[GRASS-SVN] r48351 - grass-addons/grass7/gui/wxpython/wx.wms
svn_grass at osgeo.org
Sun Sep 18 14:37:40 EDT 2011
Author: sudeepsingh
Date: 2011-09-18 11:37:40 -0700 (Sun, 18 Sep 2011)
New Revision: 48351
grass-addons/grass7/gui/wxpython/wx.wms/addserver.py
grass-addons/grass7/gui/wxpython/wx.wms/wmsmenu.py
Comments added
Modified: grass-addons/grass7/gui/wxpython/wx.wms/addserver.py
--- grass-addons/grass7/gui/wxpython/wx.wms/addserver.py 2011-09-18 17:12:39 UTC (rev 48350)
+++ grass-addons/grass7/gui/wxpython/wx.wms/addserver.py 2011-09-18 18:37:40 UTC (rev 48351)
@@ -157,6 +157,14 @@
# end wxGlade
def valueExists(self,dict, newServerName):
+ @description: to check if a value exists in the dictionary or not.
+ @todo:None
+ @param self: reference variable
+ @param dict: dictionary.
+ @param newServerName: String, value to be checked for.
+ @return: boolean
try:
for key, value in dict.items():
if value.servername == newServerName:
@@ -166,16 +174,15 @@
return False
def parse_WMS_URL(self, full_url):
- '''!Strips any WMS parts from url for easy reuse.
- Strips all WMS 1.1.1 and 1.3.0 parts from URL.
+ @description: Strips any WMS parts from url for easy reuse.
+ Strips all WMS 1.1.1 and 1.3.0 parts from URL.
This could be moved to some separate WxS support procedure file.
- @param full_url user provided WMS URL.
- @return URL as dict suitable for storage or None if provided URL isn't a valid WMS URL.
+ @todo:None
+ @param full_url: user provided WMS URL.
+ @return: URL as dict suitable for storage or None if provided URL isn't a valid WMS URL.
WMS_13_parameters = (
'VERSION',
'SERVICE',
@@ -221,6 +228,14 @@
return urlparse.urlunparse((final_url['scheme'], final_url['netloc'], final_url['path'], final_url['params'], final_url['query'], None))
def OnSave(self, event): # wxGlade: ServerAdd.<event_handler>
+ @description: Called on Save button press. Validates the information provided.
+ Saves or updates the provided information.
+ @todo:None
+ @param event: event associated
+ @return: None
newServerName = unicode(self.ServerNameText.GetValue())
newUrl = self.URLText.GetValue()
newUserName = self.UsernameText.GetValue()
@@ -350,6 +365,13 @@
event.Skip()
def OnRemove(self, event): # wxGlade: ServerAdd.<event_handler>
+ @description: Called on Remove button press. Deleted the server info selected to be deleted.
+ @todo:None
+ @return: None
if self.selectedUid == None:
message = _("No server selected. Remove unsuccessful")
self.ShowMessage(message, _('Warning'))
@@ -410,6 +432,13 @@
event.Skip()
def OnAddNew(self, event): # wxGlade: ServerAdd.<event_handler>
+ @description: Called on AddNew button press. Clears all the fields.
+ @todo:None
+ @return: None
self.checkIfModified(event)
self.selectedUid = None
self.ServerNameText.Clear()
@@ -423,6 +452,14 @@
event.Skip()
def OnQuit(self, event): # wxGlade: ServerAdd.<event_handler>
+ @description: Called on Quit button press. Closes the AddServerFrame.
+ Sends Add_Server_Frame_Closed message to wmsmenu Frame before closing.
+ @todo:None
+ @return: None
if(self.checkIfModified(event) == wx.ID_CANCEL):
return
if(not self.saveXMLData()):
@@ -437,6 +474,15 @@
event.Skip()
def OnServerList(self, event): # wxGlade: ServerAdd.<event_handler>
+ @description: Called on ServerList (ComboBox) select.
+ Parses the selected url and fills the corresponding fields with the information present.
+ @todo:None
+ @return: None
info = self.ServerList.GetValue()
if(len(info) == 0):
@@ -464,12 +510,26 @@
#wxGlade methods ends
def setModified(self, booleanValue):
+ @description: Sets SetModified function of all fields to booleanValue.
+ @todo:None
+ @param booleanValue: Boolean, boolean value to be set
+ @return: None
self.ServerNameText.SetModified(booleanValue)
self.URLText.SetModified(booleanValue)
self.UsernameText.SetModified(booleanValue)
self.PasswordText.SetModified(booleanValue)
def checkIfModified(self, event):
+ @description: To check if any field is modified and unsaved. Displays a pop-up if a field is Unsaved.
+ @todo:None
+ @return: wx.ID_CANCEL or wx.ID_YES
if(self.URLText.IsModified() or self.ServerNameText.IsModified() or self.UsernameText.IsModified() or self.PasswordText.IsModified()):
dial = wx.MessageDialog(None, 'You have unsaved changes.\n Do you want to save them ?', 'Quit',
wx.STAY_ON_TOP | wx.YES_NO | wx.YES_DEFAULT | wx.CANCEL | wx.ICON_QUESTION)
@@ -481,9 +541,24 @@
return val
def ShowMessage(self, message, type = 'Warning'):
+ @description: Display's the message as a pop-up.
+ @todo:None
+ @param message: String, message to be displayed.
+ @param type: String, the type of message
+ @return: None
wx.MessageBox(message, type)
def __populate_URL_List(self, ComboBox):
+ @description: Internal function to populate ServerList(ComboBox). Used to populate ServerList for the first time in the init function.
+ @todo:None
+ @param ComboBox: ComboBox to be updated.
+ @return: None
self.servers, self.map_servernameTouid = getAllRows(self.soup)
ComboBox.Append("")
for key, value in self.servers.items():
@@ -491,6 +566,13 @@
return
def __update_URL_List(self):
+ @description: Internal function to update ServerList(ComboBox).
+ @todo:None
+ @return: None
self.ServerList.Clear()
ComboBox = self.ServerList
ComboBox.Append("")
@@ -498,6 +580,12 @@
ComboBox.Append(value.servername+self.name_url_delimiter+value.url[0:self.urlLength])
def saveXMLData(self):
+ @description: Saves the information (soup) , in the file ServersList.xml.
+ @todo:None
+ @return: Boolean, True if save is successful else returns False.
xml = self.soup.prettify()
try:
TMP = grass.tempfile()
@@ -529,6 +617,16 @@
return True
def allFieldsValid(self, newServerName, newUrl, newUserName, newPassword):
+ @description: Validates all the field informations.
+ @todo:None.
+ @param self: reference variable.
+ @param newServerName: String, name of the server.
+ @param newUrl: String, url of the server.
+ @param newUserName: String, UserName for the server.
+ @param newPassword: String, Password for the server.
+ @return: Boolean, True if all fields are valid, else False.
# FIXME All texts should be encoded and accept all characters!
# Šitajam vajadzētu pazust, ja izmanto XML, kas automātiski kodē tekstus.
if newServerName.count(self.name_url_delimiter) > 0:
@@ -577,6 +675,12 @@
return True
def validateUrl(self, url):
+ @description: Validates the url provided. Sends a getCapabilities request to the url server and checks for the response.
+ @todo:None
+ @return: Boolean, True if valid, else returns False.
message = _('Validating URL...')
StatusBar_fields = [message]
self.StatusBar.SetStatusText(StatusBar_fields[0], 0)
@@ -605,6 +709,13 @@
return True, message
def OnWMSMenuClose(self, msg):
+ @description: Called on receiving WMS_Menu_Close message from wmsmenu Frame.
+ @todo:None
+ @param msg: message received, not used in the function though.
+ @return: None
self.Close()
self.Destroy()
return
Modified: grass-addons/grass7/gui/wxpython/wx.wms/wmsmenu.py
--- grass-addons/grass7/gui/wxpython/wx.wms/wmsmenu.py 2011-09-18 17:12:39 UTC (rev 48350)
+++ grass-addons/grass7/gui/wxpython/wx.wms/wmsmenu.py 2011-09-18 18:37:40 UTC (rev 48351)
@@ -56,13 +56,13 @@
srs = None
def printLayerData(self,layerDataDict):
@description:Function to print dictionary structure holding information of
layers with keys as integers and values as objects of type LayerData()
@todo:None
@param1:reference variable
@param2:Dictionary holding values of type LayerData() object with keys as integers from 0 to len(layerDataDict)
for key, value in layerDataDict.iteritems():
print key
print value.name
@@ -76,7 +76,7 @@
print '--------------------------------------------'
def appendLayerTree(self, layerDataDict, LayerTree, layerTreeRoot):
@description:Adds layers to LayerTree widget.
@todo:None
@@ -84,7 +84,7 @@
@param LayerTree: TreeCtrl, widget used to display fetched layers.
@param layerTreeRoot: TreeItemId, returned by LayerTree.AddRoot("Layers") (in the init function), used to refer root of the LayerTree.
@return: None
name = value.name
title = value.title
@@ -93,13 +93,13 @@
LayerTree.AppendItem(layerTreeRoot, string)
def setKeyToEPSGCodes(self, layerDataDict):
@description: Builds a dictionary to map keys of layers to EPSG codes
@todo:None
@param layerDataDict:{}, Dictionary holding values of type LayerData() object with keys as integers from 0 to len(layerDataDict)
@return: Dictionary with key as an integer in the string form str(int), and value a string (EPSG code for the key).
keytoepsgcodes = {}
srss = value.srs
@@ -120,14 +120,14 @@
def getAllChild(self,LayerTree, parentId):
@description:Returns all the children nodes of a parent node in the TreeCtrl (LayerTree).
@todo:None
@param parentId: TreeItemId, reference to the parent Node in TreeCtrl.
@return: a list of TreeItemId, the children nodes of parentId(TreeItemId)
children = []
currentchild,obj = LayerTree.GetFirstChild(parentId)
while(1):
@@ -139,14 +139,14 @@
return children
def layerTreeItemDFS(self,parent,LayerTree,nodeId):
@description: performs a DFS(Depth first search) selection on the LayerTree(TreeCtrl), starting from the nodeId(TreeItemId)
@todo:None
@param nodeId: TreeItemId, reference to the parent Node in TreeCtrl.
@return: None
if(not nodeId.IsOk()):
return
@@ -265,13 +265,13 @@
def OnGetCapabilities(self, event): # wxGlade: wmsFrame.<event_handler>
@description: called on press of getCapabilities button. Performs fetching of the getCapabilties document for the selected URL.
@todo:None
@param event: event associated.
@return: None
if(self.selectedURL == "No server selected"):
message = 'No Server selected'
self.ShowMessage(message, 'Warning')
@@ -352,7 +352,7 @@
@return: None
message = 'No server selected'
grass.warning(message)
@@ -452,7 +452,7 @@
@return: None
info = self.epsgList.GetValue()
if(not info.isdigit()):
message = 'Please select an EPSG Code'
@@ -470,7 +470,7 @@
@return: None
if(len(info) == 0):
return
@@ -498,13 +498,13 @@
def OnLayerTreeSelChanged(self, event): # wxGlade: wmsFrame.<event_handler>"
@description: called on selection of a layer from self.LayerTree. Sets self.selectedURL variable.
@todo:None
@return: None
self.epsgList.Clear()
self.epsgList.Append('')
self.selectedLayerList = []
@@ -534,7 +534,7 @@
@return: None
self.AddServerisClosed = False
self.addServer.Disable()
AddServerFrame(self)
@@ -547,31 +547,31 @@
@return: None
self.AddServerisClosed = True
self.addServer.Enable()
def onUpdateServerListmessage(self, msg):
@description: called when the updateserverlist message is received from AddServerFrame. Updates the local server list (self.ServerList)
@todo:None
@return: None
self.servers = msg.data
#self.printDict(self.servers)
self.__update_Url_List(self.ServerList)
def onUpdateMapListmessage(self, msg):
@description: called when the update.map_servernameTouid message is received from AddServerFrame. Updates the local dictionary
self.map_servernameTouid . This dictionary translates servername to itd Uid.
@todo:None
@return: None
self.map_servernameTouid = msg.data
#self.printDict(self.map_servernameTouid)
@@ -582,7 +582,7 @@
@return: None
msg = ""
if(not self.AddServerisClosed):
@@ -598,7 +598,7 @@
@return: None
def __update_Url_List(self, ComboBox):
@@ -608,7 +608,7 @@
@return: None
ComboBox.Clear()
ComboBox.Append("")
@@ -622,7 +622,7 @@
@return: None
ComboBox.Append("")
@@ -636,7 +636,7 @@
@todo:None
@return: a string containing comma separated bounding box parameters.
n=parseGrass_Region(None, 'north')
s=parseGrass_Region(None, 'south')
e=parseGrass_Region(None, 'east')
