[GRASS-SVN] r48354 - grass/trunk/lib/python
svn_grass at osgeo.org
Sun Sep 18 18:12:49 EDT 2011
Author: huhabla
Date: 2011-09-18 15:12:49 -0700 (Sun, 18 Sep 2011)
New Revision: 48354
grass/trunk/lib/python/tgis_abstract_datasets.py
grass/trunk/lib/python/tgis_base.py
grass/trunk/lib/python/tgis_space_time_datasets.py
Better sqlite database interface design. Reduced the sqlite3 open and close calls, now the registration and unregistration of maps in space time datasets should be much faster (5 - 50 times).
Modified: grass/trunk/lib/python/tgis_abstract_datasets.py
--- grass/trunk/lib/python/tgis_abstract_datasets.py 2011-09-18 21:40:25 UTC (rev 48353)
+++ grass/trunk/lib/python/tgis_abstract_datasets.py 2011-09-18 22:12:49 UTC (rev 48354)
@@ -69,43 +69,43 @@
return (north, south, east, west, top, bottom)
- def select(self):
+ def select(self, dbif=None):
"""Select temporal dataset entry from database and fill up the internal structure"""
- self.base.select()
+ self.base.select(dbif)
if self.is_time_absolute():
- self.absolute_time.select()
+ self.absolute_time.select(dbif)
if self.is_time_relative():
- self.relative_time.select()
- self.spatial_extent.select()
- self.metadata.select()
+ self.relative_time.select(dbif)
+ self.spatial_extent.select(dbif)
+ self.metadata.select(dbif)
- def is_in_db(self):
+ def is_in_db(self, dbif=None):
"""Check if the temporal dataset entry is in the database"""
- return self.base.is_in_db()
+ return self.base.is_in_db(dbif)
def delete(self):
"""Delete temporal dataset entry from database if it exists"""
raise IOError("This method must be implemented in the subclasses")
- def insert(self):
+ def insert(self, dbif=None):
"""Insert temporal dataset entry into database from the internal structure"""
- self.base.insert()
+ self.base.insert(dbif)
- self.absolute_time.insert()
+ self.absolute_time.insert(dbif)
- self.relative_time.insert()
- self.spatial_extent.insert()
- self.metadata.insert()
+ self.relative_time.insert(dbif)
+ self.spatial_extent.insert(dbif)
+ self.metadata.insert(dbif)
- def update(self):
+ def update(self, dbif=None):
"""Update temporal dataset entry of database from the internal structure"""
- self.base.update()
+ self.base.update(dbif)
- self.absolute_time.update()
+ self.absolute_time.update(dbif)
- self.relative_time.update()
- self.spatial_extent.update()
- self.metadata.update()
+ self.relative_time.update(dbif)
+ self.spatial_extent.update(dbif)
+ self.metadata.update(dbif)
def print_self(self):
"""Print the content of the internal structure to stdout"""
@@ -229,17 +229,27 @@
self.absolute_time.set_end_time(end_time)
self.absolute_time.set_timezone(timezone)
- def update_absolute_time(self, start_time, end_time=None, timezone=None):
+ def update_absolute_time(self, start_time, end_time=None, timezone=None, dbif = None):
"""Update the absolute time
@start_time a datetime object specifying the start time of the map
@end_time a datetime object specifying the end time of the map
@timezone Thee timezone of the map
+ connect = False
+ if dbif == None:
+ dbif = sql_database_interface()
+ dbif.connect()
+ connect = True
self.set_absolute_time(start_time, end_time, timezone)
+ if connect == True:
+ dbif.close()
def set_relative_time(self, interval):
"""Set the relative time interval
@@ -250,73 +260,123 @@
self.relative_time.set_interval(interval)
- def update_relative_time(self, interval):
+ def update_relative_time(self, interval, dbif = None):
@interval A double value in days
+ connect = False
+ if dbif == None:
+ dbif.connect()
+ connect = True
self.set_relative_time(interval)
+ dbif.close()
def set_spatial_extent(self, north, south, east, west, top=0, bottom=0):
"""Set the spatial extent of the map"""
self.spatial_extent.set_spatial_extent(north, south, east, west, top, bottom)
- def delete(self):
+ def delete(self, dbif=None):
"""Delete a map entry from database if it exists
Remove dependent entries:
* Remove the map entry in each space time dataset in which this map is registered
* Remove the space time dataset register table
- if self.is_in_db():
+ connect = False
+ if dbif == None:
+ dbif.connect()
+ connect = True
+ if self.is_in_db(dbif):
# First we unregister from all dependent space time datasets
- self.unregister()
+ self.unregister(dbif)
# Remove the strds register table
sql = "DROP TABLE " + self.get_stds_register()
#print sql
- self.base.connect()
- self.base.cursor.execute(sql)
- self.base.close()
+ dbif.cursor.execute(sql)
core.verbose("Delete " + self.get_type() + " dataset <" + self.get_id() + "> from temporal database")
# Delete yourself from the database, trigger functions will take care of dependencies
- self.base.delete()
+ self.base.delete(dbif)
- def unregister(self):
+ dbif.close()
+ def unregister(self, dbif=None):
""" Remove the map entry in each space time dataset in which this map is registered
core.verbose("Unregister " + self.get_type() + " dataset <" + self.get_id() + "> from space time datasets")
+ connect = False
+ if dbif == None:
+ dbif.connect()
+ connect = True
+ # Get all datasets in which this map is registered
+ rows = self.get_registered_datasets(dbif)
+ # For each stds in which the map is registered
+ if rows:
+ for row in rows:
+ # Create a space time dataset object to remove the map
+ # from its register
+ stds = self.get_new_stds_instance(row["id"])
+ stds.select(dbif)
+ stds.unregister_map(self, dbif)
+ # Take care to update the space time dataset after
+ # the map has been unregistred
+ stds.update_from_registered_maps(dbif)
+ dbif.close()
+ def get_registered_datasets(self, dbif=None):
+ """Return all space time dataset ids in which this map is registered as
+ sqlite3 rows with column "id" or None if this map is not registered in any
+ space time dataset.
+ connect = False
+ if dbif == None:
+ dbif.connect()
+ connect = True
# Select all data from the database
- self.select()
+ self.select(dbif)
+ rows = None
# Remove the map from all registered space time datasets
if self.get_stds_register() != None:
# Select all stds tables in which this map is registered
sql = "SELECT id FROM " + self.get_stds_register()
#print sql
- rows = self.base.cursor.fetchall()
- self.base.close()
+ rows = dbif.cursor.fetchall()
- # For each stds in which the map is registered
- if rows:
- for row in rows:
- # Create a space time dataset object to remove the map
- # from its register
- stds = self.get_new_stds_instance(row["id"])
- stds.select()
- stds.unregister_map(self)
- # Take care to update the space time dataset after
- # the map has been unregistred
- stds.update_from_registered_maps()
+ dbif.close()
+ return rows
@@ -371,36 +431,42 @@
self.metadata.set_title(title)
self.metadata.set_description(description)
- def delete(self):
"""Delete a space time dataset from the database"""
# First we need to check if maps are registered in this dataset and
# unregister them
core.verbose("Delete space time " + self.get_new_map_instance(ident=None).get_type() + " dataset <" + self.get_id() + "> from temporal database")
+ connect = False
+ if dbif == None:
+ dbif.connect()
+ connect = True
if self.get_map_register():
sql = "SELECT id FROM " + self.get_map_register()
- self.base.close()
# Unregister each registered map in the table
if rows:
for row in rows:
# Unregister map
map = self.get_new_map_instance(row["id"])
- self.unregister_map(map)
+ self.unregister_map(map, dbif)
# Drop remove the map register table
sql = "DROP TABLE " + self.get_map_register()
- self.base.close()
# Remove the primary key, the foreign keys will be removed by trigger
- def register_map(self, map):
+ dbif.close()
+ def register_map(self, map, dbif=None):
"""Register a map in the space time dataset.
This method takes care of the registration of a map
@@ -410,13 +476,20 @@
and return False
- if map.is_in_db() == False:
+ connect = False
+ if dbif == None:
+ dbif.connect()
+ connect = True
+ if map.is_in_db(dbif) == False:
core.fatal("Only maps with absolute or relative valid time can be registered")
core.verbose("Register " + map.get_type() + " map: " + map.get_id() + " in space time " + map.get_type() + " dataset <" + self.get_id() + ">")
# First select all data from the database
- map.select()
+ map.select(dbif)
map_id = map.base.get_id()
map_name = map.base.get_name()
map_mapset = map.base.get_mapset()
@@ -437,10 +510,8 @@
# Check if map is already registred
if stds_register_table:
sql = "SELECT id FROM " + stds_register_table + " WHERE id = (?)"
- self.base.cursor.execute(sql, (map_id,))
- row = self.base.cursor.fetchone()
- self.base.close()
+ dbif.cursor.execute(sql, (map_id,))
+ row = dbif.cursor.fetchone()
# In case of no entry make a new one
if row and row[0] == map_id:
core.warning("Map " + map_id + "is already registered.")
@@ -462,15 +533,12 @@
sql = sql.replace("TABLE_NAME", uuid_rand )
sql = sql.replace("MAP_ID", map_id)
sql = sql.replace("STDS", self.get_type())
+ dbif.cursor.executescript(sql)
- self.base.cursor.executescript(sql)
- self.base.close()
map_register_table = uuid_rand + "_" + self.get_type() + "_register"
# Set the stds register table name and put it into the DB
map.set_stds_register(map_register_table)
- map.metadata.update()
+ map.metadata.update(dbif)
core.verbose("Created register table <" + map_register_table + "> for " + map.get_type() + " map <" + map.get_id() + ">")
@@ -489,11 +557,8 @@
sql_script += sql
sql_script += "\n"
sql_script += "END TRANSACTION;"
+ dbif.cursor.executescript(sql_script)
- self.base.cursor.executescript(sql_script)
- self.base.close()
# Trigger have been disabled due to peformance issues while registration
## We need raster specific trigger
#sql = open(os.path.join(sql_path, "stds_" + map.get_type() + "_register_trigger_template.sql"), 'r').read()
@@ -508,57 +573,58 @@
#sql_script += "\n"
#sql_script += "END TRANSACTION;"
- #self.base.connect()
- #self.base.cursor.executescript(sql_script)
- #self.base.close()
+ #dbif.cursor.executescript(sql_script)
stds_register_table = stds_name + "_" + stds_mapset + "_" + map.get_type() + "_register"
# Set the map register table name and put it into the DB
self.set_map_register(stds_register_table)
core.verbose("Created register table <" + stds_register_table + "> for space time " + map.get_type() + " dataset <" + self.get_id() + ">")
# Register the stds in the map stds register table
# Check if the entry is already there
sql = "SELECT id FROM " + map_register_table + " WHERE id = ?"
- self.base.cursor.execute(sql, (self.base.get_id(),))
- self.base.close()
+ dbif.cursor.execute(sql, (self.base.get_id(),))
if row == None:
sql = "INSERT INTO " + map_register_table + " (id) " + "VALUES (?)"
#print sql
- self.base.close()
# Now put the raster name in the stds map register table
sql = "INSERT INTO " + stds_register_table + " (id) " + "VALUES (?)"
#print sql
- self.base.close()
+ dbif.close()
return True
- def unregister_map(self, map):
+ def unregister_map(self, map, dbif = None):
"""Unregister a map from the space time dataset.
This method takes care of the unregistration of a map
from a space time dataset.
+ connect = False
+ if dbif == None:
+ dbif.connect()
+ connect = True
core.fatal("Unable to find map <" + map.get_id() + "> in temporal database")
core.info("Unregister " + map.get_type() + " map: " + map.get_id())
- map.select()
+ map.select(dbif)
map_register_table = map.get_stds_register()
@@ -567,10 +633,8 @@
# Check if the map is registered in the space time raster dataset
- self.base.close()
# Break if the map is not registered
if row == None:
@@ -580,18 +644,17 @@
# Remove the space time raster dataset from the raster dataset register
if map_register_table != None:
sql = "DELETE FROM " + map_register_table + " WHERE id = ?"
- self.base.close()
# Remove the raster map from the space time raster dataset register
if stds_register_table != None:
sql = "DELETE FROM " + stds_register_table + " WHERE id = ?"
- self.base.close()
- def update_from_registered_maps(self):
+ dbif.close()
+ def update_from_registered_maps(self, dbif = None):
"""This methods updates the spatial and temporal extent as well as
type specific metadata. It should always been called after maps are registered
or unregistered/deleted from the space time dataset.
@@ -602,6 +665,13 @@
core.info("Update metadata, spatial and temporal extent from all registered maps of <" + self.get_id() + ">")
+ connect = False
+ if dbif == None:
+ dbif.connect()
+ connect = True
# Get basic info
stds_name = self.base.get_name()
stds_mapset = self.base.get_mapset()
@@ -634,6 +704,7 @@
- self.base.close()
+ dbif.close()
Modified: grass/trunk/lib/python/tgis_base.py
--- grass/trunk/lib/python/tgis_base.py 2011-09-18 21:40:25 UTC (rev 48353)
+++ grass/trunk/lib/python/tgis_base.py 2011-09-18 22:12:49 UTC (rev 48354)
@@ -137,7 +137,6 @@
class sql_database_interface(dict_sql_serializer):
"""This is the sql database interface to sqlite3"""
def __init__(self, table=None, ident=None, database=None):
dict_sql_serializer.__init__(self)
self.table = table # Name of the table, set in the subclass
@@ -151,35 +150,47 @@
return self.table
def connect(self):
+ #print "Connect to", self.database
self.connection = sqlite3.connect(self.database, detect_types=sqlite3.PARSE_DECLTYPES|sqlite3.PARSE_COLNAMES)
self.connection.row_factory = sqlite3.Row
self.cursor = self.connection.cursor()
def close(self):
+ #print "Close connection to", self.database
self.connection.commit()
self.cursor.close()
def get_delete_statement(self):
return "DELETE FROM " + self.get_table_name() + " WHERE id = \"" + str(self.ident) + "\""
- def delete(self):
- self.connect()
sql = self.get_delete_statement()
#print sql
- self.cursor.execute(sql)
- self.close()
+ if dbif:
+ else:
+ self.connect()
+ self.cursor.execute(sql)
+ self.close()
def get_is_in_db_statement(self):
return "SELECT id FROM " + self.get_table_name() + " WHERE id = \"" + str(self.ident) + "\""
- self.connect()
sql = self.get_is_in_db_statement()
#print sql
- row = self.cursor.fetchone()
- self.close()
+ if dbif:
+ else:
+ self.connect()
+ row = self.cursor.fetchone()
+ self.close()
# Nothing found
if row == None:
return False
@@ -189,17 +200,26 @@
def get_select_statement(self):
return self.serialize("SELECT", self.get_table_name(), "WHERE id = \"" + str(self.ident) + "\"")
- def select(self):
- self.connect()
sql, args = self.get_select_statement()
#print sql
#print args
- if len(args) == 0:
- else:
- self.cursor.execute(sql, args)
+ if dbif:
+ if len(args) == 0:
+ else:
+ dbif.cursor.execute(sql, args)
+ else:
+ self.connect()
+ else:
+ self.cursor.execute(sql, args)
+ self.close()
# Nothing found
if row == None:
return False
@@ -208,35 +228,42 @@
self.deserialize(row)
else:
raise IOError
- self.close()
return True
def get_insert_statement(self):
return self.serialize("INSERT", self.get_table_name())
- def insert(self):
- self.connect()
sql, args = self.get_insert_statement()
#print sql
#print args
- self.close()
+ if dbif:
+ else:
+ self.connect()
+ self.close()
def get_update_statement(self):
return self.serialize("UPDATE", self.get_table_name(), "WHERE id = \"" + str(self.ident) + "\"")
- def update(self):
if self.ident == None:
raise IOError("Missing identifer");
sql, args = self.get_update_statement()
#print sql
#print args
- self.connect()
- self.close()
+ if dbif:
+ else:
+ self.connect()
+ self.close()
class dataset_base(sql_database_interface):
Modified: grass/trunk/lib/python/tgis_space_time_datasets.py
--- grass/trunk/lib/python/tgis_space_time_datasets.py 2011-09-18 21:40:25 UTC (rev 48353)
+++ grass/trunk/lib/python/tgis_space_time_datasets.py 2011-09-18 22:12:49 UTC (rev 48354)
@@ -373,7 +373,7 @@
-def register_maps_in_space_time_dataset(type, name, maps, start=None, increment=None):
+def register_maps_in_space_time_dataset(type, name, maps, start=None, increment=None, dbif = None):
"""Use this method to register maps in space time datasets. This function is generic and
can handle raster, vector and raster3d maps as well as there space time datasets.
@@ -406,10 +406,15 @@
if type == "vector":
sp = space_time_vector_dataset(id)
+ if dbif == None:
+ dbif.connect()
+ connect = True
# Read content from temporal database
- sp.select()
+ sp.select(dbif)
- if sp.is_in_db() == False:
+ if sp.is_in_db(dbif) == False:
core.fatal("Space time " + sp.get_new_map_instance(None).get_type() + " dataset <" + name + "> not found")
if maps.find(",") == -1:
@@ -431,33 +436,36 @@
# In case the map is already registered print a message and continue to the next map
# Put the map into the database
# Break in case no valid time is provided
if start == "" or start == None:
core.fatal("Unable to register " + map.get_type() + " map <" + map.get_id() + ">. The map has no valid time and the start time is not set.")
# Load the data from the grass file database
map.load()
# Put it into the temporal database
- map.insert()
+ map.insert(dbif)
else:
- map.select()
+ map.select(dbif)
if map.get_temporal_type() != sp.get_temporal_type():
core.fatal("Unable to register " + map.get_type() + " map <" + map.get_id() + ">. The temporal types are different.")
# Set the valid time
if start:
- assign_valid_time_to_map(sp.get_temporal_type(), map, start, increment, count)
+ assign_valid_time_to_map(sp.get_temporal_type(), map, start, increment, count, dbif)
# Finally Register map in the space time dataset
- sp.register_map(map)
+ sp.register_map(map, dbif)
count += 1
# Update the space time tables
- sp.update_from_registered_maps()
+ sp.update_from_registered_maps(dbif)
+ dbif.close()
-def unregister_maps_from_space_time_datasets(type, name, maps):
+def unregister_maps_from_space_time_datasets(type, name, maps, dbif = None):
"""Unregister maps from a single space time dataset or, in case no dataset name is provided,
unregister from all datasets within the maps are registered.
@@ -467,6 +475,11 @@
mapset = core.gisenv()["MAPSET"]
+ if dbif == None:
+ dbif.connect()
+ connect = True
# In case a space time dataset is specified
if name:
# Check if the dataset name contains the mapset as well
@@ -482,7 +495,7 @@
# Build the list of maps
@@ -508,18 +521,21 @@
map = vector_dataset(mapid)
# Unregister map if in database
- if map.is_in_db() == True:
+ if map.is_in_db(dbif) == True:
if name:
- sp.select()
- sp.unregister_map(map)
+ sp.select(dbif)
+ sp.unregister_map(map, dbif)
else:
- map.select()
- map.unregister()
+ map.select(dbif)
+ map.unregister(dbif)
if name:
-def assign_valid_time_to_map(ttype, map, start, increment=None, mult=1):
+ dbif.close()
+def assign_valid_time_to_map(ttype, map, start, increment=None, mult=1, dbif = None):
"""Assign the valid time to a map dataset
@ttype The temporal type which should be assigned and which the time format is of
@@ -528,6 +544,14 @@
@increment Time increment between maps for time stamp creation (format absolute: NNN seconds, minutes, hours, days, weeks, months, years; format relative: 1.0)
@multi A multiplier for the increment
+ connect = False
+ if dbif == None:
+ dbif.connect()
+ connect = True
if ttype == "absolute":
# Create the start time object
if start.find(":") > 0:
@@ -544,11 +568,14 @@
end_time = increment_datetime_by_string(start_time, increment, 1)
core.verbose("Set absolute valid time for map <" + map.get_id() + "> to " + str(start_time) + " - " + str(end_time))
- map.update_absolute_time(start_time, end_time)
+ map.update_absolute_time(start_time, end_time, None, dbif)
else:
if increment:
interval = float(start) + mult * float(increment)
else:
core.verbose("Set relative valid time for map <" + map.get_id() + "> to " + str(interval))
- map.update_relative_time(interval)
+ map.update_relative_time(interval, dbif)
+ dbif.close()
