type
+ map = sp.get_new_map_instance(mapid)
+ # In case the map is already registered print a message and continue to the next map
+ # Put the map into the database
+ if map.is_in_db() == False:
+ # Break in case no valid time is provided
+ if start == "" or start == None:
+ core.fatal("Unable to register " + map.get_type() + " map <" + map.get_id() + ">. The map has no valid time and the start time is not set.")
+ # Load the data from the grass file database
+ map.load()
+ # Put it into the temporal database
+ map.insert()
+ else:
+ map.select()
+ if map.get_temporal_type() != sp.get_temporal_type():
+ core.fatal("Unable to register " + map.get_type() + " map <" + map.get_id() + ">. The temporal types are different.")
+ # Set the valid time
+ if start:
+ assign_valid_time_to_map(sp.get_temporal_type(), map, start, increment, count)
+ # Finally Register map in the space time dataset
+ sp.register_map(map)
+ count += 1
+ # Update the space time tables
+ sp.update_from_registered_maps()
+def unregister_maps_from_space_time_datasets(type, name, maps):
+ """Unregister maps from a single space time dataset or, in case no dataset name is provided,
+ unregister from all datasets within the maps are registered.
+ @type The type of the maps raster, vector or raster3d
+ @name Name of an existing space time raster dataset. If no name is provided the raster map(s) are unregistered from all space time datasets in which they are registered.
+ @maps Name(s) of existing map(s) to unregister
+ # In case a space time dataset is specified
+ if name:
+ else:
+ id = name
+ # Build the list of maps
+ maplist = (maps,)
+ else:
+ else:
+ mapid = mapname
+ # Create a new instance with the map type
+ map = raster_dataset(mapid)
+ map = raster3d_dataset(mapid)
+ map = vector_dataset(mapid)
+ # Unregister map if in database
+ if map.is_in_db() == True:
+ if name:
+ sp.select()
+ sp.unregister_map(map)
+ else:
+ map.select()
+ map.unregister()
+ if name:
+def assign_valid_time_to_map(ttype, map, start, increment=None, mult=1):
+ """Assign the valid time to a map dataset
+ @ttype The temporal type which should be assigned and which the time format is of
+ @map A map dataset object derived from abstract_map_dataset
+ @multi A multiplier for the increment
+ if ttype == "absolute":
+ # Create the start time object
+ if start.find(":") > 0:
+ time_format = "%Y-%m-%d %H:%M:%S"
+ else:
+ time_format = "%Y-%m-%d"
+ start_time = datetime.strptime(start, time_format)
+ end_time = None
+ # Add the increment
+ if increment:
+ start_time = increment_datetime_by_string(start_time, increment, mult)
+ end_time = increment_datetime_by_string(start_time, increment, 1)
+ core.verbose("Set absolute valid time for map <" + map.get_id() + "> to " + str(start_time) + " - " + str(end_time))
+ map.update_absolute_time(start_time, end_time)
+ else:
+ if increment:
+ interval = float(start) + mult * float(increment)
+ else:
+ core.verbose("Set relative valid time for map <" + map.get_id() + "> to " + str(interval))
+ map.update_relative_time(interval)
Modified: grass/trunk/lib/temporal/stds_map_register_table_template.sql
--- grass/trunk/lib/temporal/stds_map_register_table_template.sql 2011-09-16 19:00:16 UTC (rev 48325)
+++ grass/trunk/lib/temporal/stds_map_register_table_template.sql 2011-09-16 23:05:45 UTC (rev 48326)
@@ -21,99 +21,100 @@
FOREIGN KEY (id) REFERENCES GRASS_MAP_base (id) ON DELETE CASCADE
-CREATE TRIGGER SPACETIME_NAME_GRASS_MAP_register_insert_trigger AFTER INSERT ON SPACETIME_NAME_GRASS_MAP_register
- BEGIN
- UPDATE STDS_base SET modification_time = datetime("NOW") WHERE id = "SPACETIME_ID";
- UPDATE STDS_base SET revision = (revision + 1) WHERE id = "SPACETIME_ID";
- -- Number of registered maps
- UPDATE STDS_metadata SET number_of_maps =
- (SELECT count(id) FROM SPACETIME_NAME_GRASS_MAP_register)
- WHERE id = "SPACETIME_ID";
- -- Update the temporal extent
- UPDATE STDS_absolute_time SET start_time =
- (SELECT min(start_time) FROM GRASS_MAP_absolute_time WHERE GRASS_MAP_absolute_time.id IN
- (SELECT id FROM SPACETIME_NAME_GRASS_MAP_register)
- ) WHERE id = "SPACETIME_ID";
- UPDATE STDS_absolute_time SET end_time =
- (SELECT max(end_time) FROM GRASS_MAP_absolute_time WHERE GRASS_MAP_absolute_time.id IN
- -- Update the spatial extent
- UPDATE STDS_spatial_extent SET north =
- (SELECT max(north) FROM GRASS_MAP_spatial_extent WHERE GRASS_MAP_spatial_extent.id IN
- UPDATE STDS_spatial_extent SET south =
- (SELECT min(south) FROM GRASS_MAP_spatial_extent WHERE GRASS_MAP_spatial_extent.id IN
- UPDATE STDS_spatial_extent SET east =
- (SELECT max(east) FROM GRASS_MAP_spatial_extent WHERE GRASS_MAP_spatial_extent.id IN
- UPDATE STDS_spatial_extent SET west =
- (SELECT min(west) FROM GRASS_MAP_spatial_extent WHERE GRASS_MAP_spatial_extent.id IN
- UPDATE STDS_spatial_extent SET top =
- (SELECT max(top) FROM GRASS_MAP_spatial_extent WHERE GRASS_MAP_spatial_extent.id IN
- UPDATE STDS_spatial_extent SET bottom =
- (SELECT min(bottom) FROM GRASS_MAP_spatial_extent WHERE GRASS_MAP_spatial_extent.id IN
- UPDATE STDS_spatial_extent SET proj =
- (SELECT min(proj) FROM GRASS_MAP_spatial_extent WHERE GRASS_MAP_spatial_extent.id IN
- END;
-CREATE TRIGGER SPACETIME_NAME_GRASS_MAP_register_delete_trigger AFTER DELETE ON SPACETIME_NAME_GRASS_MAP_register
- BEGIN
- END;
+-- Triggers are disabled due to huge performance issues
+--CREATE TRIGGER SPACETIME_NAME_GRASS_MAP_register_insert_trigger AFTER INSERT ON SPACETIME_NAME_GRASS_MAP_register
+-- BEGIN
+-- UPDATE STDS_base SET modification_time = datetime("NOW") WHERE id = "SPACETIME_ID";
+-- UPDATE STDS_base SET revision = (revision + 1) WHERE id = "SPACETIME_ID";
+-- -- Number of registered maps
+-- UPDATE STDS_metadata SET number_of_maps =
+-- (SELECT count(id) FROM SPACETIME_NAME_GRASS_MAP_register)
+-- WHERE id = "SPACETIME_ID";
+-- -- Update the temporal extent
+-- UPDATE STDS_absolute_time SET start_time =
+-- (SELECT min(start_time) FROM GRASS_MAP_absolute_time WHERE GRASS_MAP_absolute_time.id IN
+-- (SELECT id FROM SPACETIME_NAME_GRASS_MAP_register)
+-- ) WHERE id = "SPACETIME_ID";
+-- UPDATE STDS_absolute_time SET end_time =
+-- (SELECT max(end_time) FROM GRASS_MAP_absolute_time WHERE GRASS_MAP_absolute_time.id IN
+-- -- Update the spatial extent
+-- UPDATE STDS_spatial_extent SET north =
+-- (SELECT max(north) FROM GRASS_MAP_spatial_extent WHERE GRASS_MAP_spatial_extent.id IN
+-- UPDATE STDS_spatial_extent SET south =
+-- (SELECT min(south) FROM GRASS_MAP_spatial_extent WHERE GRASS_MAP_spatial_extent.id IN
+-- UPDATE STDS_spatial_extent SET east =
+-- (SELECT max(east) FROM GRASS_MAP_spatial_extent WHERE GRASS_MAP_spatial_extent.id IN
+-- UPDATE STDS_spatial_extent SET west =
+-- (SELECT min(west) FROM GRASS_MAP_spatial_extent WHERE GRASS_MAP_spatial_extent.id IN
+-- UPDATE STDS_spatial_extent SET top =
+-- (SELECT max(top) FROM GRASS_MAP_spatial_extent WHERE GRASS_MAP_spatial_extent.id IN
+-- UPDATE STDS_spatial_extent SET bottom =
+-- (SELECT min(bottom) FROM GRASS_MAP_spatial_extent WHERE GRASS_MAP_spatial_extent.id IN
+-- UPDATE STDS_spatial_extent SET proj =
+-- (SELECT min(proj) FROM GRASS_MAP_spatial_extent WHERE GRASS_MAP_spatial_extent.id IN
+-- END;
+--CREATE TRIGGER SPACETIME_NAME_GRASS_MAP_register_delete_trigger AFTER DELETE ON SPACETIME_NAME_GRASS_MAP_register
+-- BEGIN
+-- END;
Modified: grass/trunk/lib/temporal/stds_raster3d_register_trigger_template.sql
--- grass/trunk/lib/temporal/stds_raster3d_register_trigger_template.sql 2011-09-16 19:00:16 UTC (rev 48325)
+++ grass/trunk/lib/temporal/stds_raster3d_register_trigger_template.sql 2011-09-16 23:05:45 UTC (rev 48326)
@@ -10,95 +10,104 @@
PRAGMA foreign_keys = ON;
-CREATE TRIGGER SPACETIME_NAME_raster3d_metadata_register_insert_trigger AFTER INSERT ON SPACETIME_NAME_raster3d_register
- BEGIN
- -- Update the min and max values
- UPDATE str3ds_metadata SET min_min =
- (SELECT min(min) FROM raster3d_metadata WHERE raster3d_metadata.id IN
- (SELECT id FROM SPACETIME_NAME_raster3d_register)
- UPDATE str3ds_metadata SET min_max =
- (SELECT max(min) FROM raster3d_metadata WHERE raster3d_metadata.id IN
- UPDATE str3ds_metadata SET max_min =
- (SELECT min(max) FROM raster3d_metadata WHERE raster3d_metadata.id IN
- UPDATE str3ds_metadata SET max_max =
- (SELECT max(max) FROM raster3d_metadata WHERE raster3d_metadata.id IN
- -- Update the resolution
- UPDATE str3ds_metadata SET nsres_min =
- (SELECT min(nsres) FROM raster3d_metadata WHERE raster3d_metadata.id IN
- UPDATE str3ds_metadata SET nsres_max =
- (SELECT max(nsres) FROM raster3d_metadata WHERE raster3d_metadata.id IN
- UPDATE str3ds_metadata SET ewres_min =
- (SELECT min(ewres) FROM raster3d_metadata WHERE raster3d_metadata.id IN
- UPDATE str3ds_metadata SET ewres_max =
- (SELECT max(ewres) FROM raster3d_metadata WHERE raster3d_metadata.id IN
- UPDATE str3ds_metadata SET tbres_min =
- (SELECT min(tbres) FROM raster3d_metadata WHERE raster3d_metadata.id IN
- UPDATE str3ds_metadata SET tbres_max =
- (SELECT max(tbres) FROM raster3d_metadata WHERE raster3d_metadata.id IN
- END;
-CREATE TRIGGER SPACETIME_NAME_raster3d_metadata_register_delete_trigger AFTER DELETE ON SPACETIME_NAME_raster3d_register
- BEGIN
- END;
+--CREATE TRIGGER SPACETIME_NAME_raster3d_metadata_register_insert_trigger AFTER INSERT ON SPACETIME_NAME_raster3d_register
+-- BEGIN
+-- -- Update the min and max values
+-- UPDATE str3ds_metadata SET min_min =
+-- (SELECT min(min) FROM raster3d_metadata WHERE raster3d_metadata.id IN
+-- (SELECT id FROM SPACETIME_NAME_raster3d_register)
+-- UPDATE str3ds_metadata SET min_max =
+-- (SELECT max(min) FROM raster3d_metadata WHERE raster3d_metadata.id IN
+-- UPDATE str3ds_metadata SET max_min =
+-- (SELECT min(max) FROM raster3d_metadata WHERE raster3d_metadata.id IN
+-- UPDATE str3ds_metadata SET max_max =
+-- (SELECT max(max) FROM raster3d_metadata WHERE raster3d_metadata.id IN
+-- -- Update the resolution
+-- UPDATE str3ds_metadata SET nsres_min =
+-- (SELECT min(nsres) FROM raster3d_metadata WHERE raster3d_metadata.id IN
+-- UPDATE str3ds_metadata SET nsres_max =
+-- (SELECT max(nsres) FROM raster3d_metadata WHERE raster3d_metadata.id IN
+-- UPDATE str3ds_metadata SET ewres_min =
+-- (SELECT min(ewres) FROM raster3d_metadata WHERE raster3d_metadata.id IN
+-- UPDATE str3ds_metadata SET ewres_max =
+-- (SELECT max(ewres) FROM raster3d_metadata WHERE raster3d_metadata.id IN
+-- UPDATE str3ds_metadata SET tbres_min =
+-- (SELECT min(tbres) FROM raster3d_metadata WHERE raster3d_metadata.id IN
+-- UPDATE str3ds_metadata SET tbres_max =
+-- (SELECT max(tbres) FROM raster3d_metadata WHERE raster3d_metadata.id IN
+-- END;
+--CREATE TRIGGER SPACETIME_NAME_raster3d_metadata_register_delete_trigger AFTER DELETE ON SPACETIME_NAME_raster3d_register
+-- BEGIN
+-- END;
Modified: grass/trunk/lib/temporal/stds_raster_register_trigger_template.sql
--- grass/trunk/lib/temporal/stds_raster_register_trigger_template.sql 2011-09-16 19:00:16 UTC (rev 48325)
+++ grass/trunk/lib/temporal/stds_raster_register_trigger_template.sql 2011-09-16 23:05:45 UTC (rev 48326)
@@ -10,79 +10,104 @@
-CREATE TRIGGER SPACETIME_NAME_raster_metadata_register_insert_trigger AFTER INSERT ON SPACETIME_NAME_raster_register
- BEGIN
- UPDATE strds_metadata SET min_min =
- (SELECT min(min) FROM raster_metadata WHERE raster_metadata.id IN
- (SELECT id FROM SPACETIME_NAME_raster_register)
- UPDATE strds_metadata SET min_max =
- (SELECT max(min) FROM raster_metadata WHERE raster_metadata.id IN
- UPDATE strds_metadata SET max_min =
- (SELECT min(max) FROM raster_metadata WHERE raster_metadata.id IN
- UPDATE strds_metadata SET max_max =
- (SELECT max(max) FROM raster_metadata WHERE raster_metadata.id IN
- UPDATE strds_metadata SET nsres_min =
- (SELECT min(nsres) FROM raster_metadata WHERE raster_metadata.id IN
- UPDATE strds_metadata SET nsres_max =
- (SELECT max(nsres) FROM raster_metadata WHERE raster_metadata.id IN
- UPDATE strds_metadata SET ewres_min =
- (SELECT min(ewres) FROM raster_metadata WHERE raster_metadata.id IN
- UPDATE strds_metadata SET ewres_max =
- (SELECT max(ewres) FROM raster_metadata WHERE raster_metadata.id IN
- END;
-CREATE TRIGGER SPACETIME_NAME_raster_metadata_register_delete_trigger AFTER DELETE ON SPACETIME_NAME_raster_register
- BEGIN
- END;
+--CREATE TRIGGER SPACETIME_NAME_raster_metadata_register_insert_trigger AFTER INSERT ON SPACETIME_NAME_raster_register
+-- BEGIN
+-- UPDATE strds_metadata SET min_min =
+-- (SELECT min(min) FROM raster_metadata WHERE raster_metadata.id IN
+-- (SELECT id FROM SPACETIME_NAME_raster_register)
+-- UPDATE strds_metadata SET min_max =
+-- (SELECT max(min) FROM raster_metadata WHERE raster_metadata.id IN
+-- UPDATE strds_metadata SET max_min =
+-- (SELECT min(max) FROM raster_metadata WHERE raster_metadata.id IN
+-- UPDATE strds_metadata SET max_max =
+-- (SELECT max(max) FROM raster_metadata WHERE raster_metadata.id IN
+-- UPDATE strds_metadata SET nsres_min =
+-- (SELECT min(nsres) FROM raster_metadata WHERE raster_metadata.id IN
+-- UPDATE strds_metadata SET nsres_max =
+-- (SELECT max(nsres) FROM raster_metadata WHERE raster_metadata.id IN
+-- UPDATE strds_metadata SET ewres_min =
+-- (SELECT min(ewres) FROM raster_metadata WHERE raster_metadata.id IN
+-- UPDATE strds_metadata SET ewres_max =
+-- (SELECT max(ewres) FROM raster_metadata WHERE raster_metadata.id IN
+-- END;
+--CREATE TRIGGER SPACETIME_NAME_raster_metadata_register_delete_trigger AFTER DELETE ON SPACETIME_NAME_raster_register
+-- BEGIN
+-- END;
Added: grass/trunk/lib/temporal/update_stds_spatial_temporal_extent_template.sql
--- grass/trunk/lib/temporal/update_stds_spatial_temporal_extent_template.sql (rev 0)
+++ grass/trunk/lib/temporal/update_stds_spatial_temporal_extent_template.sql 2011-09-16 23:05:45 UTC (rev 48326)
@@ -0,0 +1,58 @@
+-- This SQL script is to update the spatial and temporal extent as well as
+-- the modifcation time and revision of a space time dataset. This script
+-- should be called when maps inserted or deleted in a space time dataset.
+-- Author: Soeren Gebbert soerengebbert <at> googlemail <dot> com
+-- SPACETIME_NAME is a placeholder for specific stds name (SQL compliant): name_mapset
+-- SPACETIME_ID is a placeholder for specific stds id: name at mapset
+-- GRASS_MAP is a placeholder for specific map type: raster, raster3d or vector
+-- STDS is a placeholder for specific space-time dataset type: strds, str3ds, stvds
+UPDATE STDS_base SET modification_time = datetime("NOW") WHERE id = "SPACETIME_ID";
+UPDATE STDS_base SET revision = (revision + 1) WHERE id = "SPACETIME_ID";
+-- Number of registered maps
+UPDATE STDS_metadata SET number_of_maps =
+ (SELECT count(id) FROM SPACETIME_NAME_GRASS_MAP_register)
+ WHERE id = "SPACETIME_ID";
+-- Update the temporal extent
+UPDATE STDS_absolute_time SET start_time =
+ (SELECT min(start_time) FROM GRASS_MAP_absolute_time WHERE GRASS_MAP_absolute_time.id IN
+ (SELECT id FROM SPACETIME_NAME_GRASS_MAP_register)
+ ) WHERE id = "SPACETIME_ID";
+UPDATE STDS_absolute_time SET end_time =
+ (SELECT max(end_time) FROM GRASS_MAP_absolute_time WHERE GRASS_MAP_absolute_time.id IN
+-- Update the spatial extent
+UPDATE STDS_spatial_extent SET north =
+ (SELECT max(north) FROM GRASS_MAP_spatial_extent WHERE GRASS_MAP_spatial_extent.id IN
+UPDATE STDS_spatial_extent SET south =
+ (SELECT min(south) FROM GRASS_MAP_spatial_extent WHERE GRASS_MAP_spatial_extent.id IN
+UPDATE STDS_spatial_extent SET east =
+ (SELECT max(east) FROM GRASS_MAP_spatial_extent WHERE GRASS_MAP_spatial_extent.id IN
+UPDATE STDS_spatial_extent SET west =
+ (SELECT min(west) FROM GRASS_MAP_spatial_extent WHERE GRASS_MAP_spatial_extent.id IN
+UPDATE STDS_spatial_extent SET top =
+ (SELECT max(top) FROM GRASS_MAP_spatial_extent WHERE GRASS_MAP_spatial_extent.id IN
+UPDATE STDS_spatial_extent SET bottom =
+ (SELECT min(bottom) FROM GRASS_MAP_spatial_extent WHERE GRASS_MAP_spatial_extent.id IN
+UPDATE STDS_spatial_extent SET proj =
+ (SELECT min(proj) FROM GRASS_MAP_spatial_extent WHERE GRASS_MAP_spatial_extent.id IN
Added: grass/trunk/lib/temporal/update_str3ds_metadata_template.sql
--- grass/trunk/lib/temporal/update_str3ds_metadata_template.sql (rev 0)
+++ grass/trunk/lib/temporal/update_str3ds_metadata_template.sql 2011-09-16 23:05:45 UTC (rev 48326)
@@ -0,0 +1,51 @@
+-- This SQL script is to update a space-time raster3d dataset metadata
+-- Update the min and max values
+UPDATE str3ds_metadata SET min_min =
+ (SELECT min(min) FROM raster3d_metadata WHERE raster3d_metadata.id IN
+ (SELECT id FROM SPACETIME_NAME_raster3d_register)
+UPDATE str3ds_metadata SET min_max =
+ (SELECT max(min) FROM raster3d_metadata WHERE raster3d_metadata.id IN
+UPDATE str3ds_metadata SET max_min =
+ (SELECT min(max) FROM raster3d_metadata WHERE raster3d_metadata.id IN
+UPDATE str3ds_metadata SET max_max =
+ (SELECT max(max) FROM raster3d_metadata WHERE raster3d_metadata.id IN
+-- Update the resolution
+UPDATE str3ds_metadata SET nsres_min =
+ (SELECT min(nsres) FROM raster3d_metadata WHERE raster3d_metadata.id IN
+UPDATE str3ds_metadata SET nsres_max =
+ (SELECT max(nsres) FROM raster3d_metadata WHERE raster3d_metadata.id IN
+UPDATE str3ds_metadata SET ewres_min =
+ (SELECT min(ewres) FROM raster3d_metadata WHERE raster3d_metadata.id IN
+UPDATE str3ds_metadata SET ewres_max =
+ (SELECT max(ewres) FROM raster3d_metadata WHERE raster3d_metadata.id IN
+UPDATE str3ds_metadata SET tbres_min =
+ (SELECT min(tbres) FROM raster3d_metadata WHERE raster3d_metadata.id IN
+UPDATE str3ds_metadata SET tbres_max =
+ (SELECT max(tbres) FROM raster3d_metadata WHERE raster3d_metadata.id IN
Added: grass/trunk/lib/temporal/update_strds_metadata_template.sql
--- grass/trunk/lib/temporal/update_strds_metadata_template.sql (rev 0)
+++ grass/trunk/lib/temporal/update_strds_metadata_template.sql 2011-09-16 23:05:45 UTC (rev 48326)
@@ -0,0 +1,43 @@
+-- This SQL is to update a space-time raster dataset metadata
+UPDATE strds_metadata SET min_min =
+ (SELECT min(min) FROM raster_metadata WHERE raster_metadata.id IN
+ (SELECT id FROM SPACETIME_NAME_raster_register)
+UPDATE strds_metadata SET min_max =
+ (SELECT max(min) FROM raster_metadata WHERE raster_metadata.id IN
+UPDATE strds_metadata SET max_min =
+ (SELECT min(max) FROM raster_metadata WHERE raster_metadata.id IN
+UPDATE strds_metadata SET max_max =
+ (SELECT max(max) FROM raster_metadata WHERE raster_metadata.id IN
+UPDATE strds_metadata SET nsres_min =
+ (SELECT min(nsres) FROM raster_metadata WHERE raster_metadata.id IN
+UPDATE strds_metadata SET nsres_max =
+ (SELECT max(nsres) FROM raster_metadata WHERE raster_metadata.id IN
+UPDATE strds_metadata SET ewres_min =
+ (SELECT min(ewres) FROM raster_metadata WHERE raster_metadata.id IN
+UPDATE strds_metadata SET ewres_max =
+ (SELECT max(ewres) FROM raster_metadata WHERE raster_metadata.id IN
Added: grass/trunk/lib/temporal/update_stvds_metadata_template.sql
--- grass/trunk/lib/temporal/update_stvds_metadata_template.sql (rev 0)
+++ grass/trunk/lib/temporal/update_stvds_metadata_template.sql 2011-09-16 23:05:45 UTC (rev 48326)
@@ -0,0 +1,6 @@
+-- This SQL script is for now a placeholder, till the vector metadata
+-- concept is clear
Added: grass/trunk/temporal/Makefile
--- grass/trunk/temporal/Makefile (rev 0)
+++ grass/trunk/temporal/Makefile 2011-09-16 23:05:45 UTC (rev 48326)
@@ -0,0 +1,22 @@
+MODULE_TOPDIR = ..
+SUBDIRS = \
+ t.create \
+ t.list \
+ t.info \
+ t.remove \
+ tr.register \
+ tr3.register \
+ tv.register \
+ tr.unregister \
+ tr3.unregister \
+ tv.unregister \
+PGM = tgisintro
+include $(MODULE_TOPDIR)/include/Make/Dir.make
+default: htmldir
+htmldir: parsubdirs
Modified: grass/trunk/temporal/t.list/t.list.py
--- grass/trunk/temporal/t.list/t.list.py 2011-09-16 19:00:16 UTC (rev 48325)
+++ grass/trunk/temporal/t.list/t.list.py 2011-09-16 23:05:45 UTC (rev 48326)
@@ -5,7 +5,7 @@
# MODULE: t.list
# AUTHOR(S): Soeren Gebbert
-# PURPOSE: List space time datasets
+# PURPOSE: List space time and map datasets
# COPYRIGHT: (C) 2011 by the GRASS Development Team
# This program is free software under the GNU General Public
@@ -33,7 +33,7 @@
#%option
#% key: sort
#% type: string
-#% description: Sort the space time dataset by category
+#% description: Sort the space time dataset by category. Columns number_of_maps and granularity only available fpr space time datasets
#% required: no
#% multiple: yes
#% options: id, name, creator, mapset, number_of_maps, creation_time, modification_time, start_time, end_time, interval, north, south, west, east, granularity
@@ -43,10 +43,10 @@
#%option
#% key: columns
#% type: string
-#% description: Which columns should be printed to stdout
+#% description: Which columns should be printed to stdout. Columns number_of_maps and granularity only available fpr space time datasets
#% required: no
#% multiple: yes
-#% options: id, name, creator, mapset, number_of_maps, creation_time, modification_time, start_time, end_time, interval, north, south, west, east, granularity, all
+#% options: id, name, creator, mapset, number_of_maps, creation_time, modification_time, revision, start_time, end_time, interval, north, south, west, east, granularity, all
#% answer: id
#%end
Modified: grass/trunk/temporal/t.remove/t.remove.py
--- grass/trunk/temporal/t.remove/t.remove.py 2011-09-16 19:00:16 UTC (rev 48325)
+++ grass/trunk/temporal/t.remove/t.remove.py 2011-09-16 23:05:45 UTC (rev 48326)
@@ -5,7 +5,7 @@
# MODULE: t.remove
-# PURPOSE: Remove a space time raster dataset
+# PURPOSE: Remove space time or map dataset
@@ -15,7 +15,7 @@
#%module
-#% description: Remove a space time and map datasets from temporal database
+#% description: Remove space time or map datasets from temporal database
#% keywords: spacetime
#% keywords: dataset
#% keywords: remove
@@ -62,24 +62,24 @@
id = name
if type == "strds":
- sp = grass.space_time_raster_dataset(id)
+ ds = grass.space_time_raster_dataset(id)
if type == "str3ds":
- sp = grass.space_time_raster3d_dataset(id)
+ ds = grass.space_time_raster3d_dataset(id)
if type == "stvds":
- sp = grass.space_time_vector_dataset(id)
+ ds = grass.space_time_vector_dataset(id)
- sp = grass.raster_dataset(id)
+ ds = grass.raster_dataset(id)
- sp = grass.raster3d_dataset(id)
+ ds = grass.raster3d_dataset(id)
- sp = grass.vector_dataset(id)
+ ds = grass.vector_dataset(id)
- if sp.is_in_db() == False:
- grass.fatal("Dataset <" + name + "> not found in temporal database")
+ if ds.is_in_db() == False:
+ grass.fatal(ds.get_type() + " dataset <" + name + "> not found in temporal database")
# We need to read some data from the temporal database
- sp.select()
- sp.delete()
+ ds.select()
+ ds.delete()
if __name__ == "__main__":
options, flags = grass.core.parser()
Added: grass/trunk/temporal/tgisintro.html
Added: grass/trunk/temporal/tr.register/register_ECAD_maps_temp_mean_1995_2010.py
--- grass/trunk/temporal/tr.register/register_ECAD_maps_temp_mean_1995_2010.py (rev 0)
+++ grass/trunk/temporal/tr.register/register_ECAD_maps_temp_mean_1995_2010.py 2011-09-16 23:05:45 UTC (rev 48326)
@@ -0,0 +1,23 @@
+# This is an example script how to register imported ECA&D temperature data for Europe
+# in the temporal database of grass assigning valid time
+import grass.script as grass
+# Create the space time raster dataset with t.create
+dataset = "temp_mean_1995_2010_daily"
+grass.run_command("t.create", type="strds", dataset=dataset, granularity="1 days", semantic="continuous", temporal="absolute", title="European mean temperature 1995-2010", description="The european daily mean temperature 1995 - 2010 from ECA&D ")
+name = "temp_mean."
+maps=""
+#for i in range(6025):
+for i in range(365):
+ inc = i + 1
+ map_name = name + str(inc)
+ if i == 0:
+ maps += map_name
+ else:
+ maps += "," + map_name
+# Register all maps at once
+grass.run_command("tr.register", dataset=dataset, maps=maps, start="1995-01-01", increment="1 days")
Modified: grass/trunk/temporal/tr.register/test.tr.register.sh
--- grass/trunk/temporal/tr.register/test.tr.register.sh 2011-09-16 19:00:16 UTC (rev 48325)
+++ grass/trunk/temporal/tr.register/test.tr.register.sh 2011-09-16 23:05:45 UTC (rev 48326)
@@ -17,7 +17,6 @@
r.mapcalc --o expr="prec_5 = rand(0, 300)"
r.mapcalc --o expr="prec_6 = rand(0, 650)"
# The first @test
# We create the space time raster datasets and register the raster maps with absolute time interval
@@ -53,7 +52,10 @@
tr.register dataset=precip_abs7 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-01-01" increment="20 years, 3 months, 1 days, 4 hours"
t.info type=strds dataset=precip_abs7
+# Register with different valid time again
+tr.register dataset=precip_abs7 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-01-01" increment="99 years, 9 months, 9 days, 9 hours"
+t.info type=strds dataset=precip_abs7
t.remove --v type=raster dataset=prec_1,prec_2,prec_3
t.remove --v type=strds dataset=precip_abs1,precip_abs2,precip_abs3,precip_abs4,precip_abs5,precip_abs6,precip_abs7
-t.remove --v type=raster dataset=prec_4,prec_5,prec_6
+t.remove --v type=raster dataset=prec_4,prec_5,prec_6
Modified: grass/trunk/temporal/tr.register/tr.register.py
--- grass/trunk/temporal/tr.register/tr.register.py 2011-09-16 19:00:16 UTC (rev 48325)
+++ grass/trunk/temporal/tr.register/tr.register.py 2011-09-16 23:05:45 UTC (rev 48326)
@@ -5,7 +5,7 @@
# MODULE: tr.register
-# PURPOSE: Register a raster map in a space time raster dataset
+# PURPOSE: Register raster maps in a space time raster dataset
@@ -39,7 +39,7 @@
#%option
#% key: start
#% type: string
-#% description: The start date and time of the first raster map, in case the map has no date (format absolute: "yyyy-mm-dd HH:MM:SS", format relative 5.0)
+#% description: The valid start date and time of the first raster map, in case the map has no valid time (format absolute: "yyyy-mm-dd HH:MM:SS", format relative 5.0)
#% required: no
#% multiple: no
#%end
@@ -47,17 +47,15 @@
#%option
#% key: increment
#% type: string
-#% description: Time increment between maps for time stamp creation (format absolute: NNN seconds, minutes, hours, days, weeks, months, years; format relative: 1.0)
+#% description: Time increment between maps for valid time interval creation (format absolute: NNN seconds, minutes, hours, days, weeks, months, years; format relative: 1.0)
#% required: no
#% multiple: no
#%end
-import datetime
-from copy import *
def main():
# Get the options
@@ -68,70 +66,9 @@
# Make sure the temporal database exists
grass.create_temporal_database()
- mapset = grass.gisenv()["MAPSET"]
- id = name + "@" + mapset
- # Insert content from db
- sp.select()
+ # Register maps
+ grass.register_maps_in_space_time_dataset("raster", name, maps, start, increment)
- grass.fatal("Space time " + sp.get_new_map_instance(None).get_type() + " dataset <" + name + "> not found")
- if maps.find(",") == -1:
- maplist = (maps,)
- else:
- maplist = tuple(maps.split(","))
- count = 0
- for mapname in maplist:
- mapid = mapname + "@" + mapset
- map = grass.raster_dataset(mapid)
- # In case the map is already registered print a message and continue to the next map
- # Put the map into the database
- if map.is_in_db() == False:
- map.load()
- map.insert()
- else:
- map.select()
- if map.get_temporal_type() != sp.get_temporal_type():
- grass.fatal("Unable to register map <" + map.get_id() + ">. The temporal types are different.")
- # Set the time interval
- if start:
- if sp.is_time_absolute():
- # Create the start time object
- if start.find(":") > 0:
- time_format = "%Y-%m-%d %H:%M:%S"
- else:
- time_format = "%Y-%m-%d"
- start_time = datetime.datetime.strptime(start, time_format)
- end_time = None
- # Add the increment
- if increment:
- start_time = grass.increment_datetime_by_string(start_time, increment, count)
- end_time = grass.increment_datetime_by_string(start_time, increment, 1)
- grass.verbose("Set absolute time interval for map <" + mapid + "> to " + str(start_time) + " - " + str(end_time))
- map.update_absolute_time(start_time, end_time)
- else:
- if increment:
- interval = float(start) + count * float(increment)
- else:
- grass.verbose("Set relative time interval for map <" + mapid + "> to " + str(interval))
- map.update_relative_time(interval)
- # Register map
- sp.register_map(map)
- count += 1
main()
Modified: grass/trunk/temporal/tr.unregister/tr.unregister.py
--- grass/trunk/temporal/tr.unregister/tr.unregister.py 2011-09-16 19:00:16 UTC (rev 48325)
+++ grass/trunk/temporal/tr.unregister/tr.unregister.py 2011-09-16 23:05:45 UTC (rev 48326)
@@ -15,7 +15,7 @@
#%module
-#% description: Unregister raster map(s) from a specific or all space time raster dataset in which it is registered
+#% description: Unregister raster map(s) from a specific or from all space time raster dataset in which it is registered
#% keywords: spacetime raster dataset
#% keywords: raster
#%end
@@ -47,39 +47,9 @@
+ # Unregister maps
+ grass.unregister_maps_from_space_time_datasets("raster", name, maps)
- # In case a space time raster dataset is specified
- if name:
- # Read content from db
- sp.select()
- # Build the list of maps
- maplist = (maps,)
- else:
- # Unregister map if in database
- if map.is_in_db() == True:
- if name:
- sp.unregister_map(map)
- else:
- map.select()
- map.unregister()
main()
Added: grass/trunk/temporal/tr3.register/Makefile
--- grass/trunk/temporal/tr3.register/Makefile (rev 0)
+++ grass/trunk/temporal/tr3.register/Makefile 2011-09-16 23:05:45 UTC (rev 48326)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../../
+PGM = tr3.register
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script $(TEST_DST)
Added: grass/trunk/temporal/tr3.register/test.tr3.register.sh
--- grass/trunk/temporal/tr3.register/test.tr3.register.sh (rev 0)
+++ grass/trunk/temporal/tr3.register/test.tr3.register.sh 2011-09-16 23:05:45 UTC (rev 48326)
@@ -0,0 +1,61 @@
+# This is a test to register and unregister raster3d maps in
+# space time raster3d dataset.
+# The raster3d maps will be registered in different space time raster3d
+# datasets
+# We need to set a specific region in the
+# @preprocess step of this test. We generate
+# 3d raster with r3.mapcalc and create two space time raster3d datasets
+# with relative and absolute time
+# The region setting should work for UTM and LL test locations
+g.region s=0 n=80 w=0 e=120 b=0 t=50 res=10 res3=10 -p3
+r3.mapcalc --o expr="volume_1 = rand(0, 550)"
+r3.mapcalc --o expr="volume_2 = rand(0, 450)"
+r3.mapcalc --o expr="volume_3 = rand(0, 320)"
+r3.mapcalc --o expr="volume_4 = rand(0, 510)"
+r3.mapcalc --o expr="volume_5 = rand(0, 300)"
+r3.mapcalc --o expr="volume_6 = rand(0, 650)"
+# The first @test
+# We create the space time raster3d datasets and register the raster3d maps with absolute time interval
+t.create --v --o type=str3ds temporaltype=absolute dataset=volume_abs1 gran="1 senconds" title="A test" descr="A test"
+t.create --v --o type=str3ds temporaltype=absolute dataset=volume_abs2 gran="1 minutes" title="A test" descr="A test"
+t.create --v --o type=str3ds temporaltype=absolute dataset=volume_abs3 gran="1 hours" title="A test" descr="A test"
+t.create --v --o type=str3ds temporaltype=absolute dataset=volume_abs4 gran="1 days" title="A test" descr="A test"
+t.create --v --o type=str3ds temporaltype=absolute dataset=volume_abs5 gran="1 weeks" title="A test" descr="A test"
+t.create --v --o type=str3ds temporaltype=absolute dataset=volume_abs6 gran="1 months" title="A test" descr="A test"
+t.create --v --o type=str3ds temporaltype=absolute dataset=volume_abs7 gran="1 years" title="A test" descr="A test"
+tr3.register --v dataset=volume_abs1 maps=volume_1,volume_2,volume_3,volume_4,volume_5,volume_6 start="2001-01-01" increment="1 seconds"
+t.info type=str3ds dataset=volume_abs1
+tr3.unregister --v dataset=volume_abs1 maps=volume_1,volume_2,volume_3,volume_4,volume_5,volume_6
+tr3.register --v dataset=volume_abs2 maps=volume_1,volume_2,volume_3,volume_4,volume_5,volume_6 start="2001-01-01" increment="20 seconds, 5 minutes"
+t.info type=str3ds dataset=volume_abs2
+tr3.register --v dataset=volume_abs3 maps=volume_1,volume_2,volume_3,volume_4,volume_5,volume_6 start="2001-01-01" increment="8 hours"
+t.info type=str3ds dataset=volume_abs3
+tr3.unregister --v maps=volume_1,volume_2,volume_3,volume_4,volume_5,volume_6
+tr3.register dataset=volume_abs4 maps=volume_1,volume_2,volume_3,volume_4,volume_5,volume_6 start="2001-01-01" increment="3 days"
+t.info type=str3ds dataset=volume_abs4
+tr3.register dataset=volume_abs5 maps=volume_1,volume_2,volume_3,volume_4,volume_5,volume_6 start="2001-01-01" increment="4 weeks"
+t.info type=str3ds dataset=volume_abs5
+tr3.register dataset=volume_abs6 maps=volume_1,volume_2,volume_3,volume_4,volume_5,volume_6 start="2001-08-01" increment="2 months"
+t.info type=str3ds dataset=volume_abs6
+tr3.register dataset=volume_abs7 maps=volume_1,volume_2,volume_3,volume_4,volume_5,volume_6 start="2001-01-01" increment="20 years, 3 months, 1 days, 4 hours"
+t.info type=str3ds dataset=volume_abs7
+tr3.register dataset=volume_abs7 maps=volume_1,volume_2,volume_3,volume_4,volume_5,volume_6 start="2001-01-01" increment="99 years, 9 months, 9 days, 9 hours"
+t.remove --v type=raster3d dataset=volume_1,volume_2,volume_3
+t.remove --v type=str3ds dataset=volume_abs1,volume_abs2,volume_abs3,volume_abs4,volume_abs5,volume_abs6,volume_abs7
+t.remove --v type=raster3d dataset=volume_4,volume_5,volume_6
Added: grass/trunk/temporal/tr3.register/tr3.register.html
Added: grass/trunk/temporal/tr3.register/tr3.register.py
--- grass/trunk/temporal/tr3.register/tr3.register.py (rev 0)
+++ grass/trunk/temporal/tr3.register/tr3.register.py 2011-09-16 23:05:45 UTC (rev 48326)
@@ -0,0 +1,75 @@
+#!/usr/bin/env python
+# -*- coding: utf-8 -*-
+# MODULE: tr3.register
+# AUTHOR(S): Soeren Gebbert
+# PURPOSE: Register raster3d maps in a space time raster3d dataset
+# COPYRIGHT: (C) 2011 by the GRASS Development Team
+# This program is free software under the GNU General Public
+# License (version 2). Read the file COPYING that comes with GRASS
+# for details.
+#%module
+#% description: Register raster3d maps in a space time raster3d dataset
+#% keywords: spacetime raster dataset
+#% keywords: raster
+#%end
+#%option
+#% key: dataset
+#% type: string
+#% description: Name of an existing space time raster3d dataset
+#% required: yes
+#% multiple: no
+#%end
+#%option
+#% key: maps
+#% type: string
+#% description: Name(s) of existing raster3d map(s), multiple maps must be provided in temporal order in case datetime should be attached
+#% required: yes
+#% multiple: yes
+#%end
+#%option
+#% key: start
+#% type: string
+#% description: The valid start date and time of the first raster3d map, in case the map has no valid time (format absolute: "yyyy-mm-dd HH:MM:SS", format relative 5.0)
+#% required: no
+#% multiple: no
+#%end
+#%option
+#% key: increment
+#% type: string
+#% required: no
+#% multiple: no
+#%end
+def main():
+ # Get the options
+ name = options["dataset"]
+ maps = options["maps"]
+ start = options["start"]
+ increment = options["increment"]
+ # Make sure the temporal database exists
+ grass.create_temporal_database()
+ # Register maps
+ grass.register_maps_in_space_time_dataset("raster3d", name, maps, start, increment)
+if __name__ == "__main__":
+ options, flags = grass.core.parser()
+ main()
Property changes on: grass/trunk/temporal/tr3.register/tr3.register.py
___________________________________________________________________
Added: svn:executable
Added: grass/trunk/temporal/tr3.unregister/Makefile
--- grass/trunk/temporal/tr3.unregister/Makefile (rev 0)
+++ grass/trunk/temporal/tr3.unregister/Makefile 2011-09-16 23:05:45 UTC (rev 48326)
@@ -0,0 +1,7 @@
+PGM = tr3.unregister
Added: grass/trunk/temporal/tr3.unregister/tr3.unregister.html
Added: grass/trunk/temporal/tr3.unregister/tr3.unregister.py
--- grass/trunk/temporal/tr3.unregister/tr3.unregister.py (rev 0)
+++ grass/trunk/temporal/tr3.unregister/tr3.unregister.py 2011-09-16 23:05:45 UTC (rev 48326)
@@ -0,0 +1,56 @@
+# MODULE: tr3.unregister
+# PURPOSE: Unregister raster3d maps from space time raster3d datasets
+# for details.
+#%module
+#% description: Unregister raster3d map(s) from a specific or from all space time raster3d dataset in which it is registered
+#% keywords: spacetime raster3d dataset
+#% keywords: raster3d
+#%end
+#%option
+#% key: dataset
+#% type: string
+#% description: Name of an existing space time raster3d dataset. If no name is provided the raster3d map(s) are unregistered from all space time datasets in which they are registered.
+#% required: no
+#% multiple: no
+#%end
+#%option
+#% key: maps
+#% type: string
+#% description: Name(s) of existing raster3d map(s) to unregister
+#% required: yes
+#% multiple: yes
+#%end
+def main():
+ # Get the options
+ # Unregister maps
+ grass.unregister_maps_from_space_time_datasets("raster3d", name, maps)
+ main()
Property changes on: grass/trunk/temporal/tr3.unregister/tr3.unregister.py
Added: grass/trunk/temporal/tv.register/Makefile
--- grass/trunk/temporal/tv.register/Makefile (rev 0)
+++ grass/trunk/temporal/tv.register/Makefile 2011-09-16 23:05:45 UTC (rev 48326)
@@ -0,0 +1,7 @@
+PGM = tv.register
Added: grass/trunk/temporal/tv.register/test.tv.register.sh
--- grass/trunk/temporal/tv.register/test.tv.register.sh (rev 0)
+++ grass/trunk/temporal/tv.register/test.tv.register.sh 2011-09-16 23:05:45 UTC (rev 48326)
@@ -0,0 +1,61 @@
+# This is a test to register and unregister vector maps in
+# space time vector dataset.
+# The vector maps will be registered in different space time vector
+# datasets
+# vector with v.random and create several space time vector datasets
+# with absolute time
+v.random --o -z output=lidar_abs_1 n=20 zmin=0 zmax=100 column=height
+v.random --o -z output=lidar_abs_2 n=20 zmin=0 zmax=100 column=height
+v.random --o -z output=lidar_abs_3 n=20 zmin=0 zmax=100 column=height
+v.random --o -z output=lidar_abs_4 n=20 zmin=0 zmax=100 column=height
+v.random --o -z output=lidar_abs_5 n=20 zmin=0 zmax=100 column=height
+v.random --o -z output=lidar_abs_6 n=20 zmin=0 zmax=100 column=height
+# The first @test
+# We create the space time vector datasets and register the vector maps with absolute time interval
+t.create --v --o type=stvds temporaltype=absolute dataset=lidar_abs_ds1 gran="1 senconds" title="A test" descr="A test"
+t.create --v --o type=stvds temporaltype=absolute dataset=lidar_abs_ds2 gran="1 minutes" title="A test" descr="A test"
+t.create --v --o type=stvds temporaltype=absolute dataset=lidar_abs_ds3 gran="1 hours" title="A test" descr="A test"
+t.create --v --o type=stvds temporaltype=absolute dataset=lidar_abs_ds4 gran="1 days" title="A test" descr="A test"
+t.create --v --o type=stvds temporaltype=absolute dataset=lidar_abs_ds5 gran="1 weeks" title="A test" descr="A test"
+t.create --v --o type=stvds temporaltype=absolute dataset=lidar_abs_ds6 gran="1 months" title="A test" descr="A test"
+t.create --v --o type=stvds temporaltype=absolute dataset=lidar_abs_ds7 gran="1 years" title="A test" descr="A test"
+tv.register --v dataset=lidar_abs_ds1 maps=lidar_abs_1,lidar_abs_2,lidar_abs_3,lidar_abs_4,lidar_abs_5,lidar_abs_6 start="2001-01-01" increment="1 seconds"
+t.info type=stvds dataset=lidar_abs_ds1
+tv.unregister --v dataset=lidar_abs_ds1 maps=lidar_abs_1,lidar_abs_2,lidar_abs_3,lidar_abs_4,lidar_abs_5,lidar_abs_6
+tv.register --v dataset=lidar_abs_ds2 maps=lidar_abs_1,lidar_abs_2,lidar_abs_3,lidar_abs_4,lidar_abs_5,lidar_abs_6 start="2001-01-01" increment="20 seconds, 5 minutes"
+t.info type=stvds dataset=lidar_abs_ds2
+tv.register --v dataset=lidar_abs_ds3 maps=lidar_abs_1,lidar_abs_2,lidar_abs_3,lidar_abs_4,lidar_abs_5,lidar_abs_6 start="2001-01-01" increment="8 hours"
+t.info type=stvds dataset=lidar_abs_ds3
+tv.unregister --v maps=lidar_abs_1,lidar_abs_2,lidar_abs_3,lidar_abs_4,lidar_abs_5,lidar_abs_6
+tv.register dataset=lidar_abs_ds4 maps=lidar_abs_1,lidar_abs_2,lidar_abs_3,lidar_abs_4,lidar_abs_5,lidar_abs_6 start="2001-01-01" increment="3 days"
+t.info type=stvds dataset=lidar_abs_ds4
+tv.register dataset=lidar_abs_ds5 maps=lidar_abs_1,lidar_abs_2,lidar_abs_3,lidar_abs_4,lidar_abs_5,lidar_abs_6 start="2001-01-01" increment="4 weeks"
+t.info type=stvds dataset=lidar_abs_ds5
+tv.register dataset=lidar_abs_ds6 maps=lidar_abs_1,lidar_abs_2,lidar_abs_3,lidar_abs_4,lidar_abs_5,lidar_abs_6 start="2001-08-01" increment="2 months"
+t.info type=stvds dataset=lidar_abs_ds6
+tv.register dataset=lidar_abs_ds7 maps=lidar_abs_1,lidar_abs_2,lidar_abs_3,lidar_abs_4,lidar_abs_5,lidar_abs_6 start="2001-01-01" increment="20 years, 3 months, 1 days, 4 hours"
+t.info type=stvds dataset=lidar_abs_ds7
+tv.register dataset=lidar_abs_ds7 maps=lidar_abs_1,lidar_abs_2,lidar_abs_3,lidar_abs_4,lidar_abs_5,lidar_abs_6 start="2001-01-01" increment="99 years, 9 months, 9 days, 9 hours"
+t.remove --v type=vector dataset=lidar_abs_1,lidar_abs_2,lidar_abs_3
+t.remove --v type=stvds dataset=lidar_abs_ds1,lidar_abs_ds2,lidar_abs_ds3,lidar_abs_ds4,lidar_abs_ds5,lidar_abs_ds6,lidar_abs_ds7
+t.remove --v type=vector dataset=lidar_abs_4,lidar_abs_5,lidar_abs_6
Added: grass/trunk/temporal/tv.register/tv.register.html
Added: grass/trunk/temporal/tv.register/tv.register.py
--- grass/trunk/temporal/tv.register/tv.register.py (rev 0)
+++ grass/trunk/temporal/tv.register/tv.register.py 2011-09-16 23:05:45 UTC (rev 48326)
@@ -0,0 +1,75 @@
+# MODULE: tv.register
+# PURPOSE: Register vector maps in a space time vector dataset
+# for details.
+#%module
+#% description: Register vector maps in a space time vector dataset
+#% keywords: spacetime vector dataset
+#% keywords: vector
+#%end
+#%option
+#% key: dataset
+#% type: string
+#% description: Name of an existing space time vector dataset
+#% required: yes
+#% multiple: no
+#%end
+#%option
+#% key: maps
+#% type: string
+#% description: Name(s) of existing vector map(s), multiple maps must be provided in temporal order in case datetime should be attached
+#% required: yes
+#% multiple: yes
+#%end
+#%option
+#% key: start
+#% type: string
+#% description: The valid start date and time of the first vector map, in case the map has no valid time (format absolute: "yyyy-mm-dd HH:MM:SS", format relative 5.0)
+#% required: no
+#% multiple: no
+#%end
+#%option
+#% key: increment
+#% type: string
+#% required: no
+#% multiple: no
+#%end
+def main():
+ # Get the options
+ # Register maps
+ grass.register_maps_in_space_time_dataset("vector", name, maps, start, increment)
+ main()
Property changes on: grass/trunk/temporal/tv.register/tv.register.py
Added: grass/trunk/temporal/tv.unregister/Makefile
--- grass/trunk/temporal/tv.unregister/Makefile (rev 0)
+++ grass/trunk/temporal/tv.unregister/Makefile 2011-09-16 23:05:45 UTC (rev 48326)
@@ -0,0 +1,7 @@
+PGM = tv.unregister
Added: grass/trunk/temporal/tv.unregister/tv.unregister.html
Added: grass/trunk/temporal/tv.unregister/tv.unregister.py
--- grass/trunk/temporal/tv.unregister/tv.unregister.py (rev 0)
+++ grass/trunk/temporal/tv.unregister/tv.unregister.py 2011-09-16 23:05:45 UTC (rev 48326)
@@ -0,0 +1,56 @@
+# MODULE: tv.unregister
+# PURPOSE: Unregister vector maps from space time vector datasets
+# for details.
+#%module
+#% description: Unregister vector map(s) from a specific or from all space time vector datasets in which it is registered
+#%end
+#%option
+#% key: dataset
+#% type: string
+#% description: Name of an existing space time vector dataset. If no name is provided the vector map(s) are unregistered from all space time datasets in which they are registered.
+#% required: no
+#% multiple: no
+#%end
+#%option
+#% key: maps
+#% type: string
+#% description: Name(s) of existing vector map(s) to unregister
+#% required: yes
+#% multiple: yes
+#%end
+def main():
+ # Get the options
+ # Unregister maps
+ grass.unregister_maps_from_space_time_datasets("vector", name, maps)
+ main()
Property changes on: grass/trunk/temporal/tv.unregister/tv.unregister.py
