[GRASS-SVN] r48349 - grass-addons/grass7/gui/wxpython/wx.wms
svn_grass at osgeo.org
Sun Sep 18 12:18:45 EDT 2011
Author: sudeepsingh
Date: 2011-09-18 09:18:45 -0700 (Sun, 18 Sep 2011)
New Revision: 48349
grass-addons/grass7/gui/wxpython/wx.wms/wmsmenu.py
Comments added
Modified: grass-addons/grass7/gui/wxpython/wx.wms/wmsmenu.py
--- grass-addons/grass7/gui/wxpython/wx.wms/wmsmenu.py 2011-09-18 16:08:54 UTC (rev 48348)
+++ grass-addons/grass7/gui/wxpython/wx.wms/wmsmenu.py 2011-09-18 16:18:45 UTC (rev 48349)
@@ -36,6 +36,8 @@
class newLayerData():
+ """!Data structure to hold relevant details about a fetched layer
name = None
title = None
abstract = None
@@ -45,12 +47,22 @@
class LayerData():
+ """!LayerData class to manage LayerTree (Widget used to display fetched layers).
+ Includes functionality to add new layers in the LayerTree
name = None
title = None
abstract = None
srs = None
def printLayerData(self,layerDataDict):
+ @description:Function to print dictionary structure holding information of
+ layers with keys as integers and values as objects of type LayerData()
+ @todo:None
+ @param1:reference variable
+ @param2:Dictionary holding values of type LayerData() object with keys as integers from 0 to len(layerDataDict)
for key, value in layerDataDict.iteritems():
print key
print value.name
@@ -64,6 +76,15 @@
print '--------------------------------------------'
def appendLayerTree(self, layerDataDict, LayerTree, layerTreeRoot):
+ @description:Adds layers to LayerTree widget.
+ @todo:None
+ @param self: reference variable
+ @param layerDataDict:{}, Dictionary holding values of type LayerData() object with keys as integers from 0 to len(layerDataDict)
+ @param LayerTree: TreeCtrl, widget used to display fetched layers.
+ @param layerTreeRoot: TreeItemId, returned by LayerTree.AddRoot("Layers") (in the init function), used to refer root of the LayerTree.
+ @return: None
name = value.name
title = value.title
@@ -72,6 +93,13 @@
LayerTree.AppendItem(layerTreeRoot, string)
def setKeyToEPSGCodes(self, layerDataDict):
+ @description: Builds a dictionary to map keys of layers to EPSG codes
+ @todo:None
+ @return: Dictionary with key as an integer in the string form str(int), and value a string (EPSG code for the key).
keytoepsgcodes = {}
srss = value.srs
@@ -87,8 +115,19 @@
pass
class ManageLayerTree():
+ Contains functionalities to Manage TreeCtrl widget (LayerTree) , used to display layers.
def getAllChild(self,LayerTree, parentId):
+ @description:Returns all the children nodes of a parent node in the TreeCtrl (LayerTree).
+ @todo:None
+ @param parentId: TreeItemId, reference to the parent Node in TreeCtrl.
+ @return: a list of TreeItemId, the children nodes of parentId(TreeItemId)
children = []
currentchild,obj = LayerTree.GetFirstChild(parentId)
while(1):
@@ -100,6 +139,14 @@
return children
def layerTreeItemDFS(self,parent,LayerTree,nodeId):
+ @description: performs a DFS(Depth first search) selection on the LayerTree(TreeCtrl), starting from the nodeId(TreeItemId)
+ @todo:None
+ @param nodeId: TreeItemId, reference to the parent Node in TreeCtrl.
+ @return: None
if(not nodeId.IsOk()):
return
@@ -217,7 +264,14 @@
# end wxGlade
- def OnGetCapabilities(self, event): # wxGlade: wmsFrame.<event_handler>
+ def OnGetCapabilities(self, event): # wxGlade: wmsFrame.<event_handler>
+ @description: called on press of getCapabilities button. Performs fetching of the getCapabilties document for the selected URL.
+ @todo:None
+ @param event: event associated.
+ @return: None
if(self.selectedURL == "No server selected"):
message = 'No Server selected'
self.ShowMessage(message, 'Warning')
@@ -292,6 +346,13 @@
def OnGetMaps(self, event): # wxGlade: wmsFrame.<event_handler>
+ @description: called on press of getMaps button. Performs fetching of the Maps for the selected layers of a WMS Service.
+ @todo:None
+ @return: None
message = 'No server selected'
grass.warning(message)
@@ -385,6 +446,13 @@
event.Skip()
def OnEPSGList(self,event):
+ @description: called on selection of an epsg code from the epsg list(ComboBox) displayed. Sets self.selectedEPSG variable.
+ @todo:None
+ @return: None
info = self.epsgList.GetValue()
if(not info.isdigit()):
message = 'Please select an EPSG Code'
@@ -396,6 +464,13 @@
self.selectedEPSG = info
def OnServerList(self, event): # wxGlade: wmsFrame.<event_handler>
+ @description: called on selection of a URL from ServerList(ComboBox) displayed. Sets self.selectedURL variable.
+ @todo:None
+ @return: None
info = self.ServerList.GetValue()
if(len(info) == 0):
return
@@ -423,6 +498,13 @@
def OnLayerTreeSelChanged(self, event): # wxGlade: wmsFrame.<event_handler>"
+ @description: called on selection of a layer from self.LayerTree. Sets self.selectedURL variable.
+ @todo:None
+ @return: None
self.epsgList.Clear()
self.epsgList.Append('')
self.selectedLayerList = []
@@ -443,53 +525,64 @@
self.layerName = self.layersString[1:]
#print self.layerDataDict1
self.selectedEPSG = None
- for sellayer in self.LayerTree.GetSelections():
- layerNameString = self.LayerTree.GetItemText(sellayer)
- layerNameStringList = layerNameString.split(':')
- if(len(layerNameStringList)==0):
- message = 'Unable to select layers'
- self.ShowMessage(message, 'Warning')
- grass.warning(message)
- StatusBar_fields = [message]
- self.StatusBar.SetStatusText(StatusBar_fields[0], 0)
- return
- layerName = layerNameStringList[0].split('-')[1]
- key = layerNameStringList[0].split('-')[0]
- self.selectedLayerList += [layerName]
- self.layerName += ","+layerName
- keys += [key]
- lEPSG = self.keyToEPSGCodes[key]
- self.epsgList.Append('<'+layerName+'>')
- self.epsgList.AppendItems(lEPSG)
- self.layerName = self.layerName[1:]
- self.selectedEPSG = None
event.Skip()
def OnAddServer(self, event): # wxGlade: wmsFrame.<event_handler>
+ @description: called on ManageServers button press. Calls AddSerevrFrame function to display GUI to Manage Servers.
+ @todo:None
+ @return: None
self.AddServerisClosed = False
self.addServer.Disable()
AddServerFrame(self)
return
def onAddServerFrameClose(self, msg):
+ @description: called when the AddServer Frame is closed. Re-enables the addServer Button
+ @todo:None
+ @return: None
self.AddServerisClosed = True
self.addServer.Enable()
def onUpdateServerListmessage(self, msg):
+ @description: called when the updateserverlist message is received from AddServerFrame. Updates the local server list (self.ServerList)
+ @todo:None
+ @return: None
self.servers = msg.data
#self.printDict(self.servers)
self.__update_Url_List(self.ServerList)
def onUpdateMapListmessage(self, msg):
+ @description: called when the update.map_servernameTouid message is received from AddServerFrame. Updates the local dictionary
+ self.map_servernameTouid . This dictionary translates servername to itd Uid.
+ @todo:None
+ @return: None
self.map_servernameTouid = msg.data
#self.printDict(self.map_servernameTouid)
def OnQuit(self, event):
+ @description: called when the close button is pressed. Closes the AddServerFrame if it's not closed.
+ @todo:None
+ @return: None
msg = ""
if(not self.AddServerisClosed):
@@ -498,9 +591,24 @@
return
def ShowMessage(self, message, type = 'Warning'):
+ @description: Display's the message as a pop-up.
+ @todo:None
+ @param message: String, message to be displayed.
+ @param type: String, the type of message
+ @return: None
wx.MessageBox(message, type)
def __update_Url_List(self, ComboBox):
+ @description: Internal function to update ServerList(ComboBox).
+ @todo:None
+ @param ComboBox: ComboBox to be updated.
+ @return: None
ComboBox.Clear()
ComboBox.Append("")
for key, value in self.servers.items():
@@ -508,6 +616,13 @@
return
def __populate_Url_List(self, ComboBox):
+ @description: Internal function to populate ServerList(ComboBox). Used to populate ServerList for the first time in the init function.
+ @todo:None
+ @return: None
self.servers, self.map_servernameTouid = getAllRows(self.soup)
ComboBox.Append("")
@@ -516,6 +631,12 @@
return
def getBBOXParameters(self):
+ @description: to parse bounding box parameters in Grass_Region parameter.
+ @todo:None
+ @return: a string containing comma separated bounding box parameters.
n=parseGrass_Region(None, 'north')
s=parseGrass_Region(None, 'south')
e=parseGrass_Region(None, 'east')
