[GRASS-SVN] r48342 - in grass/trunk/gui/wxpython: . gui_modules
svn_grass at osgeo.org
Sun Sep 18 08:06:36 EDT 2011
Author: martinl
Date: 2011-09-18 05:06:36 -0700 (Sun, 18 Sep 2011)
New Revision: 48342
grass/trunk/gui/wxpython/gui_modules/gmodeler.py
grass/trunk/gui/wxpython/wxgui.py
wxGUI/modeler: #1448 (run model menu item does not seem to work)
run model from the menu
Modified: grass/trunk/gui/wxpython/gui_modules/gmodeler.py
--- grass/trunk/gui/wxpython/gui_modules/gmodeler.py 2011-09-18 08:13:55 UTC (rev 48341)
+++ grass/trunk/gui/wxpython/gui_modules/gmodeler.py 2011-09-18 12:06:36 UTC (rev 48342)
@@ -408,14 +408,109 @@
return errList
- def Run(self, log, onDone):
- """!Run model"""
- for action in self.GetItems(objType = ModelAction):
- if not action.IsEnabled():
+ def RunAction(self, item, params, log, onDone, statusbar = None):
+ """!Run given action
+ @param item action item
+ @param params parameters dict
+ @param log logging window
+ @param onDone on-done method
+ @param statusbar wx.StatusBar instance or None
+ name = item.GetName()
+ if name in params:
+ paramsOrig = item.GetParams(dcopy = True)
+ item.MergeParams(params[name])
+ if statusbar:
+ statusbar.SetStatusText(_('Running model...'), 0)
+ log.RunCmd(command = item.GetLog(string = False),
+ onDone = onDone)
+ item.SetParams(paramsOrig)
+ def Run(self, log, onDone, parent = None):
+ """!Run model
+ @param log logging window (see goutput.GMConsole)
+ @param parent window for messages or None
+ if self.GetNumItems() < 1:
+ GMessage(parent = parent,
+ message = _('Model is empty. Nothing to run.'))
+ return
+ statusbar = None
+ if isinstance(parent, wx.Frame):
+ statusbar = parent.GetStatusBar()
+ # validation
+ if statusbar:
+ statusbar.SetStatusText(_('Validating model...'), 0)
+ errList = self.Validate()
+ if statusbar:
+ statusbar.SetStatusText('', 0)
+ if errList:
+ dlg = wx.MessageDialog(parent = parent,
+ message = _('Model is not valid. Do you want to '
+ 'run the model anyway?\n\n%s') % '\n'.join(errList),
+ caption = _("Run model?"),
+ style = wx.YES_NO | wx.NO_DEFAULT |
+ wx.ICON_QUESTION | wx.CENTRE)
+ ret = dlg.ShowModal()
+ if ret != wx.ID_YES:
+ return
+ # parametrization
+ params = self.Parameterize()
+ if params:
+ dlg = ModelParamDialog(parent = parent,
+ params = params)
+ dlg.CenterOnParent()
+ if ret != wx.ID_OK:
+ dlg.Destroy()
+ return
+ err = dlg.GetErrors()
+ if err:
+ GError(parent = self, message = unicode('\n'.join(err)))
+ return
+ log.cmdThread.SetId(-1)
+ for item in self.GetItems():
+ if not item.IsEnabled():
continue
- log.RunCmd(command = action.GetLog(string = False),
- onDone = onDone)
+ if isinstance(item, ModelAction):
+ if item.GetBlockId():
+ continue
+ self.RunAction(item, params, log, onDone)
+ elif isinstance(item, ModelLoop):
+ cond = item.GetText()
+ # substitute variables in condition
+ variables = self.GetVariables()
+ for variable in variables:
+ pattern = re.compile('%' + variable)
+ if pattern.search(cond):
+ value = variables[variable].get('value', '')
+ vtype = variables[variable].get('type', 'string')
+ if vtype == 'string':
+ value = '"' + value + '"'
+ cond = pattern.sub(value, cond)
+ # split condition
+ condVar, condText = re.split('\s*in\s*', cond)
+ for action in item.GetItems():
+ for vars()[condVar] in eval(condText):
+ if isinstance(action, ModelAction):
+ self.RunAction(action, params, log, onDone)
+ if params:
+ dlg.Destroy()
def DeleteIntermediateData(self, log):
"""!Detele intermediate data"""
rast, vect, rast3d, msg = self.GetIntermediateData()
@@ -928,87 +1023,8 @@
def OnRunModel(self, event):
"""!Run entire model"""
- if self.model.GetNumItems() < 1:
- GMessage(parent = self,
- message = _('Model is empty. Nothing to run.'))
- return
+ self.model.Run(self.goutput, self.OnDone, parent = self)
- # validation
- errList = self._validateModel()
- if errList:
- dlg = wx.MessageDialog(parent = self,
- message = _('Model is not valid. Do you want to '
- 'run the model anyway?\n\n%s') % '\n'.join(errList),
- caption=_("Run model?"),
- style = wx.YES_NO | wx.NO_DEFAULT |
- wx.ICON_QUESTION | wx.CENTRE)
- ret = dlg.ShowModal()
- if ret != wx.ID_YES:
- return
- # parametrization
- params = self.model.Parameterize()
- if params:
- dlg = ModelParamDialog(parent = self,
- params = params)
- dlg.CenterOnParent()
- if ret != wx.ID_OK:
- dlg.Destroy()
- return
- err = dlg.GetErrors()
- if err:
- GError(parent = self,
- message = unicode('\n'.join(err)))
- return
- self.goutput.cmdThread.SetId(-1)
- for item in self.model.GetItems():
- if not item.IsEnabled():
- continue
- if isinstance(item, ModelAction):
- if item.GetBlockId():
- continue
- self._runAction(item, params)
- elif isinstance(item, ModelLoop):
- cond = item.GetText()
- # substitute variables in condition
- variables = self.model.GetVariables()
- for variable in variables:
- pattern = re.compile('%' + variable)
- if pattern.search(cond):
- value = variables[variable].get('value', '')
- vtype = variables[variable].get('type', 'string')
- if vtype == 'string':
- value = '"' + value + '"'
- cond = pattern.sub(value, cond)
- # split condition
- condVar, condText = re.split('\s*in\s*', cond)
- for action in item.GetItems():
- for vars()[condVar] in eval(condText):
- if isinstance(action, ModelAction):
- self._runAction(action, params)
- if params:
- dlg.Destroy()
- def _runAction(self, item, params):
- """!Run given action"""
- name = item.GetName()
- if name in params:
- paramsOrig = item.GetParams(dcopy = True)
- item.MergeParams(params[name])
- self.SetStatusText(_('Running model...'), 0)
- self.goutput.RunCmd(command = item.GetLog(string = False),
- onDone = self.OnDone)
- item.SetParams(paramsOrig)
def OnDone(self, cmd, returncode):
"""!Computation finished"""
self.SetStatusText('', 0)
@@ -1020,8 +1036,11 @@
message = _('Model is empty. Nothing to validate.'))
return
+ self.SetStatusText(_('Validating model...'), 0)
+ errList = self.model.Validate()
+ self.SetStatusText('', 0)
if errList:
GWarning(parent = self,
message = _('Model is not valid.\n\n%s') % '\n'.join(errList))
@@ -1133,16 +1152,6 @@
self.SetStatusText(_("Model exported to <%s>") % filename)
- def _validateModel(self):
- """!Validate model"""
- self.SetStatusText(_('Validating model...'), 0)
- errList = self.model.Validate()
- self.SetStatusText('', 0)
- return errList
def OnDefineRelation(self, event):
"""!Define relation between data and action items"""
self.canvas.SetCursor(self.cursors["cross"])
Modified: grass/trunk/gui/wxpython/wxgui.py
--- grass/trunk/gui/wxpython/wxgui.py 2011-09-18 08:13:55 UTC (rev 48341)
+++ grass/trunk/gui/wxpython/wxgui.py 2011-09-18 12:06:36 UTC (rev 48342)
@@ -400,33 +400,21 @@
"""!Run model"""
filename = ''
- dlg = wx.FileDialog(parent = self, message=_("Choose model to run"),
+ dlg = wx.FileDialog(parent = self, message =_("Choose model to run"),
defaultDir = os.getcwd(),
- wildcard=_("GRASS Model File (*.gxm)|*.gxm"))
+ wildcard = _("GRASS Model File (*.gxm)|*.gxm"))
if dlg.ShowModal() == wx.ID_OK:
filename = dlg.GetPath()
if not filename:
+ dlg.Destroy()
return
self.model = gmodeler.Model()
self.model.LoadModel(filename)
- result = self.model.Validate()
- if result:
- return
+ self.model.Run(log = self.goutput, onDone = self.OnDone, parent = self)
- self.model.Run(log = self.goutput,
+ dlg.Destroy()
def OnMapsets(self, event):
"""!Launch mapset access dialog
